 An Exercise in Install Practice.... >
Old 05-07-2013 | 06:13 AM
  #76
marc s's Avatar
Default RE: An Exercise in Install Practice....
BVM Mig15
ID:	1879928   Click image for larger version
ID:	1879929   Click image for larger version
ID:	1879930   Click image for larger version
Old 05-07-2013 | 06:20 AM
  #77
marc s's Avatar
CARF Euro
ID:	1879933   Click image for larger version
ID:	1879934   Click image for larger version
ID:	1879935   Click image for larger version
ID:	1879936   Click image for larger version
Old 05-07-2013 | 06:57 AM
  #78
Very nice.
I like you to come here for vacation. I got fishing boat need your nice install.
LOL
Old 05-07-2013 | 07:01 AM
  #79
marc s's Avatar
Tam you make the pipes I will do the instal on your fishing boat
marcs
Old 05-07-2013 | 07:09 AM
  #80
marc s's Avatar
PC21
ID:	1879943   Click image for larger version
ID:	1879944   Click image for larger version
ID:	1879945   Click image for larger version
ID:	1879946   Click image for larger version
Old 05-07-2013 | 09:54 AM
  #81
My Feedback: (61)
Biggest issue i see is running Futaba
Old 05-07-2013 | 10:46 AM
  #82
mr_matt's Avatar
My Feedback: (10)
Hi Marc,
Looks wondersfull, what did you use for adhesive on that UAT?
Old 05-07-2013 | 11:51 AM
  #83
marc s's Avatar
Matt, no adhesive, the UAT was held by a clear piece of heatshrink you can just see around it, under this is also sandwiched a piece of thin glass board (you can just see the yellow at the base) which was slightly larger than the UAT top and bottom, this was screwed to the lite ply plate underneath.
Now naturally I use the CAT which has its own simple mounting
marcs
Old 05-07-2013 | 03:40 PM
  #84
My Feedback: (106)
Marc. You make me sick. Lol. Your installs alone are a work of art. Thanks for sharing.
Old 05-07-2013 | 06:33 PM
  #85
My Feedback: (13)
Just had a flameout this weekend 4 mins not first flight. Only thing I could tell from the ECU was that it was not audio related. Anything look out of sorts? With modern components its pretty simple and there really isn't all that much in there so don't know where i could have gone wrong.
Old 05-08-2013 | 06:11 AM
  #86
AndyAndrews's Avatar
ORIGINAL: TUMBLER
I noticed that your fuel lines are not safety wired. You may be getting air leaks. Can't really tell much from the pick on the rest of the install.
Old 05-08-2013 | 06:15 AM
  #87
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: TUMBLER
What did the ECU log as the reason for the shutdown? Install looks good, nothing standing out. We would need more detail to source the cause... Last off condition in the ECU would be a good start.
Old 05-08-2013 | 06:27 AM
  #88
My Feedback: (13)
I have a k100. I tried to figure ut the cause but all I could find on the ecu was that it said no radio failure. I can't figure out how to get any additional info.
ORIGINAL: lov2flyrc
ORIGINAL: TUMBLER
Old 05-08-2013 | 12:15 PM
  #89
DrV's Avatar
DrV
Almost done with a bvm Bandit MK II with a p100. Two A123 batteries directly plugged into the RX.
ID:	1880275   Click image for larger version
Old 05-08-2013 | 05:28 PM
  #90
lov2flyrc's Avatar
My Feedback: (24)
Nicely Done DrV!
TUMBLER
After each cycle of operation, the FADEC stores the last cause of shut down and the values of RPM, temperature and pump power at the moment of shutdown. In order to access these measures,
Set the trim down (TrimLow) and push the left button on the Data display. The FADEC will display the cause of shutdown and the measured values at the moment of shut down. This will provide the last off condition, if you have attempted another start since the flame-out, the needed data is gone from display be stored in the ECU.
During engine operation the FADEC measures and stores all the engine operating parameters recorded during the last the 51 minutes of operation in .5 sec intervals. These measures can be downloaded to a PC to study the behavior of the engine in flight or to email the file for us to diagnose any possible problems. You would need the FADEC USB cable to download the data.....
Todd
Old 05-08-2013 | 06:05 PM
  #91
My Feedback: (13)
Thanks Todd. Ok this is what I get when I do what you said. This tell you anything? I am going to go get my manual.
Brian
ORIGINAL: lov2flyrc
Nicely Done DrV!
TUMBLER
Todd
Old 05-08-2013 | 07:04 PM
  #92
My Feedback: (16)
[img][/image
This is a tentative arrangement of components in my Airworld Hawk. I've built 3 other jets successfully but always looking for new and better ideas. Constructive comments appreciated.
Components in pics Switch panel
Jetcat fuel pump
AR12120 rx
Ar X-plus
TM telemetry
GPS Sensor
Jetcat telemetry sensor
(2) JR 370A gyros Ail Rud
Jetcat ECU
Jet-tronic air valves
TX
K.O.
ID:	1880367   Click image for larger version
Old 05-09-2013 | 04:02 PM
  #93
DAN AVILLA's Avatar
My Feedback: (12)
BVM Bandit ARF Dan Avilla
ID:	1880634   Click image for larger version
