Reload this Page >
Bavarian Demon Cortex PRO is here!!
Old 07-15-2018, 01:32 PM
  #551
CraigG
My Feedback: (40)
CraigG's Avatar
Originally Posted by F1 Rocket
Check that both receivers are set for EX Bus output. Also, please download and read the full manual. It has all the latest connection diagrams and warnings.
Specifically, be sure to follow these steps from the manual FIRST:
TEACHING THE INPUT SIGNAL TYPE
First, power on the radio, receiver and CORTEXpro, then connect the jumper to the programming port. The LED will start blinking a fast blue, then after a few seconds will switch to a slow blue blink. This means the signal type has been detected and set.
( ! ) On each and any occasion that the input type is taught, this MUST be followed by the complete setup process, incl. mounting orientation and bank setups, as this step sets the unit to factory default state!
( ! ) The input signal type can only be set in this way, as described above. It‘s not possible to change or set it via software, as this is not necessary.
​​​​​​I missed this step the first time I tried to program a CP. You only have to do it once but nothing works until its completed.
Craig
Old 07-15-2018, 02:32 PM
  #552
jetsflyin
My Feedback: (12)
Hi guys
I do have both receivers to ex-bus. The problem that I'm having is when i power on the transmitter and then the receivers with the gyro, i get the fast blinking BLUE but after it goes directly to Solid RED. I do not get the slow blinking blue so i can start the teach inputs.
Old 07-15-2018, 07:11 PM
  #553
gooseF22
gooseF22's Avatar
rebind the receivers to the transmitter first
Old 07-16-2018, 07:18 AM
  #554
jetsflyin
My Feedback: (12)
PROBLEM FIXED!!!! Bad bind plug..... kudos to CP customer service. I send an email and in less than an hour they refer me to someone (Not sure if i can mention his name) in the states that i can talk to over the phone.
Thank you CP FOR YOUR AWESOME SUPPORT.
Old 07-16-2018, 08:02 AM
  #555
F1 Rocket
Happy we were able to get you working quickly
Danny
Old 07-16-2018, 08:12 AM
  #556
jetsflyin
My Feedback: (12)
Danny
Thank you Danny!!!
Old 07-16-2018, 03:34 PM
  #557
jetsflyin
My Feedback: (12)
Im planing to mix tailerons with flaps in landing position, do i set up the gyro and then do the mix or mix it first before i teach the gyro?
Old 07-17-2018, 05:04 AM
  #558
DEMONjoe
So nice that you care that much about not getting us into too much trouble But hey, it was me, JOACHIM, who sent you to DANNY over there. All names allowed, we are happy to help at all times.
Old 07-17-2018, 05:16 AM
  #559
DEMONjoe
Depends if you want the aileron function on the tailerons stabilized or not. I assume it's not necessarily needed, so go the first way.
No hesitation to correct this if there are other opinions
Old 07-17-2018, 02:37 PM
  #560
jetsflyin
My Feedback: (12)
HAHAHA... Ok Ok Kudos to Joachim also..
Old 07-18-2018, 06:47 AM
  #561
DEMONjoe
It was more about DANNY
Old 08-31-2018, 03:40 AM
  #562
RobinLeblond
RobinLeblond's Avatar
Hey! Anyone know where to buy a Cortex PRO, everyone seem to be out of stock ? (Ideally in north america)
Old 08-31-2018, 04:04 AM
  #563
txjoe
Aeropanda.com website says they have 3 in stock.
Old 08-31-2018, 05:14 AM
  #564
RobinLeblond
Yes, thanks! ( I don't know why, but I thought they were oversea (in europe)...)
Old 08-31-2018, 09:50 PM
  #565
Looping31
Looping31's Avatar
Old 09-07-2018, 05:42 PM
  #566
smoknrv4
smoknrv4's Avatar
Anyone using the app? If so how is it?
Old 09-07-2018, 08:39 PM
  #567
Bob_B
Bob_B's Avatar
Blue module?
Old 09-08-2018, 01:22 PM
  #568
smoknrv4
smoknrv4's Avatar
Originally Posted by Bob_B
Blue module?
well I downloaded the app, but need to buy a Bluetooth module, and was wondering if it was worth the bother.
Old 09-08-2018, 02:54 PM
  #569
Bob_B
Bob_B's Avatar
If you are a jeti user id say no
Old 09-08-2018, 03:44 PM
  #570
smoknrv4
smoknrv4's Avatar
Sorry forgot to mention I’m using a dx18.
Old 09-10-2018, 02:13 PM
  #571
rskiba
My Feedback: (16)
rskiba's Avatar
I have searched the thread but must be blind if it's here. Looking for the setup (wiring & config) of using two Jeti 2.4 R3 receivers (Pri & BU) into the CP and only one output for both receivers from the CP to the Central Box 200 primary RX slot so that I can use the 900Mhz backup into the Central Box secondary Rx slot by-passing the CP. Is that possible?
Old 09-10-2018, 02:25 PM
  #572
F1 Rocket
This set up is pretty much exactly as you described. The details being:
Primary 2.4 receiver connected to port B
Secondary 2.4 receiver connected to port A
RX1 of the central box connected to port 6
REX 900 connected to RX2 of the central box
Also, don’t forget the additional power lead from an open servo port on the central box to the cortex pro as shown in the manual connected to port 4
Danny
Old 09-10-2018, 02:31 PM
  #573
smoknrv4
smoknrv4's Avatar
​​​​​​ no one uses the app at all? Just PC? I’m just curious if programmed using the app, is it the same as using the PC or if it’s missing some features?
Old 09-10-2018, 02:40 PM
  #574
rskiba
My Feedback: (16)
rskiba's Avatar
Danny
Danny,
Thanks for the reply - I have it working without the 900 Mhz now and two 2.4's. So, I think I just unplug the CP to Sec RX connection and install the 900 directly into the Central Box Sec Rx port. I already have the "extra" connection installed as well from Central Box servo port to Port 4 on the CP. In this configuration, the two 2.4 Rx's have to fail before the 900 is invoked, correct? and the Jeti Tx can still keep track of which receivers is doing the "work"?
Old 09-10-2018, 03:19 PM
  #575
rskiba
My Feedback: (16)
rskiba's Avatar
Danny,
Can you explain if this is correct please?
Thanks!
