 Sig Kougar Build >
Sig Kougar Build
Sig Kougar Build
Old 04-24-2013 | 04:17 PM
  #501
Default RE: Sig Kougar Build
Tojeiro 50s by Protech is about the same dimensions and size and shape as a Kougar. The gear is different and it is a tail dragger.
http://www.rcuniverse.com/forum/m_41...tm.htm#4203196
Has anyone assembled one and does it fly similar to a Kougar?
Not being a builder I am looking for a Kougar replacement.
Bill
Old 04-24-2013 | 05:14 PM
  #502
I don't think it would be much like a Kougar. Not to say it wouldn't be a good plane,but it's made quite a bit different.
The Kougar isn't too hard of a build in my opinion. Especially if you leave off the turtle deck canopy and cowl.
That said this might be a little closer,but I havn't owned one yet.
http://www.advantagehobby.com/32528/...0560/?pcat=175
Fred
Old 05-08-2013 | 08:53 PM
  #503
Thanks. I read the entire thread several times and believe the F-20 is a very close to a slightly larger Kougar copy.
Kougar
span 50"
weight 5 1/2 - 6 lb.
wing area 540 sq. in.
wing loading - 23.25 oz. per sq. ft.
F-20 Tigershark - All wood, trike gear, ARF for $139.
span - 56.7"
Weight - 5.7 pounds - probably closer to 6.5 pounds.
Wing area - 687 sq. in.
wing loading - 21.8 oz/sq. ft.
The additional wing area probably helps my aging flying skills.
Bill
Old 05-21-2013 | 12:02 PM
  #504
patniven's Avatar
My Feedback: (36)
Finally finished my second Kougar. I built the first one in 1979, and it's been my favorite plane ever since. OS .46AX with an 11-6 MA prop. Very stable and easy to fly. Couldn't quite stomach the USAF markings (retired Army), so the trim scheme isn't really complete yet. Gotta do something with that tail!
ID:	1884019   Click image for larger version
ID:	1884020   Click image for larger version
ID:	1884021   Click image for larger version
ID:	1884022   Click image for larger version
ID:	1884023   Click image for larger version
Old 05-22-2013 | 01:39 AM
  #505
Why not the F-16 varient for the tail?
I have a NIB Kougar kit that was the first and only RC kit my wife ever bought me. Along with a new K&B .40. Still have the engine, although it has flown many other planes for me.
Is there a Kougar club like there is for the Kadet? I have one of those also along with the Sig 1/4 scale Cub.
Thanks.
Old 05-22-2013 | 01:39 PM
  #506
ORIGINAL: spaceworm
Wonder where one might get a look at this?
Bill
Old 05-23-2013 | 03:18 AM
  #507
My plans show this as an option. They are in storage right now; when I get them out , I will make a copy to send you. I will also look for some pictures I have of the Kougar built that way. Good luck.
Old 05-23-2013 | 03:33 AM
  #508
Here is a picture of a Kougar Kopy: Still looking for my plans.
Old 05-23-2013 | 03:37 AM
  #509
rtf did not work. Sorry. Still looking
Old 05-23-2013 | 05:07 AM
  #510
Um, try that again:
Old 05-23-2013 | 05:21 AM
  #511
Here is the site I found the F-16 varient. Many more pics of the Kougar, Kadet, etc. Enjoy
https://www.google.com/search?q=Sig+...v&sa=X&ei=khOe
Old 05-23-2013 | 06:34 AM
  #512
Quikturn's Avatar
My Feedback: (12)
The smaller Kobra had an F-16 tail variant. I don't believe the Kougar has it. Not to say it can't be done however.
Old 05-23-2013 | 04:11 PM
  #513
ORIGINAL: spaceworm
Thank you.
Bill
Old 05-24-2013 | 03:49 AM
  #514
donnyman's Avatar
Hello
I had them all kobra with retracts kougar, and king kobra with retracts, all were excellent birds.
ID:	1884765   Click image for larger version
ID:	1884766   Click image for larger version
ID:	1884767   Click image for larger version
Old 05-27-2013 | 03:16 AM
  #515
My Feedback: (14)
Here are a few old photos of the last of three kougars I've built. For such a nice flying plane, me and sig kougars
do not get along. I did one flight on this one, then sold it to a club member who really wanted it.
ID:	1886036   Click image for larger version
ID:	1886037   Click image for larger version
Old 09-25-2013 | 02:55 PM
  #516
What didn't you like about the Kougar?
Old 09-20-2014 | 10:54 AM
  #517
pt19 flyer's Avatar
hi submikester
have a kougar kit for many years and hae have never sheeted a foam wing.
what is the precedure for using the spray adhesive? sounds like easier and simpler
than fiber glassing. any advice and suggestion greatly appreciated.
this will probably be a winter project if I get the get-up-and-go and feel adventous,
is that spelled right?
thanks
pt19 flyer
Old 09-20-2014 | 03:15 PM
  #518
PT 19, I used the old version of 3M 77 when I built it, which was quite a few years ago. I sprayed on a light coat on the foam and the balsa sheeting. By the way, I did not use the balsa sheeting that came with the kit as I don't like edge gluing all those narrow little sheets together so I bought some wing sheeting from Balsa USA which made life a bit easier when it came time to sheet the wing.
I don't know about the version of 3M 77 spray on but some people have had success with it.
Maybe some other people will chime in on this matter. As far as epoxy goes I would use West Systems as it is not like those thick gooey hobby versions sold form the LHS. West Systems is a long cure epoxy (24 hr.) and is quite thin in consistency. It does not take much to do the job. As a matter of fact most of it will be removed from the wing panels and leaving only what appears to be a slightly tacky surface.
Others please add your own thoughts on this.
Mine is powered by a Scorpion 3026-10 outrunner on 5S lipo and 10X5 APCE prop. I used a 10X7 in the past but it was drawing way too many amps and actually melted the heatshrink around the speed control.
Good luck with yours.
Old 09-22-2014 | 04:50 AM
  #519
donnyman's Avatar
Hello
Don't be intimidated by the foam wing covering precess it is really a easy thing to do. If I may make a few suggestions.
be sure to fit the sheets edges properly by sanding them straight, them hold them together with tape on one side and lightly apply glue. wipe off any excess, too much glue just makes a mess.
the 3m 77 contact cement works fine and is fast but un-forgiving as it it grabs hold instantly so take time to assure your sheets are in place before laying them down, once together that's it you cannot take them apart. you may want to read up on the technique.
I,ve built and flown all of these birds and they are good flyers but not 3D flyers...................Good luck.
Old 09-22-2014 | 02:25 PM
  #520
Originally Posted by donnyman
Hello
You got that right. The 3M77 really grabs tight. Once its on there it would be the devils own row to hoe to pull the sheeting off. I made sure the sheeting would fit as needed before applying any glue.
Old 09-22-2014 | 05:27 PM
  #521
I used gorilla glue on mine. Might not be the lightest way to go,but it gives you plenty of time.
Just spray the foam lightly with water in a spray bottle (water activates gorilla glue) . Smear the glue around the skin with a credit card.
Pile a bunch of weight on it like the pictures at the front of this thread.
Old 09-22-2014 | 06:03 PM
  #522
My Feedback: (60)
Anybody have plans for the Kougar that they would be willing to part with? Or have scanned even? I would love to blow the thing up to about 80-85 inches.
Old 09-23-2014 | 07:28 AM
  #523
An 80" Kougar would be an awesome plane to have!
put me down for a set of plans if anyone ever finds some...
Id prefer built up wings but...
BilL S.
Old 09-24-2014 | 03:01 PM
  #524
My Feedback: (60)
BilL S.
I don't do foam Bill so the wing would definitely be built up. Nobody has stepped forward with the offer of any plans though. May have to just "wing it" athough I would like to at least have a copy of the airfoil used on the original.
Old 09-25-2014 | 03:57 AM
  #525
Hi, I have a NIB Kougar. If I can find it in storage, I will, at least, scan the airfoil for you. If I can I will scan the plans also, but, I think some of the parts are on printwood.
Sincerely, Richard
