Electric Osmose Building
Old 10-23-2007 | 10:35 AM
najary's Avatar
Default Electric Osmose Building
For those of us who have no building experience, Here are some pictures:
ID:	788715   Click image for larger version
ID:	788716   Click image for larger version
ID:	788717   Click image for larger version
ID:	788718   Click image for larger version
Old 10-23-2007 | 10:49 AM
najary's Avatar
Default RE: Electric Osmose Building
more
ID:	788721   Click image for larger version
ID:	788722   Click image for larger version
ID:	788723   Click image for larger version
ID:	788724   Click image for larger version
Old 10-23-2007 | 11:17 AM
najary's Avatar
more
ID:	788739   Click image for larger version
ID:	788740   Click image for larger version
ID:	788741   Click image for larger version
ID:	788742   Click image for larger version
Old 10-23-2007 | 11:22 AM
najary's Avatar
more
ID:	788753   Click image for larger version
ID:	788754   Click image for larger version
ID:	788755   Click image for larger version
ID:	788756   Click image for larger version
Old 10-23-2007 | 11:28 AM
najary's Avatar
more
ID:	788763   Click image for larger version
ID:	788764   Click image for larger version
ID:	788765   Click image for larger version
ID:	788766   Click image for larger version
Old 10-23-2007 | 11:33 AM
najary's Avatar
more
ID:	788768   Click image for larger version
ID:	788769   Click image for larger version
ID:	788770   Click image for larger version
ID:	788771   Click image for larger version
Old 10-23-2007 | 11:39 AM
najary's Avatar
more
ID:	788784   Click image for larger version
ID:	788785   Click image for larger version
ID:	788786   Click image for larger version
ID:	788787   Click image for larger version
Old 10-23-2007 | 11:44 AM
najary's Avatar
more
ID:	788789   Click image for larger version
ID:	788790   Click image for larger version
ID:	788791   Click image for larger version
ID:	788792   Click image for larger version
Old 10-23-2007 | 02:41 PM
very nice pic[8D]
Old 10-25-2007 | 04:49 AM
Great stuff, look forward to more of your instructional photies.
Old 10-25-2007 | 04:57 AM
ram_z's Avatar
Hi
Najary.
Nice crocs you have
Waiting for more pic's!
Ram
Old 10-25-2007 | 05:38 AM
amram's Avatar
I think it is a great opportunity for the entire RC F3A community to learn how a top F3A master, 30 years in F3A,
build his new F3A ship. I will not exaggerate if I say that Itzik is one of the world top F3A builder and for him
F3A ship building is a science by itself. Itizik, please keep up the photos documentation.
I am confident that this post will become an essential masterpiece for any F3A Pilot.
Amram
Old 10-25-2007 | 12:50 PM
najary's Avatar
more
ID:	790125   Click image for larger version
ID:	790126   Click image for larger version
ID:	790127   Click image for larger version
ID:	790128   Click image for larger version
Old 10-25-2007 | 01:09 PM
najary's Avatar
more
ID:	790137   Click image for larger version
ID:	790138   Click image for larger version
ID:	790139   Click image for larger version
ID:	790140   Click image for larger version
Old 10-26-2007 | 06:49 AM
jnp
Very nice work !! Thanks for the pics . Have also done a lot of scratch building ( for the past 30 years ) and doing it very much the same way . Roly and myself were discussing the reason for the ply on the back of the wingtip ....something I don't do on a patternship. Do you do this to strengthen the tip ? One of my friends does the same on his pylon racers where the L/E tappers down to a very thin edge
Brgds
Juan
Old 10-26-2007 | 11:14 AM
najary's Avatar
ORIGINAL: jnp
Brgds
Juan
Thank you Juan
Yes, the reason for the ply is to strengthen the tips, I try to build the ship that it will look like new one after hundreds of flights. According to my experience, sometimes the tips are damaged during transportation.
Isaac Najary
Old 10-29-2007 | 12:44 PM
najary's Avatar
more
ID:	792875   Click image for larger version
ID:	792876   Click image for larger version
ID:	792877   Click image for larger version
ID:	792878   Click image for larger version
ID:	792879   Click image for larger version
ID:	792880   Click image for larger version
ID:	792881   Click image for larger version
Old 10-29-2007 | 12:59 PM
najary's Avatar
more
ID:	792899   Click image for larger version
ID:	792900   Click image for larger version
ID:	792901   Click image for larger version
ID:	792902   Click image for larger version
ID:	792903   Click image for larger version
ID:	792904   Click image for larger version
ID:	792905   Click image for larger version
Old 10-29-2007 | 01:18 PM
Hi Najary,
This is great stuff, I am also busy with the ailerons, obviously not as quick as you though . What gap do you allow between the ends of the ailerons and the wing i.e. where you have marked off on the wing for sanding/cutting?
thanks
Roly
Old 10-29-2007 | 02:13 PM
najary's Avatar
ORIGINAL: rolyjr
Hi Najary,
thanks
Roly
Hi Roly
The marking is 2.5mm from the wing tip, that allows 0.9mm gap after gluing the 1.6mm balsa sheet.
Isaac Najary
Old 10-29-2007 | 10:18 PM
Thanks Isaac, assume that with a 0.9mm gap the covering will take up about 0.4. As a matter of interest, did your angled balsa (hinging) come out straight from the box. Of the ones I have, two are scrap as they are warped so will have to make new ones. I figured drawing a line down the middle of new stock and marking the angle on the ends, then sanding and checking with a straight edge is the way to do it. Am I on the right track, any suggestions. Thanks
Roly
Old 10-30-2007 | 02:09 AM
najary's Avatar
ORIGINAL: rolyjr
Roly
Hi Roly
Mine came out straight from the box.
I suggest using the straight angled balsa on the wings/stabs (not on the ailerons/elevators).
Glue on the ailerons/elevators a new balsa sheets, about the same thickness as the original spars.
At first sand it flush with the ailerons/elevators skins, and then sand the triangle shape.
Goog luck.
Isaac Najary
Old 10-30-2007 | 12:35 PM
najary's Avatar
more
ID:	793596   Click image for larger version
ID:	793597   Click image for larger version
ID:	793598   Click image for larger version
ID:	793599   Click image for larger version
ID:	793600   Click image for larger version
ID:	793601   Click image for larger version
ID:	793602   Click image for larger version
Old 10-30-2007 | 12:49 PM
najary's Avatar
more
ID:	793604   Click image for larger version
ID:	793605   Click image for larger version
ID:	793606   Click image for larger version
ID:	793607   Click image for larger version
ID:	793608   Click image for larger version
ID:	793609   Click image for larger version
ID:	793610   Click image for larger version
Old 10-31-2007 | 01:47 AM
najary's Avatar
more
ID:	793982   Click image for larger version
ID:	793983   Click image for larger version
ID:	793984   Click image for larger version
ID:	793985   Click image for larger version
ID:	793986   Click image for larger version
ID:	793987   Click image for larger version
ID:	793988   Click image for larger version
