axe cp thread
#1176
MI
I'm in Ann Arbor.
Be careful Joe, over confidence will bite you in the @$$. I'm a totally hooked noob too and I am want to spend a lot of time on the simulator cos I've been too many times in the fly, crash, order parts, wait for parts to arrive, repair heli, balance heli, fly, crash, repeat cycle.
Ted
Ted
#1177
woooohooooo
BTW..I'm a crusty old bastage
nahh only 44 Have you gotton off the ground yet? My biggest thing is I feel the thing needs trimmed out and thats hurting my hovering skills..or lack of.
#1178
MI
Sorry, I trump you on the age front, I'm forty-something (just).
You're right that trim is an essential prerequisite but so is having your brain programmed to fly the thing. I just flew the Trex on FMS and was doing OK until I became disoriented, if that had been the real deal, it would have cost me dearly. Hence my desire to get on the FMS SIM with the actual controller.
Check out the Allan Szabo link half way down this page http://www.helihobby.com/html/t_rex_600_heli.html One day I wanna fly like that!!!!!!!!! Just try some of the manouvers he makes on FMS, the heli will do it but it aint easy!
#1179
MI
Hey Gandalf,
Let us know if your connector works for the sim. If it doesn't, you can get a "adapter/mixer" here:
http://www.milehighwings.com/
There's electronics to remove the ccpm mixing in the Stock Axe radio. Oops, forgot you have a FAAST radio.
#1180
we get old and get bored. My wife says I have too many hobbies now.
Might get the futaba but not the fast system..would this work?
http://www2.towerhobbies.com/cgi-bin...I=LG6992**&P=1
Plus..Could I use it with the axe as well? Looks like a mx50 is in my future. Too funny..Not even off the ground yet and I'm buying another..Foolish old dude I guess
Ya got my email..Give a shout whenever
Joe
Joe
#1181
Spectrum DX6
Is there different models of this? Is this the 2.4 Ghz??
I may just get the spectrum and be done with it.
Aghhhh so many choices
#1182
MI
ORIGINAL: lablover
Joe
Joe
#1183
ORIGINAL: lablover
Thanks a million Ted..I'm off to go shopping
News flash...Got her about 3 inches off the ground and she was drifting left for about 10 feet. I freked so shut her down. This drifing left is gonna kick mu butt
Joe
Joe
#1184
Got her to hover after 3 batt's..woooohoooooooooooo
I dialed down the rear motor a bit and here is the shocker..I took off the training stuff. Made it 10 times more easy to control. Now granted I can hover.....but all over the place
Anyway, I'm gettin the hang of it..tik tok...battery charge time
Joe
Joe
#1186
My Feedback: (44)
CO
Just to let you know, I agree that without the training gear it will be easier to hover and fly around. But also you should be aware that the training gear will save you much damage. When you do an emergency set down the gear will save blades, blade holders, and skids, etc. I have experienced this first hand. LOL
#1187
OK I'm going to ask this again! I understand how to setup the trims and fix the linkages to get the trims centered.
The problem is my left stick bottom trim is all the way right and I still need more. There is no linkage to correct this and the pod setting has nothing to
do with it.
So how can I get the trim centered if there is no adjustment?
do with it.
#1188
CO
Hey Lablover I'm using a 7CHP with my Axe I got off ebay for $120 shipped. It works great with the Axe. All that was required was an Rx crystal that matched the Tx. Granted it's not spectrum modulation, but since I don't fly in a crowded field it's not a problem. I will make one suggestion if you can get a radio with a 5 point curves for pitch and throttle. It makes fine tuning a little nicer.
#1189
CO
Acadwheel I'm assuming you are talking about the tail rotor. Try turning up TR trim (CCW). It should add power to the tail rotor and should allow you to bring the trim back to center.
#1190
ORIGINAL: Heliko
#1191
Ok Thanks guys I will give this a try again, although it will make the tail more sensitive right?
I think I tried this before and could not get it to work, It just made the tail to fast to the left.
You know zippp! Woops hit the chair![&o]
#1192
CA
You said previously, "Can anyone tell me the fix or adjustment to center my tail trim. It is now all the way to the right and the damn tail still goes to the right." I'm assuming it's turning/yawing counter-clockwise. If this is case, then adjust the left/right bias on the board (the top adjustment). I had this problem with mine as well. I centered the yaw trim and made real minor adjustments to the board. Look at the adjustment the way you would look at the heli top-down. So, if it has a tendency to go clockwise, then turn the adjustment counter-clockwise and vice versa.
On the otherhand, if the whole chopper is sliding left then follow Heliko's suggesting of adjusting the tail rotor trim (bottom adjustment on the board).
#1193
My Feedback: (44)
CO
I don't know if this will help, but when I was still trying to learn to hover I did all this inside my garage and was hitting something quite regulary. When I finally went outside and started to fly in the street in front of my house things changed. You are able to hover at a greater altitude and you have so much more room. The first few times of flying outside were a bit different (there is wind outside...LOL) it got easier each time though. Now that I have had "space" to learn to correct my mistakes and have gotten used to flying in some wind I am much better inside. It is fun to hover at about 15 feet. It is a way different perspective, but one we all will have to learn. Get outside and fly! I would rather fly out of doors.
#1194
I DID IT..Again
2 batt's and I was about 2 ft off the basement floor. Pretty exciting to say the least. OWEVER..Things I learned. The screw or hex bolt that holds the rotor blades like to come loose. Makes the Heli act funny. So I was stoping and tigning that thing alot.
The bigest thing I learned is Rotor blades and basement poles do not gel well together. Last batt I was TRYING to get the heli back to me but head on...WRONG..Forget the controls are now backwards when doing that..My brain knew it but my fingers did not. Toasted the blades but that was all. Time to go get another set at the LHS..I wonder if the CF ones are more durable. Heck, I have a great woodshop in my garage..I can try to make some..hehehehehe
Joe
Joe
#1196
Does anybody know where to find a "I survived the chciken dance of death" t-shirts. I think I want one.
Next question, Are we only supposed to place tape to balance blade at the C.G.?
Is it true that moving the linkages in one hole slows the reaction of the servos, or just allows the ham handed more stick movement to accomplish the same thing? I keep thinking that I don't need to do this. My dances all seem to be from impatience and thick headedness.
P.S. the trick of writing left and right on the front of my canopy works great. I used dry erase marker so I can remove it later. I am also going to stsart writing myself messages of the stupid things not to do when flying and start eating them. That way when my head is up my third point of contact I will see the notes and hopefully avoid the cost of repairs. hehe.
did a full battery hover today with only three resets. I have the 1/4" dowels with the foam balls (4" ) on the ends total size 36" of training gear. It doesn't lift very well but it takes an act of god to let the blades hit anything. yaaahhhoooo
#1198
My Feedback: (8)
MN
Hey seabee890, practice driving a car, backwards using only the rearview mirror, I got this from tip about 20 years ago and I still swear by it.[8D]
put cones in an empty parking lot, set up a course,, I used to work out in the woods with no one around, I drove backwards all the time.
Try it you will like it
#1199
CA
ORIGINAL: seabee890
ORIGINAL: acadwheel
I am talking about the bias pot.
Is there 1 or 2 screws?
It looks like the is 1 screw inside another sort wheel.
Hope this is clear!
Hope this is clear!
#1200
First balance the blades. Put tracking tape or scotch tape around the far end of the blade until it balances equal on your balancer. Then take the original heavy blade and find the c.g. Mark it with a felt tip pen and then lay the light blade next to it and transfer the mark on the light blade to coincide with the first mark. Now take scotch tape and place it over the mark on the light blade until the c.g. matches the heavy blade.
