 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 08-13-2003 | 01:14 AM
  #1351
NeoGenesis's Avatar
My Feedback: (27)
Default U Can Do 3D
Personally I've never had a problem.....but I do use a hemostats to stop the fuel flow when fueling.
Neo
Old 08-13-2003 | 01:19 AM
  #1352
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
I have two brand new stainless steel hemostats going cheap if anyone is interested.
Old 08-13-2003 | 01:08 PM
  #1353
My Feedback: (24)
Default U Can Do 3D
I just ordered my UCD .60 size and a 100 Saito. I have a question. If I move the fuel tank so it's on the CG. will I have to use a regulator, or will the saito pump the fuel ok on it's own?
thank you
John
Old 08-13-2003 | 01:20 PM
  #1354
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
You need a cline regulator or a perry pump. Do a search within this thread or in the engine section and you'll find plenty of info and some pics of installations.....
Old 08-13-2003 | 01:31 PM
  #1355
My Feedback: (24)
Default U Can Do 3D
I found a rugulator made by "Iron Bay" it's only 43 bucks, and looks sweet, anybody know anything about it?
JOhn
Old 08-13-2003 | 01:52 PM
  #1356
Default U Can Do 3D
If you use a Saito 100, don't use a perry pump! Been there,... done that. Your engine will stay flooded. Use the Cline. Coomarlin put me on to the cline and I've never been sorry.
MT$W
Old 08-13-2003 | 01:56 PM
  #1357
My Feedback: (24)
Default U Can Do 3D
I just ordered the Iron Bay, I hope it works. Ever heard of it?
Old 08-13-2003 | 02:02 PM
  #1358
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Nope. Is this meant for r/c glow engines ? Perhaps you could post a link for us to check it out. A cline regulator costs $60 but you could find a used one for $40........
Old 08-13-2003 | 02:23 PM
  #1359
My Feedback: (24)
Default U Can Do 3D
try this
www.ironbaymodelcompany.com
Old 08-13-2003 | 02:34 PM
  #1360
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Thx jrjohn. Looks similar to a cline !! And it looks real neat ! Anyone has a review on this ? Gotta check this out as it is cheaper than a cline and it does look better......
Old 08-13-2003 | 02:41 PM
  #1361
My Feedback: (24)
Default U Can Do 3D
let the digging begin
John
Old 08-13-2003 | 03:05 PM
  #1362
NeoGenesis's Avatar
My Feedback: (27)
Default U Can Do 3D
I've been running the saito 100 in it's stock configuration WITHOUT a regulator or pump with absolutley no problems. Don't waste your money. Their not needed. I've got roughly 40 flights on it now.
Neo
Old 08-13-2003 | 03:30 PM
  #1363
My Feedback: (24)
Default U Can Do 3D
neo, Is your tank back on the CG or is it up front?
John
Old 08-13-2003 | 03:44 PM
  #1364
Default U Can Do 3D
Does anybody have a spare canopy for sale or does anyone know where i could get one. Mine broke apart in flight and towerhobbies keeps on moving back the date of availability of this part. I've been waiting for months. Thanks.
Old 08-13-2003 | 03:56 PM
  #1365
NeoGenesis's Avatar
My Feedback: (27)
Default U Can Do 3D
I've got the tank right up behind the firewall. The plane builds so tail heavy that it's really not necessary to put your tank on the CG
Neo
Old 08-13-2003 | 04:12 PM
  #1366
My Feedback: (24)
Default U Can Do 3D
Neo, that explains why it runs fine, I want my tank on the CG. I"m going to use 5245 hitec digital on the elevator, that will save 1 1/2 ounces in the tail, then I plan to put a pull pull on the rudder, the weight of the servo (which will be moved foreword thus having less effect on the tail weight) will depend on how much weight I need if any. Thanks for your imput
John
Old 08-14-2003 | 06:27 AM
  #1367
Default U Can Do 3D
When is GP coming out with a 120 size UCD? I think bumping this plane up 15-20% would make a great "giant" scale plane.Looks like it would be a fun project for this winter.
Any thoughts?
Loren
Old 08-14-2003 | 06:53 AM
  #1368
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
I think they should redesign the firewall and LG first. Sadly nothing was done for the UCD40 although they are aware of the issue. I have a UCD90 and had to do a fair bit of reinforcement. Wonder who runs the engineering dept at Great Pains uumm ...err..Great Planes ??
Old 08-14-2003 | 03:53 PM
  #1369
Default Got two on the way
I have two canopies (Tower makes you order two) en route and should be here any day. My canopy flew off in flight as well at which point I learned 4 screws wasn't going to do the trick. If you like, I'll sell you the other canopy at my cost plus shipping. Just PM or email me if your interested.
When I get the new canopy I'm going to use some double sided foam tape around the edge of the canopy and then I'm going to use about 13 screws (that's what I have in there now) to hold it on. I'm thinking about hacking up my Vlade Divac bobble head doll and stuffing him in there as the pilot. I think it would look pretty cool to see a bobble head going nuts on a low level fly by or hover . Anyone else ever use a bobble head for the pilot?
Old 08-14-2003 | 04:02 PM
  #1370
rhd-RCU's Avatar
My Feedback: (36)
Default U Can Do 3D
I've seen a lot of them.
Old 08-14-2003 | 04:15 PM
  #1371
Default U Can Do 3D
I have had problems with the LG and Firewall on my UCD. The landing gear fell off after a few flights while I was taxiing back to the pits. I laminated two peices of 3/16 ply together with epoxy to make a new LG block (the old one broke during a "Small" crash...it was the second time the LG came off) I also added tri-stock to the front and back sides of the new lg block and epoxied the whole assembly in place. I wish I had pictures becasue it would be so much easier to show than describe what I did next. I drilled two holes that went through the wing dowel plate on the fuse, the LG block and then throuch a balsa truss I epoxied up in front of the LG block and inserted two peices of carbon fiber tubing for reinforcment. Has been competly bulletproof so far.
The firewall came out on the same crash the LG did. I found the firewall was held in with pretty much nothing and probably would have pulled itself off from fatigue after enough flights. To reinstall and reinforce the firewall, I cut up some 1/2" tri stock and epoxied them up in an upside-down "U" shape along the sides and top of the firewall. To plug the gaps I used CA to glue in 1/16" small strips of balsa in between the gaps then sanded them flush to get an uninterupted "U" shaped rib to butt-up agains the fuse sides and upper stringers. Epoxied the assembly in and I dont think it will ever come out now. The fuse would break first I'm sure.
I don't know how you would go about accessing the firewall from inside the plane, but it wouldnt take much just to pull out the firewall. I think maybe if you used a heat gun to head up the glue holding it on, you may, with a bit of force, be able to "rip" the fuse out and make your custom reinforcement for it. Better now than to watch your engine fly off after a couple hundred flights or so. I know it's possible...I watched one guy with his ARF (not a U-Can-Do) on the run-in stand one day and the power from the engine pulled the firewall right out. The plane had never flown!
For all you U-Can-Do owners out there, I consider reinforcing the LG and the firewall a MUST for your and others safety and longevity of the aircraft.
If you don't have a U-Can-Do yet, I have a very in depth review posted in the product reviews section on this site if you want to check it out.
Click here to go to my review of the UCD3D]
Old 08-14-2003 | 05:18 PM
  #1372
Default Belly Pan
In the same vein as the canopy, does anyone have a belly pan? It could be used or new. The plane just looks funny without it.
Dale
Old 08-14-2003 | 05:21 PM
  #1373
Default U Can Do 3D
Dale_L,
Not real hard. Just make you one out of balsa.
Old 08-14-2003 | 05:47 PM
  #1374
Default U Can Do 3D
On the belly pan, I reinforced the corners of mine with tri-stock. I put a hole through one side removing the wing once. with the tri stock its very sturdy and works very well. I also removed the covering on the wing itself and epoxied the pan to the wing that way. Much better adhesion between balsa and balsa than balsa and covering.
If you don't want to build one, I'll do it for you. $25 covered and shipped sound fair? I would be building it based off the one on my plane which is the 60 size so if you have the 46 size I wouldn't be able to do it. I could have it done this weekend, and shipped on monday. Just PM me or email me or re-post on this thread to let me know. I'll even tri-stock the corners for you. Better than new.
Old 08-14-2003 | 07:27 PM
  #1375
Default RE: Belly Pan
Thanks, guys. Yea, I know it is really easy to build one, but if someone had a crashed UCD and I didn't have to build one, that would be great. Call me lazy......
DL
