Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Typhoon 2000 (TEMPEST) modifications thread >
Old 02-07-2005 | 10:48 PM
  #251
Default RE: Typhoon 2000 (TEMPEST) modifications thread
Just curious, how do you retain the wing to the tube? What keeps it in place? Thanks for taking the time to answer my silly question.
In Christ,
Joel Chavez
Old 02-07-2005 | 10:51 PM
  #252
rodney tanner's Avatar
GF copies of Gator Canopies Cowls and Cheeks.
Canopy ($15); full cowl & cheeks ($45) or chin cowl and cheeks ($25). I have two clear canopies from Radio South that I don´t need anybody wants them. ($19 each was the RS price).
So far we have 3 canopies, 3 chin cowls, 2 full cowls and 5 sets of cheeks.
Anybody else need anything before I put through the order to the local GF supplier?
Orders will take about 2 weeks. Recommended and most economical shipping would be by registered air mail from Mexico.
NB This in NO WAY attempts to compete with Gator, it is merely a short term solution until Gator deliveries resume (to Get Tempest and other Tk2 projects finished and flying) :-)
Old 02-07-2005 | 11:10 PM
  #253
My Feedback: (10)
I will be interested in 2 cowls. Larry Please pm me.
Old 02-07-2005 | 11:22 PM
  #254
MTK
Various methods Joel. Some use hooks on each root rib, which extend into the wing bay. An oring or rubber bands are then stretched connecting the hooks.
Others locate and tap holes outboard on each wing panel bottom, through the tube, and secure with bolts on each side. Usually a good idea to also add a wood block in the tube to help lock the bolt in place
Yet others simply reinforce the fuse sides a little more and drill through each side into the root ribs. Extra ply is used in the wing at the hole location, and the hole is tapped with a 1/4-20 thread usually. The bolt is installed through the fuse side into theroot rib.
All methods work fine as long as you have it in your set-up routine and you don't miss the securing part. If you forget, then wings have been known to fly off
MattK
ORIGINAL: Rcav8torjc33
In Christ,
Joel Chavez
Old 02-07-2005 | 11:36 PM
  #255
MTK
Bokuda, a more advanced technique if you want the utmost in precision, is to cut the exact shapes you want to mold, into blocks of foam, making both the female and the male parts in foam first. Then wet the balsa really well, for a couple hours at least, until very pliable. Dry it with paper towels and then place the balsa in the "foam mold press" and let it dry overnight. Next night finish the iinstallation. The amount of internal structure this technique needs in very minimal.
Compound curves would be tough to do this way, but simpler shapes that can be accurately cut in foam, make prime candidates for molded balsa sections
For built up wings, the same technique may be used to actually mold the leading edges of the wing or stab. No balsa LE sticks are needed, the accuracy is terrific and the weight is the least possible.
MattK
ORIGINAL: bokuda
I used a combination of these methods on my T2K. I used the "wet sheet" method for the lower part of the turtle deck; I don't remember if I used 3" or 4" sheet. Then I planked the upper part because the sheet tended to split with the small radius there.
Old 02-17-2005 | 02:16 AM
  #256
ata
Hi,
Sig, how is your plane coming? My wings and stabs are almost ready to cover .
ID:	230483   Click image for larger version
Old 02-17-2005 | 03:51 PM
  #257
sigk's Avatar
Hi Attila
I just received the manifold for my engine from Just Engines so I will finish the pipe tunnel next. But there are a few fiber glass parts I like to try out and that is taking up some time.
I really enjoy seeing your plane coming together, nice work.
Old 02-17-2005 | 04:08 PM
  #258
My Feedback: (10)
Any word on Gator Cowls?
Old 02-17-2005 | 06:10 PM
  #259
MHester's Avatar
I haven't heard anything yet. But admittedly, I have my head buried in a new project and haven't asked in a while. I'll see what I can find out.
-Mike
Old 02-17-2005 | 06:35 PM
  #260
ORIGINAL: MHester
-Mike
Did you get those molds done yet? If you would have the time later on, I think it would be great if you would describe the process. Or mostly the plug making process. Lots of info on how to make molds are available, but not much on how to make nice, perfectly symmetrical plugs.
/Erik
Old 02-17-2005 | 08:02 PM
  #261
ramcfarland's Avatar
My Feedback: (44)
Dianna,
Of Gator R/C returned my call.. they now have canopy's ready to ship,But there is a problem at this time I'm told regarding the "cowl mold."
Any one have a full cowl:Tempest or Typhoon 2000 please let me knpw I have Pay Pal or will pay as you request.
[8D]
Old 02-17-2005 | 08:39 PM
  #262
MHester's Avatar
The plugs are not THAT hard, but require a LOT of time and work. I've been working on these since Christmas.
I now have all of the plugs done and waxed, and the canopy and cowl molds complete. All that is left is the belly pan, and it's going to be a mother.
I REALLY have to thank Matt K, but I also have to add that I must have done something right, because the plugs just popped right out undamaged [8D] I only hope the belly pan goes as well.
As far as alignment, well they're good but not perfect. I'm have the first test pieces curing in the molds as I type this, so we'll see. I may be good to go, or I may have to start over on something.
I'll go into detail about making the plugs in a later post. But the finish is crucial, that much I will say up front If it doesn't look like glass, you're heading for a migraine.
-Mike
Old 02-17-2005 | 10:56 PM
  #263
My Feedback: (10)
If anyone has a cowl with cheeks that is uncut I can make a mold off of it and we are back in business. I have made several Fuse molds and fiberglass fuselages and helicopter canopies. A picture is in my gallery
Old 02-18-2005 | 12:02 AM
  #264
My Feedback: (25)
ORIGINAL: MHester
It had better be a BIG can of Raid!!!!
HAHA!
That's great Mike. If you haven't chosen a name for your roach yet, may I suggest Raider?
Old 02-18-2005 | 12:37 AM
  #265
MHester's Avatar
I just think it's funny, maybe just my warped sense of humor I guess. The word "roach" is about to be turned into a battle cry [8D]
As for the sig, I thought it might be time for something a little lighter. And it just sort of fits my mood right now. hehe.
-Mike
Old 02-18-2005 | 11:01 AM
  #266
Dianna,
Old 02-18-2005 | 11:13 AM
  #267
MHester's Avatar
Quick update:
I thought you might all like to see how the new stuff is coming along. I'm playing with the composition of the layup to get the stiffness and weight right, but so far the molds are better than I had hoped. The canopy is perfect and has no seam, and the cowl looks even better. If I can get this belly pan reasonable, then I'm in the home stretch.
Working my tail off here.
-Mike
ID:	231064   Click image for larger version
Old 02-18-2005 | 12:06 PM
  #268
bokuda's Avatar
My Feedback: (7)
Rodney: I will buy 2 full cowls with cheeks to be shipped together. Please let me know total amount and how to pay you. I'm in Massachusetts.
Thanks, Dave Wartel
[email protected]
Old 02-18-2005 | 12:16 PM
  #269
My Feedback: (10)
Rodney,
I will also buy 2 cowls. I am in Colorado.
Old 02-18-2005 | 01:27 PM
  #270
OK. So far we have confirmed orders for full cowls and cheeks: 2 for Dave and 2 for Larry. Anybody else?
Old 02-18-2005 | 04:53 PM
  #271
My Feedback: (44)
Rodney,
I will take one full cowl with cheeks and one canopy.
Thanks -
Richard[8D]
Old 02-20-2005 | 08:44 PM
  #272
MTK
Nice job Mike. From the photos, Isee you have really been at it
Matt
Old 02-21-2005 | 02:12 AM
  #273
ata
Hi,
I glued on the cowling, and made the canopy frame. It needs some filling and sanding now.
Attila
Old 03-10-2005 | 04:51 AM
  #274
sigk's Avatar
Here is an update on my paperplane.
Like the rest of it, the pipe tunnel was sheeted with paper.
ID:	241564   Click image for larger version
ID:	241565   Click image for larger version
Old 03-10-2005 | 04:53 AM
  #275
sigk's Avatar
I like using the paper but must be careful when sanding, using masking tape is sometimes essential, otherwise I can sand trough the paper in a heartbeat.
ID:	241567   Click image for larger version
ID:	241568   Click image for larger version
