Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 DLE 20cc Gasser! (Data & Links 1st Post) >
Old 10-06-2013 | 04:25 AM
  #6626
Awesome Mike, glad to hear you got it!
Old 10-06-2013 | 11:38 AM
  #6627
My Feedback: (47)
Flew the Rev 70 \ DLE 20 this morning - flew \ ran great! (with factory needle settings, no less). I love this plane \ engine combination - probably my favorite plane.
Bob P - Good suggestion - I just installed filter-klunks in both my Nitro and Gas gallon containers.
Ahicks - Thanks.
Old 10-06-2013 | 03:55 PM
  #6628
Ernie Misner's Avatar
Why not put another filter right before the carb? That is the ultimate place for one also.
Old 10-10-2013 | 05:13 PM
  #6629
Bob Pastorello's Avatar
My Feedback: (198)
No harm in that - I used to do that on my 100cc stuff....just paranoid about crud magically getting into the line when filling...many of the "old heads" maintain that filtering in the jug is all that is needed...guess it just depends on comfort level.
Old 10-10-2013 | 05:30 PM
  #6630
This "old head" hates the potential for more places to leak and/or restrict fuel flow. Though I also have to say I'm also pretty good at taking a carb apart and cleaning it...
Suit yourself.
Old 10-10-2013 | 05:41 PM
  #6631
My Feedback: (198)
Kinda like Lindberg wanting a single-engine because there was less likelihood of a catastrophic engine failure. I like simple best...
Old 10-10-2013 | 06:47 PM
  #6632
w8ye's Avatar
My Feedback: (16)
With two engines, there's twice the chance of one quiting.
Old 10-11-2013 | 03:40 AM
  #6633
My Feedback: (48)
True, 2 engines equals twice the trouble. But it also means there's a 50% chance of something's still making some forward progress if one fails. It's my understanding that forward progress is always a good thing when flying.
Old 10-19-2013 | 05:14 AM
  #6634
CustomPC's Avatar
Hi,
Can anyone tell me if the sound in the attached video clip is normal.
It's my brand new DLE-20RA which i started for the first time today. The engine has less than 2 minutes run time.
The first start was by hand and was just as you'd expect. A few turns to get fuel into the carb and then away she went. It ran for about a minute at 3,500 - 4,000rpm before i shut it down.
I couldn't get it to start by hand for the second run and it took a few cranks with the electric starter to get it running. I ran it for less than a minute due to neighborly considerations.
After those 2 short runs I noticed this play and clicking noise when rocking the prop.
It's my first DLE so i'm not sure if this is normal.
http://www.youtube.com/watch?v=lHZ9xFHROgk
Old 10-19-2013 | 05:19 AM
  #6635
Lifer's Avatar
Is it occurring at TDC?
Old 10-19-2013 | 06:14 AM
  #6636
My Feedback: (48)
Hmmm....position of the magnet indicates engine is at or near BDC. Pretty normal to have a "click" when the crank goes over center. Check it at mid stroke, should be tight there. If not you may have a problem.
Old 10-19-2013 | 08:16 AM
  #6637
Hi
DLE makes a 20RA ,....................................Since when ?
Michel
Old 10-19-2013 | 11:59 AM
  #6638
Tailspin's Avatar
Since about 3 weeks ago....http://www.valleyviewrc.com/estore/d...as-engine.html
Old 10-19-2013 | 12:08 PM
  #6639
My Feedback: (47)
Custom PC - I own a DLE 20 and 30 and I'm pretty sure that's normal for these engines. Should be happening around TDC. I recently rebuilt both engines - that sound is still there, and they run fine.
Old 10-19-2013 | 12:45 PM
  #6640
Originally Posted by Tailspin
HI
Thanks TailSpin ,.................. really got to keep up with things these days .
Michel
Old 10-19-2013 | 12:53 PM
  #6641
tailskid's Avatar
My Feedback: (34)
In full scale flying with a twin: if one engine quits....the other engine will take you to the crash site!
Old 10-19-2013 | 09:53 PM
  #6642
CustomPC's Avatar
For those that asked. That noise and play occurs at all positions. TDC, BDC and mid stroke.
I took the RA to the field today and ran it some more on the stand.
It hand starts fine and with a 16x8 it was getting 8000rpm with the needles at the factory position.
I put about 8oz of fuel through it today. The noise is still there but it doesn't seem to have any effect on the running.
Old 10-20-2013 | 12:58 AM
  #6643
HI
Quote : The noise is still there but it doesn't seem to have any effect on the running.
My wife does that !!!!!!! ( love her to death )
Michel
Old 10-20-2013 | 05:49 AM
  #6644
There is nothing more fun than resurrecting an old post.
I think this conversation about fuel filters deserved a comment.
I have lost 2 birds to dirt.
The first was a Cap 21 with dirt in the filter screen that made the forced go around end badly and the second was a Cap232 to dirt choking off the fuel flow at the filter just as I pulled up hard at very low speed. I hate eating aircraft to stupid things partly because they simply don't taste good.
Since the second, I have started using automotive filters before the engine because they are large enough not to totally fail catastrophically and do a great job of cleaning the garbage out of the fuel. Oh, I think it is a Chevrolet Chevette filter and I simply tie wraped it to the firewall standing up. The only noticeable thing was sometimes the first run took about 2 minutes before the filter was full of gas and that made some of the wilder maneuvers problematical since the engine tended to stall when the airframe was inverted with G loads too early. In other installations I have found putting the filter on its side solved that issue. The only issue you might have to solve is the fuel line size to the filter port size, but that shouldn't be a show stopper as they do make reducers.
YMMV
Old 12-17-2013 | 08:06 PM
  #6645
sparky4lawndart's Avatar
My Feedback: (10)
hoping someone sees this and can help... a few months ago i planted an ESM BF110 with dual DLE 20's. I was cleaning up the other day and decided to consolidate parts from the two ruined engines to make one... I bought a new cylinder head (Tower Hobbies - $59 and muffler - $19). while reassembling the frankenstien motor I inadvertantly broke the piston ring about an 1/8 of an inch off one end while putting the piston into the new head.
Am i screwed? Will that 1/8 of an inch less piston ring ruin the compression? The bearings spin really well... Feels like there's good compression if I spin the motor with my finger over the spark plug hole... what do you think?
Old 12-17-2013 | 08:27 PM
  #6646
My Feedback: (90)
contact [email protected] for a new ring. you can not run the engine with a broken ring. it will sooner or later ruin your cylinder/piston plus you will not get the full performance.
Old 12-17-2013 | 08:48 PM
  #6647
My Feedback: (10)
Thanks.. .I just sent him an email... have you used his rings? are they expensive? and thanks for saving me from killing the plane I was going to put this motor in! happy holidays!
Old 12-17-2013 | 09:30 PM
  #6648
w1nd6urfa's Avatar
I had just sent an email to Frank for two DLE-20 rings and he replied that he's out of stock and not making new ones before mid-Feb.
If you're in a hurry you will have to order a spare from Tower.
Old 12-17-2013 | 10:05 PM
  #6649
mach2's Avatar
Lots of guys swear by bowman rings and replace stockers with them on brand new engines. I put a stock replacement ring on mine when i went through it after a crash. Probably didnt need it, but they are like 6 bucks, so why not. The stock dle ring fits nicely with very little gap.
if i were you, id just order a dle ring from tower.
Old 12-18-2013 | 10:10 AM
  #6650
My Feedback: (10)
I went ahead and ordered the new ring from ValleyView along with a new CM6 plug... Tom is a pretty great guy... need to give more business!
