 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 12-03-2003 | 01:39 PM
  #1751
SLINGSHOT-RCU's Avatar
Default RE: U Can Do 3D
I HAVE A YS9IAC ON MINE I FOUND THIS WAY TO WORK BEST FOR ME.BECAUSE YOU HAVE A CHECK V....
Old 12-03-2003 | 05:27 PM
  #1752
AcroJo's Avatar
U Can Do #4 just went out the door with its proud new owner, well not quite. On the way out he hit the hor. stab. on the door jamb and put a crack across the fuse from the stab block down to the bottom of the fuse. Dosn't take much, does it. I guess he'll have to bone up on his repair skills. Joe
Old 12-03-2003 | 06:36 PM
  #1753
hey yall
would a saito 120 be to much for the UCD to handle? i have a two stroke .91 in it now and i want a 4 stroke. thanks!
Cary C.
Old 12-04-2003 | 06:34 AM
  #1754
coomarlin's Avatar
ORIGINAL: cary c.
hey yall
Cary C.
There are several people here that use or have tried a Saito 120. I'd think it would be a little much and the added weight would just add to an already nose heavy plane. But like I said people are using them. I use a Saito 100 it it's got plenty of power and good vertical.
Old 12-04-2003 | 03:05 PM
  #1755
SunShyne's Avatar
My Feedback: (68)
ORIGINAL: cumn thru
This is the best fuel method I have found. The "Kwik Fill" fueling valve by Dubro. Part#334. It just splices into the fuel supply line. When you insert the supplied fuel niple it automatically shuts off the flow to the carb. Pretty slick. They sell a mounting bracket to mount to the firewall (wood) but its just as simple to use a piece of aluminum angle. You can also mount it right on the fuse. Joe
been using these for over a year now and have yet to have a problem on any of my planes that have it. hmm...
Old 12-04-2003 | 03:53 PM
  #1756
AcroJo's Avatar
Matt, This original Quik Fueler is about 18 months old and no problems. I have them on other planes, not quite as long, but no problems. Like I said, in the event it went bad I wouldn't hesitate to replace it with the same. Joe
Old 12-04-2003 | 10:38 PM
  #1757
ORIGINAL: DiabloKid
ORIGINAL: cumn thru
Hey Gents,
I fly with DiabloKid and we both have been using the dubro Kwik-Fills for over a year now. I have heard about leaks and the valve assembly o-rings eventually going south. If you check within close proximity of the where you got the Kwik-Fill you should also find the Kwik-Fill Rebuild Kit, about $3.65. Comes with new o-rings (big and small sizes for both sides of the valve), a new spring, shuttle (valve), nut and lock washer, and not that we need it, but easy to follow instuctions. I replace mine every 5 gallons and haven't had an air leak or fuel problem, etc. Little maintance goes a long way, heck you change your oil in your car, don't you?
Part info: http://www.shopatron.com/product/pro...d=DUB718/101.0
Well first snow just started accumulating here in VA, dispite all the hype. I am getting some ski's for my Sunday Flier. See you in the air guys!
Old 12-06-2003 | 06:06 PM
  #1758
AcroJo's Avatar
Blkopz, You boys definatly got your snow faces on. Did you get ski's?
Old 12-06-2003 | 07:13 PM
  #1759
Hey Man!
Sup? No I didn't pick them up today, but luckly the shop is open tomorrow! God Bless Christmas hours! I should have them on tomorrow and if the winds die down I will be able to fly a bit and take some pix for the site (www.hideinmy.com) (Beautiful Images). Need to find a tail dragger conversion with skis.
BLKOPZ
Hmm, grey skies are wonderful for losing profile....
Old 12-07-2003 | 05:27 PM
  #1760
Default RE: UCD
8hrs who are they kidding? Took me over 14hrs! BUT WHAT A GREAT FLYING PLANE! Have a Magnuym 91 fs and added no weight for the CG. This plane can do it all. Bought mine when they 1st came out. What a floater tho. It can take anything you dish out. Hope you all enjoy!!! JIM
Old 12-07-2003 | 05:30 PM
  #1761
SunShyne's Avatar
My Feedback: (68)
Default RE: UCD
wonder how hard it wourld be to put ski's on the ucando
Old 12-07-2003 | 05:40 PM
  #1762
HarleyRider's Avatar
My Feedback: (10)
Default RE: UCD
I went to the flying field today and what a great day to fly. Clear sky and very little wind. At one time today we had six UCANDO'S in the air or getting ready to fly. As long as I have been flying I have never seen an airplane as popular as this one. I had a ball flying mine today.
Old 12-07-2003 | 06:02 PM
  #1763
AcroJo's Avatar
Default RE: UCD
ORIGINAL: jkh
8hrs who are they kidding? Took me over 14hrs! JIM
Actually they boast 8 t0 10 hrs. After you build a couple it should get easier. #4 took me 30 hrs. with mods. I don't think you could do it in 10 with their hardware in stock version. Joe
Old 12-07-2003 | 06:04 PM
  #1764
AcroJo's Avatar
Default RE: UCD
ORIGINAL: DiabloKid
Have Lee do it!!!!!
Old 12-07-2003 | 08:25 PM
  #1765
Default RE: UCD
Hi Guys,
I have a UCD 3D 60 size on order for winter flying. I am in Canada (5 months winter) so if you love to fly, you have to fly in winter too. Just read the post on skis and wanted to say that winter flying can be fun. Some of the best skis are manufactured just 5 minutes from my place so I can't find an excuse not to fly. The owner of the company and I are friends and we chat quite often about designing other RC related items. In fact he is always trying out new manufacturing techniques though I think his skis are perfect. His skis are made from aluminum, Teflon and has a spring loaded, forward locking mechanism. They are light, RF noise free and easy to mount, less than 8 minutes. I have sat with him and designed skis for monster trucks and tried them out today, they were a blast. I will be making those with him and will be marketing them soon. See pics attached.
ID:	80545   Click image for larger version
ID:	80546   Click image for larger version
Old 12-07-2003 | 10:09 PM
  #1766
Default RE: UCD
If you have built a PQHOR or a PBF, then you have all the parts you need for skis. You can make skis out of coroplast cut lengthwise with either metal wire or carbon shafts for strength. Use some alunminum U channel and some wheel collars, and youre in business. Tail skid would be smaller, with the same aluminum channel. The edges of the coroplast act like edges on a real ski, makes for very good ground handling. I dont have pics of the skis we used last year. Try doing a search for in-flight video footage from a seniorita on RCU. I think there are pics of the skis in that thread.
You can also try looking at www.hoverbatics.com . Look on the video plane projects.
Steve
Oh yeah, You can use a Saito 150 on the UCD with a few mods, and it flies really reallly really well. It is a tad heavier than with a 91fx (been there, done that), but the two extra inches of prop diameter (17x6 on the 150 vs 15x6 on the 91) has to be seen to be believed. My plane has held up well (for a year now) with this setup.
Steve
Old 12-10-2003 | 05:56 PM
  #1767
AcroJo's Avatar
Default RE: UCD
Okay, back on topic. Ponder this fellow U Can Do'ers. With a Saito 100 this frame is carrying just under 21 oz. of engine up front. If you were to scratch build a UCD what percentage increase in size would it have to be to accomadate a 3lb. gasser? I know someone already did a weight mod on a G23 and is flying it but its got to be a lot of weight upfront. Also take into consideration not only the engine but the weight of the additional support equippment that goes with gas. Is it feasable to figure out the percentage of weight increase of hardware and apply that to determine how big the increase in size is required? Again I need a math whiz or would it be an aerodynamical guru? Joe
Old 12-10-2003 | 07:36 PM
  #1768
zonker123's Avatar
My Feedback: (21)
Default RE: UCD
to I & C TECH
Ive got a new fuse and canopy for a 60 UCAN i am not going to use
zonk
Old 12-10-2003 | 09:33 PM
  #1769
I & C Tech's Avatar
Default RE: UCD
Dang Zonk, I just received a new UCD yesterday. I may still be interested though. Where are you in NC?
Old 12-10-2003 | 09:39 PM
  #1770
I & C Tech's Avatar
Default RE: UCD
I'm thinking of something besides the stock hinges on this new build. I'd hate to regret it down the road since I've read a few bad comments on the GP variety. Any recommendations?
Old 12-10-2003 | 10:49 PM
  #1771
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: UCD
Hi Wade, sent you a couple of PMs which keep bouncing back. Can you enable your PM in your RCU settings ? Thx.........
Old 12-10-2003 | 11:18 PM
  #1772
zonker123's Avatar
My Feedback: (21)
Default RE: UCD
im in "little" washington
id use the radio south hinges, alot better than the gp hinges that come with the kit
I pancaked mine in when i ran out of fuel low to the ground while practicing elevators
orderd the fuse to rebuild it but the more i get into repairing the wing the more i find out I should gotten one those also.
rather sell the fuse and just pick up a full kit later
take care
zonk
Old 12-10-2003 | 11:42 PM
  #1773
SunShyne's Avatar
My Feedback: (68)
Default RE: UCD
man.. I have mine built just waiting for a nice day to get out there and fly it!!
Only hitch is Tower is out of the cowls and I got burned by an RCU member who I paid $10 for his and he has dissapeared Anyone know where I can get one or has one for sale?
matt
Old 12-11-2003 | 12:24 AM
  #1774
Hoss's Avatar
Default RE: UCD
Zonk,
Any chance you would want to box up the fuse and canopy and ship it? If so I would be more than happy to take it off your hands.
Old 12-11-2003 | 02:33 AM
  #1775
STEVE LENZ's Avatar
My Feedback: (45)
Default RE: UCD
Tower Hobbies had a wing in there Scratch and dent area.( 46 size) Good luck
