 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 08-18-2005 | 01:26 PM
  #3101
raideron's Avatar
Default RE: U-Can-Do 3d 46?
CeeGee... Hey CeeGee... Isn't moving, getting re-setup great..
Repair report.... No movement..... Gary kick me again...
Old 08-18-2005 | 03:09 PM
  #3102
rclement's Avatar
ORIGINAL: raideron
OH Man!! It's terrible. And we only moved about 5 miles. Still ya gotta box everything up and somehow figure out a place for it and sometimes it doesn't fit in the new place. Speaking of moving, move that airplane around some and get it done. It's bugging me seeing the picture of it laying there like that. It looks like some buzzards have come down and pecked it apart...[X(] And what all the grandkids think? There ought to be a law against that. It looks like "fuse abuse" to me.........[X(
Old 08-18-2005 | 03:58 PM
  #3103
raideron's Avatar
Hey CeeGee.... Yeah we moved just a few times... But it was more
than I wanted to... I know what you mean about... about finding
all the stuff you didn't know you had, and finding the right spot for
them..... But from one of your previous post, I see that your shop
looks good
Yeah, I feel bad for my UCD... I did move it... I thought it glued it-
self to the make shift table... But in all honesty, I did do some work
on it... I lowered the tank somewhat after installing the engine mount
The tank and Tk. saddle is ready to be glued in... etc. etc. etc.:-))))
Plus I used the old tank on my profile:-)
I "plan" to re-epoxy the firewall... install the new 10oz tank and epoxy
the tk. saddle in tonight.... Then work on making up a new landing
gear block, the old one came out in half from where I strengthen it..
I think I'm going to screw on the sheet of bulsa that I cut out in the
tank area???....... It really won't take too long if I ever get going on it,
But as the Grand daughter said just before she went back home...
That plane sure has been sitting there doing nothing since I've been
here, You should fix it or move it.. Gramps.... This was after I asked
her to crawl under the table to turn on the printer:-)
But another hold up was me trying to learn how to sew up my old props
now that there is no help on that And I'm still waiting on Gary to get
in touch with some talking dog in hopes that he'll know... But thats after
he's done watching some movie ...... In the mean time SERGIO is putting
together all these planes... And you have no time because your getting
the new place setup..... Geeees... No wonder I'm so slow.... No help...
Old 08-18-2005 | 06:36 PM
  #3104
gjeffers's Avatar
Sergio, move that really nice plane so i can kick Ron,
CEEGEE, just remember that its things and times like moving that make the rest of life so much SWEETER
Old 08-18-2005 | 10:59 PM
  #3105
rclement's Avatar
ORIGINAL: gjeffers
Gary, I hadn't thought of it quite that way, but that is very true. All the hard work is paying off. It is so nice here. We love it. I told my wife that we need to put a cemetery in the back of the property because I'm not moving again. [:-]
Ron , True, true, and true. Now get that plane back together before I sick Gary on you. [>:]
Old 08-20-2005 | 01:56 PM
  #3106
sctcrash's Avatar
I want to mount my Magnum 91 in today or tomorrow. Right now I only have the 40-70 Great Planes Mount that came with the UCD. It seems that I can mount the Magnum on it, but is that a bad idea. i am sure a 60-90 size mount will be stronger, but I will probably have to drill out the firewall for a different mount. Does anyone have a 91 on the mount that came with the plane?
Old 08-20-2005 | 02:23 PM
  #3107
My Feedback: (24)
The stock mount is fine. It's holding up to Saito 100's.
Old 08-20-2005 | 05:41 PM
  #3108
gjeffers's Avatar
no saito 100 unless you put the carb thru the firewall, i dont know about the mag though
Old 08-20-2005 | 08:11 PM
  #3109
sctcrash's Avatar
I got it in there, i took off the choke and it fit in, barely, but it fit. The manual said you dont need the choke if you use a started because it will prime itself. I do have the room to put it back on, but didnt want to deel with the cutting access for it through the cowl anyway. As long as the mount will handle the stress of the 91 I should be fine.
If I remember correctly there was a pretty good description somewhere in this thread about lowering the fuel tank. Does anyone remember where abouts it is. If not dont worry I will look through the thread for it. I believe it was atleast in the first 40 something pages. I just worry about cutting up the plane and messing it all up. What's the best way to break the existing glue so I can take it apart cleanly?
Old 08-20-2005 | 11:12 PM
  #3110
gjeffers's Avatar
hey crash its on page 71@72, on how to open up the front fuse where the tank is
Old 08-21-2005 | 10:33 AM
  #3111
My Feedback: (24)
ORIGINAL: gjeffers
All I did was file the web off the mount. My carb wasn't through the firewall , prop drive hub was in stock location.
Old 08-21-2005 | 11:05 AM
  #3112
gjeffers's Avatar
hi prophangar, yea me and my son put his 91 on his and it worked but man it just didnt look sturdy enough for me to stand around and run it up, i guess im just a scardie cat, do you have some pics, id like to use mine for weight reduction, but it still looks like the carb screws would be right where the bottom left mount screw would be, thanks
Old 08-21-2005 | 11:36 AM
  #3113
My Feedback: (24)
Yes it will hit. You need to use a 1/4 inch bit to counter sink the screw there. No pics but its plenty strong.
Old 08-21-2005 | 01:33 PM
  #3114
Banned
[link=http://www.rcgroups.com/forums/attachment.php?attachmentid=568595]my first hovering video[/link]
Old 08-21-2005 | 03:47 PM
  #3115
gjeffers's Avatar
thanks hangar, when i get around to it ill try it[8D]
Old 08-21-2005 | 06:05 PM
  #3116
My U-Can_do is one of the sweetest birds I have had...it flys fantastic...only one problem..it doesn't do a snap roll...anyone else have the same problem???????
Old 08-21-2005 | 08:26 PM
  #3117
I have a futaba 6 channel t6xas radio. What mixing do I need to set up to be successful with this U-Can Do .46?
Old 08-22-2005 | 08:26 AM
  #3118
SPUD37's Avatar
Hey Crash,
SPUD here-I have the 91 OS 4C in mine with the stock mount & have had no problems. I originally had a 70 4C on there but went to the 91 with no problem. Same mount just had to drill two holes in the mount for the dif motor, not the fire wall. I grind the round nose wheel bosses off of the mount for clearance if the mount has them.............Hope this helps.
SPUDs out.................see ya.
Old 08-22-2005 | 06:35 PM
  #3119
sctcrash's Avatar
Thanks Spud, I'll definetely grind off those wheel bosses to give me a little room. I test mounted the engine and it all looks good, now I need to run a new throttle line.
How did everyone go about cutting out the cowl? I just got a new cowl and need to cut it up to match the new engine. When I cut the first one I wound up with a lot of fibreglass strands dangling from my cuts. I even got some cracking around a couple of the cuts.
Old 08-22-2005 | 08:43 PM
  #3120
SPUD37's Avatar
Hey Crash,
I get a folder cut some 2-3" wide strips. I tape them to the plane where a hole has to be in the cowling. Make your holes, then with the strips still on the plane mount your cowling(with the proper depth of course) then mark your holes on the cowl. I use a small pointed stone tip on my dremel tool to cut out the holes to my marks. I use 220 grit sand paper folded small and litely sand the edges from the inside to get rid of any strands and rough edges. If you want you can run a little CA on the inside to reseal the edges of glass(not necessary), and thats how its done in the mohawk hangar. Hope this helps.
SPUDs out.........see ya
Old 08-23-2005 | 09:37 AM
  #3121
rfaria's Avatar
ORIGINAL: sctcrash
I started my cowl work with a dremel tool but I found a half round and rattail file to work best for me.
The cowl will chip and crack and the files seemed to give me more control over that problem.
Good luck and enjoy the UCD.
ID:	313974   Click image for larger version
Old 08-23-2005 | 11:54 AM
  #3122
Great U Can Do Thread
Been flying for a year and a half. Looking forward to flying my U Can Do. Dumb question. Is there a book or reference on how to fly 3-d manuvers? I fly mostly alone and there is no one around to explain snap-rolls, flat-spins, ect.
Doug
Old 08-23-2005 | 03:28 PM
  #3123
My Feedback: (17)
The first manever you'll want to learn is the "inverted flat spin landing" It's a once in a lifetime stunt.
Barry
Old 08-23-2005 | 09:39 PM
  #3124
all of that comes form pros teaching you or you can do it yourslef
Old 08-23-2005 | 10:10 PM
  #3125
gjeffers's Avatar
Dougwill, go here:
http://www.blaineaustin.com/3d_tips.htm
and here(to 3d university)
http://www.flyingcirkus.com/
hi Barry
