 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 07-16-2003 | 12:36 AM
  #1276
Default 2 Videos of the UCD
The above URL got messed up
www.*************.com/dodvf/ff_basicclass.htm
Old 07-16-2003 | 12:39 AM
  #1277
Default Videos
Replace the *********** with: *************.com/dodvf/ff_basicclass.htm
Old 07-16-2003 | 01:23 AM
  #1278
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Guys, don't you know that that site is banned from being ever mentioned in RCU ? Eeeer did I say that it's a great site ?
Old 07-16-2003 | 03:17 AM
  #1279
Mr.Burns's Avatar
Default U Can Do 3D
Ok, how can us little people in the dark find out what this site is?
Old 07-16-2003 | 04:09 AM
  #1280
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
OK Mr Burns, kindly take a few steps back from your monitor :
d o w n o n t h e d e c k . c o m
How did that turn out ? He ! He !
Old 07-16-2003 | 04:12 AM
  #1281
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
It works ! Hey Mr Burns, I'm sticking out my neck for ya ! LOL
Old 07-16-2003 | 09:39 AM
  #1282
coomarlin's Avatar
Default U Can Do 3D
Just out of curiousity why is that site banned? If you can't say it here maybe you can PM me. My curiousity has been peaked
Old 07-16-2003 | 11:23 PM
  #1283
Fixed Wing's Avatar
Default Re: Fixed Wing
Originally posted by nosram
You are a fountain of knowledge when it comes to good ideas. How is the Saito 150 doing. Have you finalized your planes for the big gasser, with clipped wings yet
I decided not to clip the wings. Instead, I will simply put a bigger gasser on it. Probably will need the wing area to support the weight. I will have to fabricate some taller landing gear in order to facilitate a larger diameter prop. However, this should be no problem.
On another note, I installed a simple bomb release mechanism underneath the main gear. Next I made a light weight bomb from one of my kid's toys. I took the plane up really high, slowed down and released the bomb. Then I powered the plane into a fast dive like the start of an elevator, popped it into a harrier and tried to catch the bomb in a basket I had affixed to the top of the plane. Have only been able to catch the bomb once so far but am still trying. NOSRAM, with your flying skills I know you could probably catch the bomb every time.
Old 07-17-2003 | 01:00 AM
  #1284
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
I think this plane should be renamed U-Can-Do-Anything. LOL I though the 4* series is the most bashable plane, not anymore...
Old 07-17-2003 | 01:04 AM
  #1285
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Heh ! Heh ! We'd rather let you drool for some time and keep the suspense up. Probably you have found out by now. Otherwise ask Chuck Auger coz he has the guts.
Old 07-17-2003 | 02:29 AM
  #1286
Mr.Burns's Avatar
Default U Can Do 3D
This is my first glow plane, as I transition from electric. Doing some very basic 3d maneuvers. I've D/Led all the Real Flight vivds I can find, as well as search everywhere for info. Not just tutorials, even just explanations of WHAT these maneuvers are. Any help where I can look???
______________________
Sure I'm old, but the joystisk still works.
Old 07-17-2003 | 02:40 AM
  #1287
Default U Can Do 3D
Hope this url is not banned
http://horizon.hobbyshopnow.com/articles/1022.asp
There is a part 2 from Mike McConville on thr Horizon web site
Old 07-17-2003 | 02:51 AM
  #1288
Default Fixed Wing
I tried the bomb deal, just like you said. I powered the plane into a fast dive , popped it into a harrier and tried to catch the bomb in a container on top of the plane.
Guess what the bomb struck the prop, gained momentum and took out the fin and rudder. Luckily it wasn't the elevator, or I wouldn't have managed to land safely.
Not one of your better ideas Fixed Wing
Old 07-17-2003 | 03:51 AM
  #1289
Default U Can Do 3D
That does sound like a good challenge!!!!!!!!!!!!!!
Old 07-17-2003 | 11:29 AM
  #1290
Mr.Burns's Avatar
Default U Can Do 3D
Thanx Nosram. Greatly appreciated.
____________
Older, wiser...... yea right!
Old 07-23-2003 | 02:31 AM
  #1291
Default Roll rate?????
How do you make this plane roll faster? I have it set up in accordance with the instructions and even on high rates the plane is slow to roll left and right. Can you guys recommend any thing to make it more agile or am I stuck with a roll every 1-1.5 seconds? Any comments would be greatly appreciated.
Jeff
Old 07-24-2003 | 04:22 AM
  #1292
BLT
Default U Can Do 3D
Thunderbolt P47 - Have you tried setting up ailevators? A 9C transmitter or equivalent will allow you to slave each elevator half to the same side aileron. I was sceptical until I tried it, thinking that the small span of the elevator would reduce it's effectiveness in roll. However, probably because of slipstream effect close in to the fuselage, I found that it makes a significant difference. It also results in much greater roll control availability when hovering. I am assuming that you have maxed out your aileron travel, all the way to the mechanical limit. have fun flying.
Old 07-24-2003 | 04:30 AM
  #1293
BLT
Default U Can Do 3D
Old 07-24-2003 | 01:45 PM
  #1294
birdie_in_texas's Avatar
Default in dire need of help....
i just recently decided to start flying again...got rid of all my on-road and off-road r/c stuff and got a u can do 3d 60 sized plane...also got a 9C...now...when i flew before, it was with a super7 and a rookie high wing..now i got to learn computer mixing and stuff and how to program..
is theere a guide anywhere? i read the review, but i am lost on half of the terms, and i have not the slightest idea where to start as far as learning terms and actual settings..
am getting ,91 surpassII for engine and some 5625's for servos...
please advise..anything will be usefull....
thanks in advance...
birdie
Old 07-24-2003 | 01:51 PM
  #1295
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Careful with those 5625's. I've seen threads about it locking up in the radio forum. I don't use them but somethin that you might want to be aware of. No flames intended........
Old 07-24-2003 | 02:11 PM
  #1296
Default Re: in dire need of help....
birdie
Understand exactly what you mean. The learning curve on the 9C is steep (as maybe the case with most other sophisticated computer radios). The best way to understand this radio is to start by reading every word in the manual. There is no superfluous information at all. Every word counts. After reading the manual a few times, sit down with your plane in your shop and get ready to use at least two or three battery cycles of time to get the hang of mixes, endpoints, expo, etc. You should try some mixes since the U CAN DO can take full advantage of it with dual aileron and elevator servos.
This radio is very versatile and I have yet to read about any serious shortcomings. I am confident the other competing brands are good (reminds me of Chevy vs. Ford debates.....) but I have only experience (what little I have ;-)) with the Futaba.
I have not been able to locate a guide written by someone else other than the original manual of course. If you find one please let me know. The Futaba FAQ is also a good source of info regarding the 9C.
And nothing beats basic airmanship. Every field has a flier or two who could take a U CAN DO and fly it with a 1980's AM 4 channel as if he was competing in a TOC type competition. But for now I'll take all the microchip help I can get!
Rick
Old 07-25-2003 | 06:23 PM
  #1297
Default Roll Rates
BLT,
Thanks for the great suggestions. Sounds like that is the way to go. I have a Futaba Super 8 so I think that I am in business. Do you have any switch recommendations. I think I want to experiment with the spolieron option too so that I can elevator / parachute the plane also. Will definitely give the ailevators a whirl tomorrow while flying. See ya in the sky!
Jeff
Old 07-26-2003 | 11:56 PM
  #1298
Default U Can Do 3D
Have a Magnum 91 fs in mine and just in positioning the battery and receiver no extra weight was needed. Only thing I don't like is that the covering rips real easy wherever it makes the tight bends. Ugggggh!
Old 07-27-2003 | 01:01 AM
  #1299
Default U Can Do 3D
I went with the standard setup for rudder , but this stops me getting enough throw on elevator as it is stopped by rudder pushrod , how did ye guys get around this? can i just cut the corner off elevator without affecting flight characteristics?
Old 07-27-2003 | 02:49 AM
  #1300
Default U Can Do 3D
just relocate the Rudder servo down to the bottom of the plane, and use pull - pull cables, this will leave room for the elevators to move full travel. the location of the rudder servo will be where ever the fuse is wide enough to clear the width of the servo. then put covering over the area where the servo was located, somewhere near the first 1,000 post there is some pictures of the location.
