 Wagstaff Extra 300 >
Wagstaff Extra 300
Wagstaff Extra 300
Old 06-03-2003 | 06:40 PM
  #3626
Forgues Research's Avatar
My Feedback: (7)
Default Re: Re: Re: Beila Prop
Originally posted by 232Cap-Tain
Roger,
I've been in the garage all morning and guess what, the FEDEX guy was here and left me a little tag saying he tried to deliver a package ( I guess I didn't hear the doorbell). I was getting ready for those 1 1/4" red standoffs. Either I go to the Fedex place after 6:00 tonight or I have to wait at the door from noon- 3:00 tomorrow. What do you think? Wait, no, Wait, no, Wait, no. I'll let you know what they look like when I get them on.
Sorry to hear you missed the FedEx guy. I get that problem once in a while when my wife isn't in the house.
I put my intercom on lock to hear anything that goes on in the house and if the door bell rings, I can hear it in my shop though the intercom..worth to try...
Old 06-03-2003 | 07:03 PM
  #3627
SLINGSHOT-RCU's Avatar
Default moki 2.10 on patty
232CAP-TAIN, WHAT PROP DID YOU END UP WITH ON THE MOKI ?? IM WORKING ON MY PATTY NO.2 . I HAVE A MOKI 2.10 WITH A 20X10 PRO-ZINGER TO GO ON IT. HOW DOES THE MOKI PULL YOUR PATTY? THANKS....
Old 06-03-2003 | 07:09 PM
  #3628
DENNIS C's Avatar
My Feedback: (99)
Default Re: moki 2.10 on patty
i believe you are suppose to use a 20-8 for break in
you do not want to put a load on the motor.
Old 06-03-2003 | 07:15 PM
  #3629
Default Wagstaff Extra 300
THANKS BODYMANN ,.. ILL GET A 20X8 NEXT TIME I GO TO L,O,S . SHOULD I RUN THE 20X8 ON THE PLANE THE FIRST FEW FLIGHTS???
Old 06-03-2003 | 07:40 PM
  #3630
DENNIS C's Avatar
My Feedback: (99)
YEP!!!! run it untill you feel the motor to loosen up some then go to a bigger prop. it might take a while for the moki to loosen up. but you will be pleased with the result's.
dennis
what fuel are you going to use.
Old 06-03-2003 | 07:45 PM
  #3631
IM GOING TO USE WILDCAT 5% NITRO 16% OIL, I ADDED 5 OZS OF CASTROL TO IT SHOULD PUT IT AROUND 20% OIL.
Old 06-03-2003 | 07:48 PM
  #3632
John Murdoch's Avatar
Old 06-03-2003 | 07:55 PM
  #3633
Old 06-03-2003 | 07:56 PM
  #3634
WHERE CAN I FIND A NX PROP, ?,,, HOW MUCH VERTICAL DO YOU HAVE WITH MOKI?????
Old 06-03-2003 | 07:59 PM
  #3635
The only place I know where to get them is from wildpilotshop.com. They distribute the NX. Hope my explaination of vertial helps with your prop questions.
Old 06-03-2003 | 08:00 PM
  #3636
Let's try this again. Airwildpilotshop.com
Old 06-03-2003 | 08:08 PM
  #3637
My Feedback: (7)
Would anyone know the lenth of the standoffs for the Patty and ZDZ 50.
Thanks.
Old 06-03-2003 | 08:16 PM
  #3638
Roger,
The RCShowcase specs show that it's 5.3 inches. Here's the spec address. http://rcshowcase.com/html/engines/zdz50.html
John
Old 06-03-2003 | 08:27 PM
  #3639
My Feedback: (7)
Roger,
John
Yes, but I need to know what the distance from the firewall to prop is for the ZDZ. I must have done more then a dozen of them but I don't keep tab. Its for someone in Spain...
Old 06-03-2003 | 08:49 PM
  #3640
Default Standoffs
Roger,
The book calls for 7" (or 178 mm) 0from prop washer to firewall. So I guess that would be 1.7" standoffs if the motor is 5.3 from prop washer to the back side of the mounting tabs, right? Hope this help you.
Old 06-03-2003 | 09:10 PM
  #3641
My Feedback: (7)
Default Re: Standoffs
Roger,
Thanks I think your right.
I'll pass it on to him.
Old 06-03-2003 | 11:20 PM
  #3642
Default Biela Props
X300Pilot,
Yes, I did get a chance to put in one flight with Biela 22x10. It is a beautiful prop, made in Poland and factory balanced to perfection. I got many complements for that prop at the field. Granted my BME 50 has only had three tanks of gas through it, it seemed to work harder with the Biela prop. It turned 6,000 with the Biela and 6,850 with 22x8 Pro Zinger. It takes a little longer for the engine to spool out with Biela, but pulls very strongly. The prop weights 145 grams vs. Pro Zinger only 90 grams. The plane definitely flew faster with the Biela and breaking was very efficient when the throttle was cut with the characteristic 'woosh' sound of the fast air hitting the slowed-down prop. Landing was a little hot, but that would be true for any 10 pitch prop. Idle was lower and more stable on the Biela vs. Pro Zinger. Well, decide for yourselves.
If anybody wants it, I would be willing to part with my Biela (drilled to 7/16") as I am going to stay in the 8 pitch props for my plane/engine combo.
Old 06-04-2003 | 12:05 AM
  #3643
DENNIS C's Avatar
My Feedback: (99)
Default Re: Biela Props
Originally posted by Gregolot
X300Pilot,
how much$
Old 06-04-2003 | 05:17 AM
  #3644
Default Re: A new pattie is arriving soon
[QUOTE]Originally posted by rickgell
[B]Hey guys how about a Pattie with 80" wings and weighing in at around 14lb (6.25kg).
Check this link http://www.theworldmodels.com/extra300/extra300s.htm
Think about it. Why is there a 3000+ posts thread about the GP Patty? Because the only bad thing about it is there will probably be several at the airfield. The consensus is it flys great is well built and a great value.
World Models makes great ARF's but for 1/4 scale Extra's at $400 GP has a good thing going.
Old 06-04-2003 | 12:46 PM
  #3645
SAL98's Avatar
Did anyone post any videos of there patty in flight. Ive been checking this forum but thats a lot of threads to check.
Old 06-04-2003 | 01:13 PM
  #3646
Default Bodymann
I sent you email regarding Biela prop.
Old 06-04-2003 | 01:45 PM
  #3647
Sal98: here ya go
http://www.rcuniverse.com/showthread...92#post1015325]
Old 06-04-2003 | 01:57 PM
  #3648
DENNIS C's Avatar
My Feedback: (99)
Default Re: Bodymann
greg ....got the mail sent a reply
dennis
Old 06-04-2003 | 04:57 PM
  #3649
Default Re: Newest Video
Originally posted by aerobob
rcguy, I'm jealous...Patty emailing you....sheeeeesssshhh.
Ah, well....here's the second installment, called "DeadstickPatty!"
(we hope the REAL one never does this!)
http://www.rcaerobats.net/downloads/...ffDownload.htm
Then click on "Deadstick Patty!"
Enjoy, folks!
And thanks again, rcguy.
BTW - We all *DO* hate and despise you for flying and being so BOLD to video it and send it to us to grieve over....shame!!!!!
For the new guys. Hope you enjoy.
Old 06-04-2003 | 05:28 PM
  #3650
Default Re: Prop Usage
Well, I've used the 20X10 from new. Broke in with the 20X10 and still using the 20X10. The good news is the Pro Zinger was the worst performer of them all so you're now powering up as much as with, let's say a Menz S or an NX. So far, as of yesterday, 202 flights with my Moki... The NX, for the money is the best performing prop. How I measure performance is come across horizontally and pull to vertical. Once vertical, roll as many times as I can before it falls off. The NX takes my Patty 4 1/2 rolls, just about where you can't see it before it drops off. The Zinger would only do 1 1/2 rolls before it dropped off. So much for the Moki though, putting in a BME today and I'm putting my Moki in the box for another plane some day.
I tried this vertical test with BME 50 and I lost count of the number of rolls. I stopped rolling upon cutting the throttle when I could barely hear the motor and got scared that the air traffic controllers would pick me up on their radar ( ).
