 eagle 2 mods >
eagle 2 mods
eagle 2 mods
Old 11-15-2008 | 02:58 PM
  #51
Default RE: eagle 2 mods
ok well ill keep you informened on that.... the plane at this point weighs 9.978 lbs now its recamened weight is like 5 um with the added weight wqill the plane still fly well i do have a 60 in a 40 plane. and added strength.
Old 11-15-2008 | 04:29 PM
  #52
At 10 pounds, I wouldn't add any more stuff to it. You definitely have enough sheeting, in the tail alone. The light ply fuselage is quite strong just the way it is. If you have already added the bomb drop, that's the farthest I would go on this. No more. Excess weight equals a narrow flight envelope, with unforgiving stall tendencies. Get it covered, install your OS 61 FX, add skis, and go see how it works.
NorfolkSouthern
Old 11-15-2008 | 05:05 PM
  #53
ok well thanks.
Old 11-15-2008 | 06:04 PM
  #54
Your wing loading is probably going to come in at around 28 ounces per square inch at this point. It will be very interesting to see what this plane's glide ratio will look like. If the 61 FX doesn't seem to provide quite enough power, then you could opt for a 75 AX, which would fit the same bolt pattern yet offer more power. Larger wheels would also help accomodate a larger prop, and that may help put more air over the back control surfaces and offer more torque. You will definitely benefit from the use of the flaps. A large prop and lower "gear ratio" coupled with a stump-pulling engine is what gives a 3D plane the capability of flying below stall speeds. That, and the thicker airfoil with larger control surfaces, of course. In your case, I think you'll want tractor-like accelleration and enough muscle to to get that freight to its destination with adquate airspeed .
http://www.alaskawings.com/images/Carvn04.jpg
NorfolkSouthern
Old 11-15-2008 | 06:21 PM
  #55
cool
well i was not talking full 3d i was thinking like torque rolls and like inverted spins thats like the max id do im a sisy when it comes to putting my babies in harm lol .um as for bigger tires im already at 5 inches and there heavy.
Old 11-15-2008 | 06:36 PM
  #56
I think the big tires can add some clearance for a 13 x 8 three-blade prop, which I am sure an engine like the 75 AX could drive without much difficulty. It may be the best compromise between clearance and air movement. Be sure to consult with the manual that comes with the engine, as for a 3-blade you'll step down an inch in length and pitch. Besides, I am sure the plane will look better.
NorfolkSouthern
Old 11-19-2008 | 10:26 PM
  #57
well i moved some stuff arond to compensat a little for the heavy engin in the CG. i moved them back far and i made a door at the rear. i also did some weird stuff with fule line out lets
ID:	1075349   Click image for larger version
ID:	1075350   Click image for larger version
ID:	1075351   Click image for larger version
ID:	1075352   Click image for larger version
ID:	1075353   Click image for larger version
ID:	1075354   Click image for larger version
Old 11-19-2008 | 11:49 PM
  #58
You are going to have to secure that green line fuel filter. I'm sure you thought about that. Just a reminder.
Did you consider lengthing the wing by adding additional wing bays? I hope you didn't mention it and I missed it in my reading of the thread.
Old 11-20-2008 | 05:46 PM
  #59
i did think of that i was thinking to extra bays to add something like 4 inched bolthsided but how can i do it while keeping the wings strong anuf for flihgt and with the wings l.e. being a peace of dowl how do i lengthin that. alersons i can just make soo no worries there. oh and i already thoght about the securing for the fule lines but i havent come up with a 100% sure way any sugsetions. at this point this build has gone for sooo long and i just wana cover it but soo much arises that i need to deal with. next kits i think wont be too bashes mabie scale lol .....[8D]
Old 11-20-2008 | 08:12 PM
  #60
I'm not trying to talk you into anything here.
Think it over before you attempt anything.
Cut the wing tip off one and a half bays in from the tip of the wing .... in the middle half way between the ribs.
Take the tip piece of the wing, pin it to the bench.
Now butt all the pieces that you need to build the extra bays together, to the tip that is pinned to the bench and build the extra 2 bays.
Epoxy a length of dowel rod that is one bay wide to the back of the end of the dowel that will be re-attaching to the wing.
Do this to all pieces that you cut off the end of the wing. Not with dowel rods but with pieces like the ones you used to build up the extra bays.
Butt the new end pieces that you have created against the wing that it was cut from.
Pin the wing flat against the new piece and epoxy the dowel rods together and zap the other extended pieces together.
It should be straight and even stronger than the rest of the wing.
It took me longer to write this than it takes to do it.
Ron
Old 11-21-2008 | 08:29 AM
  #61
ok i think i get what you mean soo i think ill do it thanks for the help ill post pics as i complete it so you can tell me if im doing it right.
Old 11-24-2008 | 09:17 AM
  #62
Just thought I'd show you what I did with the wingtips on mine. I didn't change the span at all, but I never liked those plastic tips that came in the kit. The last pic is what I did with the tail after seeing yours.
ID:	1078142   Click image for larger version
ID:	1078143   Click image for larger version
ID:	1078144   Click image for larger version
Old 11-24-2008 | 02:38 PM
  #63
awsome work ive never liked the tips eather so i dont bother with em. i think im not going to do the wing tip extentions i already cut the alerson and its to much work for me im only a novist at best. im still waiting on my covering to come my local hobbie shops slow when it comes to dealing with sig. still fun times building. any pics of home made skis anyone at all.????? hmmmmm!
Old 11-24-2008 | 04:11 PM
  #64
My LHS is slow when dealing with SIG. They always warn me of that in advance.
Usually when you order from SIG online it is quick.
Doesn't make sense.
Seems like they are trying to eliminate the LHS and do processing online.
Ron
Old 12-03-2008 | 12:58 PM
  #65
sorry there hasnt been any pics or info latly i havnt done much ive been running low on cash soo i put it on the back burner plus im still waiting on my covering stupid hobby shoped its like they dont care. anyways still looking for any pics at all.
Old 12-03-2008 | 05:08 PM
  #66
Don't blame the hobby shop. I owned and operated one. They order the stuff and the distributer sits on it. THey say it is being shipped right now or tomorrow or it isn't in stock but will be in soon.
The LHS owner feels just as bad as you do because he really does want your business.
I feel sorry for you and the LHS owner/operator.
LOL
Old 12-03-2008 | 05:42 PM
  #67
i know your right its always this way when i want sig parts.
Old 12-05-2008 | 08:54 PM
  #68
well i have desided to just cover useing monokote i desided id do the same at the other eagle but with some alterations im useing flat olive drab, dove greay, and mistle red red, i also got some canadian decals to put on the sides itll be a sexy plane when im done just alot of finish sanding now. i also bout the same gear and wheels for my other eagle and some great planes .40 size floats for the old eagle that is. oh man i cant wait to test fly that plane or at least thats what im saying now once i get to that point im sure ill be to scared of damageing it. also i desided to paint the landing gear and the control horned red to match the new cone and red covering. ill have to take great pride in the covering i want the best finish i can acheeve.
Old 12-05-2008 | 08:56 PM
  #69
i love bush flying with rc planes i wana do this so much http://www.youtube.com/watch?v=s_nv0...eature=related its so cool.
Old 12-05-2008 | 09:26 PM
  #70
Nice job! I fully enjoyed it.
Old 12-07-2008 | 06:36 PM
  #71
lol i love this build i have so much extras that the eagle shouldnt have today i desided to add a weird little like cover to the electronic s door to make it look as if its a cargo door. i keep it on with the same screws as the windsheild and i made a handle out of a nuckle joint on an rc car. well here are some pics so you can understand better.
ID:	1085710   Click image for larger version
ID:	1085711   Click image for larger version
Old 12-08-2008 | 01:11 PM
  #72
sooo i think ill modifi a few more things with the eagle[8D]. i want to add a tow point at the rear for madder wouing i just dont know how soo help would be nice other then that just touch ups and some stuff to do with beefing up the wings a little bitt you know add some here lill there and bam a sexy plane. i still can deside what covering so im going to wait it out and the plane will eventualy tell me lol. oh for the old eagle shes not done yet ive desided to add floats and head to a friends cottage im building some great planes .40 size ill post pics. i need to modifie the mouning points a little and i bout some big tires to so my friends can fly bush with me. damn im so stoked for this all to be done and i can spend my days off work flying.
Old 12-08-2008 | 02:58 PM
  #73
What is madder wouing? I believe that the Tow point should be around the CG, not the tail.
Old 12-08-2008 | 09:27 PM
  #74
lol thats what happens when i type to fast, lol.... i think its mounting point
Old 12-15-2008 | 11:22 AM
  #75
just a quick up date everything is final saneded and taken apart awaiting covering soo it could take a bit
