 Wagstaff Extra 300 >
Wagstaff Extra 300
Wagstaff Extra 300
Old 01-07-2003 | 02:35 AM
  #1126
Default Wagstaff Extra 300
Wow... Last time i checked this thread it was running on 24 pages...
I was gonna buy this plane, but it has been sold out for so long and new delivery wasn't expected to reach Norway until late January, so i went and got my self a Aviation Design F-117 Nighthawk instead....
I hate waiting...
Old 01-07-2003 | 02:55 AM
  #1127
Default patty landing gear
Hey patty owners, This thread has been nothing but help for me from the time I thought about buying one till no! tHANKS TO ALL! I have a question? Is any one beefing up the landing gear in anyway. I thought of drilling 2 extra hole for strenght. I already added epoxy on the inside and I corrected 2 mis-aligned holes. what do you all think! Heres a photo of her with hinges and servos. waiting on the da50, rockcity hardware, and duralites.
Old 01-07-2003 | 03:28 AM
  #1128
AndyF's Avatar
Default Re: patty landing gear
I used some 3/4" tri stock on the inside against the formers fore and aft. I trimmed it to fit and epoxied it in. But from all accounts it is pretty strong to begin with.
I also added smaller tri stock to the front of the firewall on the left and right sides to help provide extra strength.
Andy
Old 01-07-2003 | 03:49 AM
  #1129
LUNATIC's Avatar
Thanks rcguy1 and aerobob for the heads up! Good thing I didn't fly her yet, I somehow overlooked page 34(3d). I think for now I will move the ball link up until I get the proper control horns.
Can anyone recommend a good 3d control horn for this plane?
If so,what brand and size?
Old 01-07-2003 | 04:14 AM
  #1130
Lunatic,
Are you sure you are ready for 3D? The pics seem to tell you may be in over your head. There must be a hundred references about control horns in the last 5 or six pages. The stock ones work fine. But that would be to easy. Good luck. (:
Old 01-07-2003 | 05:14 AM
  #1131
LUNATIC's Avatar
Originally posted by T. Gardner
Lunatic,
Using Rocket City ball links and standard GP control horn with the push rod in the upper position I get less-than max deflection even with long dubro arms, therefore, I would probably need a different horn. First thing I need too do is fly her than worry about 3d later. Would like too have the max throws installed now on a 2 position switch then deal with all the changes later.
Would that be to easy?
Old 01-07-2003 | 01:08 PM
  #1132
SMALLFLY-'s Avatar
My Feedback: (19)
I have slammed my extra down pretty hard twice on the gear with all stock setup and have no problems at all except a little bending back to do on the alum gear. I have found if you let it get too slow on landing with a cross wind it likes to stall to one side, kind of like a tip stall but less violent
  #1133
Lunatic, don't worry about 3D now. Set the plane up as per instruction manual on page 28. Fly the Patty on low rates and after you are familar with the plane try flying on hight rates . Only after you are completely familar with the plane, go out and purchase longer control arms for your brand of servo (not control horns) and set up 3D throws as per instruction manual (page 34). Creek Hobbies (www.creekhobbies.com) has some nice servo control arms. Good luck!!!
Old 01-07-2003 | 04:31 PM
  #1134
Bob Pastorello's Avatar
My Feedback: (198)
Default 2 3D or Not 2 3D
Call me "chicken"....but...having been down that road of an overly-sensitive setup (a H9 Cap), I have *FINALLY* learned what works for me. And did this on the GP PW Extra
Two sets of servo arms for the elevator servos. The currently installed set allows me to set maximum ATV on the Tx (good thing for resolution and linearity of response) and have a VERY agile precision setup, capable of EVERYTHING *but* "3D".
Then the "other arms" which have the ball part of the ball links, and they are LONG arms, and THEY get crazy 3 D rates. Since I use DuBro High Strength arms, both lengths were in the same package.
Many would say this is a waste, but it allows me two separate setups, and I have two airplanes in memory on the JR 10X. One is the "mild mannered", the other is the crazy deal, and I cannot accidentally flip a switch and end up with disaster. BTDT, and it was VERY ugly.
Just some more ideas and ways to skin the cat from somebody who is REAL conservative/careful/chicken. (and old)
Old 01-07-2003 | 06:39 PM
  #1135
DeadSticker's Avatar
My Feedback: (18)
Looks like we are running the EXACT SAME settup!! Maybe after we get the DA we can compare numbers/flight performance because I am only at about 200' ASL.........
Old 01-07-2003 | 07:35 PM
  #1136
Default patty linkage
Wanting everyones opinion on this setup. First time Ive used this linkage system. Not permanetaly installed so i can use the stock. like it was said before just trying something different. I havent measured throw yet, but it seems solid.
Old 01-07-2003 | 07:37 PM
  #1137
Default another Pic!
another Pic!
Old 01-07-2003 | 08:39 PM
  #1138
SMALLFLY-'s Avatar
My Feedback: (19)
looks good, but you are going to need longer servo arms if you want to do some of the 3d stuff
Old 01-08-2003 | 12:40 AM
  #1139
Default patty and da50
Just talked to DA and still another possibly 2-3 weeks for the delivery. zdz50 looking better, but we will see.
Old 01-08-2003 | 12:50 AM
  #1140
PlaneKrazee's Avatar
My Feedback: (14)
My ZDZ 50 shipped today!
It's been a long wait and it will be worth it.
Brian
Old 01-08-2003 | 01:32 AM
  #1141
Interesting. I was told that my ZDZ50 shipped yesterday.
Old 01-08-2003 | 03:11 AM
  #1142
My Feedback: (18)
Default Re: patty and da50
The ZDZ50 would be sweet, but I think the all anticipated wait for the DA50 will be worth it......I am going to stick it out. I have a couple other planes I need to fly before I get hooked on the patty!!
Old 01-08-2003 | 03:57 PM
  #1143
Here's an inexpensive, light weight pushrod for the elevators on Patty. It is an aluminum "stand off" that is tapped for 4-40 threads, you can use 1" studs on each with a jamb nut, then ball links.
I used the 2-1/2" length of all-thread, that I already had cut to size, to set up the elevators, then screwed the "stand off" over it with a jamb nut on each end.
I purchased them from www.mcmaster.com. they come in sizes from 3/4" through 2" with 4-40 threads. The 1-1/4" sizes cost $1.12 each, and are just the right size.
Someone here on RCUniverse recommended them to me for finding the bolts I needed to mount my engine. They seem to have just about every fastener and size I could ever want.
This thread has been an enormous help, and a large pool of information for me and this plane. Thanks everyone!!!
Old 01-08-2003 | 04:11 PM
  #1144
John Murdoch's Avatar
Biran, James,
Where did you guys order your ZDZ's from?
Old 01-08-2003 | 05:57 PM
  #1145
Deleted
Old 01-08-2003 | 07:08 PM
  #1146
DMUCOP's Avatar
whats the thoughts of the hitec HS-5645 @ $52.00 and chief aircraft gives a four or more discount...
Old 01-08-2003 | 08:47 PM
  #1147
Jemo's Avatar
Good servos. You can also try http://www.donalds-hobby.com
I have gotten servos from both.
Old 01-08-2003 | 09:52 PM
  #1148
232 Cap -Tain, http://www.rcshowcase.com/, will sell you all the ZDZ Engines you want.
Old 01-08-2003 | 09:59 PM
  #1149
My Feedback: (18)
WOOOOHOOOO........called Dave at DA and they are going to start shipping this Friday/Monday!! He also said that he has around 400 of them so eveyone htat has ordered one should be getting it within the next week or 2......:thumbup:
Old 01-08-2003 | 10:48 PM
  #1150
DENNIS C's Avatar
My Feedback: (99)
what about hitec 475's new servo that should be plenty
