CEN Racing This forum is to discuss all CEN Racing products.
GST 7.7 problem...
Old 03-01-2008 | 07:12 PM
Default GST 7.7 problem...
The one way bearing that the pullstart uses to catch the shaft so you can start the engine isnt catching the shaft anymore? Im pretty pissed off cause I havent even got one tank of fuel run through this and now I cant even start it due to that bearing. Any suggestions?
Old 03-01-2008 | 11:45 PM
The Real Dogman's Avatar
Default RE: GST 7.7 problem...
Yep Follow these instructions on how to replace your bearing!!!
[link=http://www.cenracing.com/downloads/TRonewaywriteup.doc]My official One Way bearing replacement instructions![/link]
Old 03-02-2008 | 01:41 AM
G'day Bearster. Just wondering if when you use the pull start if it fells like it's trying to turn the engine over, but slipping, or does it feel like there is no resistance to the pull starter (other than the recoil spring). If you have the latter problem it might be the pin in the back of the crankshaft in the engine (I had this problem a while ago with a fairly new GST 7.7)
Check out this link [link=http://www.rcuniverse.com/forum/m_6962143/tm.htm]Pull Start Dramas[/link]
Hope it helps.
Cheers.
Old 03-02-2008 | 10:25 AM
I can just sit there all day and try to start it but it just wont catch the crankshaft. It will every once in awhile tho so that has me to believe that the bearing is ALREADY gone. Im pretty pissed about this too but I guess that happens.
Old 03-02-2008 | 10:36 AM
anyone know the part numbers that I would need?
Old 03-02-2008 | 07:24 PM
nomobux's Avatar
ORIGINAL: bearster18
Manual has the # ... ebay will have them ... search Cen or Genesis or Nemesis ..... all the same
Old 03-02-2008 | 10:49 PM
Ok found the parts I need now. Turned out to be the one way bearing after all. Now I am trying to install the center lock and the screws are in there so tight that now I have stripped out the screws YAY! This truck has already been a pain in the ass haha. Now I have to drill out the old screws and get news with the diff case.
Old 03-03-2008 | 06:59 PM
CEN Racing's Avatar
In order to remove the screw from the diff they need to be heated with a heat gun or torch- in order to de-bond the red thread lock that is used at the factory...
You may still be able to get them loose if you use a dremel cutting wheel and slot the screw head so you can use a bladed screw driver
Old 03-03-2008 | 07:12 PM
Thank you, What color loctite do I need to put back on them when reinstalling?
Old 03-03-2008 | 07:13 PM
CEN Racing's Avatar
No problem... blue (medium)
Old 03-10-2008 | 02:02 AM
Mr Terminator's Avatar
There is no way that should happen,the OWB I mean if you have'nt even put 1 tank of fuel though it.I know rotostarts are OWB killers but pullstarts snap before the OWB gets knackered,sounds like a manufacturing fault and should be replaced free of charge if CENs customer relations are as legendry as people make out.How about offering a free replacement then CEN,lets see if you can back up the claims of a great customer service.
Old 03-10-2008 | 06:23 AM
Yeah the OWB thing really has me upset with the truck thats for sure. I was going to contact CEN racing but I really didnt feel like messing around with that BUT if they read this and they'll warranty the OWB then I am game! So CEN how about it?
Old 03-10-2008 | 07:40 AM
LOL if CEN wont warranty that $6-$15 part, I will!! some people get so upset about very inexpensive things. All rc parts are subject to premature failure, no matter what brand!! You wil spend 4-10 times as much in time and shipping that engine back to and forth to CEN to get a commonly worn part that my or may not still be under warranty. I mean, Geeze if you dont like tearing your rig apart to repair it then you should have not got yourself a nitro vehicle.
No need to get upset about a OWB going bad on a Hobby Grade Nitro Monster Truck!! You WILLbe replacing many more during the life of your rig. Besides CEN did ot manufacture the Drawn Cup Roller Clutch(OWB), another manufacturer did, and there is now way for CEN to know which OWB out of thousands will fail!So Call it luck of the draw that you got a faulty unit.
The point here is, it will cost you and CEN less in time and money, to just order the OWB and replace it yourself. And consider the OWB a consumable item on any nitro rig, let alone one that has so much compression!!
Fix it and then enjoy it again!!
Hope this helps.
Old 03-10-2008 | 07:58 AM
Thats what I did lol...I have a OWB on the way actually so that way I can start playing again HAHA
Old 03-10-2008 | 08:03 AM
Good Call Bear!!! Sometimes it just not worth the headache to make such a stink over cheap parts!! Too many are way too willing to get excited over "What Should Be" and not focusing on "What Is"
Much respect Bear!!
Old 03-10-2008 | 12:55 PM
fastxr's Avatar
Well said Dogman!!! Too bad people dont carry that same thought on to full size vehicles. [&o]
Old 03-10-2008 | 05:11 PM
Installed new OWB and still I have the same problem. Im really starting to get frustrated now. At this rate I'll never even play with it. I guess I need to call CEN and get this taken care of now.
Old 03-10-2008 | 05:28 PM
I take its NOT the OWB after all. Then I would open the back of the engine and see if the small pin that is in the end of the crank has sheared off or the spring collapsed.
Could Be Both!! Also you might want to check to see if the OWB is in backwards(a very easy mistake!!)
Old 03-10-2008 | 05:49 PM
Checked the OWB in both directions and still the same thing. I also just pulled the back plate off the motor and found that the little pin doesnt stick out much further than the crankshaft end. So what parts am I gonna have to get now? I really dont want to have to pull my brand new motor completely apart.
Old 03-10-2008 | 05:55 PM
I have the part #'s At home. If you can wait I will post them when I get home this evening!! Now what do you mean when you say "Checked the OWB in both directions and still the same thing" Does that mean you tried to spin the OWB both directions and it spins in both directions or does that mean no change? if it spins in both directions then the new OWB is bad, which I would find hard to believe, but anything is possible. There is a slim chance you got 2 bad OWB's in a row, very slim!!
Old 03-10-2008 | 06:05 PM
No I just checked the OWB to make sure I had it the right way is all.
Old 03-10-2008 | 06:23 PM
nomobux's Avatar
Hmm ... Don't sound right. Anyway , to get the spring out of the crank, a small dab of grease on a toothpick works to grab it. Be carefull to get both parts of the spring, if in fact it's broken.
Old 03-10-2008 | 06:45 PM
I mean the OWB is good both of them LOL It never was the OWB at all. I took out that pin and spring and it looks like the spring is collapsed cause its about as long as the little pin is. The spring doesnt appear to be broke at all cause I tried my hardest to make sure that I got it out of the crank and that one piece of spring is all that came out. So I guess I gotta order some more parts huh?
Old 03-10-2008 | 06:56 PM
fastxr's Avatar
Yah sounds like your spring has collapsed it should be quite a bit longer than the pin itself in a free state. Just be sure there isnt another part of the spring still sitting in the end of the crank as nomobux advised. I'll save Dogman some trouble the p/n for the spring and pin is G70357-35, take a look at the picture on the cen direct page (www.cenracingdirect.com) and you will see what the pin and spring should look like. Also note the description is wrong it should be starter shaft spring, starter shaft pin. If this is the problem that means your original OWB is probably OK make sure you hang on to it as some point you will need it. Good Luck
Old 03-10-2008 | 07:23 PM
Ok I just ordered that part too. Now the waiting begins again! I cant wait to just get the thing broke IN LOL Thanks for all the help guys! I'll be back when this doesnt work hahaha j/k
