Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 Black Magic VF3 E build thread! >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 05-08-2010 | 07:48 PM
  #101
petec's Avatar
My Feedback: (58)
Default RE: Black Magic VF3 E build thread!
Chris, it looks like the silkspan is ok but the primer is lifted.
Chuck, I'm doing my best but I wanna play with my toy....
Old 05-08-2010 | 11:11 PM
  #102
Hey Pete,
What is the type paint you are putting down?
Larry
Old 05-09-2010 | 07:46 AM
  #103
petec's Avatar
My Feedback: (58)
Omni acrylic enamel....same stuff I used on my V2.
Old 05-16-2010 | 10:47 AM
  #104
petec's Avatar
My Feedback: (58)
Paint has been fixed....not great but way better than it was.
V2.2 meet VF3E
ID:	1436999   Click image for larger version
ID:	1437000   Click image for larger version
ID:	1437001   Click image for larger version
ID:	1437002   Click image for larger version
Old 05-16-2010 | 04:08 PM
  #105
RC_Pattern_Flyer's Avatar
Pete,
I know its not what you wanted but it looks great and puts closer to being in the air.
After liftoff your painting woes will disappear!
Chuck
Old 05-17-2010 | 11:45 AM
  #106
petec's Avatar
My Feedback: (58)
I keep saying that at 150 meters no one will see a single blemish.
Old 05-17-2010 | 12:27 PM
  #107
My Feedback: (45)
ORIGINAL: petec
You mean paint blemish I'm sure we'll be able to find many other blemishes
Arch
Old 05-17-2010 | 02:35 PM
  #108
petec's Avatar
My Feedback: (58)
ok Arch....PAINT BLEMISH
Old 05-17-2010 | 09:56 PM
  #109
Pete:
My criteria for paint blemish repair is 50/50. Fifty feet at fifty MPH
Ed
Old 05-18-2010 | 08:36 AM
  #110
petec's Avatar
My Feedback: (58)
I like that criteria.
Old 05-29-2010 | 10:30 AM
  #111
First try to upload images. Hopefully it works.
The fuz starting to take shape in the background and my stab template for cutting lightening holes in the foreground.
Something to watch out for is that the 4 5/8" measurement at the root for determining the elevator is wrong. It should be 4 3/8" (The tip measurement of 3.25" is correct). If you use this measurement as a reference line (as I did) without checking it your wing tube will not be at 90deg to the root face and you will need to do some serious work to align the stab halves.
Old 05-31-2010 | 06:54 PM
  #112
petec's Avatar
My Feedback: (58)
Lookin' good Grant.
I have a Skype account now, so if there are any questions we can talk.
Pete
Old 06-01-2010 | 01:09 AM
  #113
Thanks Pete,
It feels like it is coming together (slowly). I'm thinking of calling it a Black Magic VFME because of all the thought I've put into it [8D]
I'm mulling over how to do the stab/wing tube. I started with the stabs because I felt it might be easier. My plan is to drill a hole with a brass tube. I've already done a test hole on a piece of scrape and the size is perfect. My only problem now is how to jig the tube so that the hole is down the center of the stab and at 90deg to the root.
My current plan is to drill a hole through a 2" block of pine with a drill press and carefully position it on the stab root. The 2" long hole should maintain directional stability of the brass tube. Aligning the block square to the stab root is however still a concern.
Any ideas from the bofs?
Old 06-01-2010 | 08:12 AM
  #114
petec's Avatar
My Feedback: (58)
ORIGINAL: grantb
Thanks Pete,
My current plan is to drill a hole through a 2'' block of pine with a drill press and carefully position it on the stab root. The 2'' long hole should maintain directional stability of the brass tube. Aligning the block square to the stab root is however still a concern.
If it were me, and it will be quite soon. I would mark the center line of the tip and the root and then draw a line connecting them down the leading and trailing egde (you did block those square for wood stock correct). Then you can jig up th ecore while in the shuck to maintain those LE and TE lines parallel to the bench top and then use your pine jig to align the tube for drilling the hole in the core.
Old 06-01-2010 | 08:57 AM
  #115
Thanks Pete,
Yes, the foam is squared up.
I will post pictures of the jig and end result.
Old 06-01-2010 | 09:08 AM
  #116
petec's Avatar
My Feedback: (58)
Wonderful. Looking forward to see them.
Old 06-03-2010 | 10:03 AM
  #117
AmericanSpectre505's Avatar
Great job Pete,....
now go get some stick time,.........
after you fly it,..you won't be able to sleep!
Regards,
BHolsten
Old 06-04-2010 | 08:30 AM
  #118
petec's Avatar
My Feedback: (58)
Still need to get the wings and stabs covered. I am hoping to get that done this weekend. Seeing it sit on the basement floor mocking me is getting quite old.
Old 06-05-2010 | 11:21 AM
  #119
Apologies for the low tech approach. Would have liked to use a wider block of wood but by placing it on the shuck at an angle I seem to have achieved an acceptable result. The cutting tube is made from the tailboom of a small electric heli.
ID:	1448201   Click image for larger version
Old 06-06-2010 | 07:49 PM
  #120
petec's Avatar
My Feedback: (58)
Looking good, but I see a lack of ale and lager bottles in the background.....
Old 06-13-2010 | 10:32 AM
  #121
Slow progress. Here is the 'just finished' front turtle deck and a slightly trimmed and cleaned up version. Still a lot of work.
I've set the false ribs in the stabs and created the stab sheeting. Hope to cut the lightening holes and sheet the stabs asap. Then start on the wings.
I need the wings and the stabs sheeted so that I can fit and align them on the fuz so that I can glue the wing & stab tubes in place so that I can carry on with the fuz!
Here you go Pete. A good South African Shiraz from our Robertson region near Cape Town. Around $8 in a retail store. www.zandvliet.co.za. (Sold in US under the export label "Astonvale" on http://african-tradition.com/wine/index.php for $16. - NO, I don't get commission!)
ID:	1452400   Click image for larger version
Old 06-13-2010 | 06:15 PM
  #122
petec's Avatar
My Feedback: (58)
Looks good, you have a lot more patience that I do given your plank sheeting on the nose. I did all my Black Magics with 3 pieces of 1/8" that I wet down to bend over the radius.
Shiraz is always good when I run out of Cabernet. I wonder if that label is available in the States?
Old 06-13-2010 | 08:12 PM
  #123
petec's Avatar
My Feedback: (58)
I have the wings covered.....FINALLY....stabs are next. I need to thank my friend Buddy for the tips on covering. My covering SUCKS but Buddy came over and gave me a few quick pointers and these wings came out nice.
It would be nice if work would lighten up. If this keeps up I swear I'm going to have to just stick a fork in any chance of flying this year.
ID:	1452637   Click image for larger version
ID:	1452638   Click image for larger version
ID:	1452639   Click image for larger version
Old 06-14-2010 | 03:37 PM
  #124
ORIGINAL: petec
Looks good, you have a lot more patience that I do given your plank sheeting on the nose. I did all my Black Magics with 3 pieces of 1/8'' that I wet down to bend over the radius.
Not patience Pete, I'm just following the instructions!!! Like I was told to I've updated my previous post with US supplier details if you run out of Cab. Foam stabs with half ribs are 20g (.7oz) a piece. The sheeting, cut to size, is another 20g per side. Foam stabs sheeted, trimmed with lightening holes and glue should come in around 80grams (2.90z) My projections show that my batteries will be hard up against the firewall. I need to lighten the tail as much as possible to try to move the packs back.
Where is your battery tray located?
Old 06-14-2010 | 05:03 PM
  #125
dreadnaut's Avatar
Does anyone know the current status of Custom Airframes of America? I e-mailed the link on the site to inquire about availability of plans, but got no reply.
