RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Old 02-21-2013, 03:28 PM
  #6501
InDaTube
InDaTube's Avatar
Default RE: RC Surfer
First I removed the original brass tube for the fin/rudder shaft. Next I installed a #33 brass tube as a replacement. Then I fabricated a cross drilled bearing from a #32 brass tube. The #32 slips perfectly into the #33 that is now perminently installed, strong and water tight. Now I have a replaceable, slip in bearing that retains grease in the cross drilled holes. Eight holes in all. Now, all I do is grease up the bearing and install the fin.
Bingo.....
If this works well, the next time we build a stuffing tube for the flex drive / prop, we can use this idea as well. Big advantage is extra grease retension where you need it most and when it wears, just reach in with a small hook, pull it out and replace!!!!
In summary: #32 bearing slips into the #33 tube installed in the board. From there you just grease and install the fin into the #32 bearing .... Add water/waves and rip.
Larry
Old 02-22-2013, 07:41 AM
  #6502
RC HAWAIIAN STYLE
RC HAWAIIAN STYLE's Avatar
ok now i get it
Old 02-23-2013, 04:03 AM
  #6503
bearcave
tube
hmm nice a rudder bearing greasy bush..... post 4999 on page 200 has more thoughts as well....
thinkin drilling the holes espec on a long bush/bearing may be a pain but.... do you have any tips i'm keen to try a long one in a strait shaft with many many holes?
maui john
I had a light lunch... barfing thoughts moderate fitting parachute high when strapped in.... after finally giving myself to the gods of death it got better.... kindof.......next time i get a map of manouveres which will help but first time takin off on the biggest one ever is always the hardest hey...
btw i took "helmet cam" for more vision/editing practice of my time at the airport..... just before it was my time to feel sick inside the coffin oops cockpit..... lol.... an 11min vid prob more suited to aeroplane heads but the engine noises are good and there are at least two donkeys....will try to load up the cyberything link soon
bc
Old 02-23-2013, 04:09 AM
  #6504
bearcave
[youtube]http://www.youtube.com/watch?v=TqOkdsWNo4w[/youtube]
Old 02-24-2013, 02:47 AM
  #6505
bearcave
Propeller tubes.....
I was thinkin if you had a stainless outer tube mounted solid in a board it could be the tube the other wearable brass/bronze tubes could be inserted into..... i think K-H2o already does this..... apart from a way solid permanent fixture the extra weight could add to the self righting as well.
Anyway if a permanent staino tube was part of the board.... all types of drive scenarios could be fitted then easily removed for bearing replacement or solid to flex drive hey whatever.
So my question is.... what kind of glue/silastic/loctite could be used to provide a seal but still be able to be heated (or whatever) to release the worn bearing tube from the staino permanent tube easily for replacement?
Obviously running thrust point at the prop end of the tube would need more design thoughts (maybe run thrust washer system bearing on outer tube) but thinkin something solid as part of the board and easily replaceable wear bits maybe good for a long and repairable life for a board...
and maybe its already been sorted and i missed the post...... lol
regards bearcave
Old 02-24-2013, 08:06 AM
  #6506
InDaTube
InDaTube's Avatar
Bear....
This style of stuffing tube / bearing combo is part of MJ's "Magic" Maui******** design. The only thing I'm tinkering with is cross drilling the removable stuffng tube bearing. MJ sweat solders the two together making replacement possible.
I saw these cross drilled bearings on HobbyKings site, but I fabracated one up myself. I'm hoping for better grease retention in the all important bearing surface.
InDaTube (Larry)
Old 02-24-2013, 08:47 AM
  #6507
YPC
YPC's Avatar
[youtube]http://www.youtube.com/watch?v=NI_tyysaZGM[/youtube]
[youtube]http://www.youtube.com/watch?v=O8UCxJFLhGE[/youtube]
Bro ********. ...
Share the STOKE !
http://www.rcuniverse.com/forum/m_11...m.htm#11411721
Old 02-24-2013, 10:26 AM
  #6508
jocktime
jocktime's Avatar
How to film RC Surfing with a Copter and GoPro
Instructional video by maui********
http://www.maui********.com/index.html
Old 02-24-2013, 05:31 PM
  #6509
RC Resinator
RC Resinator's Avatar
My latest board shown here, measuring 48"...brilliant, or crazy?
RC Resinator
Old 02-24-2013, 05:44 PM
  #6510
Saildoggie
Saildoggie's Avatar
Wow, been busy and away from here for a while, that is awesome, what size motor and battery are going into that?
Have you made a figure yet?
We are getting into what, 1/2 scale now?
Old 02-24-2013, 05:46 PM
  #6511
Saildoggie
Saildoggie's Avatar
ORIGINAL: jocktime
Whoa! I am sure the Go Pro is OK, did you waterproof any of the copter stuff first?
Old 02-24-2013, 05:47 PM
  #6512
jocktime
jocktime's Avatar
Resinator,
Go with it, always wanted to build one that big.
Keep us updated.........jock
Old 02-24-2013, 05:56 PM
  #6513
InDaTube
InDaTube's Avatar
Very interesting and cool.......
I'm going to have to re-calibrate my brain to take it all in.....
Tell us more about your plans for this project.
I would love to come over and see it in person.
InDaTube
Old 02-24-2013, 05:58 PM
  #6514
jocktime
jocktime's Avatar
Saildoggie,
Actually we even forgot to put the GoPro in the waterproof case.
That is why no video from the Copter. John was able to save most of the running parts
it seems to be very durable. Everything is now fixed and ready
to try again. John is getting alot better with the copter after a few runs with Karl
who is very experenced with copters giving him some tips...........Long runtimes, jock
Old 02-24-2013, 06:11 PM
  #6515
RC HAWAIIAN STYLE
saildog
good to read your post ,, the ESC were toast,, and the batt, puff daddy ,, but saved the motors and frame,i will be flying in no time LOL
Resinator [/b]
that thing is enormous,, maybe a weed whacker motor,,,,a big weed whacker motor,,,
ps [/b]can i ride on that thing[/b]
Old 02-24-2013, 07:13 PM
  #6516
K-H2o
Hi Guys Here are is the parts list for my drive shafts, It is nessesary to use a lathe to cut down diametersto make things fit togather. adrill and a file could beused if you are handywith it. and a 4mmream isneeded and a die to cut the threads on the end. thisisfor the small 26" boards. May not be a help if you arn'tin the US ordont have the tools.
http://www.mcmaster.com/#catalog/119/1123/=lmij2e
http://www.mcmaster.com/#catalog/119/153/=lmile2
http://www.mcmaster.com/#stainless-s...shafts/=lmimd2
John-Quadcopters don't swim as good as surfers.Saildog- Great to hear fromyou!!!!!Jimi-Hope you are doing good !!!!
Resinator-On my 40"board 10" wideI put a Leopard 4082 1000kv and on 6 cells it goes around 30mph
Aloha, Karl
Old 02-24-2013, 08:56 PM
  #6517
RC Surfer
A little input on stainless steel. While working on a Hydrogen generator we use stainless steel as our electrolis plate to split water molecules into Hydrogren and oxegen atoms in a sodium hydroxide solution and found that 304 Stainless wasn't all that it was suppose to be,"corrosive resistance", but found that 316 Stainless was 100 times more resistance than 304. So if you can find what you need in 316 Stainless it's worth looking into.
Hope it helps, Later BB
Old 02-24-2013, 09:41 PM
  #6518
InDaTube
InDaTube's Avatar
Hi John,
Sorry to see the ........... problem with the copter!!!!!
Here is a photo of the conversion I did for Mark's rudder arm........
Old 02-25-2013, 01:13 AM
  #6519
bearcave
K-H2o Karl....
someone into surfing shaping AND the mechanicsof driveline'smoving surfers and custom radio systemsseems unusual in general land lol but all good imo... thanks for the info.
i'm havin a go this year to build one..... here is a pic of rough cut 28"x 8.5" shape compared to my nqd and kyo... may pull the nose in and lower the wide point yet depending on rocker etc.....but atmstill keen to runa solid shaft.
btw i've also heard that 316 staino has the best corrosive resistance......love the copter vision too lol
regards bearcave
Old 02-25-2013, 07:52 AM
  #6520
oliveDrab
oliveDrab's Avatar
ORIGINAL: YPC
Bro ********. ...
Share the STOKE !
My only R/C interest is planes, not boats, not cars. BUT - I gotta tell ya - that RC Surfer Dude is awesome. Really cool to watch. Thanks for sharing.
Can the Surfer Dude move along the board? Hang ten?
Old 02-25-2013, 10:49 AM
  #6521
RC HAWAIIAN STYLE
making progress on new surfer
[/b]ypc;;; looking good[/b]
[/b]
ID:	1856198   Click image for larger version
ID:	1856199   Click image for larger version
ID:	1856200   Click image for larger version
ID:	1856201   Click image for larger version
Old 02-25-2013, 11:13 AM
  #6522
InDaTube
InDaTube's Avatar
MJ
Looks fantistic.......
I'm starting to get visions of InDaTube II
Keep us posted
Larry
Old 02-26-2013, 12:01 AM
  #6523
bearcave
MJ
I was wondering if you might share your thoughts onthe swept down tail on the new deck..... could it be for flexing strength in wipeouts regarding water intrusion or simply just better stylin..... whatever i like it..... like your latest two vids too YPC
bearcave
Old 02-26-2013, 07:29 AM
  #6524
RC Resinator
Saildoggie - I think the 48' surfer is going to start with 2 6-cell 5000s wired to produce 6-cell power with 10,000mhs. One of the reasons I went big is to hold more batteries. more run time , more power, more FUN!  i have started on the man but still trying to get a grip on how big he needs to be. The doll is always the hardest part for me. Get ready for another Frankenstein.
K-H20- Thanks for the info. I have a 38'model that runs on 5-cells, man is it fast! Any Ideas on prop size?
Larry- Thanks for interest . get my phone number from John, and I will give you a look.
Jock- I have been thinking of this build since i got started in rcsurfing. I can't wait to see what it will perform like! Thanks for the support.
John-If you can stand up on this pig it's yours! weedwacker motor... not a bad idea.lol . Your new model looks unreal.
Aloha,
           RC RESINATOR
Old 02-26-2013, 09:30 AM
  #6525
RC HAWAIIAN STYLE
bc
i wish i did not have to put the hump step down thing ,, but i have to fit a five cell batt. in there,,, and it works good
for the control rod for the fin ,, i would like to streamline the hump out but the batt would not fit,
you have a good eye,, most people would not notice that,,
maui john
