- My mini lst2 servo
- PERMAX 400/4D discontinued
- gear ratio for detta with mamba system
- NEW DETTA TC!!!!!!!!!!!!!!!!!!!
- discharge for storage
- can i run 1/10th elecs on my losi mini baja ESC n RECEIVER?
- 3racing heat sink help
- ansmann 1200mah batt
- How to shim rc18t diffs?
- micro baja questions
- My frist body i painted what you think
- 1/16the E-revo& slayerex
- Quick Micro Desert help please
- What Brushless ESC = BEST??
- Poor Little RC18T :(
- Duratrax Vendetta TC
- RC18R running 10 cell thermals.. TOAST?
- Mini REVO and Mini Slayer are coming !!!!!!
- foamies only for carpet
- chargers for for micro/mini's stock and lipo
- Got some Nice pics. Need cropping.
- Micro DT/T
- What lipo for a bl rc18T FT???
- mini lst upgrade
- Glitching
- rc18t questions
- hs 65 hb stripped ?
- Need help! ESC and/or motor overheating (rc18t)
- Whats a good servo for rc18t?
- Scratch Building Mini T?
- Tekin Mini Rage ESC vs Castle Sidewinder Micro ESC: best for race tuning?
- Anyone who has a Exotek Single Servo Conversion Kit?
- Tire Choice..
- Mini Brushed Motor Maintenance
- Hyperion Micro Pro Brushless Mini Quake Review PICS!!
- what 1/10 wheels are you useing
- Anybody ever order from Rcmart.com??
- help me rc18mt !!! plz
- micro raminator
- Ordering my new Detta ST!
- Question anyboby know where to get a Team Blue Groove Buggy conversion for Losi Micro??
- rc18t and rc18mt differences?
- mini z racing tonight at Cruizin RC in Waldwick, NJ
- Exotek Single Servo Conversion very disappointing
- need info on mini wheel hex and pin styles??compatability??
- Batts and charger
- micro DT shocks
- Answer: Speed Control Won't Program with Radio
- nimh v lipo
- losi mini desert truck
- all my ESC are borken :(
- need better servo for mini inferno...
- how fast are stock minis?
- Quick question about stock charger.
- Would this help overheating?
- Losi Xcelorin Brushless in MLST
- max motor temp?
- Mini-B motor options
- My Exotek Single Servo Conversion should be coming tomorrow!
- What is the best Mini?
- 1/10 wheels on mini need some help
- User's Mini-t build!!!
- want a mini and a backyard track. please advise
- decent nimh pack for rc18
- Mamba 6800 Lipo Cut-Off
- XMODS are back at Radio shack
- LST2??
- Looking to Buy Part
- RC18T and sway bar kit
- Might get back in RC
- One of the tires came out of the rim? superglue ok?
- Rc18's on "driveway track"
- new rc mini forum with a mini-slider/latemodel section
- brushed motor break in?
- what does kv stand for in brushless motors?
- My 2nd xcelorin brushless setup that started on fire
- need advice on a used vendetta
- Mini lst tranny gears
- got a mini inferno half 8 and need to run street tires and wheels 1/10
- MLST SETUPS
- Charging amperage for LiPo?
- need information on Mini-LST Sway Bar
- xray m18mt vs mini lst2
- Mini-T to Lipo
- Micro RS4 or RC18R?
- how can i make my mini late model faster?????
- ALL LST/LST-2 OWNERS NEED HELP
- Just created a website dedicated to my Losi Ramunition
- mini lst2
- Made in the U.S.A
- rc18mt grating noise
- superglued mini-t diff
- Mini Baja no-go; ESC?
- Mini-t Moter?
- sportwerks chaos picco throttle linkage
- Will the Trany Handle it?
- x-raym18mt
- JR SM22 servos for MLST2?
- Frustrated with Bishop Power Products
- Mini-T wheels on Mini LST
- MLST2 HELP!!
- Are these brushless motors any good?
- Dubro Swivel Ball links for RC18T
- Who Makes best gearbox for RC18T
- Vendetta servo mount
- WHEELS AND TIRE FOR TAMTECH GB01/GB02???
- 1/10 mamba max in rc18t?
- Tailwhip
- quick question for exotek mini lxt????
- Lipo battery and charger questions (Xray)
- How much upgrade is enough?
- All mini brushless 4wd owners
- RC18T Steering Slop
- I got it!
- EXOTEX EX14 !!!!
- batery or esc first?
- will the metal kyosho mini inferno 09 gears fit in the half 8?
- Canat get the wheels off of rc18b.
- battery and charger
- want a brushless 4wd mini! whitch one should i buy???
- I believe my differential is done.....
- quick question
- Mini LSt and MIP CVD's
- xtm rage
- Yokomo 1/16 Drifting car
- TL Micro Desert Truck battery ?
- new mini
- 1/18 off road specific rules?
- Jaded owner going to try again. Need advice.
- Xray M18T RTR OEM body choices?
- ESC Motor Limit of Tamtech Gear GB01
- starting to get angry with novak customer support...
- need better motor for cheap
- OFFICAL RC18R THREAD
- Need Help Getting into Racing
- Lost my RC18r battery brace
- mini desert truck
- Need some advice on vehicles
- Dahan battery packs won't fit the Losi plugs ?? *** !
- quick question
- Where in the world can I find steel input gears for an RC18T?
- race worhty 18r?
- Herbie mini LST2
- Steering problem.....Please Help
- Mamba 25 failsafe question
- Questions about battery?
- How's the Tamiya Mighty Ballista Nitro 4WD Buggy for beginner?
- my ramunition brushless took a hard hit. front differential damage!
- how close should the pinion gear and the spur gear be in contact 1/18 Ram
- 1/18 desert truck from losi
- whats true about the detta aluminum??
- One question about battery charging.
- 3s~11.82volts?
- my new dual brushless Losi 1/18 truck is so powerful.
- Mini monster?
- half 8 Stock electronics
- Waha! Dead Mini-t
- Micro On Road and 1/18 Off Road Nationals Thread
- Just purchased a Losi 1/18 Rammunition Monster Truck.
- Rc18t question
- hobbygrade xmod
- newbie needs help
- help mini losi t
- Issues with differentials. Need help!!
- Anyone know about these: Maverick Atom XT/XB?
- Brushless Mini-baja( mini-t ) project please help!!
- which cvd's are better
- hwo to build rc18t diffs?
- A mini, maybe?
- servo,s that fit the losi mlst
- tuning help needed for a new boy!
- HS55+Servo Saver Q.
- graphite vs aluminum
- What is the shaft diameter of the mamba brushless motor?
- RC18R?
- mini baja motor brushes
- Mamaba 25 esc what motor should i get?
- Where oh where has my top speed gone...
- micro-t problems
- NEW!! White Delrin wide track arm set MINI LST
- Mini INferno ST brushless systems
- Orion Baja Motor Help
- Losi Mini Late Model Electronics
- Mini Mini...
- Slipping Sound highly modified brushless mini-t
- how much should i sell my NEW brushless detta for??
- mini moster baja f/s
- broke as a joke vendetta diff??? buggy
- lots of questions
- viscious diff for MLST
- RC18T 3s Li-po
- For my birthday?
- Pinion stuck on motor shaft.
- have you ever thought of this reciever for a rc18?
- Micro-t problem
- can u please post a link to steel pinion 4 ammo/detta
- Mini-T Issue HELP!!!
- Good 18th Scale Transmitter and Receiver?
- help, newbie on the lot
- 1/18 Losi Li-Po/Charger
- RC18MT Problems
- cheap ($50-) power supply for my charger..
- Vulcan 2 speed problems
- ftx fury
- RC18B electronics problem
- 3racing threaded shocks for rc18r on thetoyz..
- CHECK THIS OUT!
- lookin for a certain buggy body
- thetoyz.com
- how to change oil in my shocks (vendetta buggy)
- rc18t ploblem
- HS-65MG (not HS-56) servo in RC18T
- Rx-280 pinion size
- How did you mount your lipo?
- A Few questions about aftermarket XRAY M18 PRO .................
- Losi Mini - Desert Truck
- my track 18th scale
- What tool to take off mini-t's stock shocks?
- Vendetta buggy owners are these any good?
- rc18mt vs 18t
- New Novak for my NOW
- Novak Mongoose brushless
- vendetta owners.. the wait is over. finally steel ball diff gears..
- picco p-zero to chaos
- 2s lipo vs 3s lipo
- brushless ae rc18mt
- brushless detta diet plan -help (buggy)
- Mini Inferno ST vs. Mini LST help deciding
- mlst axle help
- Gearing up with 2 cell, or go 3 cell?
- Micro desert truck binding helP!!
- mini and micro Stunt tracks
- mushroom bowl pa (indoor)
- best / cheapest mini t motor??
- Xray m18t/M18MT or m18t pro body shell alternatives?
- Stripping Spur Gear
- Brushless for 1/16 KMI/mini inferno/photon/NOW
- what would you like to see in a new mini???
- onboard the Mini-t
- GPM Shocks for Tamtech Gear GB01
- 18b vs. 18t
- wow are these things for real?? gpm stl cv 4 detta buggy
- Trinity NOW motor spec question
- few brushless questions.
- vendetta buggy knuckles question (fr)
- what do u think?
- Need motor with 2.3mm shaft or need metric 2mm pinions!!!
- rc18mt
- Tamiya TamTech Gear
- ok to put pinion on motor backwards?
