Reload this Page >
New Hangar 9 P-51 60cc
Old 03-15-2015, 03:12 PM
  #701
vertical grimmace
vertical grimmace's Avatar
Not to mention it is a very juvenile endevour
Old 03-15-2015, 03:18 PM
  #702
sjhanc
sjhanc's Avatar
Default landing gear retract speed
I flew as rear pilot in the Collings Foundation's P 51 C 2 weeks ago. From the time he hit the switch to gear thump in the wings and tail and green lights on the instrument panel was about 3-4 seconds. I could not hear the main doors close but I assume that the green indication meant they had closed. My electric gears take 10 seconds up or down and battery voltage only makes a 1/2 second difference going from 4.8 sec. to 9 volts. Programming a delay for scale retraction adds another second. My air powered retracts could be set at any speed you wanted.
Old 03-15-2015, 03:31 PM
  #703
sjhanc
sjhanc's Avatar
I flew my TF GS B model today using both the Varioprop 4 blade set at 20 inches pitch and the Zinger 22-16 4 blade. The varioprop briefly reached 6100rpm on a down wind pass at 100 feet that looked pretty fast. The prop chart estimates that at 6140rpm it may have reached 125 mph. The Rimfire 65cc motor is still over speeding the VP. The Zinger 4 blade generally peaked between 5000 and 5400rpm with chart speeds at 85-90 mph. Current draw was high at 145amps and ESC temp briefly got to 178f but generally ran at 145F. It was a hot day at close to 90f and no clouds.
Old 03-15-2015, 06:06 PM
  #704
kalzone
How manny amps did you get with the vp set at 20? I need to come up to Ocala and join to fly along with yall I'm just in mt dora
Old 03-15-2015, 07:24 PM
  #705
marksp
My Feedback: (9)
marksp's Avatar
Originally Posted by kalzone
...Because of me putting the power 360 on it and pulling 140 amps I am going way faster than it was designed to go.
Video please!
Old 03-16-2015, 11:25 AM
  #706
fhollahan
This hobby is by definition a juvenile endeavor
Apparently this has already been done. Just not a good idea in the US. Guess I'll stick with the payload drop.
http://www.rcgroups.com/forums/showthread.php?t=1575324
Old 03-16-2015, 12:01 PM
  #707
Lifer
Lifer's Avatar
I'm not familiar with any definition of this hobby that identifies it with juvenile behavior. I have witnessed juvenile behavior by a few participants, however.
Old 03-16-2015, 12:35 PM
  #708
fhollahan
ok, sorry to all for non value added posts to this build thread. Enough of that for me.
On a build note, it looks like I am going to need to add 12 to 14 oz. of weight to the nose to get to a balanced CG. The Zenoah 62 engine they suggest on the website is probably close to 12 oz heavier then the DA 60 I am using. My total build weight is coming around 28 lbs prior to adding the nose weight. Not happy about adding more weight but have no choice.
Old 03-19-2015, 07:20 PM
  #709
kalzone
has anyone flying had a problem with the inner gear doors closeing in flight ? i have the one used in the manual spectrum A7040 on the inner doors.
Old 03-20-2015, 11:51 AM
  #710
nsyracuse
I have had random issues with an inner gear door not closing in flight. They are few and far between and I can't find the culprit. Usually takes a couple gear cycles to get sealed up and then doesn't reoccur for quite a few flights.
Old 03-20-2015, 12:00 PM
  #711
nsyracuse
Just put flight #16 on her. I'm a very happy camper. Powered by an EME 60 (best running engine I've ever had, so far). Level flight is in the 102-107mph range. Added 6oz to the nose and she flies very well balanced. It flew ok with no weight, but is solid as a rock with the 6oz in there.
pictured with my dad's full scale stearman
Old 03-20-2015, 12:26 PM
  #712
Lifer
Lifer's Avatar
nsyracuse,
Can you give any details on your EME 60? What prop at what rpm, etc?
Old 03-20-2015, 01:00 PM
  #713
nsyracuse
I dont have have any rpm data as I don't have a tach. I should have rpm telemetry setup sometime next week and can get back with you. It's swinging a mejzlik 24x10th carbon fiber prop. Idle is phenomenal, will stay parked on the pavement, and performance is great so far.
I I had to order 25mm standoffs from McMaster-Carr and one washer. It leaves a 1-2mm spinner gap. I had to open up the center hole in the firewall for the throttle and choke arms to move freely.
I I have a dle-61 on a giant corsair and this engine idles much better, starts much easier, and performance is at least the same if not better.
Nick
Originally Posted by Lifer
nsyracuse,
Old 03-20-2015, 01:11 PM
  #714
Lifer
Lifer's Avatar
The fact that it's turning a 24x10 enthusiastically says a lot. Their price is pretty reasonable, too.
Old 03-20-2015, 01:14 PM
  #715
nsyracuse
Yes, I bought it because it looked like the same foot print as a da, and I knew horizon had flown with with a da, but didn't want to drop the cash on a da, since I had to buy a new radio as I ran out of channels on my dx9. Very impressed so far, we'll see how it holds up.
Old 03-20-2015, 02:51 PM
  #716
Oldcrow p51
Mine is built up but the engine is remaining. I'm using DA60cc and Dave Brown spinner. I have problem with the wing joint it's very tight and not fiting flash. I don't know if any one had same issue. The plane is huge comparing to TF stang or any other brand. Can't wait to fly it. I hope any one has flying video of this beautiful bird.
ID:	2082838   Click image for larger version
Old 03-20-2015, 04:20 PM
  #717
fhollahan
I had to add about 20oz. to the nose to get to CG. With the DA-60 being light, cutting the muffler down, and the pilot in the seat at 8oz behind the CG it seemed to need extra weight. I'd rather be a bit heavy to the nose for the first flight too so I am balancing on the back of the manual range. My total weight is coming in at 29.3 lbs without fuel. I have 2 props. Starting with a Zoar 23x10 and have a mejzlik 23x8 EVO carbon fiber prop to try as well. No chance of maiden right now with snow coming down today (first day of spring) here in the northeast.
Old 03-20-2015, 04:23 PM
  #718
fhollahan
The EME sounds like a great choice and I think it is heaver then the DA so you don't have to add as much weight up front.
Old 03-20-2015, 06:30 PM
  #719
nsyracuse
IT is on the tail heavy side of the range, but flies great. I also don't have a pilot in the cockpit.
i absolutely hate adding weight! Lol
Old 03-20-2015, 07:40 PM
  #720
Shaun Evans
Shaun Evans's Avatar
Hi,
Has anyone used a DLE 55 on this bird yet? In flight performance impressions?
Old 03-21-2015, 05:13 AM
  #721
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
Two thumbs up for the EME line. I just bought a EME 55 for my 1/5 scale Spit and it runs like a Swiss watch. Smooth, reliable power. I firmly believe that the EME product trumps the DLE without question.
Old 03-21-2015, 10:48 AM
  #722
fhollahan
My wing tips were very tight and I had to dremel out one of the holes (left front) where the tab goes thru in the main section since they glued it at a down angle in the factory. Better tight then loose. I would just work it with your tool of choice to get it to go together. If it is real bad you could call HH and have them address it but I doubt that is worth it and another set will probably be worse since it did not move thru the factory with your fuse and main wing. If the main is not fitting the fuse well you'll need to address in a similar manner. One of the guys in the thread had some good pointers if you look back.
Old 03-21-2015, 10:57 AM
  #723
marksp
My Feedback: (9)
marksp's Avatar
Do you also have the EME on-board starter? Can you share pics of the engine installation and cowl mods if any?
Cheers
Old 03-21-2015, 02:22 PM
  #724
nsyracuse
I do not have the onboard starter (didn't think it would fit in the cowl); however it doesn't need it. It always pops in less than 10 flips and is running in 2-3 more. It was a bear trying to find a wrap-around muffler that would clear the firewall. Finally settled on the j'tec compact wraparound. Fits almost perfectly inside the cowl as well. I had to cut a little at the front corner and to clear the front muffler bolt.
here are some pics:[
QUOTE=marksp;12007401]Do you also have the EME on-board starter? Can you share pics of the engine installation and cowl mods if any?
Cheers[/QUOTE]
ID:	2083030   Click image for larger version
ID:	2083032   Click image for larger version
ID:	2083033   Click image for larger version
ID:	2083034   Click image for larger version
Old 03-22-2015, 02:24 PM
  #725
aehaas
How did you drill the holes in the muffler screws?
aehaas
