Welcome to Club SAITO !
Old 12-03-2015, 07:47 AM
  #30476
FlyerInOKC
FlyerInOKC's Avatar
Looks like a vintage pattern airplane with a twin setup.
Old 12-03-2015, 08:11 AM
  #30477
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It was designed by Dick Sarpolis.
Old 12-04-2015, 10:45 AM
  #30478
blw
blw's Avatar
I could be wrong, but I think Ed Moorman did a twin Sig Somethin' Extra.
We had a 12 lb turkey that I smoked on a Big Green Egg for the third year now. I used a ceramic insert that kept it from being directly over the coals. The heat comes up through 3 side vents like a Dutch oven. Kept it at 350F for about 3.5 hours with lot of apple wood chips tossed in periodically. The Egg cooks meat differently and the juice runs out when you slice the breast. Took the thighs and legs off an hour early and wrapped them. They were tender and juicy too. Cornbread dressing with thick giblet gravy. Cranberry sauce. Green bean casserole. Mashed potatoes stirred until they almost poured out of the ladle. Rolls. Apple pie with vanilla ice cream for desert.
I hope these pics make it to RCU okay. It's a pic of the nose of my stalled 4*20 build. One shows the hatch for the fuel tank too. One has the Saito 30 GK just sitting on the firewall with the cowl in approximately the right place. Thought these would give builders an idea of what is needed when building this for a Saito.
I'll redo these later tonight.
Name:	4*20 with cowl.jpg
ID:	2133925   Click image for larger version
Old 12-04-2015, 11:41 AM
  #30479
FlyerInOKC
FlyerInOKC's Avatar
Pictures came out great. The description of your turkey makes me hungry!
Old 12-04-2015, 02:49 PM
  #30480
the pope
Old fart had a Dutch oven last nite ! Was juicy and wet but I wouldnt eat it although you could cut it with a knife . Cheers
Old 12-04-2015, 03:53 PM
  #30481
vertical grimmace
vertical grimmace's Avatar
Originally Posted by Dave, FormerDairyFarmer
A great suggestion, thanks, if I can swing it this will my next twin, I already have the two Saito .30s for it.
http://eurekaaircraft.com/plan_kits/50cal.htm
I am building that aircraft right now! Gonna use FX .25's though. I have it on hold for a bit, but plan to have it flying by summer. Cool plane. I also have the plans for the Magnum 80, which is the big brother for 2 .40's
Old 12-05-2015, 04:25 AM
  #30482
Rudolph Hart
Rudolph Hart's Avatar
Hey popey what did you think of barrys 30gk in that cowl,looks neat.I was expecting pix of a huge turkey that they cook in a big green egg?? i think they need to share those drugs around.
Old 12-05-2015, 06:12 AM
  #30483
acdii
Turkey gives me the burps and farts. Tis nothing like having a rumble by the liver, and burping and farting for 12 hours. Damn, that was good turkey.
Yeah I know, TMI
Old 12-05-2015, 06:25 PM
  #30484
the pope
Yeah I know, TMI
Thanks for sharing , never too much info . O.F. why would u put a saito in a cow ? Seems like a awful waste and I dont think the cow would like it either ! Cheers
Old 12-06-2015, 07:04 AM
  #30485
vertical grimmace
This is where my .50 Caliber is at right now. I bet Saito .30's or .40's would be a good choice.
Old 12-06-2015, 07:07 AM
  #30486
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
You do nice work, did you laminate with 77 contact cement and did the foam wig come with the short kit as he calls it? Thanks
Old 12-06-2015, 08:45 AM
  #30487
vertical grimmace
THanks. I used laminating resin and skinned the cores with 1 millimeter poplar. Yes, I ordered the short kit. It was nicely done. It was cut out by a CNC router so the parts were very accurate. I modified how I built the fuselage a little. But it should build into a very nice plane. I am making mine a taidragger as well. I am building this to get twin experience for a possible larger scale twin model down the road. I have heard taildragger twins can be a little tricky, so I want to gain experience here as well.
Old 12-06-2015, 02:50 PM
  #30488
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I have had the plans for a couple of months and one of the Saito .30's for several years and the 2nd .30 about one month. I am going to run Graupner 10x5.5's, the 10x5.5 pulled my LT 25 much more authoritatively than the pictured 5"
Name:	Saito .30 006.jpg
Old 12-07-2015, 03:33 AM
  #30489
Rudolph Hart
[QUOTE=vertical grimmace;12137262]This is where my .50 Caliber is at right now. I bet Saito .30's or .40's would be a good choice.
[/QUOTE
That's a nice looking apc prop
Old 12-07-2015, 04:28 AM
  #30490
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
You're a regular stand up comedian Pete.
Old 12-08-2015, 03:33 AM
  #30491
Rudolph Hart
I had an attack of 'popey' and thought i saw something i recognized
You don't do to bad yourself.
Old 12-08-2015, 05:11 AM
  #30492
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I found two more of the Graupner 10x5.5's in a Hobby Shop 400 miles southwest of here, they should be here tomorrow.
Old 12-08-2015, 01:57 PM
  #30493
wha-tah-hey
Not knowing Club SAITO was on the forum, I posted questions and info on my FA-40 here:
http://www.rcgroups.com/forums/showt...2360061&page=2
I'm trying to figure out just how many variants there were to the pre-FA-40A and exactly which one I have.
So far I've found references to MK 2, MK 3 & 40S.
Any help will be appreciated.
Thanks.
Terry
ADD: I found the info I wanted on the FA-40 series (mine's an FA-40 MK 3), see the above link for details.
Old 12-09-2015, 04:48 AM
  #30494
Cougar429
Cougar429's Avatar
Added to the stable Monday night with an 82a picked up at the local swap meet. A bit rough and will drop in new bearings after a good cleaning, but this one has the plastic rear housing. Engine is clean, only shows signs of sitting for QUITE a while.
Sure it's back in here someplace; was wondering the best place to grab the alloy replacement cover and if anyone has one kicking around.
I am a firm believer that drones will be the most serious threat to our hobby freedoms of anything in its history. True, C/P helis weeded out the less determined, (or patient, ie. stubborn) but with availability of complete, RTF drone systems with stab, PFV and GPS that gives return-to-home a one switch effort things have changed drastically.
Unfortunately I think the problem will NOT be persons with the maturity to learn the rules, (if not an active R/C enthusiast already) and follow them. It will be the idiot or someone with definite illegal intentions that will create the risk and resultant knee-jerk reaction.
I was in aviation on 9/11 so have first-hand experience with this already.Don't take this the wrong way; grounding everything was the only effective way to remove further threat. However, once that horse had left the barn I think any further attacks would have come at us sideways, (somewhere not identified yet). Grounding further flights for days, (or longer) after the fact and the ensuing regulations and enforcement do nothing for the freedoms we enjoyed before.
ps. The really fun part is commercial aviation, (ie, airlines) are pushing to get GA to pay for a good majority simply because they share the same skies............ 'Nuff said.
Old 12-09-2015, 05:53 AM
  #30495
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Hey, here is a shot of an FA .40 and an FA .40a side by side if you're curious.
Name:	Saito .40a and .40 007.jpg
Old 12-09-2015, 05:56 AM
  #30496
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
429er, let us know how it runs, please. Thanks, Dave
~horizonhobby.com/fa-82b-rear-cover%3A-ab--rr-sai82b17
The codes for the 82a are A and B so this will fit even though it's listed under the .82b
Old 12-09-2015, 06:07 AM
  #30497
FlyerInOKC
FlyerInOKC's Avatar
WOW! Big difference in size.
Old 12-09-2015, 06:29 AM
  #30498
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks OKC, I might as well squeeze this in too, the .40a and the little .30. And their respective mufflers. I've never owned an OS .20 so I don't know how it compares.
Name:	Saito .40a and .30 001 (Small).jpg
ID:	2134990   Click image for larger version
Name:	Saito .40a and .30 003 (Small).jpg
Old 12-09-2015, 12:02 PM
  #30499
Mein Duff
Mein Duff's Avatar
Cougar..I also picked up a used FA 82a recently...did some research and apparently the plastic rear housing is not an issue with this particular engine...I have about 10 flight so far on mine with issues so far.
I agree with you comments about drones and the perils they pose for our hobby and the real perils they pose to full size aviation.....the police here in Martinez,Cal. just apprehended a young culprit deliberately targeting a Police helicopter while investigating an accident.......just a matter of time.
Old 12-09-2015, 12:17 PM
  #30500
FlyerInOKC
FlyerInOKC's Avatar
The metal back plate might make a good substitution if you are tail heavy and need a little weight in the nose.
