RC Exl Ignition Users
#76
ORIGINAL: captinjohn
<hr />Hi Tom,
A lot of people think a flywheel mag has a ''fixed timing'' but the more up to date FW mags do have a advance that can give more power, (equal too CD ignition) and also a good idle.
I hope that fills your request. Best Regards Capt,n
ORIGINAL: Tired Old Man
I'll request you might expand on the mag versus CDI power differences?
#77
Tony as I was not doing a exact measurement of degrees. I never placed a degree wheel on that mag engine. I did have a mark on the flywheel near the stationay coil and I could see 3/8-+ advance on the MB290 Mac engine in the photo. I have since placed the engine back in the leaf blower. I have beat the crap out of that thing & it still runs great. Top RPM in that blower hurts the ears. Amazingly it will Idle down real good yet too! I use Penzoil Air cooled oil in it at 32-1 ratio. Super tough blower for $49 bucks!
Best Regards, Capt,n
#78
So on a 4" flywheel that might be 10 degrees or so. I've read about the advancing mag never really saw just how much advance they provided. How much simpler can a mag ignition be? It would be nice to have it adjustable and offer 20 degrees advance. Contrary to popular belief, the mag parts(Two coils, pickup, and flywheel) from a GT80 weighted 392 grams while the C&H Ignition parts and 4 double A batteries weighted 413 grams, I'm sure other systems vary as the Zenoah engines use a small flywheel. The weight savings is all in the spring starter.
#79
Tony, I went to google and typed in "walbro flywheel ignitions" and got some interesting data. I think you will like it. Capt,n http://walbro.com/brochurefiles/3368...%206-26-03.pdf
#81
On a stock DLE30 ignition, does the North Pole of the magnet face out wards? I tested 2 picks-up by passing the pick-up past a magnet & it will fire spark both ways. Flat side of pic-up and curved side towards magnet will fire. I did notice the spark occurred past the magnet further that the other side. It seems like maybe a magnet could be installed wrong on prop hub....but timing would be advanced more. Kinda strange. I thought I read a pic-up will fire on one side only? Capt,n
#83
After more checking, the magnet on the engine has got to have the North facing outward and is smaller in Dia than the other magnet that would trigger the spark from both sides of the pick-up. Also I notice the curved side of pick-up will trigger form 1/4 inch away. Flip itover & it has to be 1/16 inch away ...further than that...no spark. So it looks like curved side off all 3 picks trigger best with curve side towards North pole of magnet. I looked at the magnet on the engine (with a magnifier)& it has no letters, but I do notice a small chip on the left edge of magnet. Anyone ever replace a magnet on a DLE30? How does DLE install it ,in case I want to replace it? Capt,n
#87
ORIGINAL: Oilsands
Sorry, meant if there was any lettering on the sensor.
#89
I have 3 sensor pick-ups.
#1 43F
724
#2 04E or Q4E
#3 is in the holder & I cannot remove it. A locking wedge holds it??
Thats about it. Been too busy staining decks & sealing them before winter. More deckwork tomorrow.......................................... .................................................. ..Capt,n
#1 43F
724
#2 04E or Q4E
#91
They all sense the North pole the same as mentioned. On another note....I wonder why some of the places that sell these CD ignitions ...DO NOT...include the pick-up sensor. Seems like every ignition sold should include the sensor pick-up. Seems like anything Hobby related is way overpriced! I cannot believe I said that!............................................ ............... ................. Capt,n
#92
My Feedback: (19)
All hall efect sensors sense a magnet pole. The response (output) to the magnet pole depends on the type of sensor. A unipolar sensor like RCEXl uses responds to either pole depending on the orientation of the sensor itself. You have the correct sensor. It's very unlikely, but possible, the magnet you have is magnetized incorrectly.
OK, I just reread your posts, and see that your magnet is chipped. Replace it. A chipped or cracked magnet creates another set of magnet poles in the magnet.
#93
I'm with you Captain John.... those Hall sensors are way overpriced. If you look at the Digikey site or somewhere similar, you will see that the sensors themselves are super cheap. The vendors are making anywhere from 5 to 12 dollars for soldering on three wires with a connector. If anyone is wondering "what's the big deal?", well, I usually have anywhere from 5 to 12 airplanes flying at one time, and engines in testing besides. 12 bucks a pop for sensors adds up!
AV8TOR
AV8TOR
#94
AB, CANADA
The Rcxel hall sensor (transistor) that I have will pick up both poles depending on which way you have it orientated. But in the manual that I got with it, it says to put the letters of the transistor (04E) towards the magnet. When I do that it only picks up the north (I think) pole magnet. Since I have a south pole magnet, I turned it over and it sensed it. But when I run the motor with the Rcxel ign, it runs like crap (can't get it to rev up very good). So thinking that it needs a different magnet or different transistor, the transistor is easier to change and allows me to switch between the two different brands of ign. The manual is a copied version so it is not very clear on the pictures, so wanted to confirm the number on the transistor so that I can look for a replacement that will pick up the south pole magnet.
By the way, I had another ign fail today so I ended up replacing it with the Rcxel ign and it works great (so no problem with the ign itself).
#95
My Feedback: (19)
ORIGINAL: Oilsands
http://www.allegromicro.com/en/Produ...olar/index.asp
Greg
#97
Here's one place. I had found others, but I misplaced my notebook and can't find them in my computer favorites.
$1.21 for from 1 to 24 sensors: http://us.element-14.com/jsp/search/...CMP=AFC-SF-T21
AV8TOR
AV8TOR
#99
ORIGINAL: gkamysz
Next question is where do I get a magnet the exact size or replacement?????? Capt,n
