 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 07-18-2004 | 03:58 PM
  #2401
Default RE: U Can Do 3D
o.k thanks for everyone...
Old 07-18-2004 | 06:21 PM
  #2402
one more question, now i have prop 15*6 of zinger and i want to know if he good for 3d or not because i put him in my u-can-do-3d only for the test.....
Old 07-18-2004 | 06:50 PM
  #2403
NeoGenesis's Avatar
My Feedback: (27)
15x6 will perform fine. A change is only needed if you don't like the way it flies.
Neo
Old 07-18-2004 | 07:05 PM
  #2404
o.k thanks....
Old 07-19-2004 | 06:35 AM
  #2405
My Feedback: (45)
Hi Joe;
Mostly it is correct, but the high compression ratio of the Saito, coupled with the fact that the engine is inverted, might very easily cause a full or partial hydraulic lock. Now, if one starts the engine by hand (I love my engines, but my fingers are more important to me than their welfare) than the chance of damaging the engine is very low, but if you apply an electric starter to the engine, you might - easier than you might think - bend then con-rod. Coomarlins description of what happened to him: first flight for that day, starting the engine, full power vertical till an engine cut-off and than a bent con-rod suggests that this might be the case.
Yaron
Old 07-19-2004 | 08:24 AM
  #2406
coomarlin's Avatar
I never really thought much of a hydrolock. I'm using a Cline regulator and I would think the cline would prevent hydrolock. Being that it works by demand. I normally flip my prop over before I start it, but I'm not sure if I did the day my engine died.
Old 07-20-2004 | 10:13 AM
  #2407
Hi again, I was in the store today and there is not the prop that I need so I took 16*6 APC.
how is this prop for 3d for saito 100?
I heard from people that he excellent for 3d, what do you think about him???
Old 07-20-2004 | 11:07 AM
  #2408
AcroJo's Avatar
Might be a little large for a Saito 100, unless you are burning 30% nitro @ sea level. 15/6 or 16/4 is good. Joe
Old 07-20-2004 | 12:40 PM
  #2409
coomarlin's Avatar
I agree with Joe. A 16x6 will be too large for the Saito 100 for 3D. Might be OK for sport flying. I use a 15x6. The other two common props are the 16x4w and the 15x4w.
Old 07-20-2004 | 09:39 PM
  #2410
check out my wild paint job!!!!!!!
Randy
ID:	155680   Click image for larger version
ID:	155681   Click image for larger version
ID:	155682   Click image for larger version
Old 07-20-2004 | 09:41 PM
  #2411
MHester's Avatar
Well Randy, it's umm.....different......
-Mike
Old 07-20-2004 | 09:57 PM
  #2412
NeoGenesis's Avatar
My Feedback: (27)
That'll turn black once it's in the air
Neo
Old 07-20-2004 | 10:11 PM
  #2413
My 12 year nephew was dieing to airbrush it, and when I first saw it I didn't know if I should kill him or tell him thanks, But the pictures really don't do it justice, it really is cool up close and when its flying, it doesn't look dark at all..
Randy
Old 07-21-2004 | 06:27 AM
  #2414
NeoGenesis's Avatar
My Feedback: (27)
Not to bad for being 12. He's got a good imagination that's for sure.
Neo
Old 07-27-2004 | 07:36 AM
  #2415
Default RE: Harrier theory
It sounds like your tip stalling or youew c.g. is off
Old 07-27-2004 | 07:39 AM
  #2416
Where r u guys getting you c.g.? I just flew my ucd do for the first time on sunday it was awsome
Old 07-27-2004 | 07:52 AM
  #2417
coomarlin's Avatar
I fly with my CG at 6". I've tried everything from 5"-6.25" and 6 seems to be the sweat spot for me.
Old 07-27-2004 | 11:42 PM
  #2418
My Feedback: (40)
Hi guys i also fly my u can do at 6" to 6.5". At 6.5" it comes down like a Harrier...... Full ele up. 50% flap up. try it at high alt first until your mix is set up.
Old 08-02-2004 | 09:47 AM
  #2419
GaryB-RCU's Avatar
...picked up one of these a couple of weeks ago (Saito 100) - so far, i really like it (10-12 flights) - no tail touches yet (APC 16-4W, CG 6" to 6 1/4" back)...
...what i like best so far? - it's ability to fly in the wind (15-22 MPH wind in the video) - i'm using a spoileron mix in the attempts at harrier rolls - 2nd video down on the page - any tips on doing harrier rolls or hovering with this plane would be appreciated...
http://rcfunflyers.com/
http://rcfunflyers.com/Ucando%208-1-04.wmv
Old 08-07-2004 | 03:16 PM
  #2420
SALMONBUG's Avatar
video of the landing here
http://212.68.218.196/aero/attero/atterovid.avi
right click and save target
Old 08-07-2004 | 04:12 PM
  #2421
AcroJo's Avatar
SALMUNBUG, excelent job, you kept a cool head. A little hot, but well done. Now for what really got me going. Thank you for your choice of formatt on the movie clip. You have enabled me to watch my first video on RCU in about 2 years. Not only the first vid, but of my favorite plane to boot. I'm on a Mac, and with so many members running Windows, all the video posts are in WMV. Thanks for the treat and get those screws back in. Joe
Old 08-07-2004 | 07:44 PM
  #2422
SALMONBUG's Avatar
a other kind of hovering
Old 08-09-2004 | 08:36 PM
  #2423
My Feedback: (40)
[X(]
Old 08-09-2004 | 09:52 PM
  #2424
Hi guys
What is a Cline? I how helps my SAITO
Old 08-10-2004 | 10:18 PM
  #2425
Electriceddie's Avatar
The .60size U can Do 3D does have a one peice wing already joined as a complete wing . The bottom of mine is Red and White checks. It is very light so far, mine is all assembeled except for radio. I am waiting for digital servos to come in. I have seen one .60size U-Cando-3D fly and that's why I went out and purchased mine. I also have seen the .40 size fly and have heard nothing but good reports about it. For my taste and preference .60 size will be better for 3D flight. Set up right weight should not be an issue. Just be ware of the thrust right and down. Great Planes has had issues here. I wrote to them on several occasions and was given conflicting answers. So check into it, they may get there act together in the future. Also beware of wheel pant mounting, when I mounted mine (exactly as stated in instructions) they are very low to the ground. Grass feilds may be a problem, but not sure have not flown it yet. If you look at they way they are mounted it will be clear to see what I mean. Keep in mind when building.
