 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 05-06-2003 | 06:30 PM
  #1101
My Feedback: (287)
Default U Can Do 3D
Clearence for an 18 inch prop in minimal. The gear is weak, I am running a 16 inch prop and anything but a perfect landing results in a prop strike.
B-
Old 05-06-2003 | 06:32 PM
  #1102
Default U Can Do 3D
I never make imperfect landings.....
Old 05-06-2003 | 06:33 PM
  #1103
Default U Can Do 3D
Simple, just set the tail wheel down first
Old 05-06-2003 | 06:38 PM
  #1104
My Feedback: (287)
Default U Can Do 3D
Nor do I...I am going to have to learn how to land or buy stock in Master Airscrew !!!
Old 05-06-2003 | 06:50 PM
  #1105
Default U Can Do 3D
Guys, unless you have alot of extra money to spend on digital servos, ... you don't need them on this particular plane. I have Hitec 605's all the way around and they are more then enough to handle the control surfaces. IMHO
Old 05-06-2003 | 07:01 PM
  #1106
Maudib's Avatar
My Feedback: (51)
Default U Can Do 3D
I'll go a step further...
you don't need 605's either....
I went with Futaba 3004's all around except for the rudder... I wen twith the 605 there...
with 2 elevator servos, a couple 405BB's or 3004's fit the bill fine....
If this plane was a speed demon with lots of slams and bams... I'd say go a little more...
But I snap the crap out of mine, hover, harrier, and anything else that accidentially happens... never felt mushy at all....
Old 05-06-2003 | 07:36 PM
  #1107
My Feedback: (31)
Default U Can Do 3D
i have seen standard servo do wonders. i think it like a high power stereo system you dont have stain the stero if you do elect to play the music loud and better yet clean power to the speakers.......
Old 05-06-2003 | 08:00 PM
  #1108
Maudib's Avatar
My Feedback: (51)
Default U Can Do 3D
Absolutley krayzc...
I just wanted to share with potential buyers out there that might be on a budget that the standards perform very well on mine...
Just like some guys are putting YS 120 and bigger in it... but it will fly great with a .91 2 stroke...
Old 05-06-2003 | 08:23 PM
  #1109
Default U Can Do 3D
The secret to doing this plane with plain servos is to set the max throw near the end if the servo travel in one direction. This has the most leverage at the servo position.
Old 05-06-2003 | 10:13 PM
  #1110
RC Havoc's Avatar
My Feedback: (-1)
Default U Can Do 3D
A buddy of mine just got one. He put it up for the first time last weekend due to some engine trouble. He was having trouble tunning his Saito FA-100, but we got the bugs worked out. Still running a little rich because its not fully broken in yet. Ill tell you this. Its a great flying plane. He has it set up by the book for the throws. Seems to fly as if it were on rails. It is a big plane and I know a 60 wouldent fly it very well. Anyway, it is a beautiful plane.
Old 05-07-2003 | 11:35 AM
  #1111
My Feedback: (15)
Default 18 inch prop
I have a 18x5 on mine with no problems! It's a zinger, I had a 17x6 apc but found the lighter zinger to be better for this application.
Old 05-07-2003 | 04:49 PM
  #1112
Default U Can Do 3D
just got one today....kept looking at my other unfinished planes and my glorious . 60 Spinks Acromaster...and figured that this bird qualified nicely to be for my first ever ARF...I'll be changing all the hardware though...hope to have it up and running by next week....
Old 05-07-2003 | 06:12 PM
  #1113
Default Cline
I've read pretty much the entire thread and haven't seen any Cline installs. I just ordered mine and am curious where y'all are mounting it.
Thanks...
Old 05-07-2003 | 06:33 PM
  #1114
coomarlin's Avatar
Default Re: Cline
There are a ton of cline installs on UCD's that I know of. I'm one of them. There are several threads out there on RCU that talk about it also. My tank is about half way between stock position and CG. The cline works great on my UCD with Saito 100.
Thanks...
Old 05-07-2003 | 06:34 PM
  #1115
Default U Can Do 3D
HEY BEERMAN!!!!
Just kidding. COOMARLIN posted some great Cline pictures under a thread called: CLINE QUESTIONS He shows how he mounted his Cline. I just wrapped mine in a piece of bicycle innertube (being careful not to cover the hole in the bottom) and zip tied it to the stock engine mount as close to the carb as possible.
Old 05-07-2003 | 06:37 PM
  #1116
Default U Can Do 3D
Cool, thanks for the follow up.
With a last name like Beer, I've heard them all. I still find it fun though.
Old 05-07-2003 | 06:50 PM
  #1117
=XGC= OzZ's Avatar
Default Re: Re: Cline
How do you like the Saito, what is it a 100?
Old 05-07-2003 | 08:24 PM
  #1118
coomarlin's Avatar
Default Re: Re: Re: Cline
Yes it's a Saito FA 100. I've got a few gallons ran through it and it runs great. I adjusted the valves as per the manual after the first gallon. The engine purrs at idle and has a lot of power. It's turning a 15x6 APC prop around 9600 which is about 200-300 lower than max rpm.
I've had ZERO problems with my cline setup on this engine. It takes one quick burp with an electric starter and fires up every time. No priming neccessary.
I run an OS #F plug instead of the Hanger 9 plug that came with the engine. Idles better with the OS and turns a few more rpm.
Old 05-08-2003 | 01:07 AM
  #1119
Default U Can Do 3D
Just got mine flying this past weekend and thought I'd pass along my experiences. Saito 100 with Cline regulator. I had to adjust the low end quite a bit for a reliable idle. Once I did that it ran GREAT! I have the Cline zip tied in the middle of the engine mount center hole (the hole in the base where the front of the fuel tank is supposed to come through.) I just drilled extra holes in the firewall for the fuel lines. I have the tank at c.g. Running a 15x6 but will try the 16x4 this weekend.
Little pitch coupling with "normal" knife edge passes. Quite a bit with "3D" rudder throws when doing a high alpha knife edge pass. I've got some mixing to do! Incredibly effective rudder at 3D rates, though.
Jamie
Old 05-08-2003 | 01:48 AM
  #1120
My Feedback: (31)
Default U Can Do 3D
were is that rcs 1.4 report??????????
Old 05-08-2003 | 04:51 AM
  #1121
Default RCS1.40 gas
its here and finally ready to fly, it weighs 10 lbs. uses a 17x8 prop and according to the engine owners manual it will produce 17 lbs of thrust with this prop so the 10 pound plane should still fly light. i used a lot of reinforcements in the landing gear area which added to the weight. fuel tank is over CG. and batteries are located in the tail.
Old 05-08-2003 | 09:07 AM
  #1122
coomarlin's Avatar
Default Re: RCS1.40 gas
10lbs! Thats the heaviest UCD I've heard of. I hope the combo works out for you, but not not real optimistic. I've always heard that for good 3D you should have a Thrust to weight ratio of 2:1. Sounds like you'll be a bit short. Please let us know how it flys. Good luck.
Old 05-08-2003 | 10:12 AM
  #1123
=XGC= OzZ's Avatar
Default Ok I should be able to order my plane .
I have 4 9202 futaba servos , 1 3003 .
What rudder dig servo would you recomend ?
I will be going with the ys 110, engine..
Any upgrade hardware, you can recomend?..
New soon to be owner....
Old 05-08-2003 | 11:49 AM
  #1124
Default U Can Do 3D
Ron, save your money. You don't need a digital rudder servo. Save it and get digitals on your Carden. I (and others) are using standard or high torque servos with great success. What I'm offering is a dollar savings without sacrificing performance.
Old 05-08-2003 | 12:19 PM
  #1125
sensei's Avatar
Default U Can Do 3D
Put the fastest 80 oz. or better servos on the elevator, and ailerons, then put the highest torque servo on the rudder 90oz. or better. make the stiffest push-rods you can and put the rudder horn as low as you can to facilitate max down elevator throw.
If you do these things, the UCD will do some incredible things beyond the scope of one set up with slow lower torque servos and spongy push-rods. I use a FX 91 with stock muffler and baffle removed and a APC 15x8 along with Byrons 15% fuel, c/g 5" back from leading edge and high rate throws as much as I can get. This has been the set up that I have used in three UCD`s that I have owned and worn out, Well two that I`v worn out sold and one I`m still working on.
Good Luck And Have Lots Of Fun
Bob Sawyer
