 KingTech K-80 >
KingTech K-80
KingTech K-80
Old 07-02-2012 | 01:17 PM
  #976
marquisvns's Avatar
Default RE: KingTech K-80
ORIGINAL: megafly
Essyou35, if you having problems with the fittings, just change them. I'm not shure but I don't think they are made by festo.
Essyou, megafly is right, if you think the O ring has gone back, you could change them out if you have access to the right part and won't void the warranty, but be careful not to break its supporting post. Most of the fittings of our engines are from Pisco: http://www.pisco.com/index.htm
Good Luck,
Barry
Old 07-02-2012 | 01:20 PM
  #977
marquisvns's Avatar
ORIGINAL: H.Dale
I have a new kero start K-80. I ran it for the first time yesterday. It's my 5th turbine so I'm not new to the setup procedure. However, when I run the throttle up to start it the starter motor starts spining like it should when the trim is all of the way down. Is this suppose to happen? The Ecu says ready, not trim low like it should to manually run the cool down.
Dale, that sounds about right, if you have the trim low and advance the throttle passed 50%, that actually activates the manual cool down in Kero mode. If something still doesn't seem right, unplug ECU battery and relearn RC.
Regards,
Barry
Old 07-02-2012 | 01:34 PM
  #978
My Feedback: (21)
The Kero Start ECU's are different. They only require you go just above 1/2 throttle for the start sequence. I have the Kero K-140 and it does the same thing at full stick for start up. This is used for manual cool down and to blow out any excess kero in the event of a failed wet start.
Hope this helps
Joe Lewis
Kingtech
K-80 and K-140
Owner
Old 07-02-2012 | 07:40 PM
  #979
Barry & Joe
Thanks for the help. I went to full throttle rather than over 1/2. I just wanted to make sure I had it set up properly. My other FADEC ECU's will not run the starter in the ready mode, only at trim low.
Old 07-03-2012 | 05:57 AM
  #980
jblloyd's Avatar
My Feedback: (17)
ORIGINAL: Jetpilot24
So ... would it be a good idea to leave the throttle up for a few seconds on normal startsin order to blow out any residual fumes before pulling it down to initializethe start-up sequence?
Old 07-03-2012 | 08:24 AM
  #981
My Feedback: (21)
ORIGINAL: jblloyd
So ... would it be a good idea to leave the throttle up for a few seconds on normal starts in order to blow out any residual fumes before pull it down to initializing the start-up sequence?
I have never found it necessary to do what you suggest. I have always had clean starts.
Joe Lewis
Kingtech
K-80 and K-140
Owner
Old 07-04-2012 | 02:43 PM
  #982
ppljr's Avatar
My Feedback: (94)
Just started up a "new" K80E. Actually it is serial no. 108 made in 2009. Has the original Kingtech pump. Fired up the first time and stabilized at 45000 rpm. Flawless. Changed the parameters to the Gaspar settings to see what effect it had. The result was a "softer" start, but a little more flames during the ramp up. Believe it or not, got the engine off of a guy on Ebay for under a grand...N.I.B. Looking forward to mounting it in my Sprint.
Old 07-04-2012 | 06:20 PM
  #983
marquisvns's Avatar
ORIGINAL: ppljr
Just started up a ''new'' K80E. Actually it is serial no. 109 made in 2009. Has the original Kingtech pump. Fired up the first time and stabilized at 45000 rpm. Flawless. Changed the parameters to the Gaspar settings to see what effect it had. The result was a ''softer'' start, but a little more flames during the ramp up. Believe it or not, got the engine off of a guy on Ebay for under a grand...N.I.B. Looking forward to mounting it in my Sprint.
Congrats Pedro and thanks for your registration.
Regards,
Barry
Old 07-11-2012 | 05:37 PM
  #984
Dblex's Avatar
My Feedback: (81)
Need help!
Went thru 6 plugs tonight trying to get her started!!!
Can someone post stock parameters please!!!!!!
Old 07-11-2012 | 06:00 PM
  #985
mate set the glow voltage at 2.1 try that if still a problem contact barry at kingtech international
ken
kingtech australia
Old 07-11-2012 | 06:07 PM
  #986
Dblex's Avatar
My Feedback: (81)
It is 2.1
Looking for the gas parameters ect...
Looking for the stock settings
Old 07-11-2012 | 10:24 PM
  #987
marquisvns's Avatar
ORIGINAL: Dblex
It is 2.1
Dblex, give me a call tomorrow, need to know which pump you are running in order to guide you with settings, also need to see why you are burning up plugs, could it be how the coils were pulled?
Barry
Old 07-12-2012 | 05:30 PM
  #988
Dblex's Avatar
My Feedback: (81)
Barry, seems all is solved. Settings for gas were at 95% and running rich apparently. Got settings from oz and messed with the gas! Actually with Texas heat and humidity, I tuned her down to 35% gas and she fires up first time everytime. I never thought taking it that low would work. I am also using the coleman green bottles for start. As for the plugs, I'm still runnin 2.2 on the plug and that seems to be working.
I have faith in her now and can continue on my build. Thanks to Australia and you guys for your support!
Old 07-12-2012 | 07:31 PM
  #989
hi Dblex
good to hear your problems are solved
ken
kingtech oz
Old 07-13-2012 | 03:02 PM
  #990
marquisvns's Avatar
Glad you got it all worked out!
Barry
Old 07-26-2012 | 09:30 AM
  #991
Guys, to reduce the flames using Jet A1 (kerostart) on startup is just lower the Pump Start Ramp value or is there other configuration I can change?
Old 07-27-2012 | 03:44 PM
  #992
Hi guys I need a big help over here, I tried today to star my new k80 but it won't start at around 12.000 rpm the engine puts a lot of flames and gets very hot, I stoped two starts atempts at around 780 degress celssius.
Here's my start parameters.
What do you think?
Pump start point Auto +2
Pump start ramp 002
Glow plug power 7.2v
Low Batt Volts 7.0v
Starter Power at ignition 080
Starter power at fuel ramp 110
RPM 100% starter power 18.000rpm
RPM OFF starter 22.000rpm
RPM to reconnect starter 20.000rpm
RPM ignition 3.000rpm
Pump Ignition 025
Engine min flow 050%
EGT end preheat 120 degrees
RPM preheat 5.000rpm
RPM fuel ramp 10.000 rpm
Preheat fuel 45%
Ignition Timeout 27s
Start mode Auto-Kero
This settings are factory setting, I didn't touch it.
Fuel Pump is MTH
Battery is a Lipo 2s 4.000
Old 07-27-2012 | 04:57 PM
  #993
2 things to try get a 3 cell life battery and reduce the preheat fuel to 30.
Old 07-27-2012 | 09:09 PM
  #994
marquisvns's Avatar
Sergio, Mark is right, you must use a 3S LiFe pack or a 7 cell NiMh, 2S LiPo doesn't have enough voltage. Besides lowering Preheat fuel to 30, you could also lower Min Flow to around 30%.
Good Luck,
Barry
Old 07-28-2012 | 10:17 AM
  #995
Thanks guys, I've started the engine 3 times with almost no flames, I started with lipo and with life pack and didn't notice anny difference I've changed pump ignition from 25 to 22, engine min flow from 50% to 27% and preheat fel from 45% to 30%, these changes save my day!
Do you know why the factory send this engine with this config?
Thanks again for the help.
Sergio.
Old 07-28-2012 | 12:13 PM
  #996
marquisvns's Avatar
Hi Sergio, It's been about one year now since our suggestions to the factory, thank goodness they have finally started to work with us on the settings. As to why this has taken so long? I do not have a good answer.
Regards,
Barry
Old 07-28-2012 | 06:28 PM
  #997
flejter1's Avatar
Megafly,
Just throwing my 2 cents in. On a freshly charged 2S Lipo pack, your K-80 will start fine. When the pack drops to 8V, you will not get the perfect starts and more than likely a no start. If you stay with your 2s Lipo pack, "CHECK THE VOLTAGE" if you have a no start. Don't mess with the settings, as you now know what settings work best on your turbine. I would take Barrys advise and go with a 3S LIFE or a 7C nimh pack as they tend to last longer through out the day of flying. As for you guys running the Kingtech propane start E model turbine, the 2S Lipo works fine.
Good Flying,
Dirk Flejter
KingTech, USA
Service Tech
Old 07-28-2012 | 07:53 PM
  #998
marquisvns's Avatar
Concerning checking voltage, please press the second button from the left during start up for real time under load voltage.
Thank you,
Barry
Old 08-05-2012 | 05:52 PM
  #999
Dblex's Avatar
My Feedback: (81)
ORIGINAL: flejter1
Megafly,
Just throwing my 2 cents in. On a freshly charged 2S Lipo pack, your K-80 will start fine. When the pack drops to 8V, you will not get the perfect starts and more than likely a no start. If you stay with your 2s Lipo pack, ''CHECK THE VOLTAGE'' if you have a no start. Don't mess with the settings, as you now know what settings work best on your turbine. I would take Barrys advise and go with a 3S LIFE or a 7C nimh pack as they tend to last longer through out the day of flying. As for you guys running the Kingtech propane start E model turbine, the 2S Lipo works fine.
Good Flying,
Dirk Flejter
KingTech, USA
Service Tech
This is a fact. I have a propane start on a 2s 5000 mah pack, and I can tell you she is good for 3 starts, after that if she drops voltage or a cell is slightly out of balanced, she will not start. You better have a good charger and balancer!
Old 08-27-2012 | 09:23 PM
  #1000
Had a strange problem with two Kingtech K80s that are installed in falcon 120s.   Last year, at around the same time we had two K80's that would not run cleanly through out the throttle range and would flame out for no apparent reason.   It was around 32 deg. C for temperature and a 100% humidity as we had rain showers and thunder storms all day.....  we sent the engines back to the factory but the factory said there was no problems and the engines were good...  they have been running well and on my unit,  i have over 12 hours of uninterrupted flight time.  <div>
</div><div>Similarly...  around 2 days ago, similar conditions (32 deg. C and 100% humidity, showers with some thunderstorms)  for the K80's existed and again, the two engines wouldnt run clean through the throttle range....  after you had achieved start up and the engine was running, sudden acceleration to 50% power would result in a flame out....  over and over again...  fuel system, fuel was clean.  no contamination....  all valves worked, fuel purge was no problem, filters, UAT were all clean......  </div><div>
</div><div>we then did a longer ground runup and slowly opened the throttles allowing the engines to adjust slowly to each throttle setting...  there was a bit of choking at 50% throttle, but if you allowed the engines to adjust slowly at each throttle position, until WOT, the engines eventually were able to adjust and did not flame out anymore...  seemed the engines had to warm up at first????  </div><div>
</div><div>I'm not really sure "warm-ups" are necessary but it has got me thinking that the ECU may have an issue with High Humidity environments?  thats the only thing i can think of as both K80's had the same problem.....  Would sealing the ECU be a good solution?  Anyone had similar occurrences?  </div><div>
</div><div>Thanks in advance!  </div>
