 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 05-11-2005 | 08:05 AM
  #2151
Default RE: U-Can-Do 3d 46?
Any body else fly in the rain to clean off the grass clippings?
Old 05-11-2005 | 10:19 AM
  #2152
My Feedback: (17)
Yeah, I do that to. If it rains hard enough it will even clean the slim off your airplane. I use a garbage sack to keep dry and have the radio inside with me to protect it. The only real problem is it's hard to see out with a garbage bag over your head.
Barry
Old 05-11-2005 | 10:31 AM
  #2153
rclement's Avatar
ORIGINAL: Barry Cazier
Barry
That't why you should use the clear garbage bags......[8D]
What's really cool is to put your plane in a white garbage and fly it around. It tends to look like a ghost....... Great for halloween.
Old 05-11-2005 | 02:00 PM
  #2154
raideron's Avatar
Man..... I'm learning so much Great tips here guy's... I have to thank ya'll
CeeGee your one up on Barry on that clear bag.... And I really like the
UCD boo hoo idea... Come to think of it, It can be used on a halloween..
say fun fly and the bag could be also filled with candy for a candy drop..
Barry, I thought I had a great idea on eliminating the fuel slime off of the
plane... I just did not fuel her up... But a problem came up on my engine
as it did not start??????????????
Old 05-11-2005 | 03:12 PM
  #2155
SPUD37's Avatar
Hey guys SPUD here, Flite 3,4,&5-just keep learning new things with this bird. Two great landings, a 10 sec. hover today. On flite 5 I was trying to get the coupling worked out, got little inverted tangle with the air kind of thing going on, then the ground was getting a little close, snapped the stick around hard when I heard a pop. Chopped pwr to idle nose dwn was 10' up flaired and I was down. On inspection found I had stripped a ail. servo. The emergency landing tore some of my wingtip covering easy repair..........Oh well have to try again another day.
Hey guys with the FUTABA 9C what % did you end up with on your ail & ele to get rid of your coupling?
I tried some turtle wax spray carnuba on the plane- cranked it up, spayed it on like CeeGee said, & woah not only the plane but also the truck mywifes car & all over the garage..........good stuff.
Old 05-11-2005 | 03:42 PM
  #2156
My Feedback: (17)
Spud, What servo did you strip? Probably because you were maxed out on your throws. You should always leave a tiny bit left for safety sakes.
The UCD does some of the best knife edge couplings you can imagine. Why would you want to change it? But if you must, I use about 5% up elevator and 5% left aileron. This is a good starting point. I can't get it completely out. And many times I just fly it and use my skills to adjust. Normally about the time the plane is so far away I can't see it is when I gather it back in and get control of it.
I'll have to try the wax job. Sounds like a time saver. This is such a great thread. So many tips.
Oh, I was flying during my lunch hour today. My rudder came off. It was kind of an annoyance. Oh well, I'll pull out some glue tonight and make it better. But tommorrow I'll fly something else till my knees quit shaking.
Barry
Old 05-11-2005 | 03:44 PM
  #2157
My Feedback: (17)
Hey Spud. I just noticed, if you put the letter c between the last two letters of your name, the last 3 letters would spell UCD. Coencidence? I think not.
Barry
Old 05-11-2005 | 04:28 PM
  #2158
SPUD37's Avatar
Hey Barry, I'm using S3004's. I have the travel set at 120%. I just want to reduce the roll and pitch coupling to a point where I can manage it. Thanks for the %'s I'll try them the next time I'm out.
Shawn
Old 05-11-2005 | 06:39 PM
  #2159
My Feedback: (17)
Spud, In my opionon the 3004 is not enough servo for the UCD. The manual recommends a minimum of 50oz torque. This servo doesn't do it at 4.8v and 6v it barely does. It's also a nylon gear servo. That is probably why you had an incident with the aileron servo. I actually blew two out before I upgraded. You can probably do it for a while but sooner or later I think you'll want to upgrade your servos or repair your plane. I use the HiTech servos, they aren't too expensive and the ones I use have metal gears. That solved the servo problems but not the crashing problems I seem to have. Although I must admit, I'm doing better this year. I've only flat spin landed one plane and I'm at about 60 flights.
Barry
Old 05-11-2005 | 09:12 PM
  #2160
gjeffers's Avatar
boy, you guys sure are and interesting and fun bunch, trash bags,stripped servos,well i finally had a great day, not with the ucd but i got to go flying, and had the sticks for about a half hour[X(]. will fly the ucd tomorrow
ID:	270193   Click image for larger version
  #2161
SPUD37's Avatar
Thanks Barry, Yeah that was my thinking when it happened. Its going to have to wait tho 'cause Iblew the bank for now. Just have to tone down the maneuvers for a while till I can get some more OT or win the lotto.
Thanks, Shawn
Old 05-11-2005 | 10:37 PM
  #2162
My Feedback: (17)
gjeffers, Are you a full scale pilot? Cool pictures looking right down the runway. What's the story?
Barry
Old 05-11-2005 | 10:54 PM
  #2163
gjeffers's Avatar
Barry
well i was a pilot today, my friends wife has a cessna and ive been wanting to go up and it worked out today and we flew out of Bishop ca and flew around for an hour and a half around the lakes by Mammoth ski resorts and she let me have the sticks 3 or 4 times and i really was having a ball.that her old man in the pic, im not that old
Old 05-11-2005 | 11:26 PM
  #2164
rclement's Avatar
Gjeffers, you must have had a blast flying..... [X(][X(][8D] That is super cool.......... I didn't even see any trash bags over the plane............
Old 05-12-2005 | 01:48 AM
  #2165
raideron's Avatar
That's cool Gary...Bet you had fun!!..... Man I think I seen that plane
on the News.... Did you happen to fly to Washington???
Old 05-12-2005 | 10:36 AM
  #2166
rclement's Avatar
Well, I think I might get to fly the UCD tonight, weather permitting...... I've been so busy buying and selling a home that I haven't been able to get away. If I don't get some flying in soon I'll be in a trash bag for sure.......[&o]
Old 05-12-2005 | 03:47 PM
  #2167
gjeffers's Avatar
no Ron, i wasnt over DC, because if it would have been me they would have shot my butt down and you could have really used one of those trashbags,haw haw!!![X(]
and it was a blast CeeGee, first time in a small plane and it was the best, you get the real feel for flying, it has a trimwheel in the clckpit and you just roll it to trim for different speeds so you dont have to work so hard on the sticks(once you get up you can pretty much use it to keep altitude and relax), i got to do some s turns and alt gains and drops by myself and learned alot. im a junkie now and might have to hang around airports selling trashbags!!!!!!
going to fly the ucd now, good weather!!
and ill send you some good weather to Ron, here it comes
those wierd looking black lines are the prop (wierd stuff)[sm=confused.gif]
ID:	270504   Click image for larger version
ID:	270505   Click image for larger version
ID:	270506   Click image for larger version
Old 05-12-2005 | 03:59 PM
  #2168
My Feedback: (17)
gjeffers, Cool. Will that Cessna do a rising flat spin?
Barry
Old 05-12-2005 | 04:00 PM
  #2169
My Feedback: (17)
gjeffers, As I look closer I see a counterbalanced elevator, APC propeller and TrueTurn spinner. Nice equipment, you know, for a Cessna.
Barry
Old 05-12-2005 | 04:10 PM
  #2170
rclement's Avatar
Yea, That is a nice TruTurn.. Musta have cost bazillions of dollars for that one. I wonder if Tower would ship that for $7.99 ?? [X(][X(]
Old 05-12-2005 | 04:58 PM
  #2171
raideron's Avatar
Hey Gary... Thanks, I used up the good weather this AM.... Great Day!!
My mind timer is still playing tricks on me..... 4 out of fuel dead sticks:-(
All made it back to the field and greased the landings... This plane floats
so good..... Held a half a foot hover for a bit... Started to go for it and
touch the tail but the YS started loading up, So up up and away she went
at the top went into a F.S., about a quarter way down I tried to climb back
up, It did not climb up but made the tightest flat spin and it seemed to just
hang in the same spot forever:-)......
Old 05-12-2005 | 08:24 PM
  #2172
My Feedback: (17)
Don't really know which forum to post this in, but I feel at home here, so here goes. Stupid, STUPID!!!!! How do you spell STUPID? Went flying today, raining like crazy, took my Mayhem because the rudder fell off the UCD last night. I'm flying, got the plastic garbage bag over my head, it's hard to see, the 110 sounds a little funny so I think I better bring it in and check it out. After I land I stand stradle my airplane with the elevators against my calves and I'm revving it up to make engine adjustments. Well I hear this stupid beeping. It's my timer. Now you must realize this time cost me my 3rd UCD 40 because I was trying shut it off in a flat spin. Well, this time I'm in the pits, right. Well I shut the throttle off and step off the plane and reach over my radio to shut off the timer. Well, the bag over my head is distorting my vision and I reach a couple of times but can't find the timer. My baggey coat I wearing (cold) snags the throttle. The plane goes ripping accross the pits and slams into a railroad tie on the border. The plane stops but the engine doesn't. The firewall, wheels, tailwheel and I don't even yet know what else just keeps on going. Stupid. Do YOU know how to spell STUPID.
I'll think I'm gonna quit this hobby.
Barry
Old 05-12-2005 | 08:35 PM
  #2173
kokamo's Avatar
Barry, Barry, Barry.........I have no other comment than that just plain sux! I feel when you mix wet weather and rc flying it gets complicated. I'm soooooo sorry to hear that. I'm just glad that wasent the UCD. Total loss on the plane hu? What about the motor?
Joe
Old 05-12-2005 | 08:38 PM
  #2174
kokamo's Avatar
BTW...... my avitar is not smiling at you.....
PLEASE DON"T QUIT!!!!!!!
Joe
Old 05-12-2005 | 08:42 PM
  #2175
gjeffers's Avatar
nooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooo
