RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
the hyper st PRO thread!
Old 08-07-2008 | 10:46 PM
  #1351
Default RE: the hyper st PRO thread!
lol, sorry.
Well when i opened it up and pulled the shoes off one of the pins that held a shoe in place came off with the shoe ( i'm using aluminium shoes ). One or more of the shoes had gotten stuck to the CB and would not disengage. It happened quickly enough that i didn't realise what was going on with an end result of a stuffed engine which i can fix when i can pump a few $$$ back into it.
Clutch bell is fine, the bearings were brand new ( protek rubber shielded 10 for 9.95 off Amain )
For the record i do periodic maintenance on the shoes and had just done so during the week prior to this happening.
Old 08-08-2008 | 09:18 PM
  #1352
j_blaze's Avatar
i've been using the hobao fly wheel with the rc8 nut and clutch shoes/springs, simply awesome. so easy to work on and adjust and should last a while with the max life shoes. 1.1 springs give the truck a nice kick when the motor hits mid, i love it.
Old 08-08-2008 | 10:16 PM
  #1353
I'm thinking i was just having one of those days...Well i was due to havea bad day out so i suppose that was it ...lol
Old 08-09-2008 | 07:23 AM
  #1354
adam-69's Avatar
hey guys, really quick question.
Do the hyper st pro chassis braces (cnc'd ones) fit straight onto the rtr or have they been moved for the pro?
cheers
Adam
Old 08-13-2008 | 07:51 PM
  #1355
j_blaze's Avatar
ORIGINAL: adam-69
cheers
Adam
not sure but i've seen a lot of people upgrade to the aluminum with no mention of mods.
Old 08-14-2008 | 04:56 AM
  #1356
My Pro kit is finally here!!! I can't wait to get this bad boy built. Anyone know if this part number will fit for a replacement tranny?
PART# 19240 [link=http://www.ofna.com/h7opt.php]Tranny[/link]
Old 08-17-2008 | 05:39 PM
  #1357
adam-69's Avatar
ORIGINAL: j_blaze
ORIGINAL: adam-69
cheers
Adam
sweet man, cheers
Old 08-17-2008 | 10:08 PM
  #1358
Is the PRO is heavier than non pro?
Old 08-18-2008 | 05:23 AM
  #1359
I would expect it is, because there is so much more metal, but Ihaven't weighed them.
Old 08-18-2008 | 04:56 PM
  #1360
j_blaze's Avatar
hyper st pro 10lb 2oz with 1/2 tank at florida regionals this weekend. 12th in b-main, motor issues.
Old 08-19-2008 | 03:14 PM
  #1361
adam-69's Avatar
Hmm it isnt a pro.. do i get kicked out? lol.
Go .28 6p
Ace ds1015 (x2)
orion battery
futaba 39m fasst
dynamite 053mr
After a three day strip and clean here she is. sorry for poor pictures, didnt get any from good angles.
ID:	1015020   Click image for larger version
Old 08-20-2008 | 01:01 AM
  #1362
How do you like that Go 28??
Old 08-20-2008 | 03:45 AM
  #1363
adam-69's Avatar
love it, starts first time everytime, runs forever, and the power delivery is unreal. no matter where im holding the throtle if i punch it, the wheels will spin haha.
Old 08-22-2008 | 09:05 PM
  #1364
spikeitaudi's Avatar
OK So I got 7/10/5 diff oil in my diffs and it pushes around the bend on power really bad. Was going to change out to 10/20/3. Thoughts?
Old 08-22-2008 | 09:35 PM
  #1365
ORIGINAL: spikeitaudi
Drop the rear to 2000 and see how you go mate
What typeof surface areyou running on ??
Old 08-23-2008 | 07:44 AM
  #1366
ORIGINAL: rckal
Baseball mount clay/dirt.
Old 08-23-2008 | 09:09 AM
  #1367
I think 5000 is too much in the rear.
Most people use 1000 to 3000 in the rear. I think...lol
Old 08-23-2008 | 10:07 AM
  #1368
what are the good points of the Hyper ST RTR and the bad points?
Old 08-23-2008 | 08:34 PM
  #1369
Yea I think I am going to go 10/20/3. It pushes real hard on power around the bend.
Old 08-23-2008 | 08:35 PM
  #1370
ORIGINAL: TTR_EB4
Maybe try posting that in the Official Hyper ST RTR Thread and not the Pro.
Old 08-23-2008 | 08:53 PM
  #1371
j_blaze's Avatar
wouldn't a lighter center oil increase on-power and reduce overall acceleration? wouldn't something like 5/5/1 be an on-power beast?
Old 08-24-2008 | 03:56 PM
  #1372
Hey guys, I am almost done with finishing my Hyper ST. I didn't use any grease on my diffs, (not in but on them, just to make it clear) Is this ok or do I have to put some on it? And what kind of stuff do I need? That yellow-jello they supplied in the kit (cuz it's metal on metal)? Thanks
Old 08-24-2008 | 05:17 PM
  #1373
If you are talking about the crown gear on the outside of the diff to the drive pinion gear you need to put grease on it. I think the kit comes with a grease that is red in color. NOt exactly sure, but I do remember the kit supplying grease for it. And yes I hope you did put Diff oil in the diff itself.
Old 08-24-2008 | 05:21 PM
  #1374
ORIGINAL: j_blaze
Lighter oil would increase on power as less dense oil mean easier to move. So how would that reduce accelerations? 5/5/1 I agree would be a on-power beast, but for what setup of a track.
Old 08-24-2008 | 05:29 PM
  #1375
Ok thanks, yes they included some yellow grease. But I didn't use it but I put some Anti-wear Grease on the diff that was layin around. It was included in one of my Tamiya kits.
