 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 07-27-2003 | 03:04 AM
  #1301
Default U Can Do 3D
okay ,that is one way , but can I just clip the corners off elvators , that would allow me get more throw , but would it adversley affect the flight characteristics? Has any1 else tried this?
Old 07-27-2003 | 03:41 AM
  #1302
Mr.Burns's Avatar
Default U Can Do 3D
I have read where some were thinking of removing the wing tips. Has anyone tried this?
Old 07-27-2003 | 04:22 AM
  #1303
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Originally posted by obi1
I went with the standard setup for rudder , but this stops me getting enough throw on elevator as it is stopped by rudder pushrod , how did ye guys get around this? can i just cut the corner off elevator without affecting flight characteristics?
The pull-pull setup pic is in post #114
But I suppose the easiest way is just to mount your rudder horn in the lowest position possible. I think in this way, there's no real need for pull-pull as the same max elevator throw can be achieved.
Old 07-27-2003 | 09:43 PM
  #1304
Default Programing my Futaba 9C
Well, my U Can Do is completed. I just need some help setting up my 9C radio. I do not want to use any Y's. Can someone tell me what channels to plug everything into? Thanks
Old 07-27-2003 | 10:06 PM
  #1305
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Rcpilot44, what receiver are you using ?
Old 07-27-2003 | 10:07 PM
  #1306
Default U Can Do 3D
Hitec 8 Channel..
Old 07-27-2003 | 10:15 PM
  #1307
coomarlin's Avatar
Default U Can Do 3D
I built my UCD in January and have spent half the summer flying it. Although I'm not an accomplished 3D pilot, the UCD has it's strengths and weaknesses. It's an awesome slow flying aircraft and one of the best hovering planes I've ever seen or used. It's very forgiving and can land like a trainer if you want it to. Some of the things it doesn't seem to do well at are Knife Edge and Harriers. When I try to KE the plane tucks to it's belly and rotates. I haven't had much luck mixing it out. And when I get the plane in a harrier it rocks back and forth pretty violently. Now as I stated above I'm certainly no expert, but I've done better harriers with other planes. I've got a rearward CG at 6.25".I need to keep practicing, but as of now those are my main flying concerns.
As for the structural integrity mine has been really good so far (cross my fingers).
Old 07-27-2003 | 10:36 PM
  #1308
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Hi cool, what engine are you using and how many flights so far ? No mods on the firewall and LG at all ?
Old 07-27-2003 | 11:24 PM
  #1309
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Originally posted by rcpilot44
Hitec 8 Channel..
Assuming you have the US manual, please see twin elevator servos on page 49 of the 9C manual.
Old 07-28-2003 | 12:46 AM
  #1310
Default coomarlin
I agree 100% with your comments, Torque roll is great as are slow fly inverted spins, blender, waterfall. Elevator has bad wing rock, and the Harrier needs loads of right rudder...a scary amount. Likewise I have better Knife edge and Harrier planes. Its a great plane to fly, but I expect like most people I am in search for the perfect model. Actually I don't think it exists, so in the meantime I guess we just make the best of each model.
I also have my CofG at 6.25" and am running a Saito 100. Still a great plane
Old 07-28-2003 | 01:58 AM
  #1311
Mr.Burns's Avatar
Default U Can Do 3D
Max travel on elevator and ailerons. I mix 80% spoilerons, and it settles into elevators and harriers, with little to no rock. Saito 100 with CG at 6.125.
Old 07-28-2003 | 02:05 AM
  #1312
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
I've seen videos at DODVF of UCD doing great harriers and rolling harriers
Old 07-28-2003 | 02:35 AM
  #1313
My Feedback: (19)
Default U Can Do 3D
I built my UCD back in October. ST 90 w/MCP, 7 lbs, 2 oz, CG at 6 3/8". During the past 9 months it's logged way over a hundred flights....and I flew it three more times today. Within the first 20 flights, the CA hinges broke on the rudder, elevator, and ailerons. Great Planes pinned hinges cured that problem completely. When the UCD was fairly new, the firewall and landing gear mounting area were knocked out after a flameout during a hover. Gorilla Glue fixed them stronger than new with no problems since.
I'm no expert 3D pilot either, but I agree with coomarlin and nosram. The UCD is a fun 3D and hovering plane, but it's got some quirks in knife edge and harrier flight.
Descending in an Elevator works well with spoilerons mixed in. And spoilerons help with outside waterfalls too. But spoilerons don't seem to help much in harrier flight. And I haven't found much use for flapperons hardly at all.
After flying my UCD for the past 9 months, I still like it. And for the price, it probably can't be beat in it's size class.
Old 07-28-2003 | 11:21 PM
  #1314
My Feedback: (-2)
Default U Can Do 3D
I have one and they are all very tail heavy. when I sday very I mean VERY heavy. It takes about 5 to 6 oz. to level them out. Move the battery all the way forward under the tank and move the engine out as far as possible. Add 2 oz. lead weight to the spinner and 2 more on the firewall and you wilo have it. It flys great but the vertical stabizer have fallen off on a number of them in flight.
Old 07-28-2003 | 11:35 PM
  #1315
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Hi wink, what engine are you using ?
Old 07-29-2003 | 02:31 AM
  #1316
My Feedback: (19)
Default U Can Do 3D
Hmmmmm......the recommended CG is 4 7/8". I started out at 5.5", and thought it was too nose heavy. So I moved the ST 90 as far back on the mount as it would go. That put the CG about 6.0" back, but it still felt too nose heavy. So I replaced the mount with a smaller and lighter 60 size GP mount, with the engine mounted back as far as it would go. That gave me a 6 3/8" CG, which I'm satisfied with.
In fact, I never installed the cowl or the wheel pants because they would have added unwanted nose weight.
Old 07-29-2003 | 04:17 AM
  #1317
Volfy's Avatar
My Feedback: (23)
Default U Can Do 3D
Originally posted by wink5360
...It flys great but the vertical stabizer have fallen off on a number of them in flight.
Wouldn't the first time be the clue to glue it back really, really good?
Compared to some ARFs I've had , the vertical stab mounting design is fairly robust. However, mine was severely cocked to one side dry-fitted. I had to tape and clamp real hard to the opposite side while the epoxy set to correct it.
I do agree that it builds a little tail heavy though. I have the servos, engine, tank and gears installed so far, and the CG is wayyyyy back there, probably 7~8" behind LE. Still, I'm sure I can shift the CG up to at least 6" once the cowl+prop+spinner+battery are added. From what you guys are saying, 6" should fly just fine.
Old 07-29-2003 | 04:33 AM
  #1318
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
There was a post here about a simple way to install fly wires to the tail. Pretty easy to do and well worth it.....
Old 07-29-2003 | 05:07 AM
  #1319
rajul's Avatar
Moderator
My Feedback: (58)
Default Fly wires
Here you go http://www.rcuniverse.com/showthread...67#post1089596]
Old 07-29-2003 | 10:30 AM
  #1320
rajul's Avatar
Moderator
My Feedback: (58)
Default Robart point hinges
Has anyone tried Robart point hinges on their UCD ? What size did you use 1/8" or 3/16" ? How much spacing between hinges ? Will appreciate some pics of installed hinges. Thx...........
Old 07-29-2003 | 12:00 PM
  #1321
Default test
test
Old 08-02-2003 | 03:35 AM
  #1322
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Do you guys take-off at full throttle or partial throttle with the Saito 100 ? What are some of your experiences ?
Old 08-02-2003 | 05:43 AM
  #1323
Default U Can Do 3D
on grass half on asphalt full and up in 2m.
Old 08-02-2003 | 06:15 AM
  #1324
rajul's Avatar
Moderator
My Feedback: (58)
Default U Can Do 3D
Hi adrian, I imagine that on grass you'll need more throttle due to the ground resistance ? Seems like it's the opposite
Old 08-02-2003 | 11:26 AM
  #1325
coomarlin's Avatar
Default U Can Do 3D
It doesn't take much. I fly off of grass and usually just use half throttle unless I want to get crazy and launch the plane like a rocket
