Helimax This is for all your Helimax questions and comments.
axe cp thread
Old 06-29-2007 | 02:56 PM
  #1276
PilotLight's Avatar
Default RE: axe cp thread
Oh! Thanks for the info Heliko. I didn't realize it was much bigger. The price of $25 per motor is steep, so we'll have to keep looking.
Disregard the above post.
Old 06-29-2007 | 05:30 PM
  #1277
ORIGINAL: Phishnvdub
ORIGINAL: harebearva
I've been having an interesting intermitent problem. I recently disconnected the red lead from my motor when I did the heatsink mod, of course this is before I found out I didn't really need to. But anyway, I pushed the connection back together and everything seemed fine. Now about every 3rd flight i'm having a complete motor failure. Since I'm still learning to hover this means that it drops from about 5 feet. After that, I push on the two connections to be sure they are seated properly and they always seem to be, and then it works again. This has happened with both lipo and stock batteries and isn't due to low power in the bat. Any ideas? Bad connector? The connectors are perfeclty clean and seem to be in good shape. What up?
I had a bad connection in the bullet connectors from the motor to ESC when I first got mine, I had to resolder it. I'd check there. Mine if I rember right was the positive motor bullet connector from the ESC. Hope this helps, Shaun
Was the bad connection at the bullet connector or an the ESC connection?
Old 06-29-2007 | 05:57 PM
  #1278
I think it was the positive bullet connector on the ESC side ( definately the bullet connector and not the mini deans). I noticed it while unplugging and plugging the motor back in. If you have shrink wrap, I'd cut the wrap off and see if the wires are soldered properly into the bullet connectors. Check to make sure this won't void your warranty if you are still under it and end up having to send it back.
Old 06-30-2007 | 09:27 AM
  #1279
I have a dumb question. WHat are the odds that they will just send me the 3 n 1 board with proof of purchase, without me having to send them my heli. The problem is so intermitent, if they get it and everything looks OK and the test fly it and it works good, they'll just send it back AS IS I suppose. Kind of a weird situation. I am gonna check the solder joint at the connector. Thanks for the info.
Old 06-30-2007 | 01:09 PM
  #1280
Hi guys,
Just got my axe cp and rebuilt the head. Put on a new set of blades and the head vibrates really bad at all speed even with a new main rotor shaft and also one of the shaft collars came out and I can't tell where it goes. I have the diagrams but that doesn't really show it either. If some one could let me know and also help me to fix the head vibration issue it would be greatly appericated.
Tom
p.s. you can email me at [email protected] with the subject AXE CP
Old 07-02-2007 | 04:46 PM
  #1281
markind's Avatar
Hi guys I have been lurking for some time but recently I got in some more stick time and am happy to report my Axe is hovering smooth as glass. [8D] I am super-pleased with my Axe CP and can hover side in Left and Right with confidence! I can go nose-in all day long on the sim, but get freaky with model, so slow, patient and steady practice is the key.
To bring up new readers, I am running DX7 radio w/ AR6000 rcvr, LiPo TIP 1320, plus Gy240 with everything else stock. Still on my 3rd set of blades! Longest mileage yet!
My DX7 program for hovering is working all too well - but its very unstable when attempting forward flight. The next step is to set up a "Stunt Mode 1" where I will have increased headspeed and * some * negative collective pitch. I was told I needed some negative CP because I may get a gust of wind and need to fight being popped up to far too fast. The increased headspeed should buy me the stability I need.
I am eager to find a cheap replacement for the tail motor. I think mine will wear out soon and I would rather not spend $25 on that little $1 piece of chinese garbage they sell us. [:'(]
My stock electronics had a problem but with a carefully worded email, they sent a replacement free no questions asked. It CAN be DONE!
~mArK
Old 07-02-2007 | 08:18 PM
  #1282
Hey Mark
I am running the DX7 also.
Would you care to compare settings?
It seems the only issue about FF is that my Axe quickly gains altitiude
which I believe is normal, outside of that it is fairly stable.
I am using the 7000 rec. which reallyshould not matter.
FJ
Old 07-02-2007 | 09:12 PM
  #1283
Hello, again. First, thanks for earlier replies and suggestions. I have the same amount in spare parts, batteries etc ordered and on the way as I paid for the Axe in the first place.
I've been doing the RADD thing (on stock battery - just get started and batt runs out) and practicing as much as I can. Thought I was doing pretty good, got the training gear back on and started the left / right tail movements. Then I thought "not too bad, I think I can lift it up and control it". Okay, that was my First mistake. Then I thought, yeah, doing OK, recovering pretty well, getting it back level not going more than 5 or 6 feet out of box, less than a foot off of ground, training gear helping, so on and so forth. Second mistake, I got it, I can recover, keep control etc. and GUESS WHAT? (you all saw this part coming didn't you) I lost control of it, hit an object and broke the main blade grip. I think I muttered something like oh! s***, and noticed that one blade was resting at a non-spec angle.
Yep, doing good, thought I was getting the hang of it, I (big I) could handle it, wasn't going to push it too much and the next thing I am doing is turning off the battery and controller and sitting down typing this message.
The point, when you think you got it, it gets you. I rushed beyond my capabilities and now I am waiting on my order so that i can fix it. Guess I will have some down time reading and trying to get it in my head not to rush things.
One question for those who do the flying on the floor trying to learn the controls etc.- does your machine slide/ scoot out of the box at the higher head speed. RADD says to keep it in the box, but mine wants to drift out of the box so I have to use a lot of right stick at 3 oclock and nudge to 12. Kind of hard to practice the 8 to 4 oclock movements when the bird is drifting. And it is hard to trim it when I can't get off the ground without it looking like a tilt -a- whirl at the local fairgrounds. Any suggestions?
Oh, it's OK to laugh at my misfortune. I knew better then and now. I will still do something stupid in the future though. We humans are so predictable.
Old 07-02-2007 | 09:49 PM
  #1284
I feel for you. With my work schedule and 2 kids, I'm Lucky if I get to fly 2 times a week. I do however get a lot of sim time. Last weekend, for no good reason....I decided to try hovering side in. So I snap it to the left and I LOSE IT! LOL I got lucky though. I hit from about 6 feet high at about a 45 degree angle. Dug the blades in and one of my blades was at that NON_SPEC angle as well. Fortunately all I had to do was pop the ball link back on my blade grip and up up and away. That was the first of 4 crashes that day. Can you say HOVER PRACTICE!!!!!!!!!!!!!!! LOL
Old 07-02-2007 | 10:47 PM
  #1285
Yeah, talk about non-spec angle...my last two crashes resulted in one of the main blades over one of the flybars. Luckily (knock on wood) nothing was broken or bent either crash.
K94max, it's a fine line between staying comfortable and pushing yourself to excel; too much on either side and you don't improve or you crash and get frustrated, respectively. As for trying to stay in the box while on the floor, I found it impossible. It kept on scooting to the 10 o'clock position. I just decided to push myself one day and get to hopping and never looked back.
Oh! Have you tried the servo links and/or flybar weights mods? If not, I highly recommend it. Tames the Axe down and allows to learn a lot and get your confidence up.
Old 07-03-2007 | 11:40 AM
  #1286
No, I haven't tried the servo or weights. I think I will try the weights first. I will do a search on the servo links. Is this the mod where you bring the arms into the hole closest to the screws (center) and I assume all 3 servos are adjusted to the same hole? Tx for encouragement.
Old 07-03-2007 | 11:46 AM
  #1287
Yep! You have that exactly right. It's suggested to adjust the pitch blades to zero at 50% throttle at idle up but I never recall doing this the first time I did it and it flew fine. *shrug*
Old 07-03-2007 | 12:04 PM
  #1288
Too many stories of gloom and doom.
I am a 1/4 scale fixed wing RC pilot of many years trouble is almost all flying fields have been taken for housing developments I sold my last 1/4 scale Cap 232 several months ago.
I really missed the sticks so for the heck of it I picked up a Lama 4 and have put many hours on this cool little heli. I have wanted to go to the next level (I want the Trex 450SE) but the system is a little $$$ at the moment.
My son need blades for his Lama 4 so we found a local hobby shop close to the house. We walked into the shop of course the normal RC fixed wing stuff but RC helios everywhere.
We were there for several hours spent some time on the sim and was able to strike up a conversation with the resident Heli expert. Of course he recommended the Trex but during the course he offered to let me fly what he thought would be a fairly stable ( I was considering the Blade CP as an a starter) heli, he put the battery in of all things the AXE CP with trainer bars on the model.
He offered to let me fly the model in a large covered building in the rear of the store a little hesitant at first but I gave it the go.
A little over correcting but eventually had the model at a hover, the CCPM works pretty well as well as the HH of the gyro.
I ended up buying the kit he had a charged battery and we trimmed the helicopter out at the shop.
After getting the heli home I recharged the battery and headed for the empty garage, I flew long enough (8-9) minutes to discharge the battery for the first time on my on.
I am addicted to this rotor craft stuff and enjoy the heck out of the stock Axe.
It just seems so many have mechanical problems I hope this is not really an indication of the reliability of the helicopters as I read thru the threads.
OH well just to say hello as a new Axe CP owner.
Old 07-03-2007 | 12:55 PM
  #1289
Hello, and welcome to the Axe community. I am indeed a noob as I only have been flying since last week. You had an advantage of having an "expert" trim your machine and to make sure it was ready. A lot of us learn this on our own which I am sure results in many mistakes and trial and error runs. I like what I have seen so far but I had to order batteries and chargers etc. and I was short on the $25 gift from Tower so I ordered extra parts figuring I would need them sooner than later. This is an addictive hobby.
Noob question - is the main rotor blade assembly supposed to be really loose? example - blades are straight and level to the boom and nose. Flay paddles level right to left. I can push one of the fly paddles down (very light touch) and the blades will pivot to about a 30 degree angle. This is not the grip of the blades to ensure each blade is the same tightness on each grip rather the entire assembly (blades, fly paddle, flybar carrier?) rocks very easily. Does the centrifugal force of the spinning blades make the "level out"? I replaced a main grip earlier - do i need to tighten the screws so that the blades/paddles do not "roll" so easily on thier own? Thanks for advice.
S_mcflurry, i just made the mods to the servo links. I will see how that does after battery charges if I have time today.
Old 07-03-2007 | 01:36 PM
  #1290
Great! Let me know how it goes!
As for the blade assembly, I think I have an idea of what you're describing. The blade grips should be tightened enough so that the blades can stay up on their own when the Axe is held on its side but will fall the same distance when shaken a bit (the manual describes this much better than I am doing here). Once you've verified this and they're still falling when you tip the flybars then that's just how it is. I wouldn't worry too much about it at that point. Yes, centrifugal force will straighten the blades out. What I do is start up slowly and let it go to about 35%-40% throttle for about 5 seconds to give the blades a chance to straighten out and the heli to settle before I lift off.
Old 07-03-2007 | 01:56 PM
  #1291
Well, tx for reply but I did not describe it well. I understand what you described about the blade grips and shaking them. My question tho, is that if you have the flybar sitting parellel to ground and the blades are thus parallel i can barely touch a paddle and the entire assembly will tilt. (like a seesaw for example). the blades themselves are tight but the entire group will swivel. I know this is hard for me to explains clearly and for you to understand what I am asking (can't talk without my hands . Thanks for trying to help me. I do appreciate it. Maybe it doesn't matter that it is "loose"?
Old 07-03-2007 | 03:07 PM
  #1292
...hm...well, if it still flies okay... *shrug* One of those if-it-ain't-broke-don't-fix-it moments I guess...
Old 07-03-2007 | 07:36 PM
  #1293
I do believe that helped having an experienced flyer there to help me trim the copter. One thing I have found and this goes against the grain of a newbie do not flounder in the prop wash, get the model up much more stability about 3 feet off the ground.
I have about 45 minutes on the model after a few more flights in the garage, thank goodness for the training wheels makes it a lot less pressured when flying the model. I wish the battery pack lasted longer.....
Many Thanks for the replies a great group of flyers here
Old 07-04-2007 | 04:09 AM
  #1294
markind's Avatar
Guys I'm gonna recommend biting the bullet and stocking up on a few spare parts. A set or two of extra blades and grips, feathering shaft, linkages, etc. Build up a crash kit - you're not doing yourselves any favors by having to wait on parts. If you consume some of your kit, re-order just what you use. BUT at least you can still get stick time while parts are on the way. Other than the blades its not too costly for the other head components.
And the really weird thing - once you get stock of parts you may find that you never need them... don't even try to figure out that one...
Old 07-04-2007 | 11:22 AM
  #1295
PilotLight's Avatar
Yeah, I've got a crash kit. Now I can crash twice in the same day!
Just kidding. Like Markind says, once you get the parts, you start to fly better cause you're not so nervous and some of the pressure is off. If you make a mistake, you can fix the heli and go back out and find what you did wrong so it doesn't happen again.
Old 07-04-2007 | 06:08 PM
  #1296
Hi all, I flew today with no crashes - then I woke up. Oh well, nice dream. I did fly today. Just got through replacing a main grip after "flying". Like a bottle of shampoo - charge, fly, repair, repeat.
Old 07-04-2007 | 07:37 PM
  #1297
BODY SPIN
Hi, I was flying mine and now all of a sudden the body spins.. I can't figure out why...the roters are still going but the body turns like a whirlwind.. any ideas
Old 07-04-2007 | 07:39 PM
  #1298
Any help with the body spin would be great.. my toy.. broken on a day off. .darn
Old 07-04-2007 | 08:50 PM
  #1299
PilotLight's Avatar
Is the tail motor still running? Unplug the main motor, power up, then while holding heli so it can't move, throttle up to around half and push right. Tail motor should spin up fast.
Old 07-05-2007 | 10:51 PM
  #1300
ORIGINAL: K94max
Yes the entire thing will pivot. It is supposed to be that way. Once things get moving, centrifugal force will level it out and keep it level until you give a control input.
