RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
the hyper st PRO thread!
Old 08-25-2008 | 06:34 AM
  #1376
Default RE: the hyper st PRO thread!
What brand of servo's can you use with the included servo horns? The plastic and the alu one. I know they'll fit Futaba, but do they also accept other brands? What servo's are you guys running in the Truggy? Need to find some servo's for my car.
Budget: brake/throttle servo ~$40 and steering servo ~$100, but less is better, unless the specs arent that good. Thanks
Old 08-25-2008 | 07:07 AM
  #1377
spikeitaudi's Avatar
I can tell you they will not fit the JR's. That is what I am running. I have a JR 9000s and 9000t in mine. I think the Hitec's might work as the spline numbers are the same.
Old 08-25-2008 | 07:08 AM
  #1378
ORIGINAL: Echelon
NOT Hitec.. Freakin' PIA too..
Old 08-25-2008 | 11:36 AM
  #1379
Hmm ok then.. And how about the Ace servo's from Thunder Tiger/ Associated? Like the popular ACE DS1015?
@ spikeitaudi: So you're using different servo horns than the ones in the kit. How long are the horns you use/ in the kit, one inch?
Old 08-25-2008 | 11:49 AM
  #1380
If i'm getting a Futaba is this a good choice?:
http://www.rcmart.com/catalog/rc-ser...Path=1099_1030
And for the steering i'll get something simple like this one: http://www.rcmart.com/catalog/rc-ser...Path=1099_1030
Old 08-25-2008 | 12:50 PM
  #1381
ORIGINAL: Echelon
I am using the Dynamite Platinum Pro linkages.
Old 08-25-2008 | 12:59 PM
  #1382
Don't cheap out on the Steering servo. The more Torque the better. I would go cheaper on the Throttle/brake servo then the Steering.
Old 08-25-2008 | 01:33 PM
  #1383
hi i'm new on this forum and this is my hyper st pro
specs:
-axial 28RR
-standard hobao exhaust
-TT ace 1313 throttle
-towerpro mg995 steer
-intellect 1400mah
Old 08-25-2008 | 01:35 PM
  #1384
xjqkz's Avatar
ORIGINAL: Echelon
DS1015 for steering and DS1313 for throttle is one of the best steering/throttle setup you can have
Old 08-25-2008 | 01:47 PM
  #1385
ORIGINAL: redsteal92
specs:
-axial 28RR
-intellect 1400mah
Welcome How do you like the Axial engine?
Old 08-25-2008 | 01:50 PM
  #1386
Nice ride redsteal 92..
I've posted the bod before, but not with the new offset wheels..
Old 08-25-2008 | 03:30 PM
  #1387
ORIGINAL: spikeitaudi
specs:
-axial 28RR
-intellect 1400mah
it's a cheap engine but is worth its money it runs great and holds its tune
Old 08-25-2008 | 04:40 PM
  #1388
Oh sorry, I didn't write that correctly. I'm going to use the expensive one on the steering and the cheaper one on the throttle/brake.
But are the ones I listed ok?
Old 08-25-2008 | 05:19 PM
  #1389
j_blaze's Avatar
the ace is a fenomenal servo, the tower pro not so much, its gonna give up soon, when it does get the 1015 then and throw it up front. no looking back after that. i would not use the "cheeper" servo in throttle cause when it goes bad your car may be gone into something or someone. not that the ace wouldn't fail but i've had mine about a year now, no issues. the 1313 is a really good steering servo, the 1015 is only slightly better all around.
Old 08-25-2008 | 08:05 PM
  #1390
ORIGINAL: j_blaze
I agree with that as well. But if it dies your failsafe or your throttle return spring should takecare of a runaway.
Old 08-25-2008 | 08:49 PM
  #1391
Dynamite Pro linkage is great it comes with different spline numbers to match what ever servo you have.
What body is that HerrSavage? Looks great on the ST. Did you have to do much modification to make it fit?
Old 08-26-2008 | 03:37 AM
  #1392
i agree with j_blaze i had a towerpro for throttle and brake. Once i was driving on a parking lot my gas reacts very slow and holds throttle for a while and after i was back home the servo died so i stopped at the right moment because i had no failsave and if i didn't stop my car had hit a truck [X(]. So just buy some ace's i did that too and you have a good combo of servo's and they are very fast and strong. (sorry if my English is bad)
Old 08-26-2008 | 03:57 PM
  #1393
hey een mede Nederlander, lol
@ Redsteal, do the servo horns fit on the Ace servos?
Old 08-26-2008 | 04:13 PM
  #1394
ORIGINAL: HerrSavage
Gotta love that red body. What's the name of the body? Is it the Kyosho ST-RR High flow body from Jconcepts?
Old 08-26-2008 | 04:19 PM
  #1395
@echelon lol ook nederlander ja and the hobao horns will fit on the ace servo's
Old 08-26-2008 | 06:35 PM
  #1396
I think he said that was the Jconcept body.
Old 08-27-2008 | 12:10 AM
  #1397
Thanks. It's the Jconcepts body for the Mugen MBX5T.. In general, most bodies for the Mugen fit the Hyper.. It fits pretty well without mods, but it's a tad snug around the pipe.. Makes me think though, maybe my pipe is just sitting too high.. I'll have to check...
Old 08-27-2008 | 12:40 PM
  #1398
what shock/damper set-up do you guys run in the Hyper ST's?
- what pistons?
- How much weight shock oil?
- what springs?
I think I'm going to change to: 4 piston hole (white color) and 35wt oil, is this a good set-up?
And if you want to run with the black pistons with 2 holes what oil do you use? cuz if you use the 2-hole the susp. setup is softer.
which springs fit on the shocks?
Old 08-27-2008 | 12:43 PM
  #1399
*edit*
Old 08-31-2008 | 06:10 PM
  #1400
looking to buy a truggy! having a hard time trying to decide. so how bout you hyper st guys tell me the pros n cons of this truggy. i've read quite a bit of this thread and it seems that the main problems are braking issues, its a bit on the heavy side n thats about it. im not looking to do competitive racing just bashing n the occasional visit to the track for non competitve racing. im not a noob to nitro, but i will be a noob to truggys n 1/8 scale. right now i have a cheap 1/10 buggy which i am ashamed to name here lol. but its been a good experience, making a crappy car run and hold up pretty decent against the abuse.
