Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 another darn ryobi post  (ryobi performance modification, analysis and comparison) >
Old 03-13-2009 | 04:55 PM
  #201
diceco's Avatar
Default RE: another darn ryobi post (ryobi performance modification, analysis and comparison)
Wow... Cool!
I assume you've got a two ring piston, yes?
I've had trouble getting a steady reading on my tach. It normally jumps around plus or minus 40 rpm. I'm not sure how much of this is instability of the motor itself or whether the tach is not getting every pulse of the prop blade. When I test it on a 60 cycle electric light bulb it's dead on. The APC prop is gray, a pretty neutral color, so maybe the sensor has a hard time picking it up against the background. Maybe if I took a black marker and colored it up it would help. I'll have to try that! The tach I've got is a "GloBee" from Tower Hobbies but I'd bet all the R/C marketed tachs are basically the same.
diceco
Old 03-13-2009 | 06:22 PM
  #202
av8tor1977's Avatar
I appreciate all the hard work everyone is doing here to come up with the best combo and/or ideas for the Ryobi. But I want to make something that is very important clear. The very first thing one should do before modifying an engine is to make sure it is in perfect shape to begin with, especially as regards to the ring seal. I have personally seen engines gain over 600 rpms with just a ring change, and even more so with the Ryobi in the case of those that do not have rings that overlap the retaining pin. Once again, the recommended ring gap in other, similar engines is .003" which is about the width of a piece of paper! It is just basic good practice when modifying engines of any type to get a good seal on all important parts before starting with modifications. Then you can get a good, honest baseline to work with, and go from there. Without a "given" of a good ring seal, all the results and comparisons you all are getting will be "all over the board" and not realistic/significant.
Just my input here....
AV8TOR
Old 03-13-2009 | 08:10 PM
  #203
combatpilot's Avatar
This is so true. Also the ring is only as good as the bore it is bieng asked to run in. In Absolute perfect conditions we shoud even have a brand spanking new cylinder. This is impractical for most of us though. I know the testing isnt perfect and we arent all gona end up with the exact same numbers. i think in this format of testing the ting to look at is the difference in the rpm of the run before the mod and the rpm after the mod. What we are really trying to find is did it increase power and how much. And yes it is gona bee all over the board.
I also have a glowbee and have the same trouble. If i put my finger over the sensor it reads zero. if i put my finger over the sensor and hold it near the ignition it jumps all over the place. I am thinking of going to a hall effect sensor type tach tor testing purposes. Also im not doing and more testing to I get my static thrust unit built as i think this is gona be far more reliable info.
I think it's more likely an inertia problem. The reed has got to change direction 7000 times a minute. That's over a hundred times a second! I bet with so little spring force on the reed it's lagging behind in getting back down to the seat as the crankcase pressure builds up on the piston's down stroke. In fact it may be still on the way up as the crankcase pressure turns around from negative to positive!
I though of this to but the rubber reed valve you could open by merely blowing on it. it had no spring action whatsoever. I will try to get some measurements as now i know how you did it. i think my scale goes to a tenth of an ounce. but im not sure.
As for the newer style cylinder with four transfer runners, I believe there are huge gains to be made by smoothing out the entrance to the transfer ports. The flow coefficient, and thus the effective flow area, of those ports just has to be abysmal with those blunt facing surfaces facing the flow. I not only bullet-nosed the web separating the two runners but also matched the outer edges of the ports to the crankcase so nowhere are there forward facing steps in the flow path. I bet you are right about the difference in cylinder volume (compared to the older cylinder, ie compression) but I'm not sure how to improve that situation with my setup. The only other cylinder I've got is the one with decompression slots.
I really dont understand why they went to the two runner set up. There is an absolute visisble difference in the combustion chamber and compression volume. If i come across a cylinder like i have got i will send it to you so you can do some comparison on it. All the port designs so far have been just like you say abysmal.
I got the parts from ajonr today. I got one of the engines with the small crank case and shrouded reed valve. I am so excited about this engine as i think its got lots of potential. Thanks anjor i cant wait to play with all this.
I think after i am done with this engine in the test peramiters i have laid out i think im gona do it again with a whole new set up and see if the results are simmilar or repeatable. I am about to get into some areas with engine that i have never seen done on the net before. not saying its never been done just saying i havent seen it so it should be interesting.
Old 03-13-2009 | 08:53 PM
  #204
diceco's Avatar
I wonder if an automotive inductive style tach would work better. You know, the kind with a pickup that clamps on to the ignition wire.
diceco
Old 03-13-2009 | 09:03 PM
  #205
Thats not a bad idea. I havent seen one of those units in a while but i bet i could find one at a auction. Im just not sure it would work with a single cylinder.
Old 03-13-2009 | 09:04 PM
  #206
diceco's Avatar
combatpilot said: I though of this to but the rubber reed valve you could open by merely blowing on it. it had no spring action whatsoever.
Yeah but it's got mass. I think there is a point where there is not enough closing force on the reed to overcome the reed inertia. The reed needs to reverse directions and get back down and close off the intake port so the transfer phase of the cycle can start. If it lags a bit there won't be as long a duration of transfer and performance will suffer.
diceco
edit: OH, SORRY. I MISSED YOUR POINT! You saw no change from stock to modified clamp plate to waist cut reed, right? Gee I don't know what's going on then. Maybe there is some distortion of the reed or a sideways twist or something on the reed with a bean hole in it.
Old 03-13-2009 | 09:33 PM
  #207
I think your overlooking the pressure differential created by the pistion travel. I think this force is far greater than any exerted on the reed valve. The fact that the rubber valve has no spring action proves this. granted it will have more mass therfore there will be more inertia energy to overcome to get it to stop change direction and go back to the seat. so what is this force if its not spring action in the reed itself. it has to be pressure differential.
The reeed valve has no effect on the transfer phase of the the cycle. this cycle starts as soon as the piston opens the transfer port and ends when the tranfer ports are closed by the piston. the only way to change the timming of this cycle is to change the intake port timming. I think what you are talking about is the lower end compresion cycle. true if there is a lag it in effect lowers the duration of the lower end compression cycle. this in turn creats a lower pressure differential and there will be less pressure energy to force or transfer the air and gas mix through the ports and into the cylinder during the transfer cycle when the transfer ports are open.
Old 03-13-2009 | 09:44 PM
  #208
Yea i dont know whats going on here either. tell ya what i will mail you a waist cut reed and you mail me the bean cut reed and we can each try these and see if we get the same reults again. I am wondering if it would be worthwhile for you to do your test again. I had done my reed valve twice and got two different results to.
Again in my first testing of test #7 reed valves
stock valve RPM 7050
modified reed valve 7410
rubber reed valve 7410
Second testing of test #7 reed valves
stock valve RPM 7410
I have my suspicions as to why there is no change in performance.
At this rate i just cant see what a y manifold with a two reed set up would do.
Old 03-13-2009 | 10:42 PM
  #209
Read some of this site on the reeds.They are useing differant designs.
http://rcshowcase.com/html/faq.html
Look at the rotary reed valve
Old 03-14-2009 | 02:43 PM
  #210
andrew66's Avatar
i just bought a tach from princess auto today. they had one on sale for $20, so i couldnt pass it up. i think that this type will be more accurate, cause i need to attach reflective tape to the prop. It says that the readings are +- 1 rpm and the max range is 8 meters. I wont have time to run the engine again til tomorrow, or monday. I will have a helper with me, so i hope to get a good video for you guys. I contacted frank about a ring (single ring piston) so i will probably be getting it in the mail in a couple weeks or so.
Old 03-14-2009 | 03:07 PM
  #211
diceco's Avatar
combatpilot said: Yea i dont know whats going on here either. tell ya what i will mail you a waist cut reed and you mail me the bean cut reed and we can each try these and see if we get the same reults again. I am wondering if it would be worthwhile for you to do your test again. I had done my reed valve twice and got two different results to.
Well... I too thought it would be interesting to exchange reeds to test, but you know, It seems that we've both come to the same conclusion, that modifying the reed or reed clamp does little or nothing for the performance of the Ryobi. Although it might be of great academic interest, I'm of a mind to keep the focus on the original purpose of your post, and that is to determine, albeit by trial and error backed by "educated guesses", what tricks and mods can be done to make the Ryobi as good as possible. I admit to having too many projects in the works and I'd rather spend the time on forging ahead with some of those than chase a configuration that might make us smarter about the operation of reed valves but not contribute to the definition of the best setup for the Ryobi.
combatpilot said: The reeed valve has no effect on the transfer phase of the the cycle. this cycle starts as soon as the piston opens the transfer port and ends when the tranfer ports are closed by the piston. the only way to change the timming of this cycle is to change the intake port timming. I think what you are talking about is the lower end compresion cycle. true if there is a lag it in effect lowers the duration of the lower end compression cycle. this in turn creats a lower pressure differential and there will be less pressure energy to force or transfer the air and gas mix through the ports and into the cylinder during the transfer cycle when the transfer ports are open.
I agree with your analysis! I had not previously thought out that the piston is blocking the transfer ports until it is well on it's way down the bore and by that time the pressure in the crankcase has built up considerably, certainly enough the close the reed, one would think!
12.7 mm carb on the way. I'm already wondering if my exhaust system needs opening up. The 1/2'' EMT (electrical metal tubing) stinger has no more area than a 12.7mm venturi. You'd think the total exhaust exit area should be greater than the carb inlet area.
diceco
Old 03-14-2009 | 03:48 PM
  #212
diceco's Avatar
andrew66 said: i just bought a tach from princess auto today. they had one on sale for $20, so i couldnt pass it up. i think that this type will be more accurate, cause i need to attach reflective tape to the prop. It says that the readings are +- 1 rpm and the max range is 8 meters.
Wow.... +-1rpm! I never see a digit in the "ones" column on my tach. How is this tach different from the ones we buy from the hobby store that would make it more accurate?
diceco
Old 03-14-2009 | 03:49 PM
  #213
Twin Star's Avatar
I've heard that you don't want to turn a Ryobi much more than 7000 rpm static
I don't know how true this is but, I do know, my wife loves to run our Weed Eater ( w/Ryobi engine) with about 2"- 3" of line sticking out of the cutting head. That engine has to be turning around 10,000 RPM and let me tell you, she don't care that it has a throttle. She runs it like this until it runs out of gas. Believe it or not, our wackers will last for several years, I haven't had one throw a rod yet.
The issue with the reeds maybe as I read on another web site. The reed system becomes less efficient with the increase in RPM. This would be similar to "valve float" in a 4 cycle engine at a high RPM. So maybe a stiffer reed with stronger impulses to open and close it with increased RPM is the answer to more horse power. HP generally increases with RPM.
Old 03-14-2009 | 05:41 PM
  #214
Pic Pic I want pics lol
I think your really gona like what you get out of that new carb. I had great results with mine. I do think im gona modify my high speed needle valve so i can tune it without a screwdriver. it needs a small t handle like my g62 zenoah has.
That should be more than enough for the outlet of the muffler. mine has two half inch tubes and you can cover one up completly with no effect at all. Did you remove all the baffling inside also? In all reality 7200 rpm isnt that far off from what im getting with the same modifications. that bigger carb should put you up or above the 7400 range where im at.
From what i understand this type sends out its own light source much like the light signal in your tv remote. it is then reflected back off of the reflective tape and with this light source it is less likely to be affected by other light sources. The regulat hobby one uses ambient light and this is why it just wont work in a room that has floresent lights.
If this were the case it is my opinion that the valve would float at this rpm under any condition or any load. with or without a prop vavle float would be the limmiting factor. When i put a smaller prop on it it went right up to 8200 rpm so this tells me the reed will operate at this higher rpm. if valve float was the limmiter it would have stopped right at 7440 just like all my other tests.
The rotary valve is interesting but i just dont think it will work on the ryobi engines as there is no practical way to mount or drive it.
This is so funny. is your wife my wifes sister. My wife will go mowing and come back and say i dont know the blades just quit. when I look there is a TREE wedged in the blades and the belt is burnt in two cause she aint got enough sense to disengage the blades at this point. yea they just quit my rear lol
Old 03-14-2009 | 06:53 PM
  #215
av8tor1977's Avatar
My modified Ryobi turns an 18 x 6 prop at 8500 rpms, and it has the stock reed valve so I don't think that is a limiting factor. I am going to put a larger prop on it, because I have heard of Ryobis blowing up when run this fast. When looking at that stamped steel rod, I am rather amazed that they hold up at the recommended 7500 static rpms. 7500 static will unload to 8000 plus in flight anyway.
AV8TOR
Old 03-14-2009 | 07:34 PM
  #216
andrew66's Avatar
i will get pics of the tach later tonight. I think it is more accurate b/c it has a laser that hits the reflector tape (sticks to the prop) and it measures the rpm from that. It says it has 5 digit read out. This tach is normally around $60.00, thats why i didnt hesitate to buy it. lol
Old 03-15-2009 | 09:57 AM
  #217
andrew66's Avatar
i got a pic of my tach. The brand is power fist. Just for the hell of it, i put a reflector on my fan in the house to test, and it works beautifully. It wont pick up a reading unless the laser beam hits the reflector. And it reads down to 1 digit.
here are the pics
ID:	1158124   Click image for larger version
Old 03-15-2009 | 08:15 PM
  #218
Man that was good deal for 20 bucks. did they by chance have another lol?
Old 03-15-2009 | 08:16 PM
  #219
I have a referance test engine working now.
A very clean stock single ring piston,large case long shaft,with a small 8mm carb that was also cleanned up,and a 2 runner port head.It has about 5 for compression.I was working with the EI,so there was no mag. and coil to mess with.I think the timming was about 15 degres BTDC.A Zoar 18x6 for the prop.I was getting abound 7100 rpms at full throtle and was idleing down to 2500rpms.The gas was 91 octane and 40:1 oil mix.I was running open exhast to see how bad it was burnning the fuel.Yea, a little loud !!
About 62 sunny little to no wind and dry( around 30%)
If anyone else is running the XYZ EI ignition that you got from China, check your magnet before you glue it into the hub. It is picky to N or S to trigger it.Hook it all up and pass the magnet up to the hall sensor to get the right side up.
Old 03-15-2009 | 08:34 PM
  #220
thats good to know about the magnet. sounds like your making progress. I worked on my test stand a little more today and should be ready to get back to testing soon.
Old 03-15-2009 | 08:47 PM
  #221
I was planning to get a static thrust reading but the batterys were dead in the scale.I was getting dark, and needing to get cleanned up.There is always tomarrow.
Old 03-15-2009 | 08:51 PM
  #222
Yea i had to quit working today early cause my wife wanted some attention today. So i got to go ridding all over the country. She didnt know it but i was secretly looking for weedeaters lol.
Old 03-15-2009 | 08:53 PM
  #223
andrew66's Avatar
they had a few left, but were going fast. Sometimes they list these items online, but its hard to find them, cause the stock varies from store to store. Maybe searching powerfist would turn something up? but i doubt that they will be on sale for as low as at princess auto.
Looks like the weather might be crap for full scale flying tomorrow, so i will probably get a chance to run the engine so i can post a video with rpms. My buddy just got back so i might have a camera man, if he isnt busy tomorrow.
Old 03-15-2009 | 10:21 PM
  #224
The Radio Shack magnets DID work fine .ie-the XYZ EI.I was also using 6volts with no problem.
Old 03-16-2009 | 08:21 PM
  #225
andrew66's Avatar
I got to run my engine today. It went well i guess... My miracle tach decided that it wouldnt work in the cold. wouldnt pick up any reading at all. I brought it home, and tested on the fan, and it works fine. Only difference is that its 20C in the house, and 3C outside. They state that the operating temp is 0-30C and a max RH of 80%, so i guess thats probably why i was having troubles. But for now, im finished testing this engine, until it gets warmer, and the 18-8 prop gets here. I now have about 3.2 hours on this engine, running 87 octane fuel and castrol grand prix motorcycle oil mixed at 32:1.
here is the link to the video from today: http://www.youtube.com/watch?v=RjF6PusJxUU
