DL-50 engine
#5476
ORIGINAL: thevirginian
ACF, I wouldn't necessarely count too much on a new plug as there could be an issue with the reed valve. The standard plug is crap but it is usable for a while, at least. If the engine starts and quits after a few seconds, it is, most likely, a problem with the fuel supply. If the carb is O.K., then there is only one other component, that could be the culprid: the reed valve.
#5477
This a new out of the box engine. Purchased it about 6-8 weeks ago from Valley View. Mounted it 2 weeks ago and am now getting around to ?starting? it. Mike
#5479
NC
ORIGINAL: rcflyrc3
Does anyone Use KLOTZ oil? I haven't seen it mentioned at all.
Rcflyr
Rcflyr
in my D+B 3.7 twin for aprox. 10 years mixed at 50:1, never a problem, never changed plugs,
7500rpm on a bolly 21X12, aprox. 50 gals., crashed airplane several months ago and bent[
]crankshaft, took apart to inspect, engine LN inside.
I just switched to Stihl Ultra synthetic because I can get local. Klots I had to order, so far 4 gal in
my 7yr old 3W75, runs great!!
#5482
My Feedback: (17)
If you are going for smell go for the Lou Anna Super Buttery Topping we get by the gallon for popcorn from our machine. Its probably a good oil to run, and nothing is better than burned coconut oil. Also for fun you guys could do Buttery Shooters at the field and see who clots up first. Its fun!!!
#5483
My Feedback: (25)
I still use the Klotz Model lube oil. Have used it for 3 years in both my DL and DA 50 engines. On the subject of plugs, most NAPA parts store either carry the NGK CM6 or can get them in 24 hours. Plus the price is right.
#5488
My Feedback: (13)
MN
I am just getting into my second gallon of gas in my DL50. I am using non oxygenated gas, with Pennzol Air Cooled oil at 32:1, NGK CM-6, and Vess 22A prop.
My engine has pretty good throttle response. It probably lags less than 1/2 second when the throttle is opened quickly. When I chop the throttle, it will either kill or go to a lower idle speed than it would normally idle at. If I close the throttle slower the engine will go back to the normal idle rate. What causes this and how can I tune it out?
The high end seems to be good.
Greg
Greg
#5493
ORIGINAL: JoeAirPort
No, don't switch to Amsoil. Anything but.
#5494
ORIGINAL: OldRookie
#5495
CA
hey mstam thats a very good way to mess up your catylitic converter in your car,,,that 2 stroke oil will clog it up especially that its being sent straight to your exhaust,,before you go driving,,you might want to siphon your tank.and put straight gas in there,,,how do i know??? its too embarrasing to tell.....
#5496
ORIGINAL: unit53
I always dump gas leftovers in my car if it's older than 2 months. My Volvo LOVES it
#5499
Wiat until you have 100 gallons through the engine using Amsoil. Rather presumptuous to think it might make it that far with that product though.... I suppose as long as you run an engine rich and cold you might have a chance, but no other way is possible with that stuff.
#5500
CA
does anyone know of a source for a canister or performance enhancing exhaust that can be mounted under ,the plane? i have a plane thats not worth whacking,,am i wrong for believing the way is eirther get a new plane ,or try one of those flex headers to make that steep offset? anybody//??
