 Showtime >
Showtime
Showtime
Old 07-23-2005 | 01:32 PM
  #426
Big Barry's Avatar
Default RE: Showtime
Barry
Dont feel bad I'm an 1/8" forward and I measured three times.
Flew my YAK this morning, all is well with the world. This is suposed to fly like a foamy, if it flys half as nice as my YAK then it will be hard to get another. I better order one on Monday!
Big Barry
Old 07-23-2005 | 01:34 PM
  #427
rcflyguy_26's Avatar
My Feedback: (8)
Yes, after neo landed and I saw that the ele linkage came apart, I checked mine ASAP! I found one loose on the right aileron.
I put 5 more flights on mine. I'm setting two different programs up... one for the SFG's and one for pattern. In pattern mode, the os1.08 and the 16-8 apc are a good combo. I forgot to go to low rates on an up line... I was planning on doing a full snap, but ended up being 1 1/4 very violent snap, it lost some momentum, but kept going on the up line.
The airframe seens to handle the speed very well. I kept the down lines back. but went to full throttle in the flat. No sign of flutter at all.
I was doing big jet like loops! Entrance and exit were almost at the same point.
The sound of the 1.08 is sweet. The mostly open pica muffler lets it cackle, when you throttle back on the down lines.
One miss... the purple covering is wrinkling in the sun... bad. Looks like I have to get out the heat gun again. Looked good out of box, when over it to seal edges and snug covering... didn't help much. It maybe getting monocote this winter.
Later, Scott
Old 07-23-2005 | 02:59 PM
  #428
My Feedback: (9)
RCFlyguy let me twiddle the sticks on his showtime for a few minutes this afternoon. I was extremely impressed!! It felt extremely smooth and precise, yet had all the control and power of a good 3D machine. To me, this is the ultimate combination.
I've been head-over-heels in love with my 35% Carden this season...flown it almost exclusively. I went to giant scale because I never found a smaller plane that flew as nice as the giant stuff. The showtime is by-far the closest I've found to a 35% plane. There was still a difference...but it wasn't much.
McConnville did an awesome job on this one!
Old 07-23-2005 | 03:29 PM
  #429
drumbum's Avatar
Well my showtime is no more...
3rd flight today, just after takeoff went vertical for about 150 ft and flipped ailerons to high rates (i keep elevator on high). did a blender with a long decent with just ailerons then another pretty long pause with the ailerons and rudder. then i went to flaten it at the bottom and it never flattenend out. by this time i was about 40ft up. so i gassed it to pull it out..It still didnt pull out and kept spiraling into the ground still at full throttle trying to pull it out.....
after examining the wreckage i found nothing out of the ordinary. so we hooked the battery up after we figured it wasnt going to explode (Li-Po).. as soon as i hooked it up i noticed that when it crashed the ailerons were in high rates and the elevator was in low rates.. so i concluded i crashed it due to pilot error.. low rates were not enough to pull it out of the blender.. that coupled with high rates on ailerons created a MAJOR fight trying to save it.. I SHOULD HAVE CHECKED BOTH SWITCHES BEFORE GOING ITO THE BLENDER[:@]..
I will have to wait a week or so but i am ordering another.. IT destroyed the fuse,cowl canopy,wing tube, damaged 1 wing,(the SFGs were not on), so now i have spare parts for the next one. it also broke my needle valve on my YS-110... hopefully there are no bent pushrods.. the ground was fairly soft where it hit but like i said it was at full throttle.. i backed off but dont know it it had hit by then or not..
Old 07-23-2005 | 04:58 PM
  #430
raideron's Avatar
Sorry about your mishap Lee[].... Hopefully all else is in good
shape for your new one!!
Old 07-23-2005 | 06:48 PM
  #431
My Feedback: (17)
Drumbum, Sorry man. I just hate it when you crash. Especially a brand new plane. Nothing anybody says helps, but it happens to all of us. If you want to fly crazy (3D) it's gonna happen. But, I'm still sorry.
thanks\\
Barry
Old 07-23-2005 | 08:27 PM
  #432
The SFG was bent on the first take off when I under estimated ground roll for the ship and brushed some high grass at the end of the field! They are not real strong, especially under load after a quick CA repair, they still bent again so I ordered a couple more.
Oh well, it flies ok without them but it is much better with the SFGs onboard.
Skyking
Old 07-23-2005 | 08:45 PM
  #433
drumbum's Avatar
ORIGINAL: raideron
thanks\\
Barry
yea it sucks, I almost had the plane dialed in perfect. and made a stupid mistake. I dont remember cuting the elevators to low rates and since i always flew the elevator at high rate i just assumed it was high.. Oh well live and learn. i had also pin pionted my wing rock. I added some lead to the nose just as a" test" the flight before i crashed it. I turned out that it stablized it.and mine started out at recommended CG before the lead test.. so i was going to remove the lead and go to pull pull when i got home but never made it that far. the last flight was back to no lead since i hate dead weight and just put it there for test purposes anyway....
Old 07-23-2005 | 09:15 PM
  #434
Ok so I have a Fun90s with a saito 150 that snaps out of everything at slow speeds and am looking at this plane that is said to fly better than it but has LESS wing area. Should I believe that it will fly much different at slow speeds? I am selling my Funtana and am thinking of this plane or a profile. What do ya think I should do?
Thanks Dave
Old 07-23-2005 | 09:17 PM
  #435
YNOT's Avatar
Had a good day with mine, 160 still fresh and fat. Vid to come.
I saw a post about ripping a wing half off due to flutter. THE SFG'S WILL FLUTTTTTER with just a bit too much speed. The first time it happened, I was running some basic patter stuff and on a very gentle pull from vertical, one flutter like CRAZY!!! It happened 2 more times on that flight. On the next i only did it once and on all the others never fluttered. Just kept is a modest pace and on down lines I made sure I rolled it or snapped it to slow it down a bit, no problem.
On the CG point, its a tad nose heavy, dry. Without the wings on, its a tad tail heavy on the tube.
Highly impressed with this plane.
Inverted flat spins slow and stable.
Only could get knife edge spin from inverted flat spin.
WATERFALL!!!!! GEEEZZZZZZ....Rotates without loosing altitude. I didn't really work on catching it back in a hover, however it should be pretty easy.
Parachute, DAM!!!! Rock solid and almost comes to a stop.
Harrier real well. Gotta keep a little power on, harrier doesn't need the nose real high.
Inverted harriers better than upright.
Suicide slides well. Motor is not turned on, so a little more precise low end and it should come almost straight down.
Snaps and flips well and easy to catch in knife edge.
Falling leaf, the best I have ever flown. Rotates very well like its crazy tail heavy, however its not.
Fat 160 puts it in orbit from a hover. Foamy power.
Flys very slow, very well. If you get it too slow, it will drop a wing, a little power and its flying again.
Would not do a toilet bowl, it would snap out.
Didn't get a pinwhell, snaps out too.
SFG Flutter, you have been warned. Throttle control and it is controllable. Maybe some flying wires, they would help a bunch. I never took the SFG's off, don't want, thats the reason I got the plane.
It has been YNOT approved. Not that means anything to you, however it means allot to me. Too many "3D" planes have not been approved.
Old 07-23-2005 | 09:30 PM
  #436
My Feedback: (17)
Thanks for the mini review YNOT. You tell us what it does and doesn't do well. You probably have more power than anybody so it sounds like the plane handles that well too. I'm betting a YNOT approved plane would be one I like as well.
Drumbum, so...you were thinking of moving the CG forward? I'm balancing mine tonight so your timing is good. Well, not the crash but the CG info. I'm releying on you to give me a starting point. The manual says 7 7/16". Where would you suggest as a starting point?
Barry
Old 07-23-2005 | 10:02 PM
  #437
drumbum's Avatar
ORIGINAL: Barry Cazier
Barry
i would try it at recomended as i did but dont cut the other side of the treaded rod off on the rudder just incase you have to go pull pull.. mine did everything fine but harriers.. harriers had wing rock.. but my tail also mushed around like it was slightly tail heavy on occasion.. I put the lead up front an could hold full deflection in harrier without wing rock. so I was just going to switch it to pull pull to fix it. mine was flying so light that when i went to full deflection on elevators at rcomended that it would eathier wing rock when slow enough to harrier or when jsut slight throttle was added it would just go vertical.. there was no happy medium.. so I was attributing the wing rock to the fact that if i was going slow enough to get in that position that it was just not enough airspeed ..(if that makes since) .. so my conclusion was move the weight around (slightly) the guys with the heavier motors are flying a heavier plane which it seems like is helpng tthe wing rock. only the guys with the lighter motors were complaining about it on this thread..
Old 07-23-2005 | 11:02 PM
  #438
My Feedback: (106)
Greetings,
I had the post on the wing flutter......I didnt mention that I did not have the SFG's on at the time........
Old 07-23-2005 | 11:05 PM
  #439
YNOT's Avatar
OH! No SFG's. I donno
VIDEO!!!!!!!
None of its low becasue the motor is new and didn;t need any low deadsticks.
Thanks to Coverup for shooting this.
http://www.netlight.org/YNOTshowtime.wmv
Old 07-23-2005 | 11:20 PM
  #440
My Feedback: (17)
YNOT, That is a great video!!! Thanks for posting that. Man that plane looks "crisp" in it's movements. I'm suspecting these were some of your first flights too, right? Very cool. Very cool.
Barry
Old 07-23-2005 | 11:22 PM
  #441
YNOT's Avatar
yea, I just put the 4th flight on it and you see the end of the 4th when the motor quit. Blew the plug.
Old 07-24-2005 | 02:22 AM
  #442
BoneDoc's Avatar
awesome!
great vid and great flying too. Do you actually have an OS 160 on it? That's a lot of motor isn't it for a "90" size frame .
Old 07-24-2005 | 06:45 AM
  #443
is it possible to fly the showtime without the bottom sfg's?....they look low to the ground and anything but a perfect landing at my field would probably damage them...my field has alots of bumps
Old 07-24-2005 | 01:31 PM
  #444
drumbum's Avatar
ORIGINAL: tukkus
No,, they hook together,,
Old 07-24-2005 | 02:14 PM
  #445
NeoGenesis's Avatar
My Feedback: (27)
ORIGINAL: tukkus
If you were willing to cut into the botom sfg to modify it...then yes it would be possible. Basically make a a plug out of it......
Neo
Old 07-24-2005 | 02:47 PM
  #446
Fly-n-3D's Avatar
Nice video! Not to get off topic, but how long did it take you all to download the video? It took me about 2 minutes.
Old 07-24-2005 | 05:58 PM
  #447
That is pretty good.
I got the same speeds, I averaged 305 kbps.
Speeds could vary due to traffic loads and such.
2 minutes for a 30 Meg download is really good.
John
Old 07-24-2005 | 07:35 PM
  #448
Ron Kinsey's Avatar
I've got DSL. It only takes about 10/15 seconds to start playing and loads ahead at the same time.
Awesome video Ynot...THANKS!
So Sorry for your mishap Drumbum...[&o]
Old 07-24-2005 | 08:22 PM
  #449
I switched from my Saito 120 to a YS 110. Central Hobbies finally got them in. I have never had a YS before. It keeps dying on my landing approach. In the air it flies great. I think it even has more power with less weight than the Saito. I am just sick od dead stick landings. Anybody have any advise? High end is set at 1 1/2 turns out and the low end is just a little less.
R/C Foolish
Old 07-24-2005 | 09:22 PM
  #450
R/C...i'm guessing that you're too lean on the low end and you might want to richen it ...so that means turning the low end needle clockwise to richen on that engine....you might also have to open the regulator screw too if richening the low end needle doesn't work
