Reload this Page >
~~SIG Brotherhood ~~
Old 02-08-2017, 03:26 PM
  #2251
spaceworm
Originally Posted by trainermaster80
Captcrunch44
yest the front end builds just like my dynaflite super decathlon. i saw your words you just offset the engine a little to compensate for the 2 degrees & 5 degrees down thrust.
but i am having trouble with the 2 degrees right thrust. how much is a little? as you said.
i have used the dynaflite manual instructions & the engine came way off from coming out the cowl center.
i must admit i am confused.
one modeler said hang by landing gear and slide the engine around till it fits. but with the DLE45ra if i had the plane built that far i could not reach the bolts to install the engine. my work bench is not that tall to do that anyhow.
i am looking for some of the offset centerline dimensions compared to the fuse firewall centerline. well i'll keep hacking at it. it shouldn't be that hard but right now i am confused.
thanks for your help frankie trainermaster 80
What I remember is that the tangent of 1 degree is 017, or about 1/64 (.0156). That means that for an angle of 1 degree, if you are at a distance of 1 inch, the distance across the short side of the triangle is 1/64 inch. So, for a 2 degree angle, 1 inch would equal 2/64 inch (1/32). If your cowl face is 4 inches from the firewall, the offset for 2 degrees angle would be 4 times 2/64 or 1/8 inch. So, for 2 degree right engine offset the engine mount hole grouping to mount the engine would be 1/8 inch offset to the right side (looking at the firewall) from the center of the firewall. Just multiply the distance you have from the firewall to the cowl face, by the angle offset you need, times 1/64 to get the hole grouping centers distance from the FW center. I hope this helps. Get back to me if I have not been clear on this. And look at it closely to make sure I have not gotten it screwed up. Good luck.
Sincerely, Richard
Old 02-08-2017, 03:40 PM
  #2252
Captcrunch44
Sincerely, Richard
Yes that sounds correct on most of my engines i put an 1/8 inch shim behind the left engine mount and compensate by sliding the engine over To the left as you sit in the cockpit. Two degrees isn't much. In the scheme of things
Old 02-08-2017, 05:12 PM
  #2253
soarrich
My Feedback: (98)
soarrich's Avatar
I am curious also. Are we talking about the 1.5 mil or the 3 mil?
I think 1.5 mil, mine is very thin, starts out frosted looking, clears when heated.
Old 02-08-2017, 07:01 PM
  #2254
Captcrunch44
Yes 1.5 mil
When you lay it on the part it droops nice around the edges and sticks vary good with around 125 to 150 heat. And when you shrink the middle it tightens up almost better than Monacote
Old 02-09-2017, 05:54 AM
  #2255
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by Captcrunch44
Yes 1.5 mil
From that description and looking at the cost vs. Monokote and add in you can get a custom paint you make it very tempting. I guess I'll need to try it at some point.
Old 02-09-2017, 09:36 AM
  #2256
spaceworm
I would like to try it, but am not wanting to buy 500 feet just to try it. I think I will visit my local Staples/Kinkos, et al, to see if I can buy just a few feet to try. (a laminating job for them without the actual laminating)
Old 02-16-2017, 03:04 AM
  #2257
Comper
I own a Sig Midget Mustang. Can I join?
Old 02-19-2017, 05:36 PM
  #2258
trainermaster80
trainermaster80's Avatar
Hello capt crunch, i solved my 2 degree ofset problem mounting my dle 35 ra on my dynaflite super decathlon. I was using the top view of the plan and the cowl drawing as a guide. It was much too long in reality. So, the farther out you get from the firewall the wider the gap between the actual centerline & the 2 degree offset. Using the plan drawing i had to ofset engine almost off the firewall.
I drew a new cowl plan based on my fiberglass cowl & the length of the dle engine. Everything worked out o,.k
& now my engine will exit @ the cowl center.
Thanks to all who offered help thanks trainermaster80
Old 02-20-2017, 07:13 AM
  #2259
skylark-flier
skylark-flier's Avatar
WELCOME, Comper, to the SIG Brotherhood!! Absolutely, you're in - I'm fairly sure you're the first brother to claim either of the Midget Mustangs (RC-6 & RC-28), and I'm 100% sure you're our first brother from Sydney. Curiosity's getting me - which one is it? Anyway, gotcha logged with #176.
Once again, here's our SIG Brotherhood, as I've got it today (3-columns):
[TABLE="width: 591"]
[TR]
[TD]1
[/TD]
[TD]-[/TD]
[TD]Hazel & Glenn Sigafoose
[/TD]
[TD]61
[/TD]
[TD]-[/TD]
[TD]Hfrank[/TD]
[TD]121[/TD]
[TD]-[/TD]
[TD]guido[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]-[/TD]
[TD]Maxey Hester & the team[/TD]
[TD]62[/TD]
[TD]-[/TD]
[TD]Lowvoltage[/TD]
[TD]122[/TD]
[TD]-[/TD]
[TD]RMeadows[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]-[/TD]
[TD]acdii[/TD]
[TD]63[/TD]
[TD]-[/TD]
[TD]US185Damiani[/TD]
[TD]123[/TD]
[TD]-[/TD]
[TD]Old_RC_Guy[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]-[/TD]
[TD]RCKen[/TD]
[TD]64[/TD]
[TD]-[/TD]
[TD]hsukaria[/TD]
[TD]124[/TD]
[TD]-[/TD]
[TD]TheComputerGeek[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]-[/TD]
[TD]DGUY[/TD]
[TD]65[/TD]
[TD]-[/TD]
[TD]lkruse[/TD]
[TD]125[/TD]
[TD]-[/TD]
[TD]hook57[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]-[/TD]
[TD]DBD1[/TD]
[TD]66[/TD]
[TD]-[/TD]
[TD]Sgt. Meyer[/TD]
[TD]126[/TD]
[TD]-[/TD]
[TD]newbiedc[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]-[/TD]
[TD]fix-n-fly[/TD]
[TD]67[/TD]
[TD]-[/TD]
[TD]G-JIMG[/TD]
[TD]127[/TD]
[TD]-[/TD]
[TD]PipeMajor[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]-[/TD]
[TD]foodstick[/TD]
[TD]68[/TD]
[TD]-[/TD]
[TD]Hydro Junkie[/TD]
[TD]128[/TD]
[TD]-[/TD]
[TD]RDJeff[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]-[/TD]
[TD]UPF-7[/TD]
[TD]69[/TD]
[TD]-[/TD]
[TD]Twin_Flyer[/TD]
[TD]129[/TD]
[TD]-[/TD]
[TD]ABORH[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]-[/TD]
[TD]jeffie8696[/TD]
[TD]70[/TD]
[TD]-[/TD]
[TD]oldsterling[/TD]
[TD]130[/TD]
[TD]-[/TD]
[TD]danpos[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]-[/TD]
[TD]skyrat71[/TD]
[TD]71[/TD]
[TD]-[/TD]
[TD]J T Caldwell[/TD]
[TD]131[/TD]
[TD]-[/TD]
[TD]mscic-RCU[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]-[/TD]
[TD]Leroy Gardner[/TD]
[TD]72[/TD]
[TD]-[/TD]
[TD]cloudancer03[/TD]
[TD]132[/TD]
[TD]-[/TD]
[TD]PSB[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]-[/TD]
[TD]CanDo[/TD]
[TD]73[/TD]
[TD]-[/TD]
[TD]Super08[/TD]
[TD]133[/TD]
[TD]-[/TD]
[TD]aggieman[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]-[/TD]
[TD]JPMacG[/TD]
[TD]74[/TD]
[TD]-[/TD]
[TD]Hab[/TD]
[TD]134[/TD]
[TD]-[/TD]
[TD]Renegade[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]-[/TD]
[TD]Thunder Chicken[/TD]
[TD]75[/TD]
[TD]-[/TD]
[TD]Smashmaster[/TD]
[TD]135[/TD]
[TD]-[/TD]
[TD]bodybuildr[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]-[/TD]
[TD]5skyhawk172[/TD]
[TD]76[/TD]
[TD]-[/TD]
[TD]Rv7garage[/TD]
[TD]136[/TD]
[TD]-[/TD]
[TD]SigSenior[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]-[/TD]
[TD]Cutlass 60[/TD]
[TD]77[/TD]
[TD]-[/TD]
[TD]Neddy191[/TD]
[TD]137[/TD]
[TD]-[/TD]
[TD]ZOR (banned)[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]-[/TD]
[TD]Mr-Punk[/TD]
[TD]78[/TD]
[TD]-[/TD]
[TD]JZHANDYMAN[/TD]
[TD]138[/TD]
[TD]-[/TD]
[TD]mike 71[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]-[/TD]
[TD]Sabreryder[/TD]
[TD]79[/TD]
[TD]-[/TD]
[TD]Pete Lane[/TD]
[TD]139[/TD]
[TD]-[/TD]
[TD]merto31[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]-[/TD]
[TD]eastkurt[/TD]
[TD]80[/TD]
[TD]-[/TD]
[TD]SIGPlanes[/TD]
[TD]140[/TD]
[TD]-[/TD]
[TD]thobin[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]-[/TD]
[TD]FlyerInOKC[/TD]
[TD]81[/TD]
[TD]-[/TD]
[TD]rcmichael[/TD]
[TD]141[/TD]
[TD]-[/TD]
[TD]numb3rulz[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]-[/TD]
[TD]rtn9105[/TD]
[TD]82[/TD]
[TD]-[/TD]
[TD]larryshobbies[/TD]
[TD]142[/TD]
[TD]-[/TD]
[TD]Gary in Fla[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]-[/TD]
[TD]oliveDrab[/TD]
[TD]83[/TD]
[TD]-[/TD]
[TD]skyraider71[/TD]
[TD]143[/TD]
[TD]-[/TD]
[TD]VincentJ[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]-[/TD]
[TD]triumphman49[/TD]
[TD]84[/TD]
[TD]-[/TD]
[TD]Hawk570[/TD]
[TD]144[/TD]
[TD]-[/TD]
[TD]RICKSTUBBZ[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]-[/TD]
[TD]ARUP[/TD]
[TD]85[/TD]
[TD]-[/TD]
[TD]hogflyer[/TD]
[TD]145[/TD]
[TD]-[/TD]
[TD]EJWash1[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]-[/TD]
[TD]willig10[/TD]
[TD]86[/TD]
[TD]-[/TD]
[TD]cubcrasher[/TD]
[TD]146[/TD]
[TD]-[/TD]
[TD]BigTeeEldorado[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]-[/TD]
[TD]malitape[/TD]
[TD]87[/TD]
[TD]-[/TD]
[TD]chandler_ace[/TD]
[TD]147[/TD]
[TD]-[/TD]
[TD]Aquila1954[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]-[/TD]
[TD]OLDFLYER2[/TD]
[TD]88[/TD]
[TD]-[/TD]
[TD]Firewalkerd1[/TD]
[TD]148[/TD]
[TD]-[/TD]
[TD]jwharkinz[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]-[/TD]
[TD]justin80[/TD]
[TD]89[/TD]
[TD]-[/TD]
[TD]Robin A[/TD]
[TD]149[/TD]
[TD]-[/TD]
[TD]TCraft Lover[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]-[/TD]
[TD]Jim Branaum[/TD]
[TD]90[/TD]
[TD]-[/TD]
[TD]GLGofLB[/TD]
[TD]150[/TD]
[TD]-[/TD]
[TD]Pork Chop[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]-[/TD]
[TD]crawler tech[/TD]
[TD]91[/TD]
[TD]-[/TD]
[TD]On the Deck[/TD]
[TD]151[/TD]
[TD]-[/TD]
[TD]drube[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]-[/TD]
[TD]yel914[/TD]
[TD]92[/TD]
[TD]-[/TD]
[TD]aircraftbuilder67[/TD]
[TD]152[/TD]
[TD]-[/TD]
[TD]trainermaster80[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]-[/TD]
[TD]ThunderBoat42[/TD]
[TD]93[/TD]
[TD]-[/TD]
[TD]FJRrider[/TD]
[TD]153[/TD]
[TD]-[/TD]
[TD]samklem[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]-[/TD]
[TD]sbd-3[/TD]
[TD]94[/TD]
[TD]-[/TD]
[TD]sdcranford[/TD]
[TD]154[/TD]
[TD]-[/TD]
[TD]tkametz[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]-[/TD]
[TD]Thatsakitbuilt[/TD]
[TD]95[/TD]
[TD]-[/TD]
[TD]AMA 74894[/TD]
[TD]155[/TD]
[TD]-[/TD]
[TD]Vinnie6[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]-[/TD]
[TD]blw[/TD]
[TD]96[/TD]
[TD]-[/TD]
[TD]W7APD Alan[/TD]
[TD]156[/TD]
[TD]-[/TD]
[TD]budof561[/TD]
[/TR]
[TR]
[TD]37
[/TD]
[TD]-[/TD]
[TD]Mike Gretz[/TD]
[TD]97[/TD]
[TD]-[/TD]
[TD]bobsrc
[/TD]
[TD]157[/TD]
[TD]-[/TD]
[TD]RKRick[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]-[/TD]
[TD]Mako17[/TD]
[TD]98[/TD]
[TD]-[/TD]
[TD]kiwi4[/TD]
[TD]158[/TD]
[TD]-[/TD]
[TD]leojzamboni[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]-[/TD]
[TD]Live Wire[/TD]
[TD]99[/TD]
[TD]-[/TD]
[TD]Flight Risk[/TD]
[TD]159[/TD]
[TD]-[/TD]
[TD]sgtmonte[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]-[/TD]
[TD]deanz406[/TD]
[TD]100[/TD]
[TD]-[/TD]
[TD]G.Barber[/TD]
[TD]160[/TD]
[TD]-[/TD]
[TD]smallrc[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]-[/TD]
[TD]bchapman[/TD]
[TD]101[/TD]
[TD]-[/TD]
[TD]I_Fly[/TD]
[TD]161[/TD]
[TD]-[/TD]
[TD]daywalker[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]-[/TD]
[TD]SrTelemaster150[/TD]
[TD]102[/TD]
[TD]-[/TD]
[TD]scaleforlife[/TD]
[TD]162[/TD]
[TD]-[/TD]
[TD]angel asenjo[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]-[/TD]
[TD]SushiHunter[/TD]
[TD]103[/TD]
[TD]-[/TD]
[TD]balsatermite[/TD]
[TD]163[/TD]
[TD]-[/TD]
[TD]Jeff Spicoli[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]-[/TD]
[TD]n8rloves2fly[/TD]
[TD]104[/TD]
[TD]-[/TD]
[TD]3136[/TD]
[TD]164[/TD]
[TD]-[/TD]
[TD]themutsnutz[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]-[/TD]
[TD]M_Callahan[/TD]
[TD]105[/TD]
[TD]-[/TD]
[TD]rc56[/TD]
[TD]165[/TD]
[TD]-[/TD]
[TD]mvarzoni[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]-[/TD]
[TD]carlosponti[/TD]
[TD]106[/TD]
[TD]-[/TD]
[TD]R/C Addiction[/TD]
[TD]166[/TD]
[TD]-[/TD]
[TD]Big Stikflyer[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]-[/TD]
[TD]xxwolfyxx[/TD]
[TD]107[/TD]
[TD]-[/TD]
[TD]Fly North[/TD]
[TD]167[/TD]
[TD]-[/TD]
[TD]gutmark[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]-[/TD]
[TD]landeck[/TD]
[TD]108[/TD]
[TD]-[/TD]
[TD]JFS737[/TD]
[TD]168[/TD]
[TD]-[/TD]
[TD]knuckleball[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]-[/TD]
[TD]cherokeenut[/TD]
[TD]109[/TD]
[TD]-[/TD]
[TD]skylark-flier[/TD]
[TD]169[/TD]
[TD]-[/TD]
[TD]capt. crunch jr.[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]-[/TD]
[TD]Mark Thomas[/TD]
[TD]110[/TD]
[TD]-[/TD]
[TD]rdgettler[/TD]
[TD]170[/TD]
[TD]-[/TD]
[TD]flygilmore[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]-[/TD]
[TD]rphiii[/TD]
[TD]111[/TD]
[TD]-[/TD]
[TD]allamericanflyer[/TD]
[TD]171[/TD]
[TD]-[/TD]
[TD]Yasbush[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]-[/TD]
[TD]n0kjf[/TD]
[TD]112[/TD]
[TD]-[/TD]
[TD]MartyPetriSr[/TD]
[TD]172[/TD]
[TD]-[/TD]
[TD]cardinalflyer[/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]-[/TD]
[TD]cymaz[/TD]
[TD]113[/TD]
[TD]-[/TD]
[TD]tribalturtle2[/TD]
[TD]173[/TD]
[TD]-[/TD]
[TD]bbrowncods[/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]-[/TD]
[TD]OldRookie[/TD]
[TD]114[/TD]
[TD]-[/TD]
[TD]Soboflyer[/TD]
[TD]174[/TD]
[TD]-[/TD]
[TD]pmoen70[/TD]
[/TR]
[TR]
[TD]55[/TD]
[TD]-[/TD]
[TD]gosch[/TD]
[TD]115[/TD]
[TD]-[/TD]
[TD]jollyroger[/TD]
[TD]175[/TD]
[TD]-[/TD]
[TD]GSXR1000[/TD]
[/TR]
[TR]
[TD]56[/TD]
[TD]-[/TD]
[TD]ThunderChicken72[/TD]
[TD]116[/TD]
[TD]-[/TD]
[TD]c-crunch[/TD]
[TD]176[/TD]
[TD]-[/TD]
[TD]Comper[/TD]
[/TR]
[TR]
[TD]57[/TD]
[TD]-[/TD]
[TD]lfd47[/TD]
[TD]117[/TD]
[TD]-[/TD]
[TD]19wingwalker48[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]58[/TD]
[TD]-[/TD]
[TD]bikerbc[/TD]
[TD]118[/TD]
[TD]-[/TD]
[TD]tzlaser44[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]-[/TD]
[TD]badger5964[/TD]
[TD]119[/TD]
[TD]-[/TD]
[TD]larscato[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]-[/TD]
[TD]N1EDM[/TD]
[TD]120[/TD]
[TD]-[/TD]
[TD]TomCrump[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Old 02-20-2017, 07:14 AM
  #2260
skylark-flier
Just checking guys - does anyone else have issues with RCU not e-mailing notices about messages in the forums? My e-mail's been blank for 2 weeks.
Old 02-20-2017, 07:29 AM
  #2261
spaceworm
No problem here in the frozen north. Got this 10 minutes max ago. Comcast Infinity X1 ISP, Win 7 Home Premium. Google. Slow but it gets there eventually. Good luck. Some here flew off of the snow on Sat and Sun. Most had skis, but the crust allowed wheels. also.
Old 02-20-2017, 08:16 AM
  #2262
acdii
Check your Spam folder. I had accidently spammed this forum and wondered why I wasn't getting any, then found I have them in the spam folder.
Old 02-20-2017, 10:42 AM
  #2263
bobsrc
Hi Guys. Bob from Sig here. Would some of you Rascal 168 be kind enough to post some of your 168 pictures on the Sig face book site? I think the world would like to see this monster project under construction. Thanks.
Old 02-21-2017, 01:57 PM
  #2264
Captcrunch44
Will do.
Old 02-21-2017, 05:47 PM
  #2265
stinsonsr9
Can I join, I am building a Sig 1/6 clipped wing cub.
Old 02-21-2017, 08:55 PM
  #2266
scale buff
My Feedback: (24)
I've been away from RCU for the last few years and was unaware that there is a Sig Brotherhood. Please sign me up. I've been a fan of Sig for over forty years, have known a lot of the old time Sig people, am a good friend with Hazel (who gave me a ride in her two seat Spacewalker) and have built many Sig kits. I still have a quarter scale Cub to build. Look forward to following the thread.
Old 02-21-2017, 09:18 PM
  #2267
skylark-flier
For sure, you're in. Welcome to the SIG Brotherhood!!! Gotcha logged with #177.
And here we are, as I've got us today:
[TR]
[TD]1
[/TD]
[TD]-[/TD]
[/TD]
[TD]61[/TD]
[TD]-[/TD]
[TD]Hfrank[/TD]
[TD]121[/TD]
[TD]-[/TD]
[TD]guido[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]-[/TD]
[TD]62[/TD]
[TD]-[/TD]
[TD]Lowvoltage[/TD]
[TD]122[/TD]
[TD]-[/TD]
[TD]RMeadows[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]-[/TD]
[TD]acdii[/TD]
[TD]63[/TD]
[TD]-[/TD]
[TD]123[/TD]
[TD]-[/TD]
[TD]Old_RC_Guy[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]-[/TD]
[TD]RCKen[/TD]
[TD]64[/TD]
[TD]-[/TD]
[TD]hsukaria[/TD]
[TD]124[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]-[/TD]
[TD]DGUY[/TD]
[TD]65[/TD]
[TD]-[/TD]
[TD]lkruse[/TD]
[TD]125[/TD]
[TD]-[/TD]
[TD]hook57[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]-[/TD]
[TD]DBD1[/TD]
[TD]66[/TD]
[TD]-[/TD]
[TD]Sgt. Meyer[/TD]
[TD]126[/TD]
[TD]-[/TD]
[TD]newbiedc[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]-[/TD]
[TD]fix-n-fly[/TD]
[TD]67[/TD]
[TD]-[/TD]
[TD]G-JIMG[/TD]
[TD]127[/TD]
[TD]-[/TD]
[TD]PipeMajor[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]-[/TD]
[TD]foodstick[/TD]
[TD]68[/TD]
[TD]-[/TD]
[TD]128[/TD]
[TD]-[/TD]
[TD]RDJeff[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]-[/TD]
[TD]UPF-7[/TD]
[TD]69[/TD]
[TD]-[/TD]
[TD]Twin_Flyer[/TD]
[TD]129[/TD]
[TD]-[/TD]
[TD]ABORH[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]-[/TD]
[TD]jeffie8696[/TD]
[TD]70[/TD]
[TD]-[/TD]
[TD]130[/TD]
[TD]-[/TD]
[TD]danpos[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]-[/TD]
[TD]skyrat71[/TD]
[TD]71[/TD]
[TD]-[/TD]
[TD]131[/TD]
[TD]-[/TD]
[TD]mscic-RCU[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]-[/TD]
[TD]72[/TD]
[TD]-[/TD]
[TD]132[/TD]
[TD]-[/TD]
[TD]PSB[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]-[/TD]
[TD]CanDo[/TD]
[TD]73[/TD]
[TD]-[/TD]
[TD]Super08[/TD]
[TD]133[/TD]
[TD]-[/TD]
[TD]aggieman[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]-[/TD]
[TD]JPMacG[/TD]
[TD]74[/TD]
[TD]-[/TD]
[TD]Hab[/TD]
[TD]134[/TD]
[TD]-[/TD]
[TD]Renegade[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]-[/TD]
[TD]75[/TD]
[TD]-[/TD]
[TD]135[/TD]
[TD]-[/TD]
[TD]bodybuildr[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]-[/TD]
[TD]76[/TD]
[TD]-[/TD]
[TD]Rv7garage[/TD]
[TD]136[/TD]
[TD]-[/TD]
[TD]SigSenior
[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]-[/TD]
[TD]Cutlass 60[/TD]
[TD]77[/TD]
[TD]-[/TD]
[TD]Neddy191[/TD]
[TD]137[/TD]
[TD]-[/TD]
[TD]ZOR (banned)
[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]-[/TD]
[TD]Mr-Punk[/TD]
[TD]78[/TD]
[TD]-[/TD]
[TD]JZHANDYMAN[/TD]
[TD]138[/TD]
[TD]-[/TD]
[TD]mike 71[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]-[/TD]
[TD]Sabreryder[/TD]
[TD]79[/TD]
[TD]-[/TD]
[TD]Pete Lane[/TD]
[TD]139[/TD]
[TD]-[/TD]
[TD]merto31[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]-[/TD]
[TD]eastkurt[/TD]
[TD]80[/TD]
[TD]-[/TD]
[TD]SIGPlanes[/TD]
[TD]140[/TD]
[TD]-[/TD]
[TD]thobin[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]-[/TD]
[TD]FlyerInOKC[/TD]
[TD]81[/TD]
[TD]-[/TD]
[TD]rcmichael[/TD]
[TD]141[/TD]
[TD]-[/TD]
[TD]numb3rulz[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]-[/TD]
[TD]rtn9105[/TD]
[TD]82[/TD]
[TD]-[/TD]
[TD]142[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]-[/TD]
[TD]oliveDrab[/TD]
[TD]83[/TD]
[TD]-[/TD]
[TD]143[/TD]
[TD]-[/TD]
[TD]VincentJ[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]-[/TD]
[TD]84[/TD]
[TD]-[/TD]
[TD]Hawk570[/TD]
[TD]144[/TD]
[TD]-[/TD]
[TD]RICKSTUBBZ[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]-[/TD]
[TD]ARUP[/TD]
[TD]85[/TD]
[TD]-[/TD]
[TD]hogflyer[/TD]
[TD]145[/TD]
[TD]-[/TD]
[TD]EJWash1[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]-[/TD]
[TD]willig10[/TD]
[TD]86[/TD]
[TD]-[/TD]
[TD]cubcrasher[/TD]
[TD]146[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]-[/TD]
[TD]malitape[/TD]
[TD]87[/TD]
[TD]-[/TD]
[TD]147[/TD]
[TD]-[/TD]
[TD]Aquila1954[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]-[/TD]
[TD]OLDFLYER2[/TD]
[TD]88[/TD]
[TD]-[/TD]
[TD]148[/TD]
[TD]-[/TD]
[TD]jwharkinz[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]-[/TD]
[TD]justin80[/TD]
[TD]89[/TD]
[TD]-[/TD]
[TD]Robin A[/TD]
[TD]149[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]-[/TD]
[TD]90[/TD]
[TD]-[/TD]
[TD]GLGofLB[/TD]
[TD]150[/TD]
[TD]-[/TD]
[TD]Pork Chop[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]-[/TD]
[TD]91[/TD]
[TD]-[/TD]
[TD]151[/TD]
[TD]-[/TD]
[TD]drube[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]-[/TD]
[TD]yel914[/TD]
[TD]92[/TD]
[TD]-[/TD]
[TD]152[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]-[/TD]
[TD]93[/TD]
[TD]-[/TD]
[TD]FJRrider[/TD]
[TD]153[/TD]
[TD]-[/TD]
[TD]samklem[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]-[/TD]
[TD]sbd-3[/TD]
[TD]94[/TD]
[TD]-[/TD]
[TD]sdcranford[/TD]
[TD]154[/TD]
[TD]-[/TD]
[TD]tkametz[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]-[/TD]
[TD]95[/TD]
[TD]-[/TD]
[TD]AMA 74894[/TD]
[TD]155[/TD]
[TD]-[/TD]
[TD]Vinnie6[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]-[/TD]
[TD]blw[/TD]
[TD]96[/TD]
[TD]-[/TD]
[TD]W7APD Alan[/TD]
[TD]156[/TD]
[TD]-[/TD]
[TD]budof561[/TD]
[/TR]
[TR]
[TD]37
[/TD]
[TD]-[/TD]
[TD]Mike Gretz[/TD]
[TD]97[/TD]
[TD]-[/TD]
[TD]bobsrc
[/TD]
[TD]157[/TD]
[TD]-[/TD]
[TD]RKRick[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]-[/TD]
[TD]Mako17[/TD]
[TD]98[/TD]
[TD]-[/TD]
[TD]kiwi4[/TD]
[TD]158[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]-[/TD]
[TD]Live Wire[/TD]
[TD]99[/TD]
[TD]-[/TD]
[TD]159[/TD]
[TD]-[/TD]
[TD]sgtmonte[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]-[/TD]
[TD]deanz406[/TD]
[TD]100[/TD]
[TD]-[/TD]
[TD]G.Barber[/TD]
[TD]160[/TD]
[TD]-[/TD]
[TD]smallrc[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]-[/TD]
[TD]bchapman[/TD]
[TD]101[/TD]
[TD]-[/TD]
[TD]I_Fly[/TD]
[TD]161[/TD]
[TD]-[/TD]
[TD]daywalker[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]-[/TD]
[TD]102[/TD]
[TD]-[/TD]
[TD]162[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]-[/TD]
[TD]103[/TD]
[TD]-[/TD]
[TD]163[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]-[/TD]
[TD]104[/TD]
[TD]-[/TD]
[TD]3136[/TD]
[TD]164[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]-[/TD]
[TD]M_Callahan[/TD]
[TD]105[/TD]
[TD]-[/TD]
[TD]rc56[/TD]
[TD]165[/TD]
[TD]-[/TD]
[TD]mvarzoni[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]-[/TD]
[TD]106[/TD]
[TD]-[/TD]
[TD]166[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]-[/TD]
[TD]xxwolfyxx[/TD]
[TD]107[/TD]
[TD]-[/TD]
[TD]Fly North[/TD]
[TD]167[/TD]
[TD]-[/TD]
[TD]gutmark[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]-[/TD]
[TD]landeck[/TD]
[TD]108[/TD]
[TD]-[/TD]
[TD]JFS737[/TD]
[TD]168[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]-[/TD]
[TD]109[/TD]
[TD]-[/TD]
[TD]169[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]-[/TD]
[TD]110[/TD]
[TD]-[/TD]
[TD]rdgettler[/TD]
[TD]170[/TD]
[TD]-[/TD]
[TD]flygilmore[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]-[/TD]
[TD]rphiii[/TD]
[TD]111[/TD]
[TD]-[/TD]
[TD]171[/TD]
[TD]-[/TD]
[TD]Yasbush[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]-[/TD]
[TD]n0kjf[/TD]
[TD]112[/TD]
[TD]-[/TD]
[TD]172[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]-[/TD]
[TD]cymaz[/TD]
[TD]113[/TD]
[TD]-[/TD]
[TD]173[/TD]
[TD]-[/TD]
[TD]bbrowncods[/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]-[/TD]
[TD]OldRookie[/TD]
[TD]114[/TD]
[TD]-[/TD]
[TD]Soboflyer[/TD]
[TD]174[/TD]
[TD]-[/TD]
[TD]pmoen70[/TD]
[/TR]
[TR]
[TD]55[/TD]
[TD]-[/TD]
[TD]gosch[/TD]
[TD]115[/TD]
[TD]-[/TD]
[TD]jollyroger[/TD]
[TD]175[/TD]
[TD]-[/TD]
[TD]GSXR1000[/TD]
[/TR]
[TR]
[TD]56[/TD]
[TD]-[/TD]
[TD]116[/TD]
[TD]-[/TD]
[TD]c-crunch[/TD]
[TD]176[/TD]
[TD]-[/TD]
[TD]Comper[/TD]
[/TR]
[TR]
[TD]57[/TD]
[TD]-[/TD]
[TD]lfd47[/TD]
[TD]117[/TD]
[TD]-[/TD]
[TD]177[/TD]
[TD]-[/TD]
[TD]stinsonsr9[/TD]
[/TR]
[TR]
[TD]58[/TD]
[TD]-[/TD]
[TD]bikerbc[/TD]
[TD]118[/TD]
[TD]-[/TD]
[TD]tzlaser44[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]-[/TD]
[TD]badger5964[/TD]
[TD]119[/TD]
[TD]-[/TD]
[TD]larscato[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]-[/TD]
[TD]N1EDM[/TD]
[TD]120[/TD]
[TD]-[/TD]
[TD]TomCrump[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Old 02-21-2017, 10:39 PM
  #2268
Comper
THATS PERFECT! Thank you!! I have the RC-6.
Old 02-22-2017, 04:22 AM
  #2269
stinsonsr9
Old 02-22-2017, 07:58 AM
  #2270
FlyerInOKC
FlyerInOKC's Avatar
Ther are a lot of brotherhoods on RCU see my signature for a partial list.
Mike
Old 02-22-2017, 08:24 PM
  #2271
skylark-flier
Yo! Mike's right - there are a whole crowd of b'hoods in RCU. Best list that I know of is in the brotherhood thread - link's here - latest compilation is post #22: http://www.rcuniverse.com/forum/ques...therhoods.html
Also, let me welcome you back to RCU and, of course, to the SIG Brotherhood!!! Gotcha logged with #178.
Comper - RC-6, cool. As far as I'm aware, you're the first brother to claim that bird. Congrats!! Would love to see some pics of her.
Hey guys, let me apologize for my recent tardiness with responses to both here and the Kadet B'hood. For the past 3 weeks we've been taking care of one of our horses that got injured - med treatments every 3 hours, round the clock, and it's kinda telling on us. We're down to 3 treatments daily though (definitely got it beat and he's beginning to heal nicely). Hope to be more prompt with replies from here on out.
So! Here's our SIG Brotherhood, as I've got it today (3-columns):
[TR]
[TD]1
[/TD]
[TD]-[/TD]
[TD]Hazel & Glenn Sigafoose[/TD]
[TD]61[/TD]
[TD]-[/TD]
[TD]Hfrank[/TD]
[TD]121[/TD]
[TD]-[/TD]
[TD]guido[/TD]
[/TR]
[TR]
[TD]2
[/TD]
[TD]-[/TD]
[TD]62[/TD]
[TD]-[/TD]
[TD]Lowvoltage[/TD]
[TD]122[/TD]
[TD]-[/TD]
[TD]RMeadows[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]-[/TD]
[TD]acdii[/TD]
[TD]63[/TD]
[TD]-[/TD]
[TD]123[/TD]
[TD]-[/TD]
[TD]Old_RC_Guy[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]-[/TD]
[TD]RCKen[/TD]
[TD]64[/TD]
[TD]-[/TD]
[TD]hsukaria[/TD]
[TD]124[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]-[/TD]
[TD]DGUY[/TD]
[TD]65[/TD]
[TD]-[/TD]
[TD]lkruse[/TD]
[TD]125[/TD]
[TD]-[/TD]
[TD]hook57[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]-[/TD]
[TD]DBD1[/TD]
[TD]66[/TD]
[TD]-[/TD]
[TD]Sgt. Meyer[/TD]
[TD]126[/TD]
[TD]-[/TD]
[TD]newbiedc[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]-[/TD]
[TD]fix-n-fly[/TD]
[TD]67[/TD]
[TD]-[/TD]
[TD]G-JIMG[/TD]
[TD]127[/TD]
[TD]-[/TD]
[TD]PipeMajor[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]-[/TD]
[TD]foodstick[/TD]
[TD]68[/TD]
[TD]-[/TD]
[TD]128[/TD]
[TD]-[/TD]
[TD]RDJeff[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]-[/TD]
[TD]UPF-7[/TD]
[TD]69[/TD]
[TD]-[/TD]
[TD]Twin_Flyer[/TD]
[TD]129[/TD]
[TD]-[/TD]
[TD]ABORH[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]-[/TD]
[TD]jeffie8696[/TD]
[TD]70[/TD]
[TD]-[/TD]
[TD]130[/TD]
[TD]-[/TD]
[TD]danpos[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]-[/TD]
[TD]skyrat71[/TD]
[TD]71[/TD]
[TD]-[/TD]
[TD]131[/TD]
[TD]-[/TD]
[TD]mscic-RCU[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]-[/TD]
[TD]72[/TD]
[TD]-[/TD]
[TD]132[/TD]
[TD]-[/TD]
[TD]PSB[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]-[/TD]
[TD]CanDo[/TD]
[TD]73[/TD]
[TD]-[/TD]
[TD]Super08[/TD]
[TD]133[/TD]
[TD]-[/TD]
[TD]aggieman[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]-[/TD]
[TD]JPMacG[/TD]
[TD]74[/TD]
[TD]-[/TD]
[TD]Hab[/TD]
[TD]134[/TD]
[TD]-[/TD]
[TD]Renegade[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]-[/TD]
[TD]75[/TD]
[TD]-[/TD]
[TD]135[/TD]
[TD]-[/TD]
[TD]bodybuildr[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]-[/TD]
[TD]76[/TD]
[TD]-[/TD]
[TD]Rv7garage[/TD]
[TD]136[/TD]
[TD]-[/TD]
[TD]SigSenior[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]-[/TD]
[TD]Cutlass 60[/TD]
[TD]77[/TD]
[TD]-[/TD]
[TD]Neddy191[/TD]
[TD]137[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]-[/TD]
[TD]Mr-Punk[/TD]
[TD]78[/TD]
[TD]-[/TD]
[TD]JZHANDYMAN[/TD]
[TD]138[/TD]
[TD]-[/TD]
[TD]mike 71[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]-[/TD]
[TD]Sabreryder[/TD]
[TD]79[/TD]
[TD]-[/TD]
[TD]Pete Lane[/TD]
[TD]139[/TD]
[TD]-[/TD]
[TD]merto31[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]-[/TD]
[TD]eastkurt[/TD]
[TD]80[/TD]
[TD]-[/TD]
[TD]SIGPlanes[/TD]
[TD]140[/TD]
[TD]-[/TD]
[TD]thobin[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]-[/TD]
[TD]FlyerInOKC[/TD]
[TD]81[/TD]
[TD]-[/TD]
[TD]rcmichael[/TD]
[TD]141[/TD]
[TD]-[/TD]
[TD]numb3rulz[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]-[/TD]
[TD]rtn9105[/TD]
[TD]82[/TD]
[TD]-[/TD]
[TD]142[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]-[/TD]
[TD]oliveDrab[/TD]
[TD]83[/TD]
[TD]-[/TD]
[TD]143[/TD]
[TD]-[/TD]
[TD]VincentJ[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]-[/TD]
[TD]84[/TD]
[TD]-[/TD]
[TD]Hawk570[/TD]
[TD]144[/TD]
[TD]-[/TD]
[TD]RICKSTUBBZ[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]-[/TD]
[TD]ARUP[/TD]
[TD]85[/TD]
[TD]-[/TD]
[TD]hogflyer[/TD]
[TD]145[/TD]
[TD]-[/TD]
[TD]EJWash1[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]-[/TD]
[TD]willig10[/TD]
[TD]86[/TD]
[TD]-[/TD]
[TD]cubcrasher[/TD]
[TD]146[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]-[/TD]
[TD]malitape[/TD]
[TD]87[/TD]
[TD]-[/TD]
[TD]147[/TD]
[TD]-[/TD]
[TD]Aquila1954[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]-[/TD]
[TD]OLDFLYER2[/TD]
[TD]88[/TD]
[TD]-[/TD]
[TD]148[/TD]
[TD]-[/TD]
[TD]jwharkinz[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]-[/TD]
[TD]justin80[/TD]
[TD]89[/TD]
[TD]-[/TD]
[TD]Robin A[/TD]
[TD]149[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]-[/TD]
[TD]90[/TD]
[TD]-[/TD]
[TD]GLGofLB[/TD]
[TD]150[/TD]
[TD]-[/TD]
[TD]Pork Chop[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]-[/TD]
[TD]91[/TD]
[TD]-[/TD]
[TD]151[/TD]
[TD]-[/TD]
[TD]drube[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]-[/TD]
[TD]yel914[/TD]
[TD]92[/TD]
[TD]-[/TD]
[TD]152[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]-[/TD]
[TD]93[/TD]
[TD]-[/TD]
[TD]FJRrider[/TD]
[TD]153[/TD]
[TD]-[/TD]
[TD]samklem[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]-[/TD]
[TD]sbd-3[/TD]
[TD]94[/TD]
[TD]-[/TD]
[TD]sdcranford[/TD]
[TD]154[/TD]
[TD]-[/TD]
[TD]tkametz[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]-[/TD]
[TD]95[/TD]
[TD]-[/TD]
[TD]AMA 74894[/TD]
[TD]155[/TD]
[TD]-[/TD]
[TD]Vinnie6[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]-[/TD]
[TD]blw[/TD]
[TD]96[/TD]
[TD]-[/TD]
[TD]W7APD Alan[/TD]
[TD]156[/TD]
[TD]-[/TD]
[TD]budof561[/TD]
[/TR]
[TR]
[TD]37
[/TD]
[TD]-[/TD]
[TD]Mike Gretz[/TD]
[TD]97[/TD]
[TD]-[/TD]
[TD]bobsrc[/TD]
[TD]157[/TD]
[TD]-[/TD]
[TD]RKRick[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]-[/TD]
[TD]Mako17[/TD]
[TD]98[/TD]
[TD]-[/TD]
[TD]kiwi4[/TD]
[TD]158[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]-[/TD]
[TD]Live Wire[/TD]
[TD]99[/TD]
[TD]-[/TD]
[TD]159[/TD]
[TD]-[/TD]
[TD]sgtmonte[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]-[/TD]
[TD]deanz406[/TD]
[TD]100[/TD]
[TD]-[/TD]
[TD]G.Barber[/TD]
[TD]160[/TD]
[TD]-[/TD]
[TD]smallrc[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]-[/TD]
[TD]bchapman[/TD]
[TD]101[/TD]
[TD]-[/TD]
[TD]I_Fly[/TD]
[TD]161[/TD]
[TD]-[/TD]
[TD]daywalker[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]-[/TD]
[TD]102[/TD]
[TD]-[/TD]
[TD]162[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]-[/TD]
[TD]103[/TD]
[TD]-[/TD]
[TD]163[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]-[/TD]
[TD]104[/TD]
[TD]-[/TD]
[TD]3136[/TD]
[TD]164[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]-[/TD]
[TD]M_Callahan[/TD]
[TD]105[/TD]
[TD]-[/TD]
[TD]rc56[/TD]
[TD]165[/TD]
[TD]-[/TD]
[TD]mvarzoni[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]-[/TD]
[TD]106[/TD]
[TD]-[/TD]
[TD]166[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]-[/TD]
[TD]xxwolfyxx[/TD]
[TD]107[/TD]
[TD]-[/TD]
[TD]Fly North[/TD]
[TD]167[/TD]
[TD]-[/TD]
[TD]gutmark[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]-[/TD]
[TD]landeck[/TD]
[TD]108[/TD]
[TD]-[/TD]
[TD]JFS737[/TD]
[TD]168[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]-[/TD]
[TD]109[/TD]
[TD]-[/TD]
[TD]169[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]-[/TD]
[TD]110[/TD]
[TD]-[/TD]
[TD]rdgettler[/TD]
[TD]170[/TD]
[TD]-[/TD]
[TD]flygilmore[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]-[/TD]
[TD]rphiii[/TD]
[TD]111[/TD]
[TD]-[/TD]
[TD]171[/TD]
[TD]-[/TD]
[TD]Yasbush[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]-[/TD]
[TD]n0kjf[/TD]
[TD]112[/TD]
[TD]-[/TD]
[TD]172[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]-[/TD]
[TD]cymaz[/TD]
[TD]113[/TD]
[TD]-[/TD]
[TD]173[/TD]
[TD]-[/TD]
[TD]bbrowncods[/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]-[/TD]
[TD]OldRookie[/TD]
[TD]114[/TD]
[TD]-[/TD]
[TD]Soboflyer[/TD]
[TD]174[/TD]
[TD]-[/TD]
[TD]pmoen70[/TD]
[/TR]
[TR]
[TD]55[/TD]
[TD]-[/TD]
[TD]gosch[/TD]
[TD]115[/TD]
[TD]-[/TD]
[TD]jollyroger[/TD]
[TD]175[/TD]
[TD]-[/TD]
[TD]GSXR1000[/TD]
[/TR]
[TR]
[TD]56[/TD]
[TD]-[/TD]
[TD]116[/TD]
[TD]-[/TD]
[TD]c-crunch[/TD]
[TD]176[/TD]
[TD]-[/TD]
[TD]Comper[/TD]
[/TR]
[TR]
[TD]57[/TD]
[TD]-[/TD]
[TD]lfd47[/TD]
[TD]117[/TD]
[TD]-[/TD]
[TD]177[/TD]
[TD]-[/TD]
[TD]stinsonsr9[/TD]
[/TR]
[TR]
[TD]58[/TD]
[TD]-[/TD]
[TD]bikerbc[/TD]
[TD]118[/TD]
[TD]-[/TD]
[TD]tzlaser44[/TD]
[TD]178[/TD]
[TD]-[/TD]
[TD]scale buff[/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]-[/TD]
[TD]badger5964[/TD]
[TD]119[/TD]
[TD]-[/TD]
[TD]larscato[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]-[/TD]
[TD]N1EDM[/TD]
[TD]120[/TD]
[TD]-[/TD]
[TD]TomCrump[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Last edited by skylark-flier; 02-22-2017 at 08:26 PM. Reason: mis-spelling - must be getting old and senile, it was an easy word. Sheesh!
Old 02-23-2017, 12:06 PM
  #2272
acdii
Been there, done that with the horses. I lost my buddy last year and it still pains me to go out to the barn and see his empty stall.
Old 02-23-2017, 01:30 PM
  #2273
FlyerInOKC
FlyerInOKC's Avatar
Losing a good horse is like losing a member of the family. My sister in-law loss a donkey last year to old age. He was pretty old when she got him but he protected her other horses from coyotes and the like. He is truly missed.
Old 02-23-2017, 06:56 PM
  #2274
skylark-flier
Default OT - our furkids
This wasn't a life or death thing but it WAS a thing that could have blinded him in one eye - at least. Vet said we'd initially caught the infection within the first 6 hours (what are the odds?) and he installed a heplock into the eyelid, anchored to his halter. Poor guy hasn't worn a halter more than 6 days in the past 10 years - he's NOT a happy camper with it.
The virus/whatever had already drilled a hole into the side of his eye and was progressing inward when we caught it. Meds through the heplock every couple hours killed the bug right away - apparently - but it's been a battle stopping the progression of damage.
We've lost our share of furkids over the past 20 years - every one of old age, the oldest being 38. ALL our horses are rescues, so we really haven't done too bad overall.
First pic is Banjo (formal name Mac Prince), our blue-eyed beauty with the problem, and my daughter.
Some of our kids, on a normal day. Banjo's in the rear in this one. Blue (my Arab) (formal name "dla Basks* Blue Smoke") is the gray ghost. As he's gotten older, he's turned nearly white. This pic is from about 5 years ago.
And, y'er right - every one of them is as much family as my human kids.
BTW, Mike - isn't that a massive listing of b'hoods?!! Haven't done the "big search" in awhile. I'm sure more have popped up and I need to check. Maybe this weekend.
ID:	2202547   Click image for larger version
Old 02-24-2017, 06:46 AM
  #2275
FlyerInOKC
FlyerInOKC's Avatar
Great looking horses Dave! And most importantly they look happy and well cared for!
