CRRC PRO GF26I
Old 02-25-2009, 04:17 PM
  #851
davidj
davidj's Avatar
Default RE: CRRC PRO GF26I
Here is a pic of the failure. High RPM's should not cause a failure like this. It appears the metal is just too thin and breaks just past the weld. I have had 3 of these mufflesr do the same thing. The engine is running smoothly and the only thing I can think of is the motor box is weak and allows too much movement of the engine. As for prop selection, I'm flying a Yak and I want a larger diameter prop to get outside the cowling. The manufactures spec states max power is at 9,000 rpms. I used a 17x8 and got 7400 rpms then switched to the 17x6 and got 8200 rpms and noticed about 10+% increase in thrust but no real increase in top speed. The muffler failure is caused by vibration and (IMHO) is related to manufacturing materials or proceedures.
ID:	1144718   Click image for larger version
Old 02-25-2009, 05:32 PM
  #852
grossy2
Hi All.
I have a 69" Extra 260 with a CRRC-Pro up front running a SY16X8 prop with a Pitts muffler.
Had nearly 18 months and lots count of the number of times its flown. I fly nearly everyweek, not always this Aircraft though.
Its ran like a dream. The only thing I had to do was swap out the defect prop adaptor as it cracked.
I was even using the SY 16X8 3 blade for awhile. Nice prop, smooths out the engine and looks great. The reason I went back to the 2 Blade is spin up time. The 2 blade was instant. 3 Blade takes a sec to wind up.
Cheers
Grossy
See pics
ID:	1144740   Click image for larger version
ID:	1144741   Click image for larger version
ID:	1144742   Click image for larger version
ID:	1144743   Click image for larger version
ID:	1144744   Click image for larger version
Old 02-26-2009, 04:47 PM
  #853
scratchbildr
HELP!
This engine (26EI) runs great when it runs FORWARD! It loves to run backward! In fact when it pops, it throws the prop backwards and starts right up. Several HARD flips to get to go the right way. When it runs forward, I get great response, good idle, good transition to full. No problem there.
When it pops backward though, to breaks loose the prop bolt from the shaft and spins it off, prop, spinner and all, in one piece!
Any corrections for the backwards pop? Timing? Anything?
And the prop shaft unscrewing? 10 lbs./sq.ft. torque right?
Prop hub. (gold anodized) is fine. no cracks.
Any help would be appreciated.
Old 02-26-2009, 05:03 PM
  #854
OK2Fly
OK2Fly's Avatar
ORIGINAL: scratchbildr
HELP!
Hello, and welcome to RCU. My engine does the exact thing, and no matter what I changed, it would still kick back. I tried retarding the timing, and made sure I wasn't over choking. It will kick reguardless, so what I did was just put another nut on the prop shaft to keep things from spinning off. You'll feel the engine try to go back a little but it's still easy to flip it through compression.
I know how annoying it is to re-tighten the prop and spinner only to have it spin off on the next flip.[:@] Good luck.
Old 02-26-2009, 05:31 PM
  #855
scratchbildr
Thanks for the reply.
It's not that the prop and spinner "kicks" off, but the whole shaft as well. Prop stays tight against the stop.
Old 02-26-2009, 05:33 PM
  #856
scratchbildr
I have double nutted the prop.
Old 02-26-2009, 05:42 PM
  #857
OK2Fly
OK2Fly's Avatar
The shaft comes out too? Tighten that sucker up, but don't overtighten. I gave it more than 10 ft/lbs. A better idea would be to find the cause of the backfiring, but, I still have no idea...
Old 02-26-2009, 05:49 PM
  #858
scratchbildr
OK. It dosen't backfire.
Flip the prop, prop turns 1 revolution, as the magnet comes around to fire the next turn, it's like it pre-ignites causing the prop to kick in reverse, then start. Backwards.
I know the timing is retarded, but how much should it be?
And, what is the stock setting?
Old 02-26-2009, 06:06 PM
  #859
OK2Fly
OK2Fly's Avatar
Hmm, that is odd. A good starting point is 28-30 degrees BTDC, or just center the sensor between the screws.
Old 02-26-2009, 06:33 PM
  #860
jedijody
jedijody's Avatar
Does the large part of the propshaft that threads onto the crankshaft go all the way down flush with the surface of the gold prop hub or does it stick up slightly above the serrated surface of the hub?
Timing should be set at 28-30 degrees BTDC, sometimes they get set to far advanced or you may just have a bad module.
Old 02-26-2009, 07:32 PM
  #861
OK2Fly
OK2Fly's Avatar
Jody to the rescue!
Old 02-27-2009, 12:05 AM
  #862
scratchbildr
Hey Jody. I've heard alot about your expertise on these. Thanks for chiming in.
The propshaft just barely sticks out. The spinner backplate does touch the hub. I'm not sure how much though. It's a 3 1/2 in. dave brown alum. It's in a 25% yak, so the visual is slightly impaired.
I don't see how it could be the module. When it fires forward, it runs great. Running on 4.8v.
Old 02-27-2009, 01:26 AM
  #863
jedijody
jedijody's Avatar
If the spinner back plate is just touching it may not be enough to get a good bite on the hub serations. Here is something to try to keep the propshaft from getting spit back at you when it pops backwards.
Unscrew the propshaft, take the lock washer out, clean the threads and put red Locktite (262) on the threads inside the propshaft and reinstall without the lockwasher, let it sit overnight. This will let the spinner back plate make full contact with the prop hub so the serations can do their job.
As far as starting backwards, this is the first 26cc engine I've heard of doing it. It was more common with the 50cc and was always associated with the timing being advanced to far. Check the timing with a degree wheel and see what it is exactly. They are usually at about 30 degrees from the factory but I have seen them as far as 36. Set it at 28 degrees and give it a try.
Besides that you can try to flip it over either a little harder or a little softer, sounds weird but sometimes it works. Get the engine right itself though first, if you don't, there will always be something else going on that will be a pain to deal with.
If you can't figure it out don't give up on it, take a break and fly something else, send it in and I'll take care of it.
Old 02-27-2009, 05:43 PM
  #864
Planeclothes
Planeclothes's Avatar
Jody, my 26cc has been doing the exact same thing. I believe it all began after replacing the module. The sensor is retarded all the way but it still starts backwards, 3 to 5 times, before it finally starts right. Once it warms up, it won't start backwards again, it only seems to happen when it is cold. I don't really have a problem with the prop as I don't use a spinner and the prop shaft is fairly tight. But I am always concerned that something might break loose one of these days.
Old 02-27-2009, 11:07 PM
  #865
jedijody
jedijody's Avatar
Hi Joe,
Not sure exactly what is going on except this is the second engine doing the same thing, has never been an issue with the 26 and as you know, it was not a problem for you until you replaced your module. Look at the pictures and notice the differences in the sensor and battery leads. Also look at the back of the module and note which model number is marked off and please report back. It would help if you could acurately check your timing with a degree wheel. If you don't know how or don't have a degree wheel go here, http://www.ch-ignitions.com click on "Instructions" and then, "Installing and Operating...", scroll down about 3/4ths of the page you will find good directions on how to do it. There is also a link at the end for a degree wheel you can print out. Before you print it make sure you have the scaling turned off in the printer properties dialog box that pops up.
ID:	1146588   Click image for larger version
Old 02-27-2009, 11:28 PM
  #866
OK2Fly
OK2Fly's Avatar
Maybe I will secretly disassembles it to find the problem? I'll get pics tomorrow.
Old 02-27-2009, 11:38 PM
  #867
jedijody
jedijody's Avatar
Go ahead, take the back cover off, if you can see anything you can fix let me know.
Old 02-27-2009, 11:50 PM
  #868
OK2Fly
OK2Fly's Avatar
Nah, I think I read somewhere that the electronics are under some kind of impenetrable black blob. Best not to risk electrocution! haha The module is zip-tied and duct taped securely in the Showtime 90, so I'll tinker tomorrow. [sm=redface.gif]
Old 02-27-2009, 11:53 PM
  #869
jedijody
jedijody's Avatar
You read right, it probably doesn't even need a housing.
Old 02-28-2009, 02:28 PM
  #870
Planeclothes
ORIGINAL: jedijody
Hi Joe,
Mine is definitely like the one on the right (first picture) with the all black wires. As for the underside numbers, I will have to remove the cowling and the module itself since it is padded and secured inside the engine box. By the way, when the first one failed, I removed the cover and there is absolutely nothing to replace, remove or even test. Everything is covered by some kind of black stuff.
Old 02-28-2009, 03:56 PM
  #871
edwal07
Sorry for the typo, it should read 13lb, I edited the post to reflect the change. Actually I got 13.5lb with the SY16X8.
Thanks for pointing the typo.
Ed
Old 02-28-2009, 04:25 PM
  #872
reg price
do you need the fuuel tank outlet to be in line wih carb ,as is you do with glow engines?reply grateful
Old 02-28-2009, 04:28 PM
  #873
dematel
Not for a gas engines you don't. You can put your gas tank enywhere in the plane. Gas engines have a fuel pumps.
Old 02-28-2009, 04:31 PM
  #874
reg price
thanks dematel
Old 02-28-2009, 04:32 PM
  #875
dematel
no problem
