Reload this Page >
Balsa USA 1/4 Scale Nieuport 28 Build
Old 05-02-2012, 03:15 PM
  #101
planedriver_2
Default RE: Balsa USA 1/4 Scale Nieuport 28 Build
The section just behing the cockpit to the tail feathers, on a nieuport it's the shape of a cone. The rear portion of the fusalage.
Knuckle got my drift.........It's really a better solution to go with the harder wood there.
GO GAS< GO NITRO 4 cycle, Sound is good. The weight will still need to go in the front. It's on either side of the firewall rounded on the outside edges to the shape of the fusalage. If your not going to scale competition and don't care about a zenoah engine showing thru that nice aluminium cowling. It's no big deal......BUT ELECTRIC WW I ..........Oh Nooooo. what's this world coming too !!!.
Plane
Old 05-02-2012, 03:52 PM
  #102
SunDevilPilot
SunDevilPilot's Avatar
Due to weight I will most likely go with balsa fuselage stringers but I can see how they would easily be broken. For the most part the people at my field never pickup my planes. The fragility of the stringers should not be a problem.
Think of electric as some advanced type of Gnome rotary motor and it will ease the pain!
SunDevilPIlot
Old 05-02-2012, 04:13 PM
  #103
roncannell
If somebody pokes a hole in the rear fuselage, Just cover it and call it a rear Hatch!
Old 05-02-2012, 04:26 PM
  #104
SunDevilPilot
ORIGINAL: roncannell
It will be better than perfect!
Amusing as it sounds, did you see the hatch on Denis' plane..... Right where mine is!
For those that don't know.... My SuperCub got a hole in the fuselage about half way between the wing and the tail, on the right side. Now it has a custom hatch where the hole was.
Phil
Old 05-02-2012, 06:21 PM
  #105
GerKonig
Some pictures of the 28 that was in Arizona. The whole collection was purchased by the software guy and moved to the museum in Seattle. A must see.
Old 05-02-2012, 06:24 PM
  #106
GerKonig
Second attempt:-)
ID:	1758003   Click image for larger version
ID:	1758004   Click image for larger version
Old 05-02-2012, 06:27 PM
  #107
GerKonig
Landing gear of the N28. And a shot of Kennedy's and LBJ office inside Air force 1
Gerry
ID:	1758006   Click image for larger version
Old 05-02-2012, 07:10 PM
  #108
radfordc
My Feedback: (14)
radfordc's Avatar
ORIGINAL: planedriver_2
Sun, I got the numbers for you, Engine 3 * degrees down, Lower wing + 2* degrees, Top Wing - 1/2 * degree,
and the Stab ended up at + 3 * degrees. This airplane fly's very well. with all the numbers given. Of course your building habits
C G, may differ. I have a good amount of lead on the firewall to balance.
That is an unusual setup! I'm in the process of building an N28 and intend to put a couple degrees of positive incidence in the tail, but was planning to keep the wings stock. What was the basis for the negative incidence in the top wing?
Charlie
Old 05-02-2012, 07:17 PM
  #109
vertical grimmace
vertical grimmace's Avatar
I know this is late (along with many other posts), but I saw a post mentioning not having to move the firewall because of the position of a side mounted carb. It is not necessary to move the firewall if a hole is cut in the firewall itself so the carb can protrude through it. I am assuming this would be a rear carb.
Also, I vote for gas all the way. Even beyond that, I would put a Mag G38 on it! I like the mag engines as they work all the time without the extra battery. Then, you will not have to worry about tail heavy especially if yuo build the tail light.
Another point, use a 1/4" music wire axel. This will save you the hassle of replacing the smaller stock axel later on.
Old 05-02-2012, 07:57 PM
  #110
wally3185
My Feedback: (26)
wally3185's Avatar
Then, you will not have to worry about tail heavy especially if yuo build the tail light. But if you add a light to the tail wouldn't that make the tail heavy? Sorry couldn't help myself.
Old 05-03-2012, 04:52 AM
  #111
cirrus4string
My Feedback: (12)
This is a great flying airplane. I have been flying mine for 3 yrs. Saito 150 no problems or big mishaps. I used small bungee on the landing gear cross member and works perfectly.
Old 05-03-2012, 12:40 PM
  #112
planedriver_2
Sun,
Top wing incidence was to keep it flying longer than the lower wing in a near stall attitude. This from the master builder from a talk with him today at Top Gun......
Old 05-03-2012, 05:30 PM
  #113
radfordc
My Feedback: (14)
radfordc's Avatar
It's interesting that you would want the bottom wing to stall first. The "typical" setup for a biplane is to have the top wing stall first. This has the effect of moving the center of pressure rearward along the wing chords and causes the nose to drop therefore recovering from the stall. The idea is that if the lower wing were to stall first the opposite effect would occur...the CP moves forward pitching the nose up and thus entering a deeper stall. However, practical experience trumps theory, and if your plane flys well, what more could you ask?
BTW, based on recommendations here, I cut a bunch of 3/16" square hardwood stringers and started installing them today. I compared the weight of the balsa vs the hardwood (pine) and found that each pine stringer weighed approximately twice as much as the balsa ones...6 grams vs 3 grams. I estimate that this will add about 2 ounces to the tail of the plane.
Charlie
Old 05-03-2012, 08:17 PM
  #114
red wing
im in the final stages of my busa n28 and have gone with the g26 aswell. when i laid out the mounting location it looked as though the velosity stack was going to interfere with the cowl. any suggestions? can i operate the engine without the stack? i'm worried the i might get spitting if i dont use it. i would appriciate any guidance.thx.
Old 05-04-2012, 05:50 AM
  #115
roncannell
Red Wing, if your not going for the ultra scale look cut a hole for the velocity stack and you can choke your g26 with your thumb in the stack.
Old 05-04-2012, 05:54 AM
  #116
knucklebutt
knucklebutt's Avatar
Ron you should be ashamed you even posted that
Old 05-04-2012, 07:33 AM
  #117
roncannell
I am a little Bit[&:][&:]
Old 05-05-2012, 07:08 AM
  #118
SunDevilPilot
This morning I was going through some of my photographs and I found several of a 1/4 Scale Balsa USA Nieuport 28 flown at one of our local events, the 2010 Gunsmoke scale qualifier. I believe the pilots / builders name is Rick.
Building on the left wing half will begin shortly, just finishing my morning coffee which is not an optional part of the morning.
SunDevilPilot
ID:	1759068   Click image for larger version
ID:	1759069   Click image for larger version
ID:	1759070   Click image for larger version
ID:	1759071   Click image for larger version
ID:	1759072   Click image for larger version
ID:	1759073   Click image for larger version
Old 05-05-2012, 08:28 AM
  #119
SunDevilPilot
In preparation of building the other wing half I double checked the plans, which are a separate piece of paper, and the plans do not match. The wing half I already build is about 1/2" longer than the plans on for the left wing half. As you can see in the photos the rib spacing also starts to deviate (Photo is the right wing panel laid over the left wing plan). This should not be much of a problem. My plan is to build the wing right on the table, using some hand drawn reference marks on the table from the first wing. Somewhat disappointing the plans don't match in scale but not totally unexpected.
SunDevilPilot
ID:	1759093   Click image for larger version
ID:	1759094   Click image for larger version
ID:	1759095   Click image for larger version
ID:	1759096   Click image for larger version
Old 05-05-2012, 11:19 AM
  #120
SunDevilPilot
Construction of the upper left wing panel begins. I used the first wing half as a guide, marked the table with a grid following the rib spacing of the first panel, and started gluing things up. It took a little while to get it drawn out but progress is being made. Now that it has started the wing should progress the same as the previous.
As you can see in the last few photos the ribs now line up as they should.
SunDevilPilot
ID:	1759120   Click image for larger version
ID:	1759121   Click image for larger version
ID:	1759122   Click image for larger version
Old 05-05-2012, 04:17 PM
  #121
SunDevilPilot
Left panel got it's wing tip and upper spars... Just waiting for that to dry then I'll install the sub-leading edge. Sheeting will begin tomorrow.
I also installed a fence onto my bandsaw. The fence should allow me to rip down small strips of balsa. For sheeting I use the table saw but the bandsaw is great for thin strips.
SunDevilPilot
ID:	1759241   Click image for larger version
Old 05-06-2012, 09:27 AM
  #122
SunDevilPilot
Bottom sheeting being glued to the main spar. After the glue dries the wing will be flipped over, weighted down onto my table to keep it flat, then the sheeting will be bent upwards and attached to the leading edge and ribs.
Second half is a little easier than the first. All is going well.
SunDevilPilot
ID:	1759507   Click image for larger version
Old 05-08-2012, 07:43 PM
  #123
SunDevilPilot
I didn't get a lot accomplished this weekend but I did get the most time consuming part done. For me sheeting the wings takes a bit of time. Because I am using regular wood glue I must clamp the parts up and let them dry. For the top wings, this process is complete. I need to add the cap strips to the left wing, add the leading edge, then sand the leading edges of both wing halves. After that the halves will be joined into one piece.
Then onto the lower wing.
I compared the two wing panels but stacking them on each other and they match perfect. I am glad I caught the mismatch in the plans.
SunDevilPilot
Old 05-10-2012, 06:01 AM
  #124
VincentJ
VincentJ's Avatar
SDP, did youtell Balsa USA of this problem? It could have been a major oops if you didn't catch it. Nice work BTW...
Old 05-10-2012, 06:06 AM
  #125
roncannell
If you read enough BUSA build threads you will hear of this problem quite often. My Super Cub plans have problems and the DR1 had issues as well.
