Reload this Page >
s/m 1/6 f16 in my hot little hands!
Old 08-21-2014, 09:58 PM
  #1751
dubd
dubd's Avatar
Tor, Awesome pic! Glad to hear you like your JB-220!
Old 08-21-2014, 10:17 PM
  #1752
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Originally Posted by Westwindpilot86
Hey guys, been slowly getting the plane ready for the maiden flight. But I hit a major problem today. I have both my saddle tanks in the bird and was filling them up when all of a sudden the right saddle tanks starts pouring out fuel. It leaked all over the inside of the jet and soaked everything. I quickly pulled the tanks out of the jet and soaked up the fuel inside the jet. I put the tanks on my driveway and got a video for you guys.
In the video the tank is already half full. As you can see as soon as fuel starts transferring to the other tank it starts leaking. It starts leaking through very small little holes. About 5-9 little holes. Enjoy the video.
https://www.youtube.com/watch?v=qiLyzEqci68&feature=youtu.be
dude that **** is simple to fix; first clean tank with alcohol, let it dry then mix up some hysol, spread the hysol over the area, make a nice 1/32" layer of it. Let it dry. Once dry the leak will be gone.
This crap happens on conformal fiber/kevlar tanks, but good thing is that they are easy to repair.
Old 09-06-2014, 08:21 PM
  #1753
Parafinsniken
Parafinsniken's Avatar
I finally made the maiden this summer!
I was a short and scary flight! I tried a few mm flaps during takeoff. The bird lifted off perfect! A few trim click on ailron. Gear up. And one round with 1/2 power on my P180RX. It felt like as on rails.
I decided to increase throttle to 3/4, and lined up for a lowpass. 50-70m away from me I saw and heard the rudder flutter! It was like an horse kick in my stomach! :-(
I throttled down, elevator input to bleed off speed. Gear out and landed!
I have now done as you recommend Tor: Pull-push with the servo installed in the fin!
I have not found time to fly it since!
Shockingly, SM continue to use their patent on their 1/5 F-16!
Also, in all their film clip they fly like hell with the same patent!
What are we doing wrong?
I read an article in latest MAN about flutter on rudder. And how to prevent it to occur!
I can only conclude, the rudder are wrongly designed! Or...?
I can not wait to get it airborne again!
Old 09-06-2014, 09:04 PM
  #1754
dubd
dubd's Avatar
Misunderstanding on my end.
Old 09-06-2014, 11:37 PM
  #1755
MNModels
MNModels's Avatar
Could you please explain your meaning of this statement. No one have seen the 1/5 f16 fin / rudder setup yet.
I would suggest you check installation again. Also check the plastic hinges. Did you make support for hinges - or is it glued with no support. The complete pin hinge must be glued into wood - only hinge should be gap between rudder post and fin trailing edge.
The 1/5 f16 uses wire hinges like f14 , avanti....
Best regards
Old 09-07-2014, 12:18 AM
  #1756
icepilot
icepilot's Avatar
This is probably where I should say "I hate to say I told you so..." - but I don't hate it!! I have told everybody so again and again,
and still people try the SM solution! No matter how tight it feels, the momentum on the rudder under power is just too tough and
the short distance between the rudder axis and the ball on the servo doesn't have a chance holding it during that kind of stress!
Dubd - I believe he has made the changes AFTER the flutter, as he writes that he has NOW done as I recommended and hasn't
had time to fly it after this... and Morne - from an earlier picture it seems like the new hinges are glued in OK.
Anyway, man - don't be afraid to fly it now that you have done this the correct way, it will take any speed and any maneuvering
without a problem when you have done things right! BTW - what is your real name?
Tor
Old 09-07-2014, 01:32 AM
  #1757
Westwindpilot86
Well I am doing what tor said but it still confused me why this flutter happens. Even the scalejets f -16 has the same rudder setup. And it works great.
Old 09-07-2014, 01:56 AM
  #1758
dubd
dubd's Avatar
Tor
Tor, gotcha. I misread his post.
Old 09-07-2014, 09:17 AM
  #1759
Parafinsniken
Originally Posted by MNModels
Shocki, ngly, SM continue to use their patent on their 1/5 F-16!
Best regards
I may have jumped to conclusion, but the 1/5 scale are "out" on YouTube! Showing mounting of wings and fins!
And yes I swapt the pin-hinges with real good quality robart pin-hinges. Even add two more! In total 5 on my rudder!
And yes, I had to build up alot with plywood(real plywood, not bananabox wood! Made a soilid suport with plywood and hysol all the way in full lenght of rudder and fin!
The flutter was brutalt! The whole aft airplane was twisting!
Old 09-07-2014, 09:32 AM
  #1760
icepilot
icepilot's Avatar
Be sure to check the entire plane for any structural damage if you actually saw the plane twisting, make sure the servos and formers
as well as your turbine mount has not been affected
Old 09-07-2014, 10:17 AM
  #1761
Parafinsniken
This is probably !
where I should say ! Just"I hate to say I told you so..." - but I don't hate it!! I have told everybody so again and again,
Tor
I know Tor, my bad! It wount happend again! I will llisten from now on! :-)
No, Im not afraid to fly it! Could not have had this hobby if so! Just too many hobbies! :-P
My real name: Staale
Old 09-07-2014, 10:21 AM
  #1762
Parafinsniken
Originally Posted by ice! All looking goodpilot
Be sure to ch! eck the entire plane for any structural damage if you actually saw the plane twisting, make sure the servos and formers
I have Tor! All looking good!
Actually I reinforced the engine mount from the beginning! Did not trust the bananabox wood supplied! They were also cracked out off the box!:-(
Old 09-07-2014, 02:36 PM
  #1763
Parafinsniken
I'm struggling to upload photos from Dropbox! Anyone knows why?
Old 09-07-2014, 03:53 PM
  #1764
Parafinsniken
https://www.dropbox.com/s/fbnt0unv5k...33445.jpg?dl=0
Old 09-07-2014, 04:06 PM
  #1765
Parafinsniken
I chose to have all function operated from the back hatch. The crossbar swapped with carbon. The "box" made of plywood with carbon look film.
Pneumatic, fuel, I/O and main switch (Fromeco) to be operated from one position!
Batteries from under the nosecone
ID:	2030017   Click image for larger version
Old 09-07-2014, 04:41 PM
  #1766
Parafinsniken
A solid carbon reinforcement together with proper plywood to make a sturdy engine mount. Overkill? Yes, I know! But it did not add many gram. Nor am I loosing my house using these few more bucks!
Old 09-07-2014, 04:46 PM
  #1767
Parafinsniken
Added a tilted plywood tab for better support of the pipe mount. Also adding a layer of leotard to make the plywood surface more sturdy!
Old 09-07-2014, 04:47 PM
  #1768
Parafinsniken
Stiffening the plywood surface with a cloth of leotard carbon-Kevlar.
Old 09-07-2014, 05:17 PM
  #1769
Parafinsniken
UAT, ECU, Pump and filter mounted on a plywood sheet in starboard side of engine. Made a smart patent, need only to loosen one screw to lift out the "Control board".
ID:	2030238   Click image for larger version
ID:	2030239   Click image for larger version
Old 09-07-2014, 07:11 PM
  #1770
pilot tw
Skymaster F-16 1/6 with K210 on Taiwan field last weekend!
http://youtu.be/AlOr8Om8fxw
Old 09-07-2014, 07:15 PM
  #1771
Parafinsniken
Greate combination!
Loving this airplane! :-)
Old 09-08-2014, 04:07 AM
  #1772
pilot tw
F-16 1/6 with K180,
https://www.youtube.com/watch?v=UJ28enJWJ4I&feature=youtu.be
Old 10-20-2014, 04:17 PM
  #1773
Thai Tiger
Thai Tiger's Avatar
Guys, this thread is THE most useful thread for the 1/6 Skymaster F-16, it's also been running now for more than 8, that's EIGHT years.
thanks for all your inputs.
My current project, A G2 Tigermeet with JB220 is on the bench now, slotted for a maiden in February 2015, I'll post photos for anyone that's interested.
Cheers.
Old 10-20-2014, 04:23 PM
  #1774
Parafinsniken
Yes please post photos.
Always greate to see other solutions and tip Thai Tiger!
Old 11-10-2014, 11:28 AM
  #1775
Damo260
Damo260's Avatar
It's been a while since I have posted here I've pulled out the Kingtech 170 out of the F -16 and put the new Jets Munt 200xbl what a difference the Jets Munt 200xbl is small than the Kingtech K-170F. And what a power house of a turbine the F -16 is a monster of a jet now and plus liking tthe fuel economy to go with it after flying for 6mins at half throttle I still have a main tank full so I should be able to fly 8mins.
Damo
