** Digitech Central Telemetric Unit for Jeti **
#106
My Feedback: (10)
The first "question mark" was a message re: RX signal, second is the funny "X1" next "X100" then finally a turbine shutdown.
I presume the "x1" and "x100" are not from CTU based on your comments .. but I'll keep looking!
I really like the CTU .. keep up the great work!
Dave
Dave
can you send me your log thru Email? want to have a look in the Jeti studio ;-)
no the X1 and the X100 are not CTU based
#108
Sandro and Carsten... If you are designing a device to measure ECU battery consumption, please note that most of the new ECUs go through cool down process when the receiver has been turned off (I.e. no power to CTU)
My Feedback: (14)
Hi CTU fans. I just spent a few hours on the test stand with a Merlin 200XBL turbine (with the brushless/digital pump) connected to the CTU.
My goal was to find the correct fuel consumption calibration number (Pump Factor), which for this setup I estimate to be 46.
Details:
I had flown the CTU (and really like it!) and found the suggested pump factor of 200 to be reporting waaaay to little fuel consumption. With Gapsar's "Telemetry 1" adapter or his Flight Computer, he suggests a default of 200. Just as Sandor does. With the Xicoy Tele-1 and FC devices hooked to the 200XBL I found that the more correct number was 185-187 .. so the 200 setting was conservative .. so that is sensible.
Clearly something very different is going on with the CTU's calculation (which is just fine .. they never stated compatible fuel factors with the Gaspar units).
After several calibration runs (as outlined in the CTU's manual) I'd say that the correct pump factor for this motor on the CTU is approximately 46 (perhaps +/-2) .. it repeated on two calibration runs and reports not only the 1L "measured mile" correctly as in the manual, but it also gets the total fuel consumption within a few percent from before startup to after shutdown when compared to the weight change of the fuel tank. I used Sandor's 0.8Kg/L fuel density number.
I was using a BVM UAT, all 1/8" (3.2mm) ID tygon on the inlet side, the usual 4mm clear tubuing on the pump output, and a 3S LiFE ECU battery.
I would be curious if others have also determined similar factors. Perhaps it is very different for the old DC motors and the brushless digital pump?
Dave
Details:
Dave
#113
Details:
Dave
Details:
Dave
Regarding the pumpfactor (fuelfactor for projet/jetcat and AMT), the default values are all from testsetups of various engines. However, the pumpfactors will vary between engine types (within the same brand) and also between setups (restrictions, tube diameters etc) so there is nothing wrong with the value being (far) off from the default value. I have some numbers from different setups (primarily from local friends that have installed the CTU in different planes/engines) and will try and make a list of whats being used around the world.
BTW, there is nothing (whatsoever) similarity between what pumpfactors are being used in other products, the algorithm I use in the CTU is fine-tuned to give good results for all engines (so far) that we know of.
It even corrects the fuel consumption numbers from jetcats and projet even though they calculate the fuel consumption directly in the ECU. This however, is with a large error which the CTU can correct for (a couple of days ago a JetCat P200SX was corrected by 13% by the CTU to get the fuel consumption spot on. I'm not sure there are that many other telemetry units on the market that does this, and at the same time supports pretty much all engines available. Regarding "all engines", 3 more brands are now creeping into the CTU, one of them already done (awaiting more testing), the next two will enter the CTU codebase shortly
More info when they are done and tested!
#114
My Feedback: (14)
Thanks Carsten. Just to be clear, I did not expect that the CTU calculations were the same as, or compatible with the numbers used by Gaspar's devices. And I am sure it will vary by specific engine and installation (that's why I included the setup info) .. especially with the Merlins where some have "classic" DC pump motors and some have the new digital/brushless motors. I just wanted to contribute a number for this one engine.
I have several Jetcat setups with Gaspar's devices (tele1/2/3 or FC) and I'm slowly converting to CTUs (just got two more from Danny last week) so it will be interesting to compare the "pre-calculated" (by the ECU) numbers from the Jetcats to the CTU. FWIW, I have found the Jetcat calculations to be pretty close, at least on the P200 and the P300.
Dave
Dave
#115
Dave
Dave
Its funny with the JetCats and their fuel calculation, I have found that all my P20SX are off by at least 10%, some even 30%, but P160 and P180 I have are all reasonably spot on (maybe 5% or so off).
With the CTU you can however finetune this as much as you like, I have seen a guy with a sense for details getting his close to 1% for the fuel
#116
My Feedback: (14)
Imagine that :-)
I presume it should be a very reliable measurement, especially on the brushless pumps where the ECU can precisely specify the RPM .. since the gear pumps have a specific displacement per rotation and the fuel is not very compressible (though presumably more compressible than water since it "entrains" air so easily).
Dave
Dave
#117
good day
I receive the CTU, follow the manual and this forum to install, I am reading in the DS24 all information coming from the CTU and kingtech 120 g2 with the LUA app can see in the device explorer also can configure the CTU from the transmitter, port configured in Exbus. but I have some doubts.
1. CTU state is 1536 with no change if move the throttle. its ok?
2. in the CTU the red light is flashing fast. its ok?
3. can I connect at the same time the kingtech GSU and the CTU?
Thanks to all and good day
#118
My Feedback: (10)
good day
yes led should be flashing fast that is ok
yes you can connect the GSU at the same time as the CTU it makes no difference. (NOT on some Jetcat GSU!)
you can use a `Y` Lead or a "V" lead depending wich country you come from , its due to a cultural difference we can call it a V or a Y lead :-). right Cartsen?
#119
Hi Yes 1536 is Trim low - turbine off all ok!
you can use a `Y` Lead or a "V" lead depending wich country you come from , its due to a cultural difference we can call it a V or a Y lead :-). right Carsten?
The "cultural differences" is an internal joke between Sandor an me, we have some very interesting emails between a Chinese manufacturer of boards and their interpretation of "right angle connectors". Basically they mounted straight connectors in a prototype board and sent us a picture of it. We replied that the BOM files/specification said the connector should be "right angle", their answer was that in china, "right angle" means straight and the problem (they did not admit it was a fault of theirs) was "due to cultural differences". Go figure....
#120
My Feedback: (53)
I email Sandor but he’s at the Jet Power and probably won’t have time to answer me...
So here the question, I installed a CTU with a KingTech G2 and a Jeti R12 Assist RX....this is my first CTU
All I see if this,
All the app screens selections work fine, got no error except the red light flash pretty fast (could be a problem)
I also have to disconnect the CTU on startup because it just chase around, I did load the Assist software...but still seem to have a power up problem...
All I see if this,
#121
My Feedback: (10)
Good morning from Jetpower..
even from here we give support..
you need to change the special assist firmware
download this : https://www.dropbox.com/s/ult1kzg4ex...ssist.sfw?dl=0
after this rename that file to firmware.sfw
put it on a sd card
insert in the ctu and power it on .
2 leds will toggle
for about 5 seconds and all should work ok.
put it on a sd card
2 leds will toggle
#123
My Feedback: (53)
Well all is good really like this Telemetry device, work fine with the screen set to white background, they are working for the dark one fix as well.....but I’m really impress with Saturday help. Thank you
