Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 12-12-2012, 02:02 AM
  #2276
Malcolm H
Malcolm H's Avatar
Default RE: C-ARF Ultra Flash build Thread + Video
I was out in Tenerife a couple of weeks ago and went flying with Ruyman. He is a very acomplished pilot but the day we went flying there was a strong 90 deg crosswind on their very short and narrow runway and he decided not to fly the Ultraflash but we did fly a Habu and a horrifically quick electric pylon racer which was nearly as fast as a Flash.
It is me who has been encouraging him to try a little less flap and a small amount of crow because that is the way I fly my Ultraflash. I totally agree with Dave that it doesn't NEED crow but what I have found as a very experienced F3A pilot but low time turbine pilot that coupled with a little less flap, it helps to extend the safe landing speed window. Without it I found I had to hit the correct airspeed exactly or I would end up with a stall and drop from a couple of feet or a too high speed touchdown. The end result of either is a nose to tail bounce down the runway that doesn't do your wing tips any good. I think once my energy management improves it might be possible to put back another 20mm of flap and maybe remove the crow to have an even slower touchdown or steeper approach but on the sites I fly at I'm happy with the 80mm flap 6mm crow setup I have now.
Malcolm
Old 12-12-2012, 02:03 AM
  #2277
Ali
Ali's Avatar
All a bit of light hearted fun to try and warm up this cold ***** day. I have found that in many cases, a set up that works for one, may not be suited to another's flying style. "each to their own" as they say.
Old 12-12-2012, 02:04 AM
  #2278
paulhat
ORIGINAL: Dave Wilshere
How many flights you guys got on the retracts? What sort of surface are you flying off? dry, dusty? The thread getting clogged seems to be the short fall that can cause issues.
Dave
Hi Dave,
I have some Electron ER-40's in a Reaction and have had about 30 flights off a dusty dirt strip.
No issues at all so far. I do take you point about the threads though. Will make sure I keep a good eye on them.
Have another set of ER-40's going into my second UF. Also have a set of the electric brakes from Electron that I can't wait to try.
Will get a video up once I have them in the plane.
On another note, I have decided to put a Kingtech 100G in this one. It's my second Kingtech but the first of the G series.
Anyway ran it up on the weekend with diesel ( I have been running diesel in a K140 since new) and it goes great. Only complaint I would have is the white smoke that comes out after shutdown. Not the engines fault I know but I wish it didn't do it
Regards,
Paul.
Old 12-12-2012, 02:07 AM
  #2279
paulhat
ORIGINAL: Ali
All a bit of light hearted fun to try and warm up this cold ***** day. I have found that in many cases, a set up that works for one, may not be suited to another's flying style. ''each to their own'' as they say.
Hi Ali,
I think the best thing about crow is the noise that it makes
Reaction really whistles!! (slows it down nice as well).
Paul.
Old 12-12-2012, 03:22 AM
  #2280
Ruymán
Thanks for your tips, I think that you proves the friend Malcom settings and if you don't like me will come back to the same behavior.
Thank you very much friends!
Old 12-12-2012, 03:51 AM
  #2281
mitchilito
My Feedback: (7)
I, for one, find this on going debate about crow very interesting. Especially because it is being waged by a couple very proficient jet pilots.
Crow absolutely transformed the landing characteristics of my Classic Flash. I'm waiting for my ultra upgrade package as we speak and I can guarantee you that I will be trying both crow and crowless when I get it upgraded. Then I'll know for sure who's right
Old 12-12-2012, 04:08 AM
  #2282
Dave Wilshere
Everyone is right! Technique will affect what works for you for sure.
The Classic Flash is a completely different animal, its was Stevie in our club who first tried CROW on the CF years ago and it transformed most people's chance of landing it on our 90m grass strip.
In have been using CROW for nearly as long as I have been flying turbines, we always had a small strip so an FD67 powered Cyclone was one of the first and my 1/7th kit AW L-39 followed back in 2002 as it is heavy and lacking flap! Some aeroplanes really gain, others not so much
Enjoy
Dave
Old 12-12-2012, 04:28 AM
  #2283
Rob Howarth
Even my friend Sheryl loves a bit of 'Crow' - I bet you'd love for her to convince you Dave..................
Old 12-12-2012, 06:11 AM
  #2284
Ali
Ali's Avatar
Yep. Business really is that slow! Special thanks to Rob H and Birdy for their inspiration and behind the scenes motivation!
Old 12-12-2012, 06:12 AM
  #2285
Duncan
Duncan's Avatar
Rob? Really? lol
Old 12-12-2012, 06:22 AM
  #2286
ricardinho
Old 12-12-2012, 08:00 AM
  #2287
Ruymán
Very good Aly!
Do and those who use good Crow tour carried part of Malcolm?
Old 12-12-2012, 09:00 AM
  #2288
Dave Wilshere
Luckily been far too busy today to get involved
Never had a thing about Ms Crow...but with a different body like that...MMMmm
In the right place, I do love CROW...just not on an UF!
D
Old 12-12-2012, 11:31 AM
  #2289
ricardinho
dave i found it works great on the kingcat and boomers...never used it on anything else
Old 12-12-2012, 03:27 PM
  #2290
Dave Wilshere
Always flew my KingCat and BobCat C without as they also have tonnes of flap. The Boomerang Nano I used to fly uses CROW, split rudders and 90 degree flap to add drag!
The Classic Flash was the biggest winner as with full flap the AB section messed up the elevator response and with less flap it was lacking drag needing glider approaches. The CROW lifted the nose and poured on the drag.
D
Old 12-12-2012, 04:00 PM
  #2291
wojtek
My Feedback: (73)
wojtek's Avatar
Crow is not about adding drag as much as it is about reducing lift. If lift is reduced by a certain margin, this leaves a more positive feeling on landing, and a larger speed envelope to perform landings without (excessive) ballooning or bounce. It allows for a more consistent feel independent of wind conditions.
Its about whatever someone likes ... its all in the eye of the beholder ( or rather the stick of the pilot )
~V~
Old 12-12-2012, 11:46 PM
  #2292
Dave Wilshere
It adds drag...sure it reduces lift too, mainly in the aileron area near the tip. On a glider wing its a good thing, its used with huge angles on a wing with massive lift. On a Jet I only want drag, the UF wing loading is "nice" on landings as it is. But like everyone says, if it works for you...
Dw
Old 12-13-2012, 05:27 AM
  #2293
wojtek
My Feedback: (73)
wojtek's Avatar
no it doesn't !! ...
lol, j/k !!
~V~
Old 12-13-2012, 05:50 AM
  #2294
Bravo77
I think that the experience of Dave on the UF speaks loud enough . Success is dependent on experience some chose to use and others try to defy , all because they want to prove themselves right. I will maiden my UF early next year and guess whose advise I will follow.
Happy Flying and Merry Christmas to all
Old 12-13-2012, 06:03 AM
  #2295
sailing1
My Feedback: (134)
Following or taking the advice of an expert is certainly a good place to start on pretty much anything we do in this sport. But in the end we all need to develope our own skills and levels of "comfort" with the way we fly. The use of Crow on my Classic Flash trasformed it from a good plane to a comfortable plane for me to fly. Now I am flying the Ultra Flash and it lands just fine without Crow, but I am still more comfortable flying into our short field with the use of Crow. So, is Crow better or worse? Who cares It just works better for me and my flying style.
Old 12-13-2012, 06:58 AM
  #2296
HAMMERDOWN
My Feedback: (100)
HAMMERDOWN's Avatar
I had 350+ flights on my CF with no damage. After selling it and building a UF I had about 50-50 of what i would call successful landings. I got tired of repairing the wing tips (and other things) and hung it up and flew other airplanes for almost a year. At BITW I asked for Ali to take a look at it. The only changes he made was decrease my flap throw from the factory recommended setting and added crow. I didn't do it for any reason except to get the thing back on the runway safely. Every airframe has different flight characteristics. That's the reason the FAA requires dual instruction when making a change even from a Cessna 172 to a 182. The CF and UF have different landing characteristics and for me, the instruction manual wasn't enough. I now make a level or slightly nose down approach (like a full scale and unlike the instruction manual) and flare. I was in the habit of a nose high approach because the CF liked. The UF seems to slow more quickly and, without adding the correct amount of power, would stall. The landing speed envelope was very small. The combination of the adjustments and a more level descent made this my favorite airplane again. With a proper approach, it almost lands itself. I'm sure I could now land it without crow but it works for me and I'm not going back. Thanks Ali!
Omega PowerSportsLLC.
Old 12-13-2012, 11:59 AM
  #2297
Ali
Ali's Avatar
Happy to be of help.
Regards Al
Old 12-13-2012, 12:37 PM
  #2298
lcvmoreira
Please, can you explain what is CROW ? How its works ?
Luis Moreira
Old 12-13-2012, 02:18 PM
  #2299
paulhat
[link=http://www.eflightwiki.com/eflightwiki/index.php?title=Crow_brakes]Crow Braking[/link]
Old 12-13-2012, 03:40 PM
  #2300
lcvmoreira
Thanks!
