Saito FG-60R3
Old 07-17-2015, 07:09 AM
  #176
JustABigKid
I've decided to pull the trigger and order an FG-60... I wonder what the longest runtime is that anyone has accumulated on this engine - has anyone managed to get 10 hours of successful running yet?
Old 07-18-2015, 09:22 AM
  #177
3 green
my saito fg 60 came in an all white box I noticed a silver one whats the change
Old 07-18-2015, 09:56 AM
  #178
hpergm
hpergm's Avatar
Originally Posted by johnhi
Well look what happend to my engine on Friday. I had two good flights, and then started the engine for the 3rd flight and within 20 seconds of runng it suddenly started to make a knocking sound. I shut down immediately and noticed that number 2 cylinder had cracked at the base. As you know from my run in period earlier in this forum blog the engine whas VERY cearfully run-in and I have subsequently had about 25 flights with no issues. Hopfully it will just need a replacement cylider and piston ring.
Not good, not good.... Sorry to hear about this John, you sure made an extra effort to run the motor in.
It could possibly be a bolt tightness issue - did you ever check the cylinder bolts?
Old 07-18-2015, 12:04 PM
  #179
SWORDSN
My Feedback: (13)
I have mine installed on a break-in box and i've run about 24oz thru on a very rich mix.It's really running well and what a sound!
Old 07-20-2015, 06:24 AM
  #180
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
It was sitting there patiently so I had to start it up... couldn't run up the motor as the table wasn't strapped to anything and the propwash was blowing my hangar something fierce!!!
https://youtu.be/9JqDS1Nw9S8
Old 07-20-2015, 11:56 AM
  #181
SWORDSN
My Feedback: (13)
Sparky did they repair yours under warranty?
Old 07-20-2015, 07:50 PM
  #182
sparky4lawndart
My Feedback: (10)
replaced it.. It took a month but I'm okay with it...
Old 07-25-2015, 06:11 AM
  #183
johnhi
johnhi's Avatar
It could have been a bolt issue, who knows, anyway I have ordered a new cylinder head and new piston ring. When I replace this I am going to thread lock all the cylider bolts and all the back plate bolts. I'm also just glad this failure happend on the ground rather than in flight as it could have been much worse. I have to wait 3 weeks for the new parts when they come I'll post some pics of the repair.
Old 07-26-2015, 07:08 AM
  #184
BobH
John,
hat should be a warranty repair item. Most likely a crack like the is a caused by a bad casting.
Doubtful anything you could do would cause that.
hydrolic lock can happen but only if one doesn't manually pull the prop through first clearing the cylinders before using an electric starter.
Old 08-02-2015, 11:23 AM
  #185
johnhi
johnhi's Avatar
I took the engine apart today to see what the cause of the cracked cylinder was and I think it was a bolt tightening issue, two of the bolts on the cylider were undone by about one turn. After I removed the cylinder, the crank case was full if bits if aluminium shavings so I have had to strip the whole thing down and give it a good check over and clean. Lukly no more damage inside or to any of the other cylinders. Interestinly when removing the other two cyliders the bolts were tight but not realy tight if you know what I mean. When replacing all the bolts I am going to thead lock them all.
Also the main bearing has got a brass bush.
ID:	2112483   Click image for larger version
ID:	2112485   Click image for larger version
ID:	2112486   Click image for larger version
ID:	2112488   Click image for larger version
ID:	2112490   Click image for larger version
Old 08-02-2015, 05:19 PM
  #186
hyltaiwan
The material of cylinder gasket and camgear cover gasket will deform under heat, that is why you should check every cylinder screws
and camgear cover screws during initial stage of break-in as stated in th manual.
Old 08-02-2015, 07:13 PM
  #187
chorner
Johnhi you wouldn't be able to measure the diameter and length of those connector pins for the 2 other cylinders off the master rod would you?? If you could that would be awesome
Old 08-05-2015, 04:16 AM
  #188
TomH
TomH's Avatar
hey guys,
re-read all these post again, I was on the backorder list for the new version of the motor, which I got back in Dec. was ready to send it out to Ray to break it in for me, but I lost my younger brother in Feb. so everything has been on hold. I bought a Extreme Flight 91" YAK to put this in once the motor was benched in, but I would like to see if anyone has this motor in a civilian style plane. would really like to put it in the Hangar 9 super cub. don't want a bi-plane yet, just a good easy flying single wing plane. anyone got the Super Cub that could help with cowl dem.
Tom
Old 08-05-2015, 12:21 PM
  #189
marksp
My Feedback: (9)
marksp's Avatar
I have both the FG-60R3 (Byron Original Staggerwing) and the Hangar 9 Super Cub PA/18. Here's a quick pic of the SC cowl. Looks like it's about 8.25"
Old 08-05-2015, 12:37 PM
  #190
TomH
TomH's Avatar
thanks mark, someone posted the Hangar 9 Beaver @ 231mm which is a shade over 9" I think that would work. I need to pull the spec on that motor, seems the centerline was 220mm (8.66") and 207mm (8.14")was distance from rocker of one cyl. to rocker of another. sure would be nice to have it in that super cub. I'm sure the 1/3 World Models super cub would have no problem with it fitting within the cowl. just not sure I want a plane that big yet.
Old 08-05-2015, 12:44 PM
  #191
TomH
TomH's Avatar
hey Mark,
im a little confused with your last post, you have a Staggerwing and super cub, but do you also have the FG-60R3 in each of those planes as well? cause if you do then you answered my ? about the cub, and I would love pic of as well.
T
Old 08-05-2015, 02:49 PM
  #192
marksp
My Feedback: (9)
marksp's Avatar
No, my FG-60 is in the Staggerwing. My H9 SC is electric.
I'm thinking the FG-60R3 may not fit entirely inside of the SC cowl, but unfortunately, mine is mounted so I can't confirmed.
Old 08-06-2015, 05:29 AM
  #193
Joespeeder
Hi Guys,
Unless I'm missing something, I don't believe the radial needs to fit inside the cowl of a Cub ??
Joe
Old 08-08-2015, 10:07 AM
  #194
johnhi
johnhi's Avatar
Hi Chorner, is this what you want all sizes in mm.?
ID:	2113266   Click image for larger version
ID:	2113267   Click image for larger version
Old 08-17-2015, 04:57 AM
  #195
miker49
anyone have a better idea than the wire clips that hold the spark plug cap on? using the keleo exhaust ring on my FG-60,unless they are perfectly lined up they won't stay on.the engine is in a TF Corsair.the exhaust ring is small enough that the plug wires will rub on the ring.you turn them to clear and maybe one side of the clip does grab.still not good,its gonna vibrate off.maybe if the ring was bigger in Dia.,it might stay on.who ever came up with this idea would probably have a hard time building a ham sandwich.has to be a better way.a few pages back,someone was grinding some off the bottom of the cap and was wondering if that worked.any ideas?
Old 08-17-2015, 05:29 AM
  #196
chorner
Johnhi - that's perfect! Thank you very much for doing that, much appreciated
Old 08-18-2015, 11:17 AM
  #197
johnhi
johnhi's Avatar
Hi Mike,I noticed the same thing with mine I cut 1.5mm off the bottom of the HT lead cap, this makes it fit much better, works a treet.
Old 08-18-2015, 11:56 AM
  #198
kwik
kwik's Avatar
I tried my FG-60 for the first time this weekend.
The CG on the plane was a bit too far aft, therefore the steep takeoff.
That was the reason for not giving some elevator just before touchdown, too; I was nervous it could set the nose upwards too much again.
Also it is perhaps not adjusted quite correctly on top speed....but will leave it for now;
When cutting power after landing, I measured the temperature on all 3 cylinders, on the middle, up front. It was around 35 degrees Celsius on all 3. ( !! ).
Outside temperature was, oh, about 18 degrees Celcius.
https://www.youtube.com/watch?v=bVbix9bM27o
Old 08-18-2015, 01:20 PM
  #199
SWORDSN
My Feedback: (13)
The landing gear held up well.Brand?
Old 08-18-2015, 01:24 PM
  #200
kwik
kwik's Avatar
Yes. On a Fw 190 it is more a question on whether the wing holds. (Except if you have Robarts and was unlucky, and got the weak pin.)
Its Sierra.
It held this time too;
https://www.youtube.com/watch?v=Hjdl6rGjt0U
The wing held this time, too. Its because on the Sist Fw 190 all the innards of the wing in the gear area is carbon-fiber.
