 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 11-10-2003 | 06:18 AM
  #1626
coomarlin's Avatar
Default RE: can u
Nice looking pics tech. I've heard of people wrapping their tanks with strapping tape. Does that really work? Are you using a YS engine, or a regulator?
Old 11-10-2003 | 07:25 PM
  #1627
I & C Tech's Avatar
Default RE: can u
Don't know if the strapping tape is a cure-all but I got it from a suggestion on this thread. (I think) I'm using a YS-110. I also put the bag in a Zip-Loc freezer bag poking the lines thru it. Kinda hoping if a get a leak that it may help minimize the damage.
Old 11-10-2003 | 10:05 PM
  #1628
Default RE: can u
your crazy man dual bags
for your bags????
help reitterate.
Old 11-11-2003 | 10:09 AM
  #1629
CougarRules's Avatar
Default RE: can u
Can anyone tell me how to get hold of a U-CAN-DO-3D 60 here in the u.k i believe irvine imports great planes models but cannot find a website.
Cheers Lee.
Old 11-11-2003 | 10:24 AM
  #1630
Sprink's Avatar
Default RE: can u
Inwoods list them. I suggest emailing/phoning to check whether in stock or not.
http://www.inwoodmodels.co.uk.html
Also I think Slough Radio Control had them, though it is not on their website.
http://www.srcm.co.uk/
Otherwise just phone around the usual suspects: Sussex Model Centre, Als Hobbies, etc. I'm sure someone has one in stock.
Old 11-11-2003 | 10:25 AM
  #1631
Default RE: can u
Hi Lee,
Try Sussex Models or Inwood Models they list U Can Do on their Web site.
Cheers
Rowdy
Old 11-11-2003 | 10:27 AM
  #1632
Default RE: can u
Cheers Guys
Lee.
Old 11-11-2003 | 05:14 PM
  #1633
Default RE: can u
hey all i have a u can do 3d with an os 91 four stroke.
i came across a check valve at tower hobbies and wondering if this would do anything.
i will be setting my tank on the cg just like I&amp tech.
i am not running a pump because i don't want to spend any more money on this thing.
the link to the check valve is right here
http://www2.towerhobbies.com/cgi-bin...?&I=LXG869&P=0
will this help out keeping pressure in the tank????
thank you all for your concern.
Old 11-11-2003 | 06:34 PM
  #1634
Mr.Burns's Avatar
Default RE: can u
You cannot use a check valve without a regulator of some kind. Others have posted of several brands of regs.
Old 11-11-2003 | 07:46 PM
  #1635
Default RE: can u
ok what would it do without a regulator.
i was in the understanding that the check valve will prevent pressure from leaving the tank and to prevent fuel from going into the engine while fueling.
please help me understand.
Old 11-11-2003 | 07:53 PM
  #1636
Default RE: can u
oh almost forgot have to show off custom stickers.
ID:	74145   Click image for larger version
Old 11-11-2003 | 08:02 PM
  #1637
Default RE: UCD
I'm putting an OS 50 on my U CAN DO 3D 46, what size prop do I need for hovering?
Roy
Old 11-11-2003 | 08:46 PM
  #1638
coomarlin's Avatar
Default RE: UCD
You can't use a checkvalve without a regulator because without the regulator to control fuel flow there would be too much fuel coming into the carb. You'd never get a consistant idle.
Old 11-11-2003 | 08:56 PM
  #1639
Default RE: UCD
haha
thanks i was thinking along the lines of to much fuel flow.
and then i thought regulator and what is its use????
and then it clicked.
thanks a bunch
Old 11-12-2003 | 06:09 AM
  #1640
My Feedback: (20)
Default RE: UCD
ORIGINAL: Roy L. Wilson
Roy
Try a APC 12.25"X3.75
Old 11-12-2003 | 10:32 PM
  #1641
Default props
he all with the os 91 surpass
what props do you use???
i had bought an apc 15x6 and 16x4
will these work???
Old 11-13-2003 | 12:03 AM
  #1642
SBR_RV's Avatar
Default RE: UCD
the amount of replyies here is crazy
Old 11-13-2003 | 06:01 AM
  #1643
coomarlin's Avatar
Default RE: props
ORIGINAL: james yeram
will these work???
I don't own a 91 FS, but my hunch would be that those props might be just a tad too much. however I could be wrong. I've heard some people complain about slow spool-up time on a Saito 100 and a 16x4W prop, so it would probably be even a little slower on the OS. I would think the APC 15x4W might be a better choice, but someone here might be able to provide you with better info. If those props are a bit large, you could try running more nitro. Let us know what kind of results you get.
Old 11-13-2003 | 02:28 PM
  #1644
Default RE: props
no problem thanks!
Old 11-13-2003 | 05:56 PM
  #1645
MRMcFarlandM's Avatar
Default RE: props
Hi I use a 15X4 on the .91 surpass and it works good but the pull out is a little slow from a hover
the 15X6 pulls out faster but for me it is harder to get it just hang there.
Mike
Old 11-13-2003 | 06:35 PM
  #1646
Default RE: props
thanks for the info
Old 11-14-2003 | 01:09 PM
  #1647
HarleyRider's Avatar
My Feedback: (10)
Default RE: UCD
This week my friend and I were flying our 60 size UCANDO with Saito100's. My engine quit due to pressure fitting blowing out. I turned into the wind but unable to make the runway. Airplane was very slow on touch down in grass. Gear popped right out.
Next flight by my friend and on a very gentle landing his gear popped out. Both airplanes had wing damage due to wheel pants sticking into covering. Our gear had been hot glued in. It appears it is very weak in this area. Flies very well.
My two cents worth.
Old 11-14-2003 | 09:39 PM
  #1648
Default RE: UCD
here is my tank
ID:	74791   Click image for larger version
Old 11-14-2003 | 10:28 PM
  #1649
Default RE: UCD
i am going to hook up a remote glow and had a question???
can i hook the ground wire to the landing gear or does it have to go to the engine???
of course i would sand down the paint on the landing gear
thanks for your help
Old 11-14-2003 | 10:35 PM
  #1650
cmassa's Avatar
Default RE: UCD
James,
The ground for the remote glow driver needs to be attached to the engine somewhere. The easiest thing is to put it under one of the screws for the engine back plate.
Chris
