 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 10-30-2002 | 10:28 PM
  #451
seanychen's Avatar
Default U Can Do 3D
Not all washers have the same thickness. I use 1 each thick washer on the left top and left bottom. This setup gives me 3 degrees of right thrust. It seems to fly and hover fine w/o torque veer.
Old 10-31-2002 | 03:44 AM
  #452
Default YS120SC weight/CG
DKjens, how much does your YS120SC weigh, and where's your CG at this point? I've got a brand spankin' new Saito 1.80 that's been sittin'round awhile and well, I've been thinking. I've ordered the UCD and waiting for it's arrival so I don't have a refferance. Do you think a 17x6 would clear the ground w/ the stock gear?
Old 10-31-2002 | 02:44 PM
  #453
My Feedback: (20)
Default Fuel tubing size for OS 91 fs
For you guys using the OS surpass 91 II. What size fuel tubing are you using? Standard or large?
Old 10-31-2002 | 05:01 PM
  #454
Default Re: Fuel tubing size for OS 91 fs
I am using Aerotrend Blue medium tubing.
Some large size tubing (i.e Aerotrend) will fit loose on the connectors/nipples.
Old 10-31-2002 | 05:06 PM
  #455
eness76-RCU's Avatar
My Feedback: (13)
Default Surpass II
Medium for me as well.
Old 11-01-2002 | 05:46 AM
  #456
Default im going on gas
Got my U can do tonight. and made all the measurments of the fire wall. my RCS 1.40 will fit perfectly with the stock motor mount. this engine has rear exhaust pits stile muffler. Ill be useing a 17x6 prop.
I hope ill be able to reinforce all the week areas of this plane with out meassing up the looks of it, like the fire wall and landing gear blocks.
Old 11-01-2002 | 11:20 PM
  #457
Default Loose Turtle Deck ?
Has any one else had a problem with a loose turtle deck that leads from the end of the canopy to the stab? It appears that the bent balsa sheeting is glued to the fuselage bulkhead pcs. but not to the underlying balsa sheeting on the fuselage sides. You can actually feel the two pieces separate when gently squeezing the fuselage sides (as if you were picking it up). I also think I heard it rattling when the engine is running. I ran a whole 2oz bottle of medium CA along the inside sides where the two pcs. of balsa sheeting are supposedly joined. It seemed to have fixed most of the problem.
Old 11-02-2002 | 02:37 AM
  #458
Default Yay
Hey guys,
Finally picked mine up tonight. Had to wipe off the box before i got her into the house........... :sunsmiley hehe. Anyways, i think im going to slap a saito 100 in her, this seems to be the overall best motor from what it sounds like, is this correct? I dont want to go with the huge 1.20's, but i want good power. What do you think?
Old 11-02-2002 | 02:47 AM
  #459
mecam's Avatar
Default Re: Yay
Originally posted by FlyByWire
Hey guys,
I was using the Saito 91 but then the bearings went out and didn't want to bother rebuilding it. I just bought a saito 100 and tomorrow will be it's maiden. The UCD flew great with the 91 using a 16x4W. I was breaking-in the 100 yesterday and tweaking the low and highs and I can already tell that this motor is a lot stronger than my 91. With the 100 it spools the 16x4W a lot faster from idle to top end compared to my 91. Haven't Tached it yet but it seems a lot stronger. I can hover with the 91 at just above half throttle and I bet it's even gonna be better with the 100.
Old 11-02-2002 | 02:54 AM
  #460
rhd-RCU's Avatar
My Feedback: (36)
Default U Can Do 3D
Hi,
Is anybody sealing the control surfaces?
Old 11-02-2002 | 03:02 AM
  #461
Default WHERE'S MINE!?!
Hey guys,
How the heck are you guys getting your UCD's? I've had mine on order forever! Has Tower recieved them? What's the deal? Let me in!!!
Old 11-02-2002 | 03:32 AM
  #462
Default hehe
Walked into my LHS (its been there for about 2 weeks), walked out with it, no tax, no shipping charges..... HEHE its PURDY!!!!!
Old 11-02-2002 | 03:53 AM
  #463
Default oh...
...that must be the damaged one that I returned
Old 11-02-2002 | 03:59 AM
  #464
Default U-3
Hi I finally got mine dialed in dual rates expos where i like it and motors is getting broken in I sealed ailerons that seamed to really crisped up the role rate I have a 91 OS FX 16x4 APC tach it today I am getting 9700rpms hovers about 1/3 throttle pulls out with authority . GREAT PLANE lands slower than a trainer Mark,
Old 11-02-2002 | 04:01 AM
  #465
Default U Can Do 3D
Jhonnylightning, nah, i heard about you... i made SURE i looked through it before i walked out..... lol J/k man
Old 11-02-2002 | 04:06 AM
  #466
Default your killin' me...
...well, just enjoy the darned thing.
Old 11-02-2002 | 05:02 AM
  #467
mecam's Avatar
Default UCD 3D Video part 2
Here are some other 3D manuevers (elevator to harrier, blender, inverted flat spin, knife edge spin, so so waterfall, rolling loop, rolling circle)
http://www.3dbatix.com/videos/ucd3d-2.wmv
Old 11-02-2002 | 09:04 AM
  #468
My Feedback: (22)
Default mecam UCD video part 2
mecam,
Great video!
Is your UCD 3D powered with the new Saito 100 w/16x4W or the old Saito 90 in this second film clip?
______
jmboss
  #469
My Feedback: (22)
Default mecam UCD 3D video part 2
mecam,
Did you have to add more side thrust with the Saito 100 vs the 90?
Thanks.
_______
jmboss
Old 11-02-2002 | 08:48 PM
  #470
Default U Can Do 3D
Is anyone flying this plane with a OS 1.08?
What props?
Thanks, Mike
Old 11-02-2002 | 11:09 PM
  #471
mecam's Avatar
Default Re: mecam UCD 3D video part 2
Originally posted by jmboss
mecam,
Thanks.
_______
jmboss
I was still using the 91 on the second film. I just got back from flying today with a Saito 100 and man what a difference. On the 91 it was swinging my 16x4W at 8600 but with the 100 it was up to 9800~9900. The pull out from a hover is like a 2 to 1 power to weight ratio. I also used the same right thrust configuration and still flew straight vertically. In my opinion, the Saito 100 is the perfect engine for this plane.
Old 11-02-2002 | 11:30 PM
  #472
seanychen's Avatar
Default U Can Do 3D
Mecam,
What fuel did you use on the Saito 100 16x4W? I was turning only about 9100 rpm with my Saito 100 on 10% nitro Sig fuel. How about the throttle response with the 16x4? Mine setup result in very slow spin-up, like 0.5 second from idel to full.
Old 11-02-2002 | 11:41 PM
  #473
mecam's Avatar
Default U Can Do 3D
Originally posted by seanychen
Mecam,
I'm using Powermaster YS20/20 fuel. Throttle response is a bit better than the .91, not as sluggish. These APCs are pretty heavy so it won't respond like it is on wooden props.
Old 11-04-2002 | 03:09 PM
  #474
cmassa's Avatar
Default Lots of mix needed for knife edge
We have three UCD's in our club (number 4 on the bench) They all use YS91FZ's for power and have CG's about 5 1/2 back. Mine and one of the others needs very little mixing for knife edge flight. Mine needs only a little down and the other needs a little up mixing. The third one, however, pitches much more violently down and rolls opposite the rudder. With the control surfaces centered it will fly straight and level with almost no trim changes. He already has a lot of correcting mix in it but it keeps happening (especially the pitch down) Does anyone have any ideas why this plane is so different? What else should we look for? We've been scratching our heads trying to figure it out. When side by side the control surfaces seem identically positioned and are centered. The pushrods are all 4-40. Loops are straight and rolls are axial, hovering is easy.
Chris
Old 11-04-2002 | 03:45 PM
  #475
hroachen's Avatar
Default U Can Do 3D
Chris,
Mine flys straight and pretty neutral too, but also has the strong pitch down with rudder, and with a lot of rudder it rolls too.
I'm almost wondering if the rudder or elevators on some UCD's are more flexy than others... it might explain why only some of them exhibit the trait.
I really like the plane, but if I could get rid of the pitch coupling I'd be in love...
David
