NEW QUEST
Old 05-02-2005 | 02:42 PM
  #101
Default RE: NEW QUEST
i am thinking to try this model electric....weight should be under 9 pounds....Can you tell me the RPM on the 13X10 prop?? I can swing anything from 14X10 up to 22X12, but prefer to stay approx the same size as the fuel motors do so that flying characteristics remain approx the same.
I just need to figure out the required pitch speed, and then i'm off..........
I don't need " unlimited" vertical as I will be flying sportsman or maybe at best intermediate, so I don't necessarily need a fire breathing dragon, just about the same as a .91??? or is a 91 more than required for this type of flying??...I had a Venus that was powered by much less than everyone said the computer programs predicted was needed, and it had much more than adequate power. ( according to some more experienced fliers that flew it )
Old 05-02-2005 | 04:22 PM
  #102
I'd love to help on that one, but I paid someone to build mine and I have no idea where those pieces went.
Ken
Old 05-02-2005 | 04:28 PM
  #103
eflier,
I ran an OS 120 w/pump, swinging an APC 14X10 at approx. 9300 to 9700 RPM depending on the day.
Ken
Old 05-02-2005 | 04:32 PM
  #104
ORIGINAL: jetmech43
alson says the distance from the fire wall to drive hub 137mm or 143mm which one do you use
It all depends on how much overlap you want on your cowl to fuse.
I would put a lighter engine farther out on the rails than a heavy one, it makes it easier to balance.
Old 05-02-2005 | 11:37 PM
  #105
cart3192's Avatar
Noahb,
Did you use the stock engine mount or go with the Hydes A mount? I plan to use a saito 91...
Old 05-02-2005 | 11:40 PM
  #106
cart3192's Avatar
Ken,
What type batteries and weight are you running?
Old 05-03-2005 | 12:23 AM
  #107
My Feedback: (67)
I used the stock mount. Mount everything as far forward as you can. I mounted the throt. servo on the bottom of the fuel box, right behing the fire wall. I also am running a 5 cell 2500 mah pack that is mounted in the fuel tank area. It weighs around 6.5 oz. You will prolly need any where from 3-6 oz of lead in the nose. However, if you can keep the elevator servo out of the tail, and move it up front, this should bal. out perfect.
Hope this helps.
Old 05-03-2005 | 05:01 AM
  #108
GC,
With my motor setup I used a 2700 NiMH pack placed just behind the wing saddle for balance.
Remember, I was running a 120 FS, quite a bit heavier than your motor.
Ken
Old 05-03-2005 | 09:59 AM
  #109
Ken....Thanks for that information.....I can turn a prop that size at approx 9400 RPM max, but will go up in dia and down in pitch, till the pitch speed is about 2 1/2 time the models stall speed,
this will give me a fair amount more thrust than the model weighs. Has anyone done one of these electric?...
Old 05-05-2005 | 09:12 AM
  #110
My Feedback: (9)
does anyone know how many ounces the fuel tank is that comes with the quest
Old 05-13-2005 | 09:17 AM
  #111
My Feedback: (9)
ok I got brave, I removed the bottom sheeting on the fuse ran 2 guides for a 2 servo elevator hook up, and carbon fiber push rods works great, now all I have to do is resheet the bottom and recover
Old 06-06-2005 | 04:49 PM
  #112
hi , any idea how it flies FAI F3A???
Old 07-02-2005 | 08:41 AM
  #113
JVB
How did you guys mount a 91 2C with stock muffler? Rotate so the muffler is lined up with the bottom of the fuse? Would have to cut the cowl for engine head then. Anyone have a pic of say an OS91 FX with stock muffler mounted? Thanks.
Old 12-02-2005 | 10:50 PM
  #114
Eric.Henderson's Avatar
FYI - I have heard that there is currenyly a special running on the QUEST-2 for around $200.
Regards,
Eric.
Old 12-03-2005 | 08:33 AM
  #115
Eric,
The website still shows the $249 price.
Ken
Old 12-03-2005 | 04:38 PM
  #116
Just call and ask :-)
Old 01-05-2006 | 07:17 PM
  #117
I just order a Quest last night. I have been out of RC for about 12 years and a lot of things have changed. WOW have they. I bought a stick over thanksgiving and what little skills I had seen to be returning. I figured that the Quest would be the next step, I don't know whether I want to go back into pattern or just fly big planes. so the Quest looks like the best of all worlds for now.
I don't want to over power it, so I think I will go with a ST.90. I may not use a pipe, just have a Macs muffler run down the center of the bottom. In the past I have had very good luck with set up and have not had to use pumps, so I might try it again. I guess that I may have some minor GC issue. I will most likely put the elevator and rudder servos as far up front as I can get them.
I was just sitting here and trying to figure out what type of servos to get. Any suggestion on a modest selection. and will just one work for the elevator? MLC, what prop did you end up using?
thanks all for any help.. T green
Old 01-06-2006 | 01:08 PM
  #118
One servo will work for the elevator. I have the older Quest sold by Creek Hobbies. I have Futaba S9202 servos on all but the rudder. There I have a 9151 digital. That made a big difference in the rudder control. I have seen the new Quest flown with the ST90. It did well, but I don't know what prop he had.
Larry
Old 01-06-2006 | 01:16 PM
  #119
My Feedback: (9)
Hey Larry I was running a 13-8 now switched to a 14-5
Old 01-06-2006 | 09:40 PM
  #120
Hi Randy. I still have the same old plane; so far it's survived. Thinking about a new one though.
Larry
Old 01-06-2006 | 11:00 PM
  #121
Hello,
I used the Hitec 635's all around and a YS .91fz with great results....
Old 01-07-2006 | 07:07 PM
  #122
Thanks for the info on servo, did the ht 635 fit in the wing OK. I may just wait until I get it before
I buy servos. I have not gotten a engine yet eigther. I wanted to keep the cost down. If i go back to pattern type planes then I would like to have Otop or the Ice berg?? Heck, I don't know what I want to do, but the quest just look like a nice plane. and seem to be the obvious next for me.. Terry
Old 01-07-2006 | 11:41 PM
  #123
Hey Terry,
The 635 is standard size servo. Check out the old thread on the original Quest 3D, you may find some interesting alternative power plants and some setup tips.
http://www.rcuniverse.com/forum/m_81.../tm.htm#814634
Here's another article on the original Quest 3D 90.
http://www.geocities.com/beaton90/quest3d.html
Old 01-09-2006 | 05:50 PM
  #124
Just got home from work, and the Quest was here. It looks good. My last Pattern plane was an Aurora, I think it cost about $200 for the kit and took me about four months of steady work to finish it. I will keep you"ll posted on finished product.. thanks again for the help..tg
Old 01-09-2006 | 06:24 PM
  #125
jlkonn's Avatar
Craptech,
Mine came today too!
I think UPS did the best ever on the box.
Not even a scuff mark!
The model is packed very well from what I can tell so far.
Looks good but I have hardly unpacked it.
My last pattern plane was a Dick Hanson Dalotel!
JLK
