Reload this Page >
Meister scale P-47 D-25 Diary of a scale build
Old 08-23-2015, 12:02 PM
  #76
rt3232
T/B
I like it !, when a plan comes together.
Cheers Bob T
Old 08-23-2015, 12:21 PM
  #77
TonyBuilder
TonyBuilder's Avatar
Thanks Bob!
TB
Old 08-23-2015, 12:23 PM
  #78
TonyBuilder
Originally Posted by DGrant
Subscribing.... This is pro stuff. Very nice!.
thanks DGrant!
TB
Old 08-24-2015, 04:08 AM
  #79
TonyBuilder
Progress.
I set my fuel tray in between F2 and F3. I use the side saddle tank system and two 16oz tanks.
The tray is removable for now and may get glued in later. There will be a bit of g force on it as the tanks hang when the plane is upright. I have used this before so not worried, but probably will glue it in.
So fare the only thing missing from my kit is the F123 center stringer. This is 1/4" balsa for the noes profile. also missing was F123 "a" and F123 "b" both 1/4" balsa.
I just ended up going to the HS and got some 1/4" balsa sheets and cut them myself. I made the center F123 out of base wood as I wanted the strength at the spine.
I added a few extra stringers to the top.
Not sure why there is a set back notch in the firewall? My guess is they want you to use a thinner balsa sheet to round over on the top. Guess I will have to read the instructions
FS3 is glued in and ready for the inner cooler door layups.
I will make the doors before I glue in FS2 and FS 4
TB
Name:	meister 7 001.JPG
ID:	2116397   Click image for larger version
Name:	meister 7 002.JPG
ID:	2116398   Click image for larger version
Name:	meister 7 003.JPG
ID:	2116399   Click image for larger version
Name:	meister 7 004.JPG
ID:	2116400   Click image for larger version
Name:	meister 7 005.JPG
ID:	2116401   Click image for larger version
Name:	meister 7 006.JPG
ID:	2116402   Click image for larger version
Name:	meister 7 007.JPG
ID:	2116403   Click image for larger version
Name:	meister 7 008.JPG
Name:	meister 7 009.JPG
ID:	2116405   Click image for larger version
Name:	meister 7 010.JPG
Old 08-24-2015, 09:11 AM
  #80
rt3232
Hay T/B
I like your tank plan, but I question having that much weight about 3 1/4 lbs. fwd of the C/G unless I am missing something, maybe a couple of the jet guys saddle tanks in the belly pan at the C/G and yea tat makes for long lines but the engine you going to use should have no problems with them. I have also used the hanging tank platform and use rubber band to hold them in place, seams to work well and easy removal.
PS Please post a side view of the whole fuse, then I wont need to upset you build.
Cheers Bob T
Old 08-24-2015, 09:17 AM
  #81
TonyBuilder
Bob, my tanks are at the CG, most push the tank all the way forward but I like it over the CG so it does not change much in flight.
I use velcro to keep the tanks from sliding around and HD Velcro straps securing the tanks to the tray, they are not going anywhere.
TB
Old 08-24-2015, 06:14 PM
  #82
rt3232
T/B
I am good with both of your answer's, and I to use a lot of h/d valcro,
So back to my dish to lay down
Cheers Bob T
Old 08-26-2015, 03:34 AM
  #83
TonyBuilder
Progress.
All the stringers are installed on the top half of the fuselage.
I sanded the front stringers that make up the tapered noes.
One reason I used base wood on the spine top stringer F-123 is to give strength if when I put the plane in a cradle upside down.
This area is subject to stress and can crack.
On the balsa top four stringers from F-2 to F-3 I added some carbon fiber strips to stiffen these up. This is a weak area in my opinion so the added strength is needed
Both sides have the sheeting FS 1and FS 1a, FS 3 and FS 3a glued in, along with the two WSD.
This is all I will do until all the push rods are in and the inner cooler doors are installed.
Both carbon fiber inner cooler door layups are laid and curing.
I will cut them and back them with 1/32 birch ply. This will lock them in.
The frount underside chine gets base wood stringers for strength, this area will end up with a carbon fiber skin that will house the exhaust exits.
The servo tray for the elevator and rudder is just behind F4 and between F5. this location allows for the pushrod to be high in the top of the fuselage to clear the tail wheel when retracted.
It also gives a strait shot for the pull pull on the ruder and steering.
Onward.
TB
ID:	2116751   Click image for larger version
ID:	2116752   Click image for larger version
ID:	2116753   Click image for larger version
ID:	2116754   Click image for larger version
ID:	2116755   Click image for larger version
ID:	2116756   Click image for larger version
ID:	2116757   Click image for larger version
ID:	2116759   Click image for larger version
ID:	2116760   Click image for larger version
Name:	meister 7 011.JPG
ID:	2116761   Click image for larger version
Name:	meister 7 012.JPG
ID:	2116762   Click image for larger version
Name:	meister 7 013.JPG
ID:	2116763   Click image for larger version
Name:	meister 7 014.JPG
ID:	2116764   Click image for larger version
Name:	meister 7 015.JPG
ID:	2116765   Click image for larger version
Name:	meister 7 016.JPG
Name:	meister 7 017.JPG
ID:	2116767   Click image for larger version
Name:	meister 7 018.JPG
Old 08-27-2015, 12:57 PM
  #84
TonyBuilder
Default Inner Cooler Doors
Got a start on the inner cooler doors.
The doors are going to be maid from three pieces.
One is the door itself.
It has a piece of 1/32" birch ply glued to the underside. This gives it a lot of rigidity.
The second piece is the inside bottom that houses the door and will have the track on it. this gets attached to the inside of the fuselage.
The third piece is the skin that is just in front of the door as this area needs to be thin and strong. This skin will get glued in and flush out with the fuselage skin.
The opening is cut out and the two base wood stringers help keep it all together as I cut out the center crutch.
This is what the inside bottom piece will look like but with sides. This gets mounted to F7
The skin is in front to the door just behind F6.
This is kind of what the door looks like closed. but it is not finished, just a dry fit.
I will work on the sled and the rest later this week.
TB
Name:	meister 9 011.JPG
ID:	2116910   Click image for larger version
Name:	meister 9 010.JPG
ID:	2116911   Click image for larger version
Name:	meister 9 009.JPG
ID:	2116912   Click image for larger version
Name:	meister 9 008.JPG
ID:	2116913   Click image for larger version
Name:	meister 9 007.JPG
ID:	2116914   Click image for larger version
Name:	meister 9 006.JPG
ID:	2116915   Click image for larger version
Name:	meister 9 004.JPG
ID:	2116916   Click image for larger version
Name:	meister 9 005.JPG
Name:	meister 9 003.JPG
ID:	2116918   Click image for larger version
Name:	meister 9 002.JPG
ID:	2116919   Click image for larger version
Name:	meister 9 001.JPG
ID:	2116920   Click image for larger version
Name:	meister 9 012.JPG
ID:	2116921   Click image for larger version
Name:	meister 9 013.JPG
ID:	2116922   Click image for larger version
Name:	meister 9 014.JPG
ID:	2116923   Click image for larger version
Name:	meister 9 015.JPG
Old 08-30-2015, 05:46 AM
  #85
TonyBuilder
Some progress on the inner cooler doors.
Figuring out how it all works takes time but I think I got it.
This is the finished layered door. The rear 2/3 is flush with the fuselage skin. The front 1/3 is stepped down so when it slides forward it is under the skin and then start to open up.
The base is what will hold the bottom housing of the door. This is just tacked for fitting and will get glued in.
The bottom plate gets attached to the base bracket, this holds the door and slide mechanism.
The sides of the bottom plate will have the groves in it and will be glued to the bottom plate.
The sides of the door are laminated carbon fiber laminates and 1/32 birch ply. These get glued to the doors as the sides.
Still some fabricating to do but I am getting there.
TB
Name:	meister 10 001.JPG
ID:	2117299   Click image for larger version
Name:	meister 10 002.JPG
ID:	2117300   Click image for larger version
Name:	meister 10 003.JPG
ID:	2117301   Click image for larger version
Name:	meister 10 004.JPG
ID:	2117302   Click image for larger version
Name:	meister 10 005.JPG
ID:	2117303   Click image for larger version
Name:	meister 10 006.JPG
ID:	2117304   Click image for larger version
Name:	meister 10 007.JPG
ID:	2117305   Click image for larger version
Name:	meister 10 008.JPG
Name:	meister 10 009.JPG
ID:	2117307   Click image for larger version
Name:	meister 10 010.JPG
ID:	2117308   Click image for larger version
Name:	meister 10 011.JPG
ID:	2117309   Click image for larger version
Name:	meister 10 012.JPG
ID:	2117310   Click image for larger version
Name:	meister 10 013.JPG
ID:	2117311   Click image for larger version
Name:	meister 10 014.JPG
ID:	2117312   Click image for larger version
Name:	meister 10 015.JPG
ID:	2117313   Click image for larger version
Name:	meister 10 017.JPG
Name:	meister 10 018.JPG
ID:	2117315   Click image for larger version
Name:	meister 10 019.JPG
Old 08-30-2015, 01:05 PM
  #86
rt3232
T/B
I like it but they are just for effect ?
Cheers Bob T
Old 08-30-2015, 03:04 PM
  #87
TonyBuilder
Progress.
So the left door is done and being fitted for adjustments.
The frame that houses the door is complete, it has the slots to guide the door.
The track is a slot cut into the 1/8" ply that has the 1/32 birch ply laminated to it.
The hardware is brass soldered to make a linkage frame, plus this is threaded to receive the 2-56 button head shrews.
2-56 screws, and servo grommets.
The doors have the carbon fiber laminated to the 1/32 ply.
To reinforce the joint I use tine as a L bracket, this works good.
I did two slots instead of just one. The first one is strait and guides the door level backwards. The second is lower and guides the door level until it starts to open and then it dips down.
I like this so I can make the servo linkage on the upper one that is strait so it is pulling or pushing strait, no binding this way.
So all together and ready to drop in for final fitting.
I had to redo the mounting bracket to get the proper fit. I made it more compact.
This is glued in.
With the mount glued in I just drop the door assembly in and temp bolt it down.
I had the bracket for the linkage on backwards in the previous pics it was on the lower track, now it is on the upper strait track.
Pushrod lines up well. Not sure if I will use a servo or the liner actuator. The actuator will be smoother and I will have more control so we will see.
Here is a short vid of the working door.
https://youtu.be/TQg5nYNpNwg Next I will do the right side.
TB
Name:	meister 11 001.JPG
ID:	2117438   Click image for larger version
Name:	meister 11 002.JPG
ID:	2117439   Click image for larger version
Name:	meister 11 003.JPG
ID:	2117440   Click image for larger version
Name:	meister 11 004.JPG
ID:	2117441   Click image for larger version
Name:	meister 11 005.JPG
ID:	2117442   Click image for larger version
Name:	meister 11 006.JPG
ID:	2117443   Click image for larger version
Name:	meister 11 007.JPG
ID:	2117444   Click image for larger version
Name:	meister 11 008.JPG
Name:	meister 11 009.JPG
ID:	2117446   Click image for larger version
Name:	meister 11 010.JPG
ID:	2117447   Click image for larger version
Name:	meister 11 011.JPG
ID:	2117448   Click image for larger version
Name:	meister 11 012.JPG
ID:	2117449   Click image for larger version
Name:	meister 11 013.JPG
ID:	2117450   Click image for larger version
Name:	meister 11 014.JPG
ID:	2117451   Click image for larger version
Name:	meister 11 015.JPG
ID:	2117452   Click image for larger version
Name:	meister 11 016.JPG
Name:	meister 11 017.JPG
ID:	2117454   Click image for larger version
Name:	meister 11 018.JPG
ID:	2117455   Click image for larger version
Name:	meister 11 019.JPG
ID:	2117456   Click image for larger version
Name:	meister 11 020.JPG
ID:	2117457   Click image for larger version
Name:	meister 11 021.JPG
ID:	2117458   Click image for larger version
Name:	meister 11 022.JPG
ID:	2117459   Click image for larger version
Name:	meister 11 023.JPG
ID:	2117460   Click image for larger version
Name:	meister 11 024.JPG
Name:	meister 11 026.JPG
ID:	2117462   Click image for larger version
Name:	meister 11 027.JPG
ID:	2117463   Click image for larger version
Name:	meister 11 028.JPG
ID:	2117464   Click image for larger version
Name:	meister 11 029.JPG
ID:	2117465   Click image for larger version
Name:	meister 11 030.JPG
ID:	2117466   Click image for larger version
Name:	meister 11 031.JPG
Old 10-21-2015, 12:22 PM
  #88
TonyBuilder
Building will start up this weekend!
TB
Old 10-25-2015, 01:55 PM
  #89
TonyBuilder
Default Inner Oil Cooler Doors
I got the second door all built and fine tuned the existing one so now they are ready to install.
I bolted the side panels as everything gets bolted on this bird.
8- #80 counter sunk SS screws on the door, and 3- #80 counter sunk SS on the side panels each side.
Sleds are matched up and done, had to do some fine tuning.
They drop in pretty good now and once they are all painted some lubrication for smooth in serves operation.
So there you have it, two inner cooler door sets.
TB
Name:	oil cooler doors 002.JPG
ID:	2127660   Click image for larger version
Name:	oil cooler doors 005.JPG
ID:	2127661   Click image for larger version
Name:	oil cooler doors 006.JPG
ID:	2127662   Click image for larger version
Name:	oil cooler doors 007.JPG
ID:	2127663   Click image for larger version
Name:	oil cooler doors 008.JPG
ID:	2127664   Click image for larger version
Name:	oil cooler doors 009.JPG
ID:	2127665   Click image for larger version
Name:	oil cooler doors 010.JPG
ID:	2127666   Click image for larger version
Name:	oil cooler doors 011.JPG
Name:	oil cooler doors 012.JPG
ID:	2127668   Click image for larger version
Name:	oil cooler doors 013.JPG
ID:	2127669   Click image for larger version
Name:	oil cooler doors 014.JPG
ID:	2127670   Click image for larger version
Name:	oil cooler doors 015.JPG
ID:	2127671   Click image for larger version
Name:	oil cooler doors 016.JPG
ID:	2127672   Click image for larger version
Name:	oil cooler doors 017.JPG
ID:	2127673   Click image for larger version
Name:	oil cooler doors 018.JPG
ID:	2127674   Click image for larger version
Name:	oil cooler doors 019.JPG
Name:	oil cooler doors 020.JPG
ID:	2127676   Click image for larger version
Name:	oil cooler doors 021.JPG
ID:	2127677   Click image for larger version
Name:	oil cooler doors 022.JPG
ID:	2127678   Click image for larger version
Name:	oil cooler doors 023.JPG
ID:	2127679   Click image for larger version
Name:	oil cooler doors 024.JPG
ID:	2127680   Click image for larger version
Name:	oil cooler doors 025.JPG
ID:	2127681   Click image for larger version
Name:	oil cooler doors 026.JPG
Old 10-25-2015, 05:06 PM
  #90
rt3232
T/B Looking great
Cheers Bob T
Old 11-01-2015, 03:00 PM
  #91
TonyBuilder
Default Stab
I started to work on the stab today.
At first I was like what the hell am I going to do with this as I do not like the method of how the stab is assembled. The parts are difficult to discern haw they go. In all the other P-47s I have built the stab is equal top and bottom, no difference. All my drawings show the same but the parts are not the same at the point they are attached to the TE.
So I just went for it and will adjust once I have something to work with.
I glued the ribs in as best as I could figure out and will adjust later. They are uneven as once you get them in and they are plumb, the LE is all wavy.
Once I sheet the sab I will sand the LE strait that should do it.
I much prefer the tab method of framing as I can lay the stab flat and true it up.
So a strait aluminum angle is used to get the TE strait and plumb.
A center line is drawn to keep it strait in elevation.
Then I glued tabs to the ribs to equal it out and keep it flat and level.
Control lines are on the board to keep it all square and aligned.
Some blocks to keep it firm for sanding and when I sheet the top.
Now I can sand it and get it ready for hinges and sheeting.
I want to sheet the top to hold it all in place.
I am starting to layout the control torque rod and the hinges next.
The torque rod is solid 1/4" aluminum and will get cut into two halves.
The inner hinge is what takes all the stress from the control arm so this has two sealed baring's per mount. T
he arm will be next to this on the inside. They are 1/4" x 1" aluminum arms from Dream works.
The inside bearing is held with a set screw and the outer will get a sleeve to hold it in.
They are 3/8" OD and 1/4" ID, they fit tight.
I will do the same at the lower hinge for the rudder as there will be a lot of tension from the pull-pull.
I will tap in two post to the bottom for mounting this to the stab.
These are the pins for the hinges I will be making out of G-10. that will be next.
TB
Name:	meister 20 001.JPG
ID:	2128666   Click image for larger version
Name:	meister 20 002.JPG
ID:	2128667   Click image for larger version
Name:	meister 20 003.JPG
ID:	2128668   Click image for larger version
Name:	meister 20 004.JPG
ID:	2128669   Click image for larger version
Name:	meister 20 005.JPG
ID:	2128670   Click image for larger version
Name:	meister 20 006.JPG
ID:	2128671   Click image for larger version
Name:	meister 20 007.JPG
ID:	2128672   Click image for larger version
Name:	meister 20 008.JPG
Name:	meister 20 009.JPG
ID:	2128674   Click image for larger version
Name:	meister 20 010.JPG
ID:	2128675   Click image for larger version
Name:	meister 20 011.JPG
ID:	2128676   Click image for larger version
Name:	meister 20 012.JPG
ID:	2128677   Click image for larger version
Name:	meister 20 013.JPG
ID:	2128678   Click image for larger version
Name:	meister 20 014.JPG
ID:	2128679   Click image for larger version
Name:	meister 20 015.JPG
ID:	2128680   Click image for larger version
Name:	meister 20 016.JPG
Name:	meister 20 017.JPG
ID:	2128682   Click image for larger version
Name:	meister 20 018.JPG
ID:	2128683   Click image for larger version
Name:	meister 20 019.JPG
ID:	2128684   Click image for larger version
Name:	meister 20 020.JPG
ID:	2128685   Click image for larger version
Name:	meister 20 021.JPG
ID:	2128686   Click image for larger version
Name:	meister 20 022.JPG
ID:	2128687   Click image for larger version
Name:	meister 20 023.JPG
ID:	2128688   Click image for larger version
Name:	meister 20 024.JPG
Old 11-05-2015, 12:47 PM
  #92
TonyBuilder
Default Stab
I added some blocking for the hinges.
The blocks are just to add strength to the TE, internal blocks will be added before the top skin is glued on.
Blocks are added for the center baring hinges for the torque rod.
Tip blocks for the two dowels that will pin the front.
All sanded and ready for the skins.
I framed up the elevators to see how those will work.
They need a bit of work to get them right.
I am sheeting the bottom first to hold it all together.
Then I will install the hinges (dry) before I skin the top.
The tabs worked great to keep it all level and in the right place.
I made some contoured jigs for when I flip the stab and sheet the top, plus this is good for when I work on the hinges.
TB
ID:	2129210   Click image for larger version
ID:	2129211   Click image for larger version
ID:	2129212   Click image for larger version
ID:	2129213   Click image for larger version
ID:	2129214   Click image for larger version
ID:	2129215   Click image for larger version
ID:	2129216   Click image for larger version
ID:	2129218   Click image for larger version
ID:	2129219   Click image for larger version
ID:	2129220   Click image for larger version
ID:	2129221   Click image for larger version
ID:	2129222   Click image for larger version
ID:	2129223   Click image for larger version
ID:	2129224   Click image for larger version
ID:	2129226   Click image for larger version
ID:	2129227   Click image for larger version
ID:	2129228   Click image for larger version
Old 11-05-2015, 01:40 PM
  #93
tailskid
My Feedback: (34)
tailskid's Avatar
Your inner oil cooler doors are nothing shy of awesome!
Jerry
[h=2][/h]
Old 11-07-2015, 03:26 PM
  #94
TonyBuilder
Been working on the elevators.
I added some balsa to the TE to build it up as I will be trying something new.
I never liked the thick fat TE on the surfaces, dead giveaway that it tis a model.
So I am using some thin G-10 that will get glued into the TE between the top and bottom skins.
Also the ribs are all of and different sizes so I need to add some balsa and get them all the same.
Once the TE fir was added I put the two halves together and sanded them so they would both be the same shape.
Next I sanded the added fir so it tapered to the bottom skin (1/16"). The fir was 1/8"
Once the fir was shaped I had to reses it to accommodate the G-10
I cut the G-10 and cut the trim tab into it
The G-10 glued in and the ribs all lined up as I fired them too.
The blocks are for the hinges and the one at the inner part is for a dowel to pin the torque rod to.
I held them back about 5/8" as I will be cutting 3/4 off for the new LE.
Top skin is now glued on and I joined the two halves together with tape so I could sand them equal.
You can see how the ribs are off in size and I should have checked them before I skinned them, but I used 3/32" balsa on the top so I could sand it to fit the stab.
I wont sand the TE until the ends are put on.
I cut the old LD off and sanded them equal.
I first glue in a 3/32" balsa to face the elevator. Then a 1/4" balsa followed by a 1/2" balsa to bring the elevator up to size.
This will give me some sanding room on the TE.
With the ends squared up and sanded I can add the ends.
Ends and tips all glued in. I wont sand them until the stab is ready to sand.
TB
Name:	meister 15 001.JPG
ID:	2129472   Click image for larger version
Name:	meister 15 002.JPG
ID:	2129473   Click image for larger version
Name:	meister 15 003.JPG
ID:	2129474   Click image for larger version
Name:	meister 15 004.JPG
ID:	2129475   Click image for larger version
Name:	meister 15 005.JPG
ID:	2129476   Click image for larger version
Name:	meister 15 006.JPG
ID:	2129477   Click image for larger version
Name:	meister 15 007.JPG
ID:	2129478   Click image for larger version
Name:	meister 15 008.JPG
Name:	meister 15 009.JPG
ID:	2129480   Click image for larger version
Name:	meister 15 010.JPG
ID:	2129481   Click image for larger version
Name:	meister 15 011.JPG
ID:	2129482   Click image for larger version
Name:	meister 15 012.JPG
ID:	2129483   Click image for larger version
Name:	meister 15 013.JPG
ID:	2129484   Click image for larger version
Name:	meister 15 014.JPG
ID:	2129485   Click image for larger version
Name:	meister 15 015.JPG
ID:	2129486   Click image for larger version
Name:	meister 15 016.JPG
Name:	meister 15 017.JPG
ID:	2129488   Click image for larger version
Name:	meister 15 018.JPG
ID:	2129489   Click image for larger version
Name:	meister 15 019.JPG
ID:	2129490   Click image for larger version
Name:	meister 15 020.JPG
ID:	2129491   Click image for larger version
Name:	meister 15 021.JPG
ID:	2129492   Click image for larger version
Name:	meister 15 022.JPG
ID:	2129493   Click image for larger version
Name:	meister 15 023.JPG
ID:	2129494   Click image for larger version
Name:	meister 15 024.JPG
Name:	meister 15 025.JPG
ID:	2129496   Click image for larger version
Name:	meister 15 026.JPG
ID:	2129497   Click image for larger version
Name:	meister 15 027.JPG
ID:	2129498   Click image for larger version
Name:	meister 15 028.JPG
ID:	2129499   Click image for larger version
Name:	meister 15 029.JPG
ID:	2129500   Click image for larger version
Name:	meister 15 030.JPG
ID:	2129501   Click image for larger version
Name:	meister 15 031.JPG
ID:	2129502   Click image for larger version
Name:	meister 15 032.JPG
Name:	meister 15 033.JPG
ID:	2129504   Click image for larger version
Name:	meister 15 034.JPG
ID:	2129505   Click image for larger version
Name:	meister 15 035.JPG
ID:	2129506   Click image for larger version
Name:	meister 15 036.JPG
Old 11-07-2015, 04:51 PM
  #95
rt3232
Hi T/B
Been away for a bit, and looks kike you are coming along in great stile, really looks good
Cheers bob t
Old 11-14-2015, 03:55 AM
  #96
TonyBuilder
Progress.
I have the hinges all fabricated and ready to install.
Hinges ate made from 1/32 black G-10 laminated three layers.
The pins are from Robart.
Robart hinge pins are used for initial fitting.
Tab covers are .19mm carbon fiber laminates. I drilled and bolted all for together and then sanded to size, this way they are all the same size.
They will be bolted on with three #80 button head screws.
An aluminum plate will be recessed into the TE, tap threaded for the tabs.
Tips are glued and rough sanded.
TB
Name:	meister 16 001.JPG
ID:	2130511   Click image for larger version
Name:	meister 16 002.JPG
ID:	2130512   Click image for larger version
Name:	meister 16 003.JPG
ID:	2130513   Click image for larger version
Name:	meister 16 004.JPG
ID:	2130514   Click image for larger version
Name:	meister 16 005.JPG
ID:	2130515   Click image for larger version
Name:	meister 16 006.JPG
ID:	2130516   Click image for larger version
Name:	meister 16 007.JPG
ID:	2130517   Click image for larger version
Name:	meister 16 008.JPG
Name:	meister 16 009.JPG
ID:	2130519   Click image for larger version
Name:	meister 16 010.JPG
ID:	2130520   Click image for larger version
Name:	meister 16 011.JPG
ID:	2130521   Click image for larger version
Name:	meister 16 012.JPG
ID:	2130522   Click image for larger version
Name:	meister 16 013.JPG
ID:	2130523   Click image for larger version
Name:	meister 16 014.JPG
ID:	2130524   Click image for larger version
Name:	meister 16 015.JPG
ID:	2130525   Click image for larger version
Name:	meister 16 016.JPG
Name:	meister 16 017.JPG
ID:	2130527   Click image for larger version
Name:	meister 16 018.JPG
ID:	2130528   Click image for larger version
Name:	meister 16 019.JPG
ID:	2130529   Click image for larger version
Name:	meister 16 020.JPG
ID:	2130530   Click image for larger version
Name:	meister 16 021.JPG
ID:	2130531   Click image for larger version
Name:	meister 16 022.JPG
ID:	2130532   Click image for larger version
Name:	meister 16 023.JPG
ID:	2130533   Click image for larger version
Name:	meister 16 024.JPG
Name:	meister 16 025.JPG
ID:	2130535   Click image for larger version
Name:	meister 16 026.JPG
Old 11-14-2015, 05:33 PM
  #97
rt3232
T/B
Every thing is looking great.
Cheers Bob T
Old 11-14-2015, 05:59 PM
  #98
TonyBuilder
Thanks bob, it's nice working on a larger canvas!
TB
Old 11-15-2015, 05:59 AM
  #99
TonyBuilder
Progress.
I am fitting the hinges for installation.
Installation of the pin as it was designed, I use tweezers and it works fine.
The aluminum torque rod is test fitted. Once everything is all lined up and working well I will glue the hinges, and torque rod in all together.
Then when its all dried I will cut the rod in the center separating the halves.
All looks good so far, the tabs will be fitted next.
TB
Name:	meister 17 002.JPG
ID:	2130673   Click image for larger version
Name:	meister 17 003.JPG
ID:	2130674   Click image for larger version
Name:	meister 17 004.JPG
ID:	2130675   Click image for larger version
Name:	meister 17 005.JPG
ID:	2130677   Click image for larger version
Name:	meister 17 006.JPG
ID:	2130678   Click image for larger version
Name:	meister 17 007.JPG
ID:	2130679   Click image for larger version
Name:	meister 17 008.JPG
ID:	2130680   Click image for larger version
Name:	meister 17 009.JPG
Name:	meister 17 010.JPG
ID:	2130683   Click image for larger version
Name:	meister 17 011.JPG
ID:	2130684   Click image for larger version
Name:	meister 17 012.JPG
ID:	2130685   Click image for larger version
Name:	meister 17 013.JPG
ID:	2130687   Click image for larger version
Name:	meister 17 014.JPG
Old 11-15-2015, 07:45 AM
  #100
TonyBuilder
Progress.
The third hinge with the bearings and the two control arms are test fitted to the elevator.
I have adjusted the hinges and I am gluing them in with gorilla glue as I like the expansion action it offers.
Once this sets up I will do the other side, then the elevator's, then the torque rod.
TB
Name:	meister 18 001.JPG
ID:	2130714   Click image for larger version
Name:	meister 18 002.JPG
ID:	2130715   Click image for larger version
Name:	meister 18 003.JPG
ID:	2130716   Click image for larger version
Name:	meister 18 004.JPG
ID:	2130717   Click image for larger version
Name:	meister 18 006.JPG
ID:	2130718   Click image for larger version
Name:	meister 18 007.JPG
ID:	2130727   Click image for larger version
Name:	meister 18 008.JPG
