 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 10-24-2003 | 07:42 AM
  #1526
My Feedback: (20)
Default RE: U Can Do 3D
Hey Bob
Who makes the 13 x 4W prop?
APC >
http://www.apcprop.com/html/prop_list.htm
And Zinger >
http://www2.towerhobbies.com/cgi-bin...?&I=LXESM7&P=7
I use APC and like them, I think there are other brands.
Old 10-24-2003 | 07:52 AM
  #1527
coomarlin's Avatar
ORIGINAL: rajul
Hi Adrian, I remember seeing a pic of your wing tips removed ? Did you put them back ?
Good eye Raj Maybe they are not so fresh after all. lol
Old 10-24-2003 | 08:17 AM
  #1528
rajul's Avatar
Moderator
My Feedback: (58)
ORIGINAL: coomarlin
Hi Coo, actually my eyesight is getting worse. Must be all that time I spend in front of the monitor. I am desperate enough to get one of those "pinhole" glasses to improve my eyesight, plus getting on a regiment of eye exercises.
At least my memory still serves me well.......
Old 10-24-2003 | 02:15 PM
  #1529
rajul - this is no 2 - soon these wing tips will also go - for sure
Old 10-25-2003 | 07:19 PM
  #1530
Robermonti's Avatar
That's me hovering my UCD hands off on the cover of the Aerotec magazine from Spain
Old 10-26-2003 | 11:34 AM
  #1531
SunShyne's Avatar
My Feedback: (68)
nice pic, congrats!
Guys-
After days of reading the other 50+ pages on this plane I am scared my stock Saito 100 is gonna require the Cline reg and I really dont want to mess with that. I dont have a clue as to where to tap etc, etc. I dont want to mess with the engine if it requires cutting into it. I am novice as far as that is concerned. Any input on this would be appreciated.
thanks
matt[&:]
Old 10-26-2003 | 11:46 AM
  #1532
THEY ARE THREE MEMBERS AT OUR CLUB FLYING THE 3-UCAN DO. ONE HAS A .40 SIZE AND THE OTHER TWO HAVE THE .60 SIZE. ALL THREE LOVE THEM, I WANT ONE MYSELF!!
Old 10-26-2003 | 11:53 AM
  #1533
My Feedback: (24)
matt, who told you that you had to cut or tap your engine? First of all save yourself some money and buy the Iron Bay Regulator. It also comes with the oneway valve and T you will need to preasurize your fuel tank. Here is the set up.
You only need two lines to the tank
1.The fuel line that runs from your exhaust will have the supplied oneway valve in it. It will allow preasure to build in the tank, but not come back out.
2 Between the oneway valve and the fuel tank(SAME LINE) you will put the T conector and run one line wild out the bottom of the cowl. You will have to put a plug in it. (GOLF TEE ECT) This is so you can remove the plug when fueling, or taking fuel out of the tank. Remember you now have a closed preasurized system so if you don't provide a vent for fueling you will expand and rupture the tank. (the reverse when taking fuel out)
3. Now the other fuel line.... Come out of your tank, into the regulator, out of the regulator and connect to the carb.
No cutting, nipping, slicing, diceing, taping ect. maybe the Cline needs all this I don't know.
Everything comes with the Iron Bay Regulator for $43.00 plus shipping.
John
Old 10-26-2003 | 01:19 PM
  #1534
AcroJo's Avatar
Ponder this, and its only a thought. Could there be any benefits from just a one way valve on the pressure line from exhaust to tank? (no regulator) You would think that any pressure built up would be lost, lets say when you throttle down. A simple valve like this would keep any pressure in the tank from escapeing. In low pressure spray equippment there is such a valve for this purpose. It's about the size of a dime and would accept standard fuel line. I do not have a regulator. If it regulates pressure thats one thing, if it acts like a small fuel pump thats different.
Old 10-26-2003 | 01:25 PM
  #1535
My Feedback: (24)
Never work, you engine will run like crap trust me. I don't sell regulators, I sell insurance, but I will tell you this, when I find something that really works well I tell everybody, if it doesn't work I tell everybody too! My engine runs soooooo sweet with the regulator I still can't believe it. Idel is perfect, transition is perfect, no flame outs.
John
Old 10-26-2003 | 02:21 PM
  #1536
Rocketman_'s Avatar
[]Does the Saito 100 have some kind of inherent fuel flow problem. Is there a real need to buy a pump/regulator if the tank is located at the firewall of the UCD 60? It seems that some people may be trying to solve a problem that doesn't exist. The Saito 72 in my UCD 46 has no such problem.
If the tank is moved to some location that is distant from the engine a pump/regulator may be necessary. Is it correct to assume that some fliers relocate the tank farther back in the UCD fuselage to achieve a more favorable CG location for 3d flying?
I moved the CG farther back in one of my UCD 60's (I have two) by moving the battery to the rear of the fuselage in a hatch I made in the bottom. In this way I avoided having to move the tank, the throttle servo, the receiver and having to buy a regulator for $43.00 plus shipping. I did notice that the plane becomes a little squirrelly with 3d elevator throws.
My two UCD 60's are powered by OS 91 2-strokes. The OS 2-stroke with its giant muffler weighs 24.3 oz which is more than the Saito 100 4-stroke. A Saito in the nose may move the CG a little farther rearward.
My next engine purchase may be a Saito 100 4-stroke and I was hoping to use it without buying any additional gadgetry to attach to it.
Old 10-26-2003 | 02:58 PM
  #1537
coomarlin's Avatar
ORIGINAL: Rocketman_
There is no inherent problem with a Saito 100. The reason people use a regulator on UCD's is because Great Planes did a poor job of engineering the plane itself. The stock location of the tank puts the centerline of the tank at least 1 inch above the carb centerline. It only makes sense that if a tank is higher than the carb it's going to syphon down into the carb and flood the engine. When the tank and the carb at at the same level they are at equalibrium and there is no tendency to load up the carb with fuel. A regulator stops the flow of fuel when there is no demand for it (suction). Thats why they work perfectly in this application.
Great planes should've dropped the tank down about an inch or so and there never would've been a problem.
Old 10-26-2003 | 03:12 PM
  #1538
NM_Mark's Avatar
My Feedback: (8)
I run a Perry Pump (the Oscillating pump) on a Saito motor...and no problems since I've installed it. Only $27 through Tower...
Old 10-26-2003 | 04:14 PM
  #1539
My Feedback: (24)
coolmarlin is correct, the tank if too high. it will flood w/o a regulator. been there, done that!
You have to understand something.... when you read a thread as old as this one. all of the problems have been worked out. You get the correct CG. the right engine, the right thrust angle, servo's, linkages, fuel system and set up. what more could a person want.
Old 10-26-2003 | 04:46 PM
  #1540
AcroJo's Avatar
I was under the impression that the regulator was needed when the tank was placed further aft ( at the CG ) that it was too far to push fuel with supplied pressure of exhaust. As far as the tank being too high wouldn't mounting the engine in the upright position correct this? Flooding is inherant in any plane when the engine is mounted inverted. Normally I will spin the prop several times after fueling before starting. It never kicks, spins a prop or runs backward.
Old 10-26-2003 | 04:59 PM
  #1541
My Feedback: (24)
RE: U Can Do 3D (in reply to jrjohn) Contact Moderator | | Revisions: 1 (Post No. 1540)
Your right, it's needed in both situations. On the CG because it needs preasure to push the fuel, and when the tank is up front to stop the syphon effect. Turn the engine right side up if you want, What a mess that will be
John
Old 10-26-2003 | 05:07 PM
  #1542
coomarlin's Avatar
ORIGINAL: cum'n thru
As jrjohn mentioned, you are correct in that both situations can be cured by a regulator.
You won't need a regulator if you decide to mount the engine upright, but since the plane was designed for an inverted engine, you'll have a very odd looking plane. Somewhere in these 50 pages there are photos of someone mounting an engine upright, and although it worked, it looked very odd. If you don't mind the asthetic drawbacks go ahead and mount the engine upright.
Old 10-26-2003 | 06:17 PM
  #1543
rajul's Avatar
Moderator
My Feedback: (58)
I mount my Saito 100 in the upright position, with tank at cg, and with a cline. Looks good to me, better than no cowl. No hassle in installation (very easy to do), no hassle in starting, no additional weight/wiring complications from glow head connector, and I don't need to remove the cowl for minor engine or fuel line jobs. My engine likes the additional cooling too, especially in a hover.
Old 10-26-2003 | 06:49 PM
  #1544
coomarlin's Avatar
ORIGINAL: rajul
I mount my Saito 100 in the upright position, with tank at cg, and with a cline. Looks good to me, better than no cowl. No hassle in installation (veary easy to do), no hassle in starting, no additional weight/wiring complications from glow head connector, and I don't need to remove the cowl for minor engine or fuel line jobs.
Hey Raj, show us some closeup pics.
Old 10-26-2003 | 07:09 PM
  #1545
Rocketman_'s Avatar
Ok, ok, it sounds like some of us are talking about engine performance and the rest are talking about siphoning and leakage. All I wanted to know is whether the Saito 100 ran well in flight in the stock UCD 60 installation without Perrys and Clines and Iron Bays, etc.
Everybody who has a UCD knows where the tank is and that the engine is inverted and we know it leaks.
And yes my UCD 46 with its Saito 72 leaks while parked but it runs perfectly on the ground and in the air through any maneuver with no assistance from regulators or pumps.
I handle my siphoning problem a different way. Since the UCD 46 cowl covers my Saito 72, I use a Sullivan filler valve to fill the tank. This valve requires no special fitting to fuel it, just a short length of brass tubing. Between flights I just stick a plugged piece of brass tubing in the valve to block it. This is no more labor intensive that switching off the receiver after each flight.
Old 10-26-2003 | 07:15 PM
  #1546
rajul's Avatar
Moderator
My Feedback: (58)
Coo, I'll get some pics posted as soon as my digicam comes back from service.
Old 10-26-2003 | 07:39 PM
  #1547
coomarlin's Avatar
If your not bothered by the fuel seepage issue on your 72 then you won't be on the 100. The problems are identical. Buy the 100 and use the brass tubing method on it if you want to save $43.
Old 10-26-2003 | 08:13 PM
  #1548
AcroJo's Avatar
My Saito is inverted and has never leaked thru the carb after several months of use or kicked back, thrown a prop etc. We all know the pros and cons of asthetics when choosing the position of an engine and the results anytime you put the carb below the fuel tanks outlets. My original question was about a flapper valve which stops pressure loss in tank from going back out the pressure tube when at low throttle settings. JrJohn replied, and I thank him for that, but did not extend a reason as to why it won't work. Has it been tried? Does it hold too much pressure? I just thought I'd throw it out there before I try it. Thanks for everyones input so far. Joe
P.S. Rocketman, it runs great as stock.
Old 10-26-2003 | 08:28 PM
  #1549
My Feedback: (24)
I assume your talking about putting a one way valve in the preasure line from the exhaust? if so, I don't have to tryit to know it won't work. I can guarantee it won't. As soon as you put preasure in the tank without a regulator in the fuel line you will totally flood your engine as soon as you shut it off, not to mention eratic running. you'll never be able to tune the engine to run right at all rpms. Once you have a preasurized system, you need the preasure to be constant, it can't be without a regulator.
Your trying to reinvent the wheel, Trust me on this one, If you need pics of the set up, I'll send some
JOhn
Old 10-26-2003 | 08:36 PM
  #1550
AcroJo's Avatar
Now thats what I've been looking for. Thank you JrJohn." Been there, done that" was just a little vague. We took the long way around the block but ended up at the right spot. Thanks guys.
