 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 12-22-2006 | 09:44 PM
  #5651
My Feedback: (197)
Default RE: U-Can-Do 3d 46?
ORIGINAL: raideron
mnrcaerobat... Great advice above from the experts!!... Can't beat CF rods... I tried to save
some $$$$, so I just used 440 rods that I had with the stock horns etc. all else is what came
with the "D0"... Well not that I had too, or gained much if any, but I went with the bigger
engine mount and a different tk. I also started with the sulivan tailwires, but they have been
removed and all is still hanging on there... The biggest thing is to in no way score the bulsa
when removing the covering and you should have no problems... Ohh I also went with GP
pinned hinges and used Gorilla/pro bond glue, I love the stuff, and I only used it on two
planes so far.. the "Do" and S.T. but it will be the glue of "my" choice from now on...
OK.. some help.. I started to work on installing the Hyde mount, but that's on hold.. but
anyhow... Here is some pic of the S-82 after just 4 15min flts. starting out clean....
is that about how it is even with the stack(fuel mess)... or am I still running too rich? my H.S.
is almost always at 1&1/4-1/2 open...
I have never had a four stroke get that much black oil on it. I used to get a lot of it on the MDS and Magnum two strokes though.
Old 12-22-2006 | 09:48 PM
  #5652
My Feedback: (197)
What servos should I run on my ailerons and elevator? I have some standards and/or Hitec HS-625MG.
Old 12-22-2006 | 10:31 PM
  #5653
rclement's Avatar
ORIGINAL: mnrcaerobat
ORIGINAL: rclement
Have fun with your U Can Do build. It's been the funnest plane I've owned.
I make my own rods out of carbon fiber tube and 2-56 rod ends. I'm sure they're not as good as the Central hobbies ones but I can the components at my LHS. Don't know if anyone mentioned but you'll want to beef up the landing gear too. Gjeffers has pictures of how to do it. It's very easy to do and needed. I never did install the tail wire set up. Kept forgetting to. But I've owned 3 Do's and never needed them. [insert: knock on wooden head : here]
The Do's are the best plane around and since I'm the only one at my field that flies one I look like a genius. [X(] I'm sure that would change if Gjeffers, Barry and Ron showed up......[>:]
Here's some pics of my Do......
What did you use at the ends of your cf rods? I have had problems with the smaller rods wanting to split in the past. I have used shrink tubing over my cuts.
I use aluminum tubing over the ends. Just a short section. I get CF tube from the hobby shop that is about the same inside diameter as the 2-56 rod then I carefully run a drill bit into the rod. It doesn't really take much out at all. It's just seems to clean it up enough for the 2-56 to fit. Then I glue them in with JB weld and put them in the oven on the warmest temp which is about 170 degrees and leave them in there for about 15 min. I've used these on several planes now and they have never given me any problems.
Old 12-22-2006 | 11:09 PM
  #5654
The MacDaddy's Avatar
My Feedback: (10)
Radieron,
What's up with all that fuel line?? Looks like a problem.... my S72 is as clean as a whistle, add the opt. Saito Velocity Stack and run that crankcase vent out the bottom by itself.
Mac
Old 12-22-2006 | 11:29 PM
  #5655
gjeffers's Avatar
with 76oz of torque their perfect
Old 12-22-2006 | 11:30 PM
  #5656
I have the same engine Saito 82 and I never had any black stuff coming out like that. It definitely not good, when it's coming black it's because something is not right inside the engine. Anybody idea? I would maybe send an email to horizon hobby and see from there???
Old 12-22-2006 | 11:43 PM
  #5657
You know guys, at first I wasn't a big fan of that plane, but now that I fixed my gear thank to you! I really like it now especially with the Saito82 14x4W go match. It's a ruff plane specially after many snap rolls! I know now that is one the busiest post on RCU!
Right now in Cold Lake it's winter and I flight on the lake one block from my house, there a video I made with the plane on ski, noting special just winter flying!
By the way, I think that the regular hardware who come with the plane is just fine except for the tail wheel.
Have a good weekend all!
http://www.youtube.com/watch?v=pR0hftwq71Q
Old 12-22-2006 | 11:55 PM
  #5658
gjeffers's Avatar
man, i bet that ucd never overheats..... hey Barry, i thought you said it was too cold to fly in Idaho?
great vid choopi
Old 12-23-2006 | 12:58 AM
  #5659
My Feedback: (17)
That is a good video. Now I have no excuse not to fly.....One benefit I see....the prop won't get any green on it from the grass....
Barry
Old 12-23-2006 | 01:00 AM
  #5660
My Feedback: (17)
Barry
Old 12-23-2006 | 09:47 AM
  #5661
rclement's Avatar
Great video choopi. It's neat to see some Do action. It's been too rainy / windy here to fly. Yuk! We had a major wind storm that demolished the area. Hopefully I can out soon. I need a Do fix. []
This must be Gary's favorite time of year to fly......[8D]
Old 12-23-2006 | 10:43 AM
  #5662
gjeffers's Avatar
i hate rubbing it in Rob........ but it is gonna be 60 today and winds at 3 mph all day........ so here i go right after patty finishes that bacon and eggs[X(]
Old 12-23-2006 | 12:54 PM
  #5663
My Feedback: (17)
gjeffers...
Sounds like August in Idaho.
Have fun. Fly low.
Barry
Old 12-23-2006 | 01:01 PM
  #5664
Thanks guys,
I know it's a cold but at least there is no bugs! I usually flight around 30 degrees if it is not to windy, you just have to dress good! and when it's colder that when I start with the electric like my funjet.
Old 12-23-2006 | 02:05 PM
  #5665
Black and Grey steaks around a Saito motor. Aluminum and oxygen make grey/black. I had this once on a Saito 150 for a few flights. Turned out to be a loose exhaust elbow. I think the elbow is steel, and it was vibrating on the aluminum muffler. By the time I found the problem the threads on the muffler were stripped. Had to purchase a new muffler. Check you exhasut elbow to head connection, your elbow to muffler, and your intake from carb to engine. Bet one of them is loose. Tighten and problem goes away, if you are not too late. Jim Tucker, Midhurst, Ontario, Canada
Old 12-23-2006 | 05:55 PM
  #5666
raideron's Avatar
Ahh.. That's just great... [:@] Thinking I got a lemon 82.. she sure does shake a bit.. But
she just runs and runs.. I went through all the screws and they were all tight, I did pull the
intake and greased the o-rings when I put the stack on.. And the exhaust has never come
loose, it's locked tite and screwed as far in as possible... Guess I'll clean her up leave the
cowl off, run and check it out.....
Old 12-23-2006 | 06:00 PM
  #5667
My Feedback: (17)
choopi....
Do you use some kind of cover on your radio? I tried flying with gloves one time...that didn't work for me. Kinda like flying without my lucky hat. Anyways, if you have a link to something you've purchased to keep your hands warm while flying, I'd appreciate you sharing it.
Barry
Old 12-23-2006 | 07:07 PM
  #5668
Barry,
I always use my flying glove that we use in the Canadian Air Force, you can get those on line, they are very good(25$). That is the only glove that I can feel the sticks on the radio and the swtiches they are good for me anyway easily down to 15F.
http://www.uswings.com/gloves.asp (US Wings Nomex Flyer's Gloves)
Old 12-23-2006 | 08:10 PM
  #5669
rclement's Avatar
ORIGINAL: gjeffers
Bacon and eggs.....? Now I am jealous... We don't have bacon and eggs. We had a bad wind storm here and we were out of power for 6 days and when the power came back on the refrigerator didn't work. The repair guy can't make it here untill next Tuesday. All our cold food is in a cooler on the kitchen table... But that reminds me....... I think I'll take my wife out for breakfast in the morning... [8D]
Old 12-23-2006 | 09:06 PM
  #5670
raideron's Avatar
Not that it gets that cold here... But for us AZ folk... 40degs is freezing, as they say
first one in starts the fire
I tried some light wool gloves last time out.... It wasn't too bad, but funny thing on
my second flt. on to the last the gloves were off... It just does not feel right, it
seems to take the touch away....
Old 12-23-2006 | 10:08 PM
  #5671
gjeffers's Avatar
a big ol pouch made out of rabbit fur(Something like the nfl quarterbacks use except way bigger and sewed up on one end) and put your ant out a top slit, then slid your paws in the bottom and that way your hands would be warm and you wouldnt loose the touch
Old 12-24-2006 | 11:23 AM
  #5672
raideron's Avatar
People at the field were talking about something like that... I also tried cutting the thumb
and finger on the gloves some so that the tips of my finger/thumb were out, but those
gloves started staying home also... Guess it just does not get that cold here.. But in that
snowy area you would need something for sure....
Old 12-24-2006 | 11:31 AM
  #5673
gjeffers's Avatar
you could always park next to the runway with the heater on if it that cold.... or maybe just build some glass boxes to stand in
Old 12-25-2006 | 10:17 AM
  #5674
My Feedback: (35)
Here's a couple of links. The first one looks pretty nice but I don't know anyone that has ordered from the company. The second one is a home made version with the basic plans posted so you can make your own.
http://www.raydiowarm.com/new_mitts.htm#
http://www.blueangels.rchomepage.com...tter_glove.htm
Old 12-25-2006 | 06:27 PM
  #5675
I have a Saito 80 on my U-CANDO and because it needs to be rebuilt I want to put a new Saito 82 on it but have heard that it doesn't run well up side down, any input on this would be great.
