PDA
View Full Version : JetCat Turbine Direct Support
Pages : 1 2 [3] 4 5 6 7 8 9
  1. Counter Rotating P200
  2. P70 catastophic fail?
  3. Who MAKES
  4. P-80 ECU Help
  5. classic P180 rear leak / bolts loose
  6. P70 Fod Screen
  7. JETCAT P100-RX Seize on Start
  8. SPT5-H Power Failed.. :(
  9. p180 kero start ECU
  10. Jetcat HP-5 Power Up Problem
  11. ECU Battery Question
  12. popping at idle
  13. p80 jetcat spools up to full throttle on ground run with no command from tx (SCARY)
  14. Brand new 200Sx will not iniatiate the start
  15. Running P80SE without receiver?
  16. Balance tap on P-100 ECU battery?
  17. 80SE “low-rpm”
  18. P200SX Intermittent Flame Outs
  19. Bad Fuel?
  20. Bad Fuel
  21. P-160 Titan Fuel Leak
  22. The baddest cat of them all...
  23. P-200
  24. P-60 starts spinning with on battery
  25. P20 no full throttle
  26. P20 strange happening
  27. initial configuration of the radio starting the turbine JetCat p-80 se
  28. jetcat manual
  29. clerification on starter tanks.
  30. Oil again!!!
  31. P-70 and Pipe Clearance: HELP???
  32. p80 problem
  33. P-60SE Limitations
  34. FOD screen for P-70
  35. JetCat P-140 Rpm issues.
  36. What plug is on the ecu battery?
  37. Question about P80
  38. P120Sx # 3363 with very high fuel consumption
  39. ph-6
  40. Jet cat p-80 over reved
  41. Is the P100 shipping?
  42. P-70 and LifePo4 batteries?
  43. Jetcat P180 IO board lights
  44. Jetcat P-70 Install Help??
  45. P-200 SE PLUG failure
  46. Exhaust leak
  47. Mobil DTE oil and Jetcat warranty?
  48. P20SE manual
  49. P-60 thinks it's a P-120
  50. No data on the data terminal
  51. Jetcat P-160sx A123 3S pack
  52. What kero plug for a P20-SE ?
  53. P-120 start help.
  54. P120se
  55. P80 V4.9ECU Nicad to lipo?
  56. Correct distance for P120 non SE ver. to pipe
  57. JetCAT data cable (rpm + EGT) help
  58. 120sx fuel pump wont stop
  59. Windows software rs 232.
  60. Hot Keys on JetCats
  61. pump ques for 180 and 200sx
  62. Jetcat lock up during start up
  63. P120 and Flight Works Pump
  64. P200SX none starter
  65. Throttle/Aux 2 lead length?
  66. P80 Tailpipe installation
  67. P-160SX Flame out
  68. Spool up Problems with hp5 Jetcopter
  69. P200 starter motor
  70. SX series keroplug connection
  71. P-160SX case screws Bent
  72. P80 starter problem? ECU PROBLEM!!!
  73. Jetcat P60
  74. large hawk new 'bellmouth' installment
  75. P-120SX Idle
  76. P80 SE Problem
  77. p-80 starter motor help
  78. p120 problem...
  79. Spinner for 4 Blade Biela 24x10 prop?
  80. P20SE dual "Valve Plug Here" on pump
  81. New here: Jet Forum?
  82. hight altitude P-20 STARTING PROBLEMS
  83. STARTING A P-80 SE KEROSTART PROBLEM
  84. JetCat P-60 Problem
  85. What causes a P120 to Flame Out
  86. protech PT80 PLEASE HELP ! !!
  87. Factory settings
  88. Newbie question?
  89. P-80 and similar turbines
  90. Titan Kero Start and GSU
  91. Fuel Pump Electric Motor
  92. P70 vs P80????
  93. 120/160 Layout drawing
  94. 120 Over speed flameout
  95. P120 Fail to Start
  96. P80 Max RPM
  97. P80 hot spot
  98. P20 accelaration start up problem
  99. P80 V6 ecu repair?
  100. P80 starting problems
  101. ECU/ LEANING AT ALTITUDE
  102. P1602x bad temp reading
  103. Old P-70 Battery ???
  104. propane tubes blocked
  105. Flame out
  106. Battery boost using Led I/O board
  107. 0 Hours on 30 Hour engine?
  108. P20 Autostart gas problem
  109. cables
  110. P200 very slow accel, not learning low
  111. bearings cooling
  112. accel2 where is it
  113. Flashing green IO light
  114. powermax substitute
  115. ecu cable
  116. JetCat Support
  117. Running a P-60 on LiPo's
  118. P20 and A123's
  119. failsafe and futaba 2,4ghz
  120. ECU version No
  121. P-80SE PRM sensor problem
  122. throttle response setting
  123. 160se throttle problem
  124. GSU cord to LED I/O Board
  125. P80 upgrades
  126. p80 se
  127. P70 erratic rpm reading on gsu not on turbine
  128. P80se oring change
  129. Tail Pipe clearance
  130. Jetcat P-80 SE P-100
  131. A New P-120SX... Offered In Propane Start?
  132. Thrust Chart
  133. Rookie 2 Info
  134. jet-tronic
  135. U-accelr2
  136. Fuel pump break-in
  137. SpoolUp Time Change after ECU update
  138. P120SE erratic problem
  139. P 200SX /Ignite-Time-Out
  140. Balance Tap Adapter for Jetcat Lipo?
  141. 120 sx wont ignite
  142. Leaking hot exhaust
  143. ECU Version
  144. Smoke on P-60
  145. Big Flame on Start up of My 120SE
  146. Help with ECU
  147. 6.0 ECU?
  148. P-120 fuel line size
  149. Very slow acceleration rate on 120SE
  150. Jetcat 160 of Titan?
  151. p- 80 flame out
  152. P-70 not transiting from idle to full power
  153. pheonix 30/3 turbine
  154. P200SX is leaking hot fuel
  155. P-160sx temp high
  156. P120SE Abnormal behavior
  157. For repair of turbine
  158. Hi guys,
  159. Location Of Kero Start Plug
  160. Turbine Oil?
  161. 160SX UACCEL2
  162. P-200 SX BATTERY
  163. JetCat P80 has something metallic rolling around inside
  164. P80 Thrust Tube Question
  165. Flame outs in same plane with different motors
  166. P80 not hitting full RPM?
  167. HELP : Error in Temprature Sensor Calibration
  168. p80 kero start
  169. Converting Back to Powermax Start
  170. What Size Torx
  171. PHT3-3
  172. Data cable failure infomation
  173. P80 gone wild, RPM to high
  174. P-200 FOD damage
  175. Is This Temp Probe In Too Far??
  176. 160SX problem
  177. P-160 over heated
  178. P-80 howling at half throttle
  179. 160sx overtemp on start
  180. P 80 kero start lipo
  181. Kero start
  182. problems getting a P120 to run
  183. 120SX RPM outside of parameters
  184. 120SX shooting flames on start
  185. I did some s....
  186. Computer operated P200
  187. Jetcat, thank you
  188. Jetcat will not start
  189. P200SX wont light off
  190. P-70 kerostart starting problems
  191. SOLENOID SHUT-OFF BY RADIO
  192. JETCAT 120 White smoke,will not start
  193. JETCAT P70 showing low batteries
  194. This is for the guys in Australia
  195. Fuel flow info display
  196. JetCat P80 Questions?
  197. P60-SE Startup Problems
  198. P60-SE Starting Problems
  199. JetCat P-80 outer shell dent
  200. delayed spool up during humid conditions
  201. JetCat fuel pump
  202. P120 Overtemp/Hitemp
  203. Starting Problem with P-70
  204. P120 Low RPM
  205. Problem with P-70
  206. P-60SE won't start- ECU problem?
  207. Diesel fuel in JetCat's
  208. can't light the burner!!
  209. Throttle Curve
  210. P120SX won't start
  211. P-120SX won't start (starts now, my own mistake)
  212. Enough Propane?
  213. Part number for P-70 EGT Sensor
  214. ECU Battery Question
  215. Battery's
  216. Jetcat P60 noisey starter
  217. My p-70 is real sloooow
  218. SX pump start voltage?
  219. 120 pipe install
  220. No power to P80Se
  221. battery HELP please !
  222. Low rpm flameout 160sx from idle
  223. Carbon build up ?
  224. Which battery type?
  225. battery connector
  226. p80 low rpm
  227. P60 Fuel Pump
  228. P120SX max RPM
  229. P200SX pump voltage
  230. Fuel Change
  231. P-60 " Acel Slo" Message
  232. Jetcat P-80 Temperature problem
  233. Anyone parting out a P-80?
  234. Back from 25 hour svce, still has flame
  235. Bendix Blues
  236. Pulsing batt indicator on start terminal
  237. run w/o the I/O board?
  238. P60 service-25 hour maintenance
  239. Also problems with Kero Start
  240. Kerostart fuel line purge
  241. Jet Cat aquired.
  242. Turbine upgrade Question
  243. Jet Cat P 60
  244. Fuel Pump specs
  245. P200SX Ign Time Out
  246. Current Draw 160 SX
  247. ECU Version Updates and for A123 use also
  248. use P-160 ECU for P-120 ?
  249. Bearing noise during start up
  250. Jetcat ECU
