Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
kmp dc3 due november 30th i just ordered one
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 09-30-2012, 05:03 AM
  #151
BUGGS50
Default RE: kmp d3 due november 30th i just ordered one
Hi Everybody,
Just wanted to let you know that I flew my c47 yesterday. It flew really well, I will make a few minor adjustments and will fly again today. I ended up having to put 2-1/2 lbs of led in the nose for a total weight of 25lbs, cg @ 4" can't wait to fly it again. I do have some video and pictures which I will post later.
Bill
Old 09-30-2012, 05:34 AM
  #152
AncientCityFlyer
AncientCityFlyer's Avatar
Bill, congrats on your maiden flt. Glad to hear all went well. Mine is still sitting on the bench. I've just got too many other things going on right now to work on it. Maybe during the holidays. Good to know the weight required to balance and the actual cg location. That's always a shot in the dark for a lot of ARF's. Looking forward to your video. Mike
Old 09-30-2012, 06:46 PM
  #153
BUGGS50
Hi Mike,
Hopefully I get a couple pictures posted and a couple short videos, I had a friend (Chris the best pilot in our club) madien it for me. We didn't have the cowls on and we were having a little trouble with the left retract sticking so we flew it with gear down. otherwise it flew fantastic.
Bill
Old 09-30-2012, 06:57 PM
  #154
BUGGS50
can anyone explain to me how to post pictures?
Bill
Old 09-30-2012, 07:17 PM
  #155
BUGGS50
Old 10-02-2012, 02:03 PM
  #156
BUGGS50
I figured out pictures but cant't figure out video.
Bill
Old 01-14-2013, 02:13 PM
  #157
mnourse26
hey guys have a stupid qestion for you, so iam sorry but is esm and kmp the same model??? iam looking to get a esm dc-3 its on back order at troybuild models got my name on the list. also anybody gone elctricte with the esm dc 3 thanks for the help matt.
Old 01-14-2013, 03:06 PM
  #158
AncientCityFlyer
I have the ESM DC-3 which I purchased from ARF-Pro. It's basically the same, as I believe it is ultimatey manufactured by the same company in China. It's a well built arf for what an arf is. As with most arf's the instructions suck, and the DC-3 has one issue that I had to change and that is the tail wheel itself and the linkage that goes with it. I got the coverd wing set which is ok, but I wish I had spent the extra $ and gone with the built up wings. There was some one here that did go electric but don't recall the details. The problem with going electric would be easy access for battery exchange. You would probably have to cut a hatch in the fuse belly forward of the wing. Plus you will need a lot of extra weight to get it balanced, which with the size batteries needed to power this arf would provide. Just my $.02 ACF
Old 01-14-2013, 09:40 PM
  #159
RajuPradhan
Hi Guys,
I have just converted my DC3 into electric, earlier I had installed 2 Zenoah 20cc engines, but, that made this plane very heavy and also twitchy to fly.
Now, I am using 2 RIMFIRE motors with two, 6 Cell 5000 mAh LiPos. I have installed batteries right under the nose and their combined weight of 1.5 Kgs. perfectly balances the model.
Old 01-14-2013, 09:43 PM
  #160
RajuPradhan
I am also eyeing those new Evolution 10cc engines. I guess I will wait for 6 months, so that they will have enough time to iron out teething issues.
Old 08-29-2013, 06:22 PM
  #161
robbie9859901
Default kmp dc3 November 30
I'm getting close to starting the engines. Two DLE 20's.
ID:	1914645   Click image for larger version
Old 09-16-2013, 05:53 AM
  #162
UK Warbird Guy
UK Warbird Guy's Avatar
Default 2 yrs in the making
All,
This is a great thread and gives some fantastic advice to those building this Kit...I've built 2 of these now... My first was the standard Kit and I left it as it came out the box in the Springbok Scheme which is the pic of the DC3 flying.
Unfortunately I lost this due to a rib failure where the outer wing joins to the inner wing.. There must have been some kind of failure in the rib on the outer section of the wing.. as it just came away from the wing.
Never known this before and never seen it happen to any other models so I think it was a one off.
I loved it so much though and it flies like a trainer it really does..!! Once you have got over the initial torgue and pull to the left its so easy to take off and fly round.
I have 2 x Laser 100 4 strokes in mine throwing 3 blade 14x6 props which give just about 3 mm clearance on the Fuz when spinning..Painted black with yellow tips they give a very realistic prop ring when running.
The second version had to be a C-47 for me... So I set about deciding which one.
I ended up going for the aircraft that flew Easy Company into Normandy on D-Day. It flew from RAF Uppotery airfield in the UK so has a very Historical relevance.
here are my pic... Hope you enjoy...
ID:	1921254   Click image for larger version
ID:	1921255   Click image for larger version
ID:	1921256   Click image for larger version
ID:	1921257   Click image for larger version
ID:	1921258   Click image for larger version
ID:	1921259   Click image for larger version
ID:	1921260   Click image for larger version
ID:	1921262   Click image for larger version
ID:	1921263   Click image for larger version
ID:	1921264   Click image for larger version
ID:	1921265   Click image for larger version
ID:	1921266   Click image for larger version
ID:	1921267   Click image for larger version
ID:	1921268   Click image for larger version
ID:	1921270   Click image for larger version
Old 09-16-2013, 03:58 PM
  #163
AncientCityFlyer
You are doing a fantastic job of building your C-47. I love the detail you're putting into it. I was a flight engineer on C-47s for 3 years while was in the Air Force. Best aircraft ever built.
Old 09-17-2013, 04:38 AM
  #164
UK Warbird Guy
Thanks for your compliments... I would love to go up in one sometime but unfortunately all the ones in the UK are now not allowed to take passengers due to new CAA regulations.. ;-((
Mine is ready to test fly now.. I was just waiting on a replacement Carb for one of the engines... I'll fit it and see how it runs before I take it over the airfield...
This is the link to the Yuotube video for the maiden flight of my first DC-3
http://youtu.be/qnqFykBhPS0
Old 09-17-2013, 02:40 PM
  #165
AncientCityFlyer
Great video. You're right it seems like it flies very well and stable. Mine is still sitting on the bench waiting to be finished. I came out of retirement about 3-1/2 years ago and just haven't had time to really sit down and focus on finishing her. I fully retire the end of Oct. Will take a week or 2 break then get back on the project and finally finish her. Will keep you posted. Mike
Old 11-03-2013, 04:02 PM
  #166
edge540purple
Hi UK Warbird Guy,
Nice Video... I have the same ESM Dc3 ready for Maiden, where did you put the COG? instructions say 120mm, 4 3/4 inch or 4"? Mine has two 20cc RCGF beam mount engines with 14 x 9 Master Air screws...
Name:	DC3 at SEMAC 1.JPG
ID:	1936367   Click image for larger version
Name:	DC3 at SEMAC.JPG
Old 11-18-2013, 03:40 PM
  #167
yankphan
My Feedback: (9)
Do 14" props fit good?
I will be starting my build soon ..I've read 4" for the CG.
Post a video of the maiden if you can...
Old 11-18-2013, 04:34 PM
  #168
edge540purple
Hi yankphan,
I Maidened mine yesterday, lost throttle on right engine, failed servo so engine went to idle, did a complete circuit and came in under power on left engine. not much rudder imput was required...
I'm using 14 x 9 Master Air screws with about 3/4 " clearence... Way over powered with the RCGF 20cc engines spinning the 14 x 9;s at 9400...
I ballanced mine at the 4 1/2'' mark which felt great... It fly's really well...
ID:	1940407   Click image for larger version
ID:	1940408   Click image for larger version
ID:	1940409   Click image for larger version
ID:	1940410   Click image for larger version
Old 11-18-2013, 09:20 PM
  #169
yankphan
My Feedback: (9)
Nice... I didn't take mine out of the box yet but read that a 13" prop was biggest... Did you mount the engines center of the cowl? That rpm seems high... Run a xoar 3 blade to put more of a load on the engines. Those master airscrew props are too flexible... I'd use wooden props. Do you have a YouTube link ? Looks awesome... And one more question.... You said went to idle... Are you using a twin sync ?
  #170
yankphan
My Feedback: (9)
Oh yeah... Did you use nose weight ? Is that the stock landing gear ? Did you use the stock control hardware.... I'm not crazy about the elevator pull pull, was thinking of using carbon rods ?
sorry for so many questions.
Old 11-19-2013, 01:14 AM
  #171
edge540purple
yankphan,
I also read 13" props were biggest untill i put a couple on, way to small for the 20cc's. yes, stock landing gear used, might replace them with retracts some day.
Not using twin sync, nthing fancy at all, have both engines on one channel mechanicaly adjusted to run together which they both do very well, Gas engines are very reliable set up properly. Nose weight is 0.8 kilos about 1.7 lbs with the CG at 4 3/4" felt good in the air...
I replaced most of the hardware with Dubro 4-40 including the pull pull cables... if you need any info as you build just ask, happy to help...
Old 11-19-2013, 02:01 AM
  #172
yankphan
My Feedback: (9)
Thanks for your time.. If possible when u get a chance can you maybe take a few pics of your setup with your phone maybe ? Pics of inside the fuselage front and rear inside the fuselage ? My email address is [email protected] to make things easier.
Old 11-19-2013, 02:59 AM
  #173
yankphan
My Feedback: (9)
Thanks for your time. Question... I will be using the stock landing gear also until I get retracts. Do the stock wooden blocks get glued in place .... And if they do, would it be too late for retracts ? Not sure how that would work adding retracts later on.
Old 11-19-2013, 01:58 PM
  #174
edge540purple
yankphan,
Will send through lots of build pictures to your email... The stock wooden blocks get glued in and i think they will need to be removed to fit retracts for sure. If you do fit the standard stock landing gear i would recomend the main blocks be reinforced, the small block on top of the base mine came apart on ground testing just befor the maiden both sides and had to glue them in at the field they had very little glue from the factory...
Old 11-19-2013, 02:33 PM
  #175
yankphan
My Feedback: (9)
Very much appreciated to receive allot if build pics.... Thank you. Do you have a YouTube page ? You can see some of my other planes at yankphan100
