U Can Do 3D
#1501
My Feedback: (68)
Update guys
just got mine in the mail today! very excited about it!
several issues I need to deal with:
- I got it cheap, only thing is it doesnt come with a cowl, Tower has them back ordered until later this month
anyone know where I can get one now?
- I have a saito 91 but from what I have read its gonna need a 100 or the YS. Any ideas where to get the YS cheap?
Looks like I will be searching the classifieds here
matt
anyone know where I can get one now?- I have a saito 91 but from what I have read its gonna need a 100 or the YS. Any ideas where to get the YS cheap?
matt
#1504
MI
Hi Seanychen, sorry on your loss. Are you getting another UCD or something else ?
I later found that the cause of engine quitting is indeed low on fuel: there was like 3 CC left in the tank. Also, the clunk pick-up in the tank broke off from the fuel line, that's why it didn't pick up the last 3 CC I guess.
I think to avoid this situation in the future, profiles come in handy because we can see the fuel level with the exposed fuel tanks.
#1511
Nosram, I knew I saw the picture of your rudder someplace. Could you please explain the rudder mod. as opposed to coupling? I'm not sure if I understand coupling but I do know when attempting KE with left rudder input the plane dives to the deck and to the left. The size of this rudder almost seems like it stalls the plane. Saito 100 W / CG @ 5.5 - 15 X 6 prop. Thanks to radio trouble I have two on the bench right now and thought that I might try chopping the rudder on one of them. Thank You for your time. Joe
#1512
ORIGINAL: Blueskies21
knife edges are acomplished with hardly any input,
Steve
Steve
#1513
Moderator
My Feedback: (58)
It depends where your cg is. The more aft, the more rudder coupling. The fuel tank position matters too - the "effective cg" during flight with the fuel tank behind the firewall is less than if the tank is at cg. My tank is at cg and my cg (with empty fuel tank) is at 5 1/2". I guess that you have to experiment with the cg position and see what you like best....
#1514
Thanks Rajul, I'm not afraid of expermenting but always want to check with the ones that have been there and dealt with it already. !00 Saito-15x6 prop. Tank at firewall W/CG at 5 3/4" I just felt that compared to other models the inputs required were a bit extreme to KE. I do realize the comparison is apples to oranges (against other models). What piqued my interest was reading some reports that hardly any coupling was experienced in KE on other UCD's yet, there is another of cutting the rudder down due to this. This plane is neutral, inverted requires a whisper of down elv. it tracks straight. It dosn't seem like I could ask for more. Thanks for the response. Joe
#1515
Cum'n thru,
Its not clear on how you get your UCD to !QUOT!dive to the deck!QUOT! during knife edge flight. Do you use enough rudder deflection and speed to maintain knife edge flight? The UCD will go into a knife edge loop with lots of rudder. Do you use your ailerons to keep the wings vertical and elevator to keep the plane going straight?
I have two UCD 60's and a UCD 46. The UCD 60's do have severe coupling that varies with the amount of rudder deflection and speed. You either have to fly it out with your ailerons and elevator or mix it out with your computer radio.
This "coupling" is characteristic of models that have no dihedral (flat wings) or too little dihedral. It seems that no one is addressing this and are concentrating on the rudder. In the past I've redesigned fins and rudders on other flat wing models but there was no significant change in flight characteristics. Pattern fliers used to get rid of this problem by sawing their foam wings in half on a band saw then re-gluing the wings together at a different dihedral angle. The correct dihedral will also help correct the tendency of the model to pitch to its top or bottom while in knife edge flight.
Since we're not going to modify the wings on our UCD's we'll just have to live with coupling and enjoy the other great flight characteristics of this airplane.
#1516
My Feedback: (24)
I have my tank on the CG and ballanced at 6 1/4. it's real touchy to fly, but the flat spins, torquerolling, hovering, and waterfalls, oh and blenders are great. I'm thinking of moving the Cg foreword, anybody else doing these stunts at say 5 3/4 to 5 1/2?
#1517
Rocketman. I can compensate with ail. & elv. but just thought the huge inputs were a little abnormal especially after reading some posts about little or no corrections. I've got #3 in the shakedown stages but weather is not optimal lately. Its snowing today! #4 is still on the bench and at this point in time I wanted to make any mods that might help. My radio gear is computerized but I still like to fly with the sticks. This will KE loop tighter than some planes inside or outside loops. I havn't tried KE at higher rpms to much. Rudder turns end up with the same results. The only other plane I've owned that had coupling problems was a Stinger .60 and I never figured that one out either. Thanks for your time in this. Good flying, Joe
#1518
My Feedback: (62)
NJ
Does anyone have the recipe for the UCD to do a respectable elevator? I don't like putting reflex on a switch. I'd rather have it linked to the elevator on a switch if that makes any sense. Haven't flown mine enough to do any thorough testing_bob
#1519
I don't know what you mean by reflex but, with a little throttle mngt. there not bad w/ my basic ability. One way to improve is to mix in some up ailerons with the elevator. Is that reflex?
#1521
3D rates on elevator and low rates on ailerons. Mix in on these settings about half travel of up ailerons. Best case scenerio is to start with a low mix and check the results. Gradually work up to performance/comfort level. Keep in mind all planes respond differently. Go slow and good luck. Joe
