OFNA Buggy - How much is this worth?
I'm looking to sell/trade my buggy. I'm having a hard time trying to figure out how much it's worth. These are the details, and here are some photos.
It's in very good condition...other than it needs to be cleaned The ESC and motor are practically new...probably 6-7 runs on them. It is the Novak 6.5 HV series setup to take two LiPo batteries. You can find more details about it here: http://teamnovak.com/products/brushl...axx/index.html. It's super fast, and fun. I got it directly from Novak last fall and didnt use it more than 2 or 3 times. The buggy chassis itself is in good condition. The bottom is scuffed up as per normal but the inside is very clean. All the arms are in good condition as are the shocks and braces. The body is new.
Thanks! I believe it's an OFNA Buggy 8 make. It was a nitro, and has been converted to electric. I just tried to run it for the first time in ages, and the capacitor started smoking. I'm going to send the motor/ecs into Novak tomorrow to have them look at it.
My plan was to sell this and get a erevo or an xmaxx. My son is starting to get into it and he really wants me to get a monster truck. I don't really care if i sell as a roller or with everything included. It's def a fun car, so if it's not worth too much I would consider just keeping it. Was just trying to get an idea. Thanks a lot for your quick reply
Ha! Good news. I decided to cut the wires to the capacitor because i know it's blown/junk and everything seems to work perfectly still. I'm very new to RC's so I don't really have any idea of the capacitor is required or what will happen if I run it without one. At least everything works.
Have you looked over the wheel bearings and such to look for any binding? Anything bent? If it's all in good shape, you might could get ohh...$160-180 as a roller, add another Benjamin with the motor system. Providing one can still get parts for it. If ya can't get parts for it, it's a shelf queen. I looked HERE and didn't see a listing that might be a "Buggy 8". AH...found it at NitroHouse . So parts shouldn't be an issue. He's out of rear arms right now... But it looks like parts are out there. As always, what something is worth is what someone is willing to pay for it. RC Universe does have a Classified Ads section. Post an ad and see.
Looking at Traxxas, hey? I do think the eRevo is pretty cool, looking*. And the XMAXX is brand new, comes with Traxxas Stability Management for easy driving (and has the cool self-righting feature). Always easy parts support at your LHS. Going BIG, huh? Look at the Arrma Nero truck. Same price as the eRevo, but could be better than the eRevo with it's "Diff-Brain" tech. It's clearly aimed at it's market. Sounds like you're willing to drop some serious coin.
* You might want to read up on the forums about the eRevo's "required parts" to make it durable.
Oooohhh... that's no fun. Could just be that the capacitor is old (?) and its dielectric dried up and it's died. Cheap fix.
Cool! Then you may have something you can get a few bucks out of. Is the cap needed? Maybe. It's probably a standard "glitch buster" cap. Might cost ya ten bucks. Unless you're good with soldering, especially on circuit boards, I'd suggest soldering the new cap (if you get one) onto the old wires and use shrink wrap on the joints. Getting the polarity of the cap right might be an issue. Use a volt meter and find out which wire has a positive voltage, and connect the + side of the cap to that wire.
From what I can tell it's an Ofna 9.5 MBX buggy. Btw the front wheels look like they're pointing in a weird direction. It's likely caused, at least in part) due to the front upper arms facing the wrong way, flip them over and you'll also gain shock clearance.
As for the capacitor, yes it's needed. Hit the throttle from a stop and that's the largest load drawn by the motor. Voltage drops on the pack under any load and the capacitor helps supplement the pack. It also helps to lower ripple voltage which is basically the voltage fluctuating in the pack as the esc fires a phase in the motor then rests and fires another phase. More capacitance is not a bad thing so don't worry about going too big, a low esr cap is recommended though. If you can't find a cap (try an online electronics dealer) maybe consider Castle Creations cap pack instead.
As for price, that's a tough one. There are more modern rtr buggies with better power systems that sell for $400-450 brand new. I think $250-300 is fair as the 9.5 MBX rollers go for about $100 up to $150 depending on condition and parts included. Maybe you can find someone that'll trade you for a monster truck. Whatever you do I wouldn't use the Novak in a monster truck, unless it's a 1/10 like the Stampede 4x4. The Maxx, Revo are really on the heavy side for the HV as it has an undersized 380 size rotor in it. But at least you have the HV6.5 which out of all the HV's is the most compatible with heavier vehicles if you end up having to use it.
Rushmorepdf (05-11-2020)
Waterproof. Out of the box, nothing that I am aware of is "water proof". "Water resistant", yes. Splash-proof is more like it.
There are ways to make things even more water resistant, but generally, water and electricity don't mix well. So I would not go mud bogging or fording streams, unless you've done a lot more research on how to protect your expensive electronics. The most sensitive is the receiver. There are water resistant receiver boxes, and some guys just put them in a balloon. But I don't like the idea of getting the battery and it's connector wet. Most of the trail-scalers use BRUSHED motors that don't mind getting wet, but I don't know what if any brushless motors can take it.
Do you think that Castle Creations Cap Pack will work fine for a replacement capacitor ?
https://www.youtube.com/watch?v=1IfQgMfuYkI
There are a few water proof esc options out there but waterproofed motors are a different story. Traxxas is the only one that i know of that flat out claims that the 3500kv velineon is water proof but if it breaks they will tell you sorry there is no warranty on that. Of course you can always look up a vid on youtube about waterproofing motors or escs and go that route (its not that hard if you have some space to work).The biggest thing that i have learned running though water/hydroplaning/puddle jumping is plan on a lot more maintenance, and i mean A LOT more. Plan on lubing the bearings (especially the wheels) after every outing and get some brushless motor cleaner along with a few sets of motor bearings. Do the motor bearings anytime they feel off at all and it will help to keep you from a catastrophic failure. Use a balloon (I use condoms lol) for the lipo packs If you adhere to this regimen i have found that my motors don't wear out nearly as quickly and i haven't had one blow apart since i started doing this. Just remember that you get lazy and skip it even once it can seriously lower the life span of the car/truck. I learned this by treating the velenion like it was waterproof and after a month is grenaded on me while just running on the street. Never again i told myself lol Once last thing to know is that water makes A TON of drag in comparison to just running on the street with will strain the electronics a lot more than you would think, be sparing and let the car have a rest every couple minutes to let all of the connections cool. I know you are only planning on hitting some puddles, that was my plan too! Until i hydroplaned across one and was hooked. Hope this little run down helps!
Good news! I took a video of it in action below. It's almost too fast for me to control...haha. I do have a weird issue where the throttle stops responding for a couple seconds every once in a while. You can actually see it happen twice in the video i think. I did notice that my servos turn my wheels still when that happens...so not too sure what that's about. Any ideas? My radio and receiver are really old traxxas models..i'm assuming it's an issue with those. Does anyone have any suggestions on a new radio/receiver combo?
https://youtu.be/CN3gcQ53VIU
A good 2.4ghz basic radio set can be had for $20 with a FlySky GT2. It's a "nuthin fancy" set, but it works. It's what I use. Otherwise, a Spektrum radio will set you back $200. By "old Traxxas radio" do you mean the kind with the old whip antenna? If so, I'd suggest getting some sort of modern 2.4ghz set, cheap or otherwise.
Lol you have a pretty great dane. The gt2 is a great deal for the money. I personally like the DX4s from spectrum that way i have avc if i want it. I think its one of the best sub $200 radios out there but if you only have one car then its prolly not worth it to go all out on a radio. Its all about preference really. What you have to spend and how many/what kind of cars you will want linked to it.
