Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 TS2 POST IT HERE... >
TS2 POST IT HERE...
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
TS2 POST IT HERE...
Old 04-23-2007 | 06:25 PM
  #176
Default RE: TS2 POST IT HERE...
hey wave waker- the pitch on the o.s. c/f prop is 1.984. CARTER
Old 04-23-2007 | 06:42 PM
  #177
hey rico- leave the low speed needle at the factory setting for now. 2.5 turns out on the needle is for breakin.start leaning it 1/8 turn & listen to the engine. keep leaning till you hear the r.p.m. start to pick up.then go 2 clicks at a time. if you go past the sweet spot, it will die, or kill the glow plug.when you get close, pull the plug & read it after each run. good luck. CARTER
Old 04-23-2007 | 07:50 PM
  #178
ORIGINAL: kb guy
awesome! thanks much[sm=thumbup.gif]
Old 04-24-2007 | 07:49 AM
  #179
Carter,
I know exactly where the high speed needle should be, and I know how to lean out the motor, but for whatever reason even when set rich (2.5 turns out), the boat WILL NOT ACCELERATE. Runs 10-15mph with no revs. Prop depth and angle set exactly as specified in the TS2 Manual.
Checked the fuel line to the tank, no kinks. Pressure tap to muffler is good to go. Glow plug is like new. This is why I suspect that I screwed up the low speed needle. I just need to know exactly where to set the low speed ( turns out), so that I can rule out that setting. Next step is tearing it down ( which I dont really have the time for about now). Frustrated,
Bill
Old 04-24-2007 | 09:35 AM
  #180
Hey LES301M, I have a question about the Dewalt battery set up you have for your starter. Can one of those starters handle 14.4 volts alright? Aren't they designed for 12 volts?
John
Old 04-24-2007 | 10:41 AM
  #181
ORIGINAL: macbane
John
John,
Most of these starters are based on motorcycle/ATV parts, and are typically rated at 9 - 16 volts. If your starter gets hot, Don't do it. However, I've been using this setup for years.
Larry
Old 04-24-2007 | 08:40 PM
  #182
unclecrash's Avatar
Ive heard and have been told to double 2 rc 12 volt batteries to start big nitro motors that are hard to crank over using a 12volt starter. I haveny tryed it yet but others tell me they have done it. As long as you arnt wheeling it over also long.
Old 04-25-2007 | 12:03 AM
  #183
MOST LOW SPEED JETS ARE 1 1/2 TO 2 TURNS OUT THATS BEEN MY EXPERIANCE IN AIR CRAFT, CARS AND BOATS IT SHOULD BE CLOSE TO START FROM.
Old 04-25-2007 | 09:25 AM
  #184
The best looking quality of fuel my LHS has is O'Donnell 20% R2R. This will my first time running a nitro engine, and the engine is brand new. Is this fuel OK to run in an OS 21XM outboard? I don't plan on racing. The O'Donnell website says:
"Sport fuel with legendary O'Donnell quality. Made using the highest-quality oils and blending techniques. Special lubricant package benefits the operation and performance of sport engines found in most ready-to-run vehicles. Helps to protect your engine as you learn the skills to provide proper care, tuning, and maintenance.
I like the sound of the last part.
What do you think guys?
John
Old 04-25-2007 | 05:04 PM
  #185
Ok folks so I tore her down, the piston and sleeve looks great, and on the bottom end the connecting rod looks ok, but I am still very concerned with the hitch at top dead center. If I grab the connecting rod with a finger, and try spinning the flywheel, I cannot feel any real slop in the pin, but when it hits top dead center it feels like it moves just a bit. Is this nasty hitch normal? Am I just overreacting to what could ultimately be a bad low speed needle valve? Ahhh I need to figure this out.................
Old 04-25-2007 | 07:31 PM
  #186
ORIGINAL: Ricoswave
the slack on the top end is normal as long as no metal like grinding feeling,,,also u may include checking the bearings and bearing housing is intact and no play as much as possible.
Old 04-25-2007 | 07:33 PM
  #187
macbane- i would be concerned about the oil %. boats need 18%. i use 60% o`donnell, but it says "boat " under the 60%. the one you`re talking about says for cars/trucks. they use less oil%. the ones labeled "boats" doesn`t start until 30%. i also have the o.s. xm. the nitro % is o.k., just less power. if i were you i would try to find something you know has 18% oil. i get mine from tower hobbies. good luck. CARTER
Old 04-25-2007 | 08:39 PM
  #188
Thanks Carter,
The oil % is what I was concerned about too. I'll try to get my hands on some of the Boat fuel.
John
Old 04-25-2007 | 08:57 PM
  #189
Good News! After taking apart the bottom end and further investigating, I have narrowed down my problem to the carb/ fuel delivery. Piston and sleeve fine, connecting rod is fine, bearings are good to go with no slop, I guess that just leaves the carb. I noticed that there is what looks like a little crack in the low speed needle looking from the inside of the carb out......( bottom), is this normal?)
Old 04-25-2007 | 10:49 PM
  #190
will you chose the TS2 over the VEE 27 ?
Old 04-27-2007 | 12:19 AM
  #191
is it normal to have about 5oz of lead in the nose to balance this boat with a stock os 21 outboard. I have a bad porpose problem and didnt set the cg previously. I now set the cg at 9 1/2" from the back edge but it took almost 6oz of weight in the nose to level it off....by the way i used triangle stock as the balancer on top my granite countertops. I have the prop at just above c/l 3/16ths. what can i do to improve this thanks.
billy
Old 04-28-2007 | 11:26 AM
  #192
hey guys...ok so i'm new into tunnel boats and i purchased a top speed 2 with a cmb .21 engine with a k&b lower unit. it came with a black swivel looking unit that im guessing is the motor mount of some sort..its very simple looking, maybe it just mounts directly onto the ts2 i dont know...i need to know how i can get the right motor mount for my ts2 with some kind of trim tab that i can adjust it with...also it needs a steering arm as well and where i can purchase one of those from...also what is the best prop i should use with such a powerful engine as the cmb....another question i have is whether i should just start with a neutral prop angle...positive or negative with that engine...also what time of glow plug to use and what temp. should i be running it at....o and with the starter does it need to spin clockwise or counter to start it...
thanks
joe
Old 04-28-2007 | 02:42 PM
  #193
hey jojo- what you have is half of a dubro mount. you`re missing the 2 angle brackets. you can get the complete mount from tower hobbies. tower stock # lxd582. engine runs c.w. viewed from top. start w/ neg. thrust angle. engine propshaft c/l 1/8" above bottom of sponsons. not familiar w/ cmb eng. someone else will have to help w/ plug, prop, etc. CARTER
Old 04-28-2007 | 02:47 PM
  #194
correction. start w/ 0 thrust angle. CARTER
Old 04-29-2007 | 05:59 PM
  #195
thanks...do you know where i can get a steering arm from?
Old 04-29-2007 | 10:08 PM
  #196
no. you might have to make one. CARTER
Old 04-29-2007 | 11:26 PM
  #197
ORIGINAL: jojo81084
dubro makes one also the precision boat, htb.
Old 05-01-2007 | 06:39 AM
  #198
has anyone had any know the guys from Hyperformance products??
im trying to order a rossi power head and some of their staino drices for the out board but habent heard any thing from them in well over a week.[][]
Old 05-01-2007 | 08:39 AM
  #199
VOODOOHYDRO's Avatar
TS2 sterring problems? Anybody having problems with the steering on the TS2? Mine works fine on the work bench but put it in the water and it wont steer. Theres no bindings any where or hangups so im thinking i need a new servo. Any thoughts? Thanks[]
Old 05-01-2007 | 08:10 PM
  #200
Well I had the same problem you are having with my TS2 and it would work perfect on the bench, put it into the water and
No steering, and I found that I had to up grade the steering rods as the original thin rods which come with the kit were bowing in the turn ( could not over come the torque of the motor) and this sorted out the problem.
Peter T
